prophet Posted March 9, 2015 Report Share Posted March 9, 2015 Mislim da nije loÅ¡a ideja da postoji jedna tema u kojoj bi se objedinila merenja pojedinih zvuÄnih kutija. Za poÄetak merenja nekoliko FR drajvera: http://rutcho.com/speaker_drivers/default.html Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Zatim merenja većeg broja zvuÄnih kutija Blue Planet Acoustic Power Trio15.pdf Visaton Zyklop .pdf KLANG+TON Kormoran.pdf Millan Audio Trople Play Ribbon Compact.pdf BPA Competition aktiv.pdf BPA Competition pasiv.pdf Lautsprechershop Maja.pdf JBL 4355.pdf Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Visaton Zyklop .pdf Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 KLANG+TON Kormoran.pdf Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Millan Audio Trople Play Ribbon Compact.pdf Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 BPA Competition aktiv.pdf Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 BPA Competition pasiv.pdf Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Lautsprechershop Maja.pdf Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 JBL 4355.pdf Moderacija može da spoji ove postove u jedan zbog bolje preglednosti. Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Na ovom linku ima dosta izmerenih zvuÄnika: http://www.soundstagenetwork.com/index.php?option=com_content&view=article&id=16&Itemid=18 Ovde su uglavnom loÅ¡i primeri: http://techtalk.parts-express.com/showthread.php?229108-The-Worst-Speakers-Ever!-Shiny-Finishes-Good-Marketing-Terrible-Sound&s=878410c8ca00351ce776e6c7dcc46be4 Quote Link to comment Share on other sites More sharing options...
Филип Posted March 9, 2015 Report Share Posted March 9, 2015 @prophet Hvala na linku, kako se kotira Vivid B1? Osim ovoga da je zbog konfiguracije bas jedinica primetna anomalija na 350Hz (napred/nazad u istoj osi, gde zadnji drajver svira sve ispod 100Hz) - pozicija mikrofona ispred i iza zvucnika - ostali grafikoni mi nisu bas jasni… Bio bih zahvalan za pojasnjenje u kratkim crtama.http://www.soundstagenetwork.com/index.php?option=com_content&view=article&id=409:nrc-measurements-vivid-audio-b1-loudspeakers&catid=77 Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Koliko sam razumeo postoje dva basa jedan sa prednje koji svira do pomenutih 900Hz i jedan sa zadnje strane odseÄen negde oko 100Hz . Tu zbog konfiguracije dolazi do poniÅ¡tavanja na toj frekvenciji. Plus postoji bas reflex port koji je koliko vidim tjuniran na 39Hz. Ovo je sa SF sajta radi lakÅ¡eg razumevanja: En general, svaki drajver svira i preko/ispod frekvencije rezanja, u zavisnosti od reda i tipa skretanja opadajućom krivom. Ono Å¡to bih na osnovu ovih merenja naveo kao nedostatak je pik na 500Hz i faza u centralnom delu . Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Treba napomenuti da su ova merenja samo jedan od pokazatelja. Uglavnom nearfield, jedan signal, jedan zvuÄnik, jedan prostor. Quote Link to comment Share on other sites More sharing options...
prophet Posted March 9, 2015 Author Report Share Posted March 9, 2015 Zaph - merenja nekoliko kategorija drajvera: http://www.zaphaudio.com/tweetermishmash/ http://www.zaphaudio.com/smalltest/ http://www.zaphaudio.com/5.5test/ http://www.zaphaudio.com/6.5test/ http://www.zaphaudio.com/8test/ http://www.zaphaudio.com/nondomes/ Quote Link to comment Share on other sites More sharing options...
milovan1963 Posted March 9, 2015 Report Share Posted March 9, 2015 dobra ti je tema, i linkovi...Zaph je kralj,a manjkavo mu je sto se on 99% oslanja na merenja, a kako drajver tonalno zvuci mu je na marginama Quote Link to comment Share on other sites More sharing options...
Филип Posted March 10, 2015 Report Share Posted March 10, 2015 Koliko sam razumeo postoje dva basa jedan sa prednje koji svira do pomenutih 900Hz i jedan sa zadnje strane odseÄen negde oko 100Hz . Tu zbog konfiguracije dolazi do poniÅ¡tavanja na toj frekvenciji. Plus postoji bas reflex port koji je koliko vidim tjuniran na 39Hz. Ovo je sa SF sajta radi lakÅ¡eg razumevanja: Vivid B1.jpg En general, svaki drajver svira i preko/ispod frekvencije rezanja, u zavisnosti od reda i tipa skretanja opadajućom krivom. Ono Å¡to bih na osnovu ovih merenja naveo kao nedostatak je pik na 500Hz i faza u centralnom delu . Hvala na odgovoru, JA je pojasnio izmerene vrednosti i potencijalne probleme sa prostorijom tj. poziciniranjem (vezano za moguce preklapanje sobe i bas refleks porta na 38-39Hz tj. pravljenje boomy efekta). Navodno, osim malo vise vremena za pozicioniranje radi optimalnog tj. ravnijeg odziva u nizem-srednjotonskom i bas podrucju, ne vidi veci problem zbog same konstrukcije bas drajvera sa prednje i zadnje strane (detektovano je i kasnjenje od 1.5 milisekundi zvuka sa prednjeg u odnosu na zadnji drajver). "Fig.5 shows the B1's lateral dispersion, referenced to the response on the tweeter axis so that the changes are emphasized. This is textbook behavior above 1kHz, the speaker having a wide, even, well-controlled radiation pattern—something that correlates with stable, well-defined stereo imaging." Ovo citirano mi potencijalno znaci s obzirom da mi je desni deo dnevne sobe otvoren u stranu i dubinu prema kuhinji i potreban mi je zvucnik sa stabilnom pozornicom i stereo slikom.http://www.stereophile.com/content/vivid-audio-b1-loudspeaker-measurements Da ne bude zabune, druga fotka je pogled na zadnju stranu zvucnika. Quote Link to comment Share on other sites More sharing options...
