jager Posted May 5, 2015 Report Share Posted May 5, 2015 Samo mi ovo nije jasno ? http://www.sonarquest.net/new-p-079-gold-plated-pure-copper-eu-schuko-power-plug-c-079-iec-plug-connector.html Quote Link to comment Share on other sites More sharing options...
rokijana Posted May 5, 2015 Report Share Posted May 5, 2015 Gledaj desno! Quote Link to comment Share on other sites More sharing options...
rokijana Posted May 5, 2015 Report Share Posted May 5, 2015 SONAR 24k Gold-Plated IEC connector Audio Tweak / 28 October, 2010 One piece brand new 24k Gold-Plated SONAR IEC connector. CRYO -192 degrees 10A 250V / 15A 125V Accommodates cable: 9mm – 21mm Material: 99.99% OFC R-Copper Poles with 24K Gold Plated SPECIFICATION: Sonar CRYO -196 Degrees Sonar Audio Grade CRYO -196 Degrees Power Plug Series CRYO-192 Degree of Freezing Technology – 48 hours freezing treatment with Japanese professional refrigeration equipment to enhance the quality of conduction on the copper metal power plug. A very cold environment enhances the quality of conductive metal; the copper metal molecules release pressure therefore enhancing the molecular structure. It decreases copper resistance, the electronic transmission speed processes faster and reduces external interference. Additionally electrical noise will be reduced. As a result of the freeze treatment, the conductive quality of the metal will be significantly improved. • Metal power plug made from 100% high-purity copper • Gold plated 5 microns • Copper power plug has been treated with CRYO -192 Degree freezing treatment to enhance the quality of conductive metal • Enclosed in black cover with glass-fibre filled nylon material and manufactured with fire-retardant treatment Dimensions: Approximate 70mm body length x 39mm diameter x 88mm overall length Quote Link to comment Share on other sites More sharing options...
Aibo Posted May 5, 2015 Report Share Posted May 5, 2015 Od majstora koji metar kabla prodaje po ceni kotura 100 metara kod Aliexpressa. Ova priÄa se već vrtela ranije, sa sve linkovima ka onih 100 m za 28$. Ne budem lenj, kontaktiram prodavca sa Alija kad ono to je ipak cena za metar. 100m je kotur sa kog on to seÄe i zato mu stoji u naslovu, kako kaže. Tj. klasiÄna navlakuÅ¡a da neko klikne na buy. Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 6, 2015 Report Share Posted May 6, 2015 P.S. Sonar ( orig.japanski) nema blage veze sa Sonarquest-om Rece mi jedan audiofil da je neka Kineska firma kupila Sonar i da ga sad marketira pod imenom Sonarquest. Kad ga vidim pitacu ga za konkretne detalje. ( Rece mi da zna da je jos par firmi kupio i koji su to sad brandovi) BTW vise puta sam narucivao od Sonarquesta , razne vrste strujnih prikljucaka ali i RCA i zvucnicke terminale i uvek sam bio veoma zadovoljan kvalitetom. Pomenuti strujni koji nazivate Oyaide kopijom je veoma kvalitetno uradjen u Oyaide ambalazi. Uopste nemam zamerki na njega. Cak mislim da je Sonarquest OEM proizvodjac za Oyaide. Quote Link to comment Share on other sites More sharing options...
hardwareGQ Posted May 6, 2015 Author Report Share Posted May 6, 2015 Sonar i Sonarquest deluju zaista identicno. tako da je moguce i da je ista firma u pitanju. Vidim da su na sajtu izbacili upozorenje da su se pojavile i male kolicine njihovih kopija, ali da su lako uocljive razlike. Nov sam u svetu strujnih i IEC konektora, pa se izvinjavam zbog pocetnickih pitanja. Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted May 6, 2015 Report Share Posted May 6, 2015 Kopija Oyaide ima u viÅ¡e kvaliteta.Razlikuju se i vizuelnokonstrukcijski i po kvalitetu plastike.Neke imaju kontakte reÅ¡ene preko kontakt ploÄica, a neko kao uslovno reÄeno, kao lusterklema. Ja sam Äak nabavio i varijantu Å¡ukoa sa red koper pinovima, koja u originalu ne postoji.ZvuÄno je odliÄna, kvalitet plastike i opÅ¡te izrade, proseÄan. Pozlaćene, Å¡to prodaje ovaj Zvonko sa linka su odliÄne u svakom pogledu. Ranije je kolega sa foruma Denis imao na prodaju odliÄnu varijantu, ali na žalost nema viÅ¡e! .Na nekim varijantama koje imaju kontakt preko ploÄica, Å¡raf za pritezanje je oÄajnog kvaliteta, pa oblazne, ali i za to ima jednostavno reÅ¡enje. Quote Link to comment Share on other sites More sharing options...
