pollux Posted April 18, 2016 Author Report Share Posted April 18, 2016 Quote Link to comment Share on other sites More sharing options...
Golum Posted April 18, 2016 Report Share Posted April 18, 2016 Svaka cast Boki! Brutalno izgleda..kapiram jos bolje svira Pozz i nadam se da se vidimo u Bg nekom prilikom ili ovde u blizini na skijanju (moze Saas Fee npr) A sta bi sa onim velikim iz Haga? Quote Link to comment Share on other sites More sharing options...
robespierre Posted April 18, 2016 Report Share Posted April 18, 2016 A sta bi sa onim velikim iz Haga? Pa dobio presudu da je nevin Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
Golum Posted April 18, 2016 Report Share Posted April 18, 2016 Pa bas zato treba da ugleda sunce dana Quote Link to comment Share on other sites More sharing options...
pollux Posted April 18, 2016 Author Report Share Posted April 18, 2016 Razvija se ali sporo ,tako je sa aktivnmi zvucnicima, sa gomilom drivera i pojacala, a i preseljen je iz Haaga u NY. Quote Link to comment Share on other sites More sharing options...
pollux Posted April 11, 2018 Author Report Share Posted April 11, 2018 Soba se malo upgrade-ovala na 56kvm pa je sistem mogao da prodise. konacno je Dynaudio dobio 4.5m izmedju zvucnika. Od ostalog RAAL supertweeter-i su sad pogonjeni sa YBA w202 a i phono sekcija je Korato anniversary MM/MC. Quote Link to comment Share on other sites More sharing options...
den!s Posted April 12, 2018 Report Share Posted April 12, 2018 Jao lepote! Svaka čast! Quote Link to comment Share on other sites More sharing options...
pera451 Posted April 13, 2018 Report Share Posted April 13, 2018 Sjajno sredjeno. Samo jedno pitanje (zanima me posto ja preuredjujem dnevnu sobu). Da li ti, kada gledas ovaj TV, gledas navise, tj. glava ti je podignuta navise? Quote Link to comment Share on other sites More sharing options...
Father Posted April 13, 2018 Report Share Posted April 13, 2018 To se lako može i videti, obzirom da je donja ivica TV-a u visini očiju ili čak i malo iznad. Malo izdignuta glava na duže vreme može da dovede do sušenja grla i blage neprijatnosti, osim ako se redovno kvasi Whisky-jem ili Pivom. 57 minuta ranije, pera451 said: (zanima me posto ja preuredjujem dnevnu sobu). Računaj da ti je linija prve trećine visine TV-a (znači nešto ispod polovine ekrana) na 95-110cm od poda gde ćeš izbeći da gledaš na dole a neće ti smetati ta mala uzdinutost do stedine ekrana. Ostatak će obaviti normalan zahvat užeg fokusa vidnog polja. Ova visina će biti ok čak i ako ležiš na trosedu i gledaš TV sa nešto niže pozicije. Quote Link to comment Share on other sites More sharing options...
pera451 Posted April 13, 2018 Report Share Posted April 13, 2018 54 minuta ranije, Father said: To se lako može i videti, obzirom da je donja ivica TV-a u visini očiju ili čak i malo iznad. Da, upravo me ovo i zanima. Prema onome sto sam do sada imao prilike da procitam, anatomski polozaj za gledanje u monitor (TV) bi trebao da bude takav da covek gleda nanize. Znaci, ne cak ni potpuno horizontalno, vec nanize, a nikako navise. Ovo u praksi stvara odredjen problem, jer je mnogo pogodnije podici TV i na taj nacin stvoriti ispod njega prostor za elektroniku itd. Ovo podizanje TV-a i ne bi bio problem ako bi gledalac sedeo na relativno visokoj stolici, ali je sigurno problem ako on sedi na niskoj sofi. U bioskopu gledalac cesto mora da gleda navise, pogotovo ako je u prvim redovima. Koliko to neprijatno moze da bude zna svako ko je tako sedeo... U pozoristu je to donekle neizbezno (u prvih nekoliko redova), jer je scena tako postavljena da glumci ipak moraju da budu razdvojeni od gledalaca. Ipak mi se cini, da, ako je to moguce, ekran treba postaviti tako da njegova sredina bude ispod nivoa ociju. Quote Link to comment Share on other sites More sharing options...