prophet Posted March 10, 2015 Author Report Share Posted March 10, 2015 Da, moraju da se izvuku napred u prostor. Ako se ograniÄimo na bas segment ova koncepcija bi najoptimalnije radila sa zvuÄnicima pozicioniranim tako da bas drajver bude na polovini visine sobe. Quote Link to comment Share on other sites More sharing options...
Филип Posted March 10, 2015 Report Share Posted March 10, 2015 Å to je u mom sluÄaju praktiÄno nemoguće… makar u trenutnom prostoru u svakodnevnom sluÅ¡anju. Quote Link to comment Share on other sites More sharing options...
prophet Posted March 10, 2015 Author Report Share Posted March 10, 2015 ZaÅ¡to ne razmiÅ¡liÅ¡ u pravcu zvuÄnika predviÄ‘enih da stoje uz/na zidu, recimo Karlson? Quote Link to comment Share on other sites More sharing options...
Филип Posted March 10, 2015 Report Share Posted March 10, 2015 Hehehe, pa zato Å¡to mi se B1 sviÄ‘a i kako izgleda i kako zvuÄi, a ni ne zauzima prevelik prostor ni gabaritno ni vizuelno (ne kažem da bi se svakom dopao). SluÅ¡ao sam viÅ¡e puta njegovu mlaÄ‘u i stariju bratiju, i mnogo mi se dopada zvuk Vivida. A Å¡to se tiÄe prostora, valjda isti neće biti uvek ograniÄen Quote Link to comment Share on other sites More sharing options...
destimulacija Posted September 19, 2015 Report Share Posted September 19, 2015 Zaph - merenja nekoliko kategorija drajvera: http://www.zaphaudio.com/tweetermishmash/ http://www.zaphaudio.com/smalltest/ http://www.zaphaudio.com/5.5test/ http://www.zaphaudio.com/6.5test/ http://www.zaphaudio.com/8test/ http://www.zaphaudio.com/nondomes/ ОÑим ових мерења Ñпакованих у категорије, доÑта каÑнијих окачио је на блог.. http://www.zaphaudio.com/blog.html Zaph je kralj,a manjkavo mu je sto se on 99% oslanja na merenja, a kako drajver tonalno zvuci mu je na marginama Ðа оÑнову његових мерења Ñа 99% тачноÑти може Ñе проценити како неки драјвер тонално звучи.. То што неки ''мајÑтори'' узму Ñјајан драјвер па оÑфушере Ñкретницу, или га употребљавају тамо где му није меÑто и Ñврха, никако није објективан показатељ шта он заправо може.. Quote Link to comment Share on other sites More sharing options...
destimulacija Posted September 19, 2015 Report Share Posted September 19, 2015 Узгред, одлична тема, треба је неговати.. http://www.audiogurman.com/index.htm https://www.hifi-selbstbau.de/datenbler-mainmenu-40 Quote Link to comment Share on other sites More sharing options...
destimulacija Posted September 19, 2015 Report Share Posted September 19, 2015 Пар кућних мерења.. PMC TB2S+ Vienna Acoustics Mozart Signature Ðа крају домаћа памет.. https://rupicaudiobeograd.wordpress.com/2013/05/20/bubinga/ Quote Link to comment Share on other sites More sharing options...
Milosav Grozni Posted September 20, 2015 Report Share Posted September 20, 2015 Po stoti put. Akonto domace pameti. Niti je konstruktor, niti sam ja dozvolio objavljivanje merenja, koja na koncu nisi cak ni ti radio. Postavlja se pitanje objektivnosti i dobronamernosti. Tvoje vidjenje zvuka, hi fija, pseudoakustike i bihevioralne patologije treba objaviti na nekim drugim forumima. Zvuk nije samo merenje (bogu hvala), a socijalna patologija, bar u tvom slucaju je konstanta. NIti su tvoje usi, niti su tvoji udovi referentni. Ne zelim da radim na istima, ali nateraces me. Pozdrav a komsijama prijatno popodne uz pesmu OVAMO CIGANI Quote Link to comment Share on other sites More sharing options...
MRMOT Posted September 20, 2015 Report Share Posted September 20, 2015 Po stoti put. Akonto domace pameti. Niti je konstruktor, niti sam ja dozvolio objavljivanje merenja, koja na koncu nisi cak ni ti radio. Postavlja se pitanje objektivnosti i dobronamernosti. Tvoje vidjenje zvuka, hi fija, pseudoakustike i bihevioralne patologije treba objaviti na nekim drugim forumima. Zvuk nije samo merenje (bogu hvala), a socijalna patologija, bar u tvom slucaju je konstanta. NIti su tvoje usi, niti su tvoji udovi referentni. Ne zelim da radim na istima, ali nateraces me. Pozdrav a komsijama prijatno popodne uz pesmu OVAMO CIGANI WTF....sta ovo treba da znaci??? Quote Link to comment Share on other sites More sharing options...