Father Posted May 6, 2015 Report Share Posted May 6, 2015 Oyaide .... http://www.aliexpress.com/snapshot/6580690945.html?orderId=66546346212602 Ako je sudeći po trakicama i fontu, ovo je izvor onih jeftinijih, a oni skuplji kod majstora su pitanje odakle dolaze? On tvrdi da je posebnim kanalima/kontaktima doÅ¡ao inkognito do dobavljaÄa koji iz senke to distribuira!? ... Može da se proÄita na oglasu sa poÄetka posta! Ja sam proÅ¡le nedelje sebi kupio Wattgate IEC i dok sam se upućivao u detalje, saznam da postoji dodatni sloj izmeÄ‘u bakra i zlata. *WATTGATE Three Layer Plating Process 1. Oxygen free copper plating improves conductivity 2. Electroless nickel platingnecessary to prevent the leeching of the copper through the pure gold layer 3. 24k gold plating improves conductivity Meni taj 1 kom. IEC radi fantastiÄno, ali ozbiljno koÅ¡ta, za 3 kopije Oyiade kompleta. PoÅ¡to mi je trebao samo taj odluku sam lako doneo. Nisam siguran ni u Äistoću bakra, kvalitet poliranja, ni u debljinu pozlate ni u iskrenost u 24k gold kod ovih kopija. Ne kažem da nema onih koji rade poÅ¡teno, a uz to i ne žele da klepaju poÅ¡ten svet. Samo je pitanje kompromisa nas sa samim sobom koliko daleko želimo da odemo. Nebo je granica! Quote Link to comment Share on other sites More sharing options...
Toza Posted May 6, 2015 Report Share Posted May 6, 2015 Te kopije, bilo koja, su odliÄne za novac koji se traži za njih i odliÄne za manje zahtjevne korisnike/sisteme. Za ozbiljno rezolutan zvuk imaju mane i ne mogu da pariraju furutech-u i ieGo. Wattgate nisam probao, ali vjerujem da je i kod njega ista stvar. Nedostaci su najlakÅ¡e uoÄljivi u rezoluciji najviÅ¡eg spektra. Nemaju Äistoću i pomalo guÅ¡e to podruÄje Å¡to direktno utiÄe na dubinu pozornice i pozicioniranje po dubini. Izraženije kod iec nego kod Å¡uko. Ako se izbjegne iec i koristi samo Å¡uko (direktno lemi na uredjaj na strani iec), rezultati su odliÄni. Iz ovoga, moja preporuka je da ako se već koristi iec, obavezno Å¡to kvalitetniiji. Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 6, 2015 Report Share Posted May 6, 2015 Te kopije, bilo koja, su odliÄne za novac koji se traži za njih i odliÄne za manje zahtjevne korisnike/sisteme. Za ozbiljno rezolutan zvuk imaju mane i ne mogu da pariraju furutech-u i ieGo. Wattgate nisam probao, ali vjerujem da je i kod njega ista stvar. Nedostaci su najlakÅ¡e uoÄljivi u rezoluciji najviÅ¡eg spektra. Nemaju Äistoću i pomalo guÅ¡e to podruÄje Å¡to direktno utiÄe na dubinu pozornice i pozicioniranje po dubini. Izraženije kod iec nego kod Å¡uko. Ako se izbjegne iec i koristi samo Å¡uko (direktno lemi na uredjaj na strani iec), rezultati su odliÄni. Iz ovoga, moja preporuka je da ako se već koristi iec, obavezno Å¡to kvalitetniiji. Uporedjivao sam Furutech i "moj" svajseraj sa Sonarquestom ( rodijumskim) i razlike su minimalne uglavnom objasnjive samim karakterom rodijumskih konektora. Svakako ne opravdavaju razliku u ceni. I najvaznije je da nema pravila i da se mora probati da bi se odabrala najbolja sinergija izmedju kabla i uredjaja. Generalno bolji uredjaji su manje osetljivi na kablove od slabijih uredjaja. ( kod najgorih uredjaja razlike pa i nema ) I da. Ako vam nije imperativ da se igrate cable swap-a onda je bolje izbaciti sto je moguce vise elemenata koji mogu da negativno uticu, pa tako fiksni kabl na strani uredjaja predstavlja bolje resenje od IEC prikljucka. Quote Link to comment Share on other sites More sharing options...
