Vlajo Posted March 9, 2015 Report Share Posted March 9, 2015 Kad smo već o struji, jedno podpitanje: koju duplu Å¡uko utiÄnicu da kupim u moru domaćih i manje domaćih proizvodjaÄa ? Treba da promenim staru utiÄnicu i da umesto nje stavim duplu Quote Link to comment Share on other sites More sharing options...
pantaNS Posted March 9, 2015 Report Share Posted March 9, 2015 TEM modularnu, ako se ogranicimo na 'sirotinjska' resenja Quote Link to comment Share on other sites More sharing options...
Vlajo Posted March 9, 2015 Report Share Posted March 9, 2015 Kakve su ove ostale - Makel, Legrand, Aling, Majur ... Quote Link to comment Share on other sites More sharing options...
goxy62 Posted March 9, 2015 Report Share Posted March 9, 2015 Au jbt. "kad se sad nisam slogir'o", ne znam samo da sam dobro video,ali ako ste dosli dotle da vam treba poklopac za prasinu na strujnom kablu onda(k) ste pod pravim stesom,zapravo mi smo sto ga nemamo Gedzet godine,pardon veka. Mislim,glasno sam se nasmejao kad videh ovo,ima da probudim ukucane. nije to samo zbog prašine mogu i mravi da se uvuku ili vlaga i td. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted March 10, 2015 Report Share Posted March 10, 2015 nije to samo zbog prašine mogu i mravi da se uvuku ili vlaga i td. Tako je Quote Link to comment Share on other sites More sharing options...
Vlajo Posted March 10, 2015 Report Share Posted March 10, 2015 Zamenio utiÄnicu -saaaaam !!! Hvala Äika Zokiju na kontroli radova putem video prezentacije na daljinu Quote Link to comment Share on other sites More sharing options...
Vlajo Posted March 10, 2015 Report Share Posted March 10, 2015 Na mesto broj dva će se utaći cd plejer, tako da sam izbegao letvu, koja je pedalirana iz ovog timskog sastava. Savet mi je (opet) dao ZokiFTA. Hvala Zorane puno Quote Link to comment Share on other sites More sharing options...
ab Posted March 10, 2015 Report Share Posted March 10, 2015 Eto resenija Quote Link to comment Share on other sites More sharing options...
rokijana Posted March 10, 2015 Report Share Posted March 10, 2015 Na mesto broj dva će se utaći cd plejer, tako da sam izbegao letvu, koja je pedalirana iz ovog timskog sastava. Savet mi je (opet) dao ZokiFTA. Hvala Zorane puno Da li na ovom "vodu" imas samo ova dva potrosaca? Quote Link to comment Share on other sites More sharing options...
Vlajo Posted March 10, 2015 Report Share Posted March 10, 2015 Da, ima još jedna uticnica sa ups-om na kome je komp. Why ? Quote Link to comment Share on other sites More sharing options...
Spachek Posted March 10, 2015 Report Share Posted March 10, 2015 Bem ti, na ovaj gajtan bi glatko mogao motor od 10 kw da sljaka, bez da stuca Quote Link to comment Share on other sites More sharing options...
uzvarb Posted March 11, 2015 Report Share Posted March 11, 2015 Sad ja da pitam, ne zemam vas kao ostali nego sam stvarno ozbiljan. Pominje se uticaj utikaca, i suko i iec. Kako utice na zvuk iec uticnica na samom uredjaju, uticnica u zidu, a ono sto me takodje interesuje je unutar samog uredjaja od iec uticnice, parcici kablova do PCB, i konektor na PCB, ono parcence plastiÄice nabijeno na ona 2 pina sto vire iz ploce. Dalje vodove po ploci, i dovodne kablove do uticnice u zidu necu da pominjem, jer nikog necu onda uveriti u ozbiljnost pitanja. Ja imam pojacalo u D klasi, jel neko probavao efekte strujasa na njima. Ipak drugaciji princip rada, mozda se efekti gube, ili idu na sasvim drugu stranu. Imam sve strujase fabricke, oni sto je stiglo sa spravama, poigrao bih se sa tim al pre toga da pitam za miÅ¡ljenja. Dalje, uticnicu na zidu gde su sprave nemam, struju vodim produznim, pravjlnenim za ovu namenu od bakarnog licnastog kabla 2,5mm po vodu, gumena izolacija, sa strane dovoda nalona nije utaknut u zid nego je otvorena trofazna uticnisa i pod srafove slonena 1 faza, nula i uzemljenje naravno. To je bolje od 3x1,5 koji bi eventualno isao kroz zid, ta se uticnica ne korisri nizasta osim za audio, a sat i osiguraci su odmah sa suprotne strane zida te trobafne uticnice. Ako je neko u voljan da malo napise sta misli. Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted March 11, 2015 Report Share Posted March 11, 2015 A sta je ovo... http://www.kempelektroniksshop.nl/shunt-conditioners/maxiimus-p16.html Quote Link to comment Share on other sites More sharing options...
