giZ_Mo Posted May 10, 2015 Report Share Posted May 10, 2015 Par. Мени други пар Quote Link to comment Share on other sites More sharing options...
wwweljko Posted May 10, 2015 Report Share Posted May 10, 2015 Moze. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 10, 2015 Report Share Posted May 10, 2015 Moze. Ето, већ један ГБ. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted May 10, 2015 Report Share Posted May 10, 2015 Koja je svrha GBa ako je slanje dzabe? Da vas rebne carina na kolicinu( dva mozda i prodju)? Dodatni troskovi i cimanje oko raspodele? Upravu si. Takve carina najbolje voli Quote Link to comment Share on other sites More sharing options...
jager Posted May 10, 2015 Report Share Posted May 10, 2015 Do 1kg uglavnom sve prolazi bez kontrole , na to me savjetovao drug koji ima preko 100 porudzbina. Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 10, 2015 Report Share Posted May 10, 2015 Do 1kg uglavnom sve prolazi bez kontrole , na to me savjetovao drug koji ima preko 100 porudzbina. Da narucim 990grama koke? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 10, 2015 Report Share Posted May 10, 2015 Da narucim 990grama koke? Боље ћурке Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 10, 2015 Report Share Posted May 10, 2015 Боље ћурке To nije ni batak od curke. Quote Link to comment Share on other sites More sharing options...
jager Posted May 10, 2015 Report Share Posted May 10, 2015 Боље ћурке Provaj sta te kosta Quote Link to comment Share on other sites More sharing options...
Aleksandar75 Posted May 10, 2015 Report Share Posted May 10, 2015 Da narucim 990grama koke? Tako je pok. Bata Trlaja podigao u poÅ¡ti na Bežanijskoj Kosi paket od skoro 4 kg koke iz Hondurasa pa ga uhapsili Ostala je Äuvena njegova odbrana da mora da je u pitanju neka Å¡ala jer nikada nije ni Äuo za Honduras, Äuo je samo za Kolumbiju, a ne bi ni za tu zemlju Äuo da nije gledao ''Scarface'' Quote Link to comment Share on other sites More sharing options...
ZeAgiu Posted May 13, 2015 Report Share Posted May 13, 2015 Iz mog iskustva, sve fake verzije oyaide, sonarquest i sl. vriste i to bolesno, isto vazi za mesing Kaiser, sa posrebrenim je vec druga prica... Wattgate 320 odlican, za te pare posebno. Quote Link to comment Share on other sites More sharing options...
patason Posted May 13, 2015 Report Share Posted May 13, 2015 iz mog iskustva oyaide(kopije) zvuce odlicno,wattgate 320 mutno i cebovana sa naduvanim basom. Quote Link to comment Share on other sites More sharing options...
hardwareGQ Posted May 14, 2015 Author Report Share Posted May 14, 2015 Mozda je ovaj posrebreni Kaiser cak i bolja varijanta od Oyaide kopija. Mada, nista dok se ne proba. Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted May 14, 2015 Report Share Posted May 14, 2015 U taj Kaiser ne može, fiziÄki da se montira skoro ni jedan ozbiljniji kabl.Tako je konstruisan, prima max 2.5mm2 preseka žice! Quote Link to comment Share on other sites More sharing options...
ZeAgiu Posted May 14, 2015 Report Share Posted May 14, 2015 U taj Kaiser ne može, fiziÄki da se montira skoro ni jedan ozbiljniji kabl.Tako je konstruisan, prima max 2.5mm2 preseka žice! Pazi, ja montirao cak i Tomin Yarbo SP 8000PW od 3x4mm na Kaiser posrebreni IEC/Shuko doduse uz obavezno lemljenje posle zavrtanja srafova za svaki slucaj. Nisam imao problema od tada... Btw, posebno je interesantan Gekko Kaiser posrebreni shuko sa posrebrenim bakarnim pinovima. Quote Link to comment Share on other sites More sharing options...
Toza Posted May 14, 2015 Report Share Posted May 14, 2015 Iz mog iskustva, sve fake verzije oyaide, sonarquest i sl. vriste i to bolesno, isto vazi za mesing Kaiser, sa posrebrenim je vec druga prica... Wattgate 320 odlican, za te pare posebno. Izgleda da tebi nešto drugo u sistemu vrišti, i to bolesno. Pogotovo mi nije jesno kako ti vrišti sa svim ostalim osim sa posrebrenim Kaiser-om. Ali, u pravu si. Skroz. Ako tako kažeš, onda mora da je tako... Quote Link to comment Share on other sites More sharing options...
jager Posted May 14, 2015 Report Share Posted May 14, 2015 Pazi, ja montirao cak i Tomin Yarbo SP 8000PW od 3x4mm na Kaiser posrebreni IEC/Shuko doduse uz obavezno lemljenje posle zavrtanja srafova za svaki slucaj. Nisam imao problema od tada... Btw, posebno je interesantan Gekko Kaiser posrebreni shuko sa posrebrenim bakarnim pinovima. Zasto posrebreni na yarbo ? Kakav je rezultat . Quote Link to comment Share on other sites More sharing options...
tsuyoshi Posted May 14, 2015 Report Share Posted May 14, 2015 Da ne otvaram novu temu, trenutno pravim sebi kablove za struju, pa imam dilemu po pitanju povezivanja vodova strujnog kabla na Å¡uko utiÄnicu (deo vezan za uplitanje Å¡irma i uzemljena samo sa te strane kabla), i zamolio bih da mi neko objansi u Äemu je tu caka. Konkretno, gledajući ovu DIY temu video sam da je konstruktor IEC utiÄnicu povezao sasvim "normalno".MeÄ‘utim, kod povezivanja na Å¡uko utiÄnicu, on je upleo Å¡irm sa žuto-zelenom žicom (uzemljenje) i to zajedno stavio na konektor uzemljenja.Kada (i da li uopÅ¡te) ovo treba raditi, i kakav je uticaj na zvuk (ili smetnje, ne znam, pitam) ovakvog povezivanja samo sa te jedne strane?Hvala. Quote Link to comment Share on other sites More sharing options...