Toza Posted May 6, 2015 Report Share Posted May 6, 2015 Slažem se. Uslovno reÄeno mane kod iec i Å¡asijskog i kablovskog se na taj naÄin izbjegavaju, a i naroÄito problematiÄan dio ožiÄenja oko trafoa. Quote Link to comment Share on other sites More sharing options...
zoranzu Posted May 6, 2015 Report Share Posted May 6, 2015 Cak mislim da je Sonarquest OEM proizvodjac za Oyaide. Tesko,cikica je usao u legendu sa poliranjem pinova Quote Link to comment Share on other sites More sharing options...
hardwareGQ Posted May 6, 2015 Author Report Share Posted May 6, 2015 Napominjem da sam pocetnik u shuko konektor svetu, pa mi oprostite ako ovo pitanje zvuci amaterski: Zasto su svi poceli da koriste rodijum kada mu je provodljivost jako mala, jedva malo bolja od mesinga, skuplji su od pozlacenih pa cak i posrebrenih, a imaju manju provodljivost. Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 6, 2015 Report Share Posted May 6, 2015 Cak mislim da je Sonarquest OEM proizvodjac za Oyaide. Tesko,cikica je usao u legendu sa poliranjem pinova Simpaticno kao duhovita digresija. Ali ko pogleda raznolikost Sonarquest ponude, kvalitet sa kojim rade ( pogotovo carbon seriju) a na kraju i OEM ponudu ( http://www.sonarquest.net/oem-service ) ne moze a da ne pomisli da je Oyaide proizveden kod Sonarquesta. (kao Apple kod Foxcona npr) Bilo bi interesantno videti kako izgledaju proizvodni pogoni Sonarquesta . Quote Link to comment Share on other sites More sharing options...
zoranzu Posted May 6, 2015 Report Share Posted May 6, 2015 Sonarquest se razlikuje od Oyaide(suko),prednji deo,kontakti za GND Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted May 6, 2015 Report Share Posted May 6, 2015 Uporedjivao sam Furutech i "moj" svajseraj sa Sonarquestom ( rodijumskim) i razlike su minimalne uglavnom objasnjive samim karakterom rodijumskih konektora. Svakako ne opravdavaju razliku u ceni. I najvaznije je da nema pravila i da se mora probati da bi se odabrala najbolja sinergija izmedju kabla i uredjaja. Generalno bolji uredjaji su manje osetljivi na kablove od slabijih uredjaja. ( kod najgorih uredjaja razlike pa i nema ) I da. Ako vam nije imperativ da se igrate cable swap-a onda je bolje izbaciti sto je moguce vise elemenata koji mogu da negativno uticu, pa tako fiksni kabl na strani uredjaja predstavlja bolje resenje od IEC prikljucka. Ovo je pravilo svih pravila.Skupa terminacija ne garantuje uspeh.Poredili smo Acrolink sa pozlaćenim IEGO sa posrebrenim IEGO, i kombinacijom IEGO srebro-zlato.Sve kombinacije isto koÅ¡taju, razlike u zvuku su znaÄajne, da ne pominjem poreÄ‘enja sa nekim drugim terminacijama ( Å¡to kopije Oyaide, HI-FI tuning itd) izbiće "konektorski rat" rezultati su vrlo interesantni. Dobre kopije Oyaide bolje rade od Wattgejta 320. Taj konektor je taman, ćebovan, guta detalje. 350, 390 su znatno bolji, ali mislim da ne opravdavaju cenu, Äak ni ovu na akciji od 60E komad.NIsam probavao direktno montiran kabl bez IEC i neću iz raznoraznih praktiÄnih razloga, ali mislim da Å¡uko viÅ¡e utiÄe na zvuk i daje krajnju nijansu kablu Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 6, 2015 Report Share Posted May 6, 2015 Sonarquest se razlikuje od Oyaide(suko),prednji deo,kontakti za GND Ako ti nije tesko molim te daj slike. Ja sam od Sonarquesta narucivao i dosao mi je Oyaide. E sad sta to znaci nemam pojma. ( OEM, fake, nesto trece,...) Quote Link to comment Share on other sites More sharing options...
