fancy74 Posted April 4, 2017 Author Report Share Posted April 4, 2017 Evo danas stigao levi roller iz kosica slovacka preko e-bay i covek mi poslao mesinganu cauru zamenio pazljivo i podesio zatezanje i naleganje i evo vec nekoliko kaseta sam isprobao niti seta sa azimuta niti ostavlja tragove na traci sada cu da proverim i kalibraciju sta ce ona reci i mislim da ce biti ok Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 4, 2017 Author Report Share Posted April 4, 2017 Dali neko moze da mi kaze koja je oznaka RECORD/PLAY glave na ovom deku posto se nevidi napisano na samoj glavi a u servisnoj dokumentaciji nije napisana tacna oznaka glave Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 4, 2017 Author Report Share Posted April 4, 2017 DALI JE DD68421 oznaka ? Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 4, 2017 Author Report Share Posted April 4, 2017 nasao oznaku 74211A Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 4, 2017 Report Share Posted April 4, 2017 И шта са том ознаком? Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 5, 2017 Author Report Share Posted April 5, 2017 NA satrim glavama je bio zarez koji je pravio traku na kaseti tj na traci i nabavio druge polovne ali malo koristene glave original 74211 i sada je to to kalibracija ide dobro svira odlicno Quote Link to comment Share on other sites More sharing options...
aco Posted April 5, 2017 Report Share Posted April 5, 2017 Čekaj,kupio si za 120 eura dek i onda menjao glave Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 5, 2017 Author Report Share Posted April 5, 2017 Ma da totalni promasaj dek je skroz mehanicki bio rastelovan fizicki je kao iz radnje ali kada sam poceo da slusam kasete primetio sam sve ove nedostatke , levi i desni roleri stavljeni novi vodjenje trake je nastelovano i to radi jedino sto sam mislio da mi trag ostavlja stara glava nabavio sam drugu za 10 eura koja je u boljem stanju sada to radi i nebrljavi azimut neostavlja po traci taj trag kao na satroj glavi ukoliko je i to bilo do stare glave , samo sve steloujem odokativno i sa mirror kasetom i signalima sa kompa a na drugom kompu sa programom simulatorom osciloskopa podesavam kaseta mi je ipak jako pomogla oko stelovanja rolera levog i samo vodjenje trake koje je bilo nestabilno jer je stari bio neispravan i istrosen, Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 5, 2017 Author Report Share Posted April 5, 2017 imam starije dekove iz slabije serije SONY TC-K570 I 670 pa sam mislio da cu uspeti nabaviti i dobro ocuvan ovaj 790es ali preplatio sam ga nikada ama bas nikada necu vise kupovati bilo sta da je starije od 20 godina a bez pregleda Quote Link to comment Share on other sites More sharing options...
aco Posted April 5, 2017 Report Share Posted April 5, 2017 Ne vredi ništa bez pregleda. Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 5, 2017 Author Report Share Posted April 5, 2017 Sredicu ja ovaj dek i on ostaje samo bi hteo da pitam dali postoje neka upustva za podesavanje deklinacije i polozaja play rec glava ovako to odokativno i sa slusnim pregledom dobro zvuci ali vidim da se koristi za to alat kojim se steluje polozaj glave naspram pinchrolera , Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 5, 2017 Report Share Posted April 5, 2017 Имаш огледало касету. Quote Link to comment Share on other sites More sharing options...
fancy74 Posted April 5, 2017 Author Report Share Posted April 5, 2017 to je to Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 5, 2017 Report Share Posted April 5, 2017 Нисам стигао да одем до стаклорезца али отом потом. Мислим да пре уградње самог огладала треба извући две танке линије неким квалитетнијим фломастером и то да је размак измеђуједнак колика је ширина траке. Quote Link to comment Share on other sites More sharing options...