Aleksandar75 Posted May 14, 2015 Report Share Posted May 14, 2015 Ovi prate forum: Poskupeli su Äim su Äuli za grupnu nabavku Quote Link to comment Share on other sites More sharing options...
jager Posted May 14, 2015 Report Share Posted May 14, 2015 Ovi prate forum:Untitled.jpg Poskupeli su Äim su Äuli za grupnu nabavku Popust za forumase Quote Link to comment Share on other sites More sharing options...
Aleksandar75 Posted May 14, 2015 Report Share Posted May 14, 2015 Pusti ti to, niÅ¡ta im ne verujem, upravo sam naruÄio da ne poskupe joÅ¡ viÅ¡e kad krene navala sa foruma Quote Link to comment Share on other sites More sharing options...
ManicP Posted May 15, 2015 Report Share Posted May 15, 2015 Jedan praktiÄan savet vezan za povezivanje provodnika mrežnog kabla unutar konektora: NIKAD, ALI NIKAD, nemojte povezivati provodnike kao na slici! shuko2.jpg ZaÅ¡to? Raspored je ispravno povezan, problematiÄne su dužine provodnika. Naime, žuto-zeleni provodnik je vod zaÅ¡titnog uzemljenja i posao mu je da Å¡titi od elektriÄnog udara u sluÄaju dolaska pod napon neizolovanog metalnog kućiÅ¡ta ureÄ‘aja (kroz uzemljenje se zatvori petlja kvara, kratak spoj, osiguraÄ je gecrkt a ukućani na broju). Ovako kako je na fotografiji iz linka, u sluÄaju mehaniÄkog naprezanja kabla (iskljuÄivanje konektora povlaÄenjem za kabl, saplitanje o kabl, susret kabla sa usisivaÄem...) zaÅ¡titini provodnik se otkine prvi, vi nemate pojma o tome a ureÄ‘aj nastaje normalno da radi. Ukoliko doÄ‘e do nekog kvara i kućiÅ¡te doÄ‘e na nominalnih 230V može doći do nemilih dogaÄ‘aja u porodici. Kada povezujete kabl uvek ostavite žuto-zeleni zaÅ¡titni provodnik malo duži od ostalih! Tako će, ako doÄ‘e do kidanja provodnika, to biti najkraći (fazni ili nulti) i ureÄ‘aj će jednostavno prestati da radi. Znaćete da neÅ¡to nije u redu, uzemljenje je sigurno i dalje ispravno a ureÄ‘aj bezbedan. U najgorem sluÄaju opet sledi zamena osiguraÄa i ponovna terminacija kabla. Molim vas shavatite ovo ozbiljno, svi naponi iznad 50V se smatraju opasnim po život. Ako niste sigurni kako neka vam konektor stavi neko struÄan. Izvinjavam se na vikanju i boldovanom tekstu, mislim da je ovo jako bitno. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted May 15, 2015 Report Share Posted May 15, 2015 Ðко је црна пречага довољно Ñтегнута и како треба никада, али никада Ñе кабл неће извући из утикача. Проверено више пута. Иначе колега је ово одлично урадио а Ñам лем је за 10! Quote Link to comment Share on other sites More sharing options...
ZeAgiu Posted May 15, 2015 Report Share Posted May 15, 2015 Izgleda da tebi nešto drugo u sistemu vrišti, i to bolesno. Pogotovo mi nije jesno kako ti vrišti sa svim ostalim osim sa posrebrenim Kaiser-om. Ali, u pravu si. Skroz. Ako tako kažeš, onda mora da je tako... Pazi, ne moram da budem u pravu, uostalom, svaki je sistem prica za sebe gde svaka komponenta pa i konektor predstavlja ekvilajzer. Samo kazem da u poredjenjui sa Wattgate 320, Yarbo copper i Kaiser posrebrenim, fake "japanci" vriste, testirano sa Yarbo flat copper, Tominim Monster "power line 400" i Furutech fp-314ag II strujnim kablovima. Mozda je sa Lapp-om stvar drugacija ali to je ionako bezivotan kabl. A i nisam jedini koji uocio tu pojavu... Quote Link to comment Share on other sites More sharing options...
tsuyoshi Posted May 15, 2015 Report Share Posted May 15, 2015 @stoN_Cold, imate li predstavu Äemu onda uopÅ¡e ovo upredanje Å¡irma sa uzemljenjem na kraju gde se postavlja Å¡uko utiÄnica? ili da ponovim pitanje iz proÅ¡log posta, obzirom da privodim svoj kabl kraju pa da znam da li to tako da odradim, ili da idem na standardnu varijantu povezivanja. Dakle, ako neko zna, i voljan je da pomogne...Kada (i da li uopÅ¡te) ovo treba raditi, i kakav je uticaj na zvuk (ili smetnje, ne znam, pitam) ovakvog povezivanja samo sa te jedne strane? Quote Link to comment Share on other sites More sharing options...