zoranzu Posted May 6, 2015 Report Share Posted May 6, 2015 Cela prica se odnosila na razliku izmedju Sonarquesta i original Oyaide Sonarquest ima kontakte za GND tj uzemljenje,bocno i preko sredine(izmedju pinova) Oyaida original, samo bocno Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 6, 2015 Report Share Posted May 6, 2015 Cela prica se odnosila na razliku izmedju Sonarquesta i original Oyaide Sonarquest ima kontakte za GND tj uzemljenje,bocno i preko sredine(izmedju pinova) Oyaida original, samo bocno Kod mene je ako se dobro secam inline sve tri rupe . GND u sredini. Ako neko divani svapski da nam preprica: http://www.ebay.de/gds/Oyaide-Faelschungen-Plagiate-leicht-erkennen-/10000000012427504/g.html Otprilike se svodi na to da ovi Oyaide sa KP ( aliexpressas) su verovatno fake . Empirijski probano dobro zvuce. Cak daju izuzetan price/performance faktor. Pitanje ostaje da li su i koliko sigurni. Ipak je to struja, opasno po zivot. Valjda nece da se tope, smelcuju,... Quote Link to comment Share on other sites More sharing options...
Aibo Posted May 6, 2015 Report Share Posted May 6, 2015 BaÅ¡ je fino ovo Å¡to Sonarquest može da se kupi direktno bez posrednika, free shiping... ÄŒekam silikonske kablove pa da sklopim jedan strujni po receptu Ozrena Bilena. Isprobao bih ga prvo sa obiÄnim Å¡ukoom koji imam pri sebi pa onda da dobavim neku od ovih "Oyaide P-079", verovatno neku gold-plated varijantu jer vidim da njen zvuk opisuju mekÅ¡im a meni baÅ¡ to treba. IEC mi ne treba jer mi na pojaÄalu ide direktno. Nego se razmiÅ¡ljam da li sam Äitav Å¡to sve to planiram za jedan obiÄni HK6500. Slabo mi ide racionalno razmiÅ¡ljanje kad se za neÅ¡to zagrejem. Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 6, 2015 Report Share Posted May 6, 2015 Zaobidji silikonske. Quote Link to comment Share on other sites More sharing options...
jager Posted May 6, 2015 Report Share Posted May 6, 2015 Zaobidji silikonske. Ni ja ne volim silikonske ... nisu mi prirodne Quote Link to comment Share on other sites More sharing options...
Aibo Posted May 6, 2015 Report Share Posted May 6, 2015 Prvobitno sam hteo prosto da stavim onaj Å¡irmovani lapp, meÄ‘utim proÄitah sve ono "PVC nikako", ozrenov kabal je mama itd. Quote Link to comment Share on other sites More sharing options...
hardwareGQ Posted May 6, 2015 Author Report Share Posted May 6, 2015 @aibo lapp nije nista posebno, ali je ok. drug je pravio strujni koristeci njega i one posrebrene kaizer shuko i iec konektore sa KP, cuo je malu razliku u odnosu na fabricki kabal. Kasnije je napravio strujni kabal koristeci punu OFHC zicu 0.6mm preseka, sa tim istim posrebrenim Kaizer konektorima i odusevio se. Kaze mnogo dinamicnije i punije zvuci, otvorenije... E sad, cena lapp kabla je pristupacnija, ali zato i losije zvuci. a i ja sam se uverio kad je donosio kod mene. Quote Link to comment Share on other sites More sharing options...
Iron man Posted May 6, 2015 Report Share Posted May 6, 2015 Zaobidji Lapp. Quote Link to comment Share on other sites More sharing options...
