gordan84 Posted November 22, 2015 Report Share Posted November 22, 2015 Trenutno imam 2 zvučnika od 8 oma spojena na pojačalo. http://www.audioreview.com/cat/speakers/floorstanding-speakers/mordaunt-short/ms-906/prd_125754_1594crx.aspx Interesuje me da li smijem dodati par zvučnika od 6 oma na isto pojačalo na drugi kanal? To su ovi zvučnici http://www.qacoustics.co.uk/3020-stereo-speaker.htm Slušao bih nekada zajedno na oba kanala a nekada posebno. Quote Link to comment Share on other sites More sharing options...
zek Posted November 22, 2015 Report Share Posted November 22, 2015 Zavisi od pojačala, kako je urađeno i šta preporučuje proizvođač (obično piše na konektorima za zvučnike na pojačalu koja kombinacija je moguća). Quote Link to comment Share on other sites More sharing options...
gordan84 Posted November 22, 2015 Author Report Share Posted November 22, 2015 Može li se to viditi na osnovu modela pojačala? U pitanju je Technics SU-VX920, http://www.hifiengine.com/manual_library/technics/su-vx920.shtml Quote Link to comment Share on other sites More sharing options...
zek Posted November 22, 2015 Report Share Posted November 22, 2015 Pa lepo ti piše pozadi. Ako uključuješ samo zvučnike grupe A ili grupe B onda mogu pojedinačno zvučnici biti od 4 do 16 oma svaki. Ako pak uključuješ oba para zvučnika A+B, onda svaki od zvučnika mora biti 8 do 16 oma. Ako se oba para konektora upotrebljavaju za bi-wiring vezu za jedan par zvučnika onda svaki može biti 4-16 oma. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 22, 2015 Report Share Posted November 22, 2015 3 sati ranije, gordan84 said: Slušao bih nekada zajedno na oba kanala a nekada posebno. Може ал' немој да одврћеш. Quote Link to comment Share on other sites More sharing options...
Kuršum Posted November 22, 2015 Report Share Posted November 22, 2015 Može, može, pa posle kod Stona na kanal. Quote Link to comment Share on other sites More sharing options...
gordan84 Posted December 2, 2015 Author Report Share Posted December 2, 2015 Samo da javim da evo zvučnici od 6 oma rade bez problema skupa sa zvučnicima od 8 oma. Quote Link to comment Share on other sites More sharing options...
Technicssss Posted December 3, 2015 Report Share Posted December 3, 2015 3 sati ranije, gordan84 said: Samo da javim da evo zvučnici od 6 oma rade bez problema skupa sa zvučnicima od 8 oma. Na SU-VX920 nema sta nece raditi, mislim da bi i sporet mogao da potera:) Salu na stranu, kao sto rece Ston samo nemoj da odvrces. Pojacalo ima zastitu tako da ce se ugasiti ako mu se nesto ne svidja u naponu, velikom padu impedanse itd. E sad mozda to nisam trebao da ti kazem jer prosli kome sam rekao je namerno odvrtao bas da vidi da li ce stvarno da se ugasi...i jeste se ugasilo...ali ne zauvek:) Quote Link to comment Share on other sites More sharing options...
timautobj Posted March 26, 2022 Report Share Posted March 26, 2022 postovani,kupio sam yamaha r-s202r, pa vas molim za savet koja 4 zvucnika da uparim sa njim.unapred hvala Quote Link to comment Share on other sites More sharing options...
zek Posted March 26, 2022 Report Share Posted March 26, 2022 4 sati ranije, timautobj said: koja 4 zvucnika da uparim sa njim Zašto 4 zvučnika, u dve prostorije će biti ili u jednoj. Ako misliš da u jednu prostoriju staviš 4 zvučnika ništa bolje nećeš dobiti nego da uzmeš dva bolja zvučnika. Izbor zvučnika zavisi od budžeta, veličine sobe, udaljenosti na kojoj slušaš, nivoa glasnosti koju preferiraš, vrste muzike koju slušaš, izvora i kvaliteta muzičkih zapisa ... Quote Link to comment Share on other sites More sharing options...
Zexx Posted March 27, 2022 Report Share Posted March 27, 2022 5 sati ranije, timautobj said: postovani,kupio sam yamaha r-s202r, pa vas molim za savet koja 4 zvucnika da uparim sa njim.unapred hvala S obzirom da proizvođač navodi u uputstvu da minimalna impedansa ukoliko se koristi jedan par zvučnika treba da bude 8 oma, odnosno 16 oma ukoliko se koriste dva para, odgovor je prilično jasan jer praktično ne postoje komercijalni zvučnici od 16 oma. Znači - nijedne. Quote Link to comment Share on other sites More sharing options...
timautobj Posted March 27, 2022 Report Share Posted March 27, 2022 hvala vam Quote Link to comment Share on other sites More sharing options...