pantaNS Posted March 11, 2015 Report Share Posted March 11, 2015 Warp field generator Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted March 11, 2015 Report Share Posted March 11, 2015 A sta je ovo... http://www.kempelektroniksshop.nl/shunt-conditioners/maxiimus-p16.html ГлупоÑÑ‚ за децу богатих родитеља. Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted March 11, 2015 Report Share Posted March 11, 2015 ,E sto mi roditelji nisu bili bogati.... Quote Link to comment Share on other sites More sharing options...
zoranzu Posted March 11, 2015 Report Share Posted March 11, 2015 @uzvarb Sve i cela prica je oko transfera i prolaska ili prelaska energije,potrebne za rad uredjaja,kroz razne ne savrsene sredine tj materijale. Sto je blize samom potrosacu,to ce imati veci uticaj,bilo da se radi o 20 mikrona pozlate ili 1,8m UPOCC bakra ili srebrnom osiguracu... Kod D klase ,zbog samog principa rada SMPS,ima uticaja strujni na konacni zvuk. Quote Link to comment Share on other sites More sharing options...
zika Posted March 11, 2015 Report Share Posted March 11, 2015 A sta je ovo... http://www.kempelektroniksshop.nl/shunt-conditioners/maxiimus-p16.html Iz iste radnje, ovo (295€) je joÅ¡ bolje: a ovo (2.390€) (obavezno MkII jer je znaÄajno poboljÅ¡ano) ne može da omane Quote Link to comment Share on other sites More sharing options...
ManicP Posted March 11, 2015 Report Share Posted March 11, 2015 Mogli su uz taj gong da daju i neku udaraljku za te pare Quote Link to comment Share on other sites More sharing options...
prophet Posted March 11, 2015 Report Share Posted March 11, 2015 Aaahhahahaha... Quote Link to comment Share on other sites More sharing options...
pantaNS Posted March 11, 2015 Report Share Posted March 11, 2015 Iz iste radnje, ovo (295€) je još bolje: Ovo lici na neki hi-and-dildo-buzdovan Quote Link to comment Share on other sites More sharing options...
uzvarb Posted March 11, 2015 Report Share Posted March 11, 2015 @uzvarb Sve i cela prica je oko transfera i prolaska ili prelaska energije,potrebne za rad uredjaja,kroz razne ne savrsene sredine tj materijale. Sto je blize samom potrosacu,to ce imati veci uticaj,bilo da se radi o 20 mikrona pozlate ili 1,8m UPOCC bakra ili srebrnom osiguracu... Kod D klase ,zbog samog principa rada SMPS,ima uticaja strujni na konacni zvuk. Ok, jasno. Ono sto imam i sto mi duze vreme vec stoji, a nikako da probam jer nikako da se nakanim da kupim uticnice. Nemam pojma sta je, receno mi je da je Neotech, mada meni to lici na Lapp. Ima 5 provodnika i sirm u providnoj izolaciji. 2,5 kvadrata. E sad kako to terminisati. Faza, nula, faza, nula i uzemljene... Ili faza, faza, nula, nula uzemljenje. Garantovano postoji razlika kako se zice uvezu u sam utikac. Evo i slicice da bude jasnije o cemu pricam/sta pitam. Quote Link to comment Share on other sites More sharing options...
zika Posted March 11, 2015 Report Share Posted March 11, 2015 Mogli su uz taj gong da daju i neku udaraljku za te pare To je dodatna oprema koja se kupuje na poseban zahtev. Mada, udarac bi mogao poremetiti chakra-u tepsije. Šuška se da će MkIII imati posebno to (raz)rešeno. Quote Link to comment Share on other sites More sharing options...
pantaNS Posted March 11, 2015 Report Share Posted March 11, 2015 U taj gong se udara iskljucivo .i. Quote Link to comment Share on other sites More sharing options...
milovan1963 Posted March 11, 2015 Report Share Posted March 11, 2015 Ok, jasno. Ono sto imam i sto mi duze vreme vec stoji, a nikako da probam jer nikako da se nakanim da kupim uticnice. Nemam pojma sta je, receno mi je da je Neotech, mada meni to lici na Lapp. Ima 5 provodnika i sirm u providnoj izolaciji. 2,5 kvadrata. E sad kako to terminisati. Faza, nula, faza, nula i uzemljene... Ili faza, faza, nula, nula uzemljenje. Garantovano postoji razlika kako se zice uvezu u sam utikac. Evo i slicice da bude jasnije o cemu pricam/sta pitam.IMG_20150311_161410.jpg lapp petozilni...taj koji ti je rekao da je to neotech, je bash saljivdzija. Inace neotech na dosta modela redja zice faza nula, faza nula i tako se kopcaju u utikacu. Ako hoces da to prosvira kako treba, ignorisi to uzemljenje i omotaj novo oko kabla i na strani schukoa dodas mu zicu sa shirma, to sam vec opisivao, time udaljavas smece od zive struje i ono sa shirma vodis na uzemljenje...poenta je u borbi protiv buke-sum, a to najlakse radis na taj nacin Taj lapp prodaje tip iz Subotice, nije skupo, poenta je doci do 7 zilnog lappa koji je roba Quote Link to comment Share on other sites More sharing options...