Iron man Posted April 13, 2018 Report Share Posted April 13, 2018 Ovo je položaj TZV kladioničarski. Quote Link to comment Share on other sites More sharing options...
Father Posted April 13, 2018 Report Share Posted April 13, 2018 7 minuta ranije, pera451 said: Znaci, ne cak ni potpuno horizontalno, vec nanize, a nikako navise. U takvoj situaciji bi veliki TV subjektivno delovao dosta manji. Danas su na neki način TV-i dosta dominanti u dnevnim sobama, pa je i njihov dizajn i značaj potrebno adekvatno "ispoštovati", zato sam naveo u prethodnom postu blago uzdignut manir gledanja podražavajući bioskop u funkciji kućnog bioskopa kao sveprisutnijoj pojavi u enterijerima. Quote Link to comment Share on other sites More sharing options...
pera451 Posted April 13, 2018 Report Share Posted April 13, 2018 Ima smisla... pogotovo ako je TV bitniji od gledaoca Razumem ideju, ali meni TV nije toliko bitan, a verovatno i ne bi puno dosao do izrazaja pored TDL monitora koji stoje duboko unutar sobe :). Mislio sam da postoji neki ergonomsko-fizioloski razlog. Ali hvala na razjasnjenju, potpuno je smisleno. Quote Link to comment Share on other sites More sharing options...
Father Posted April 13, 2018 Report Share Posted April 13, 2018 19 minuta ranije, pera451 said: Mislio sam da postoji neki ergonomsko-fizioloski razlog. Ali hvala na razjasnjenju, potpuno je smisleno. Nažalost je više pitanje "većeg uzorka". Naravno ako klijent iznese specifične zahteve obično bivaju ispoštovani ili ako su ekstremno ne izvodljivi ili skupi, pokušavamo (kolege arhitekte/enterijeristi) da osmislimo neko kompromisno rešenje koje zadovoljava sve aspekte i potrebe u funkcionalnom i estetskom smislu. Quote Link to comment Share on other sites More sharing options...
pollux Posted April 13, 2018 Author Report Share Posted April 13, 2018 3 sati ranije, pera451 said: Sjajno sredjeno. Samo jedno pitanje (zanima me posto ja preuredjujem dnevnu sobu). Da li ti, kada gledas ovaj TV, gledas navise, tj. glava ti je podignuta navise? Za idealno gledanje (bioskopsko) a i za kicmeni stub je nekih 7.5 stepeni podignut pogled e sad to u praksi nije bas uvek postici narocito kad varira visina ukucana (ja sam 194cm a supruga 178). U trenutku kad sedim na trosedu moje oci su na 118 cm a televizor pocinje na nekih 93cm. e sad posto u vecini slucajeva lezimo a ne sedimo a plus je televizor i zakrivljen (55inch) sve to pada u vodu . Gledao sam da bude sto idealnije sedecim uslovima a da ne remeti estetiku. Quote Link to comment Share on other sites More sharing options...
pera451 Posted April 13, 2018 Report Share Posted April 13, 2018 Hvala, imas li neki izvor za taj podatak? Da li on podrazumeva odredjen oblik "stolice", odnosno naslona? Ne zaboravimo da je naslon sofe obicno suvise nizak da bi obezbedio bilo kakav adekvatan oslonac za vratni deo kicme... Quote Link to comment Share on other sites More sharing options...
Father Posted April 13, 2018 Report Share Posted April 13, 2018 On 4/11/2018 at 22:24, pollux said: Prosto ne verujem da je ovaj TV 55inch? Deluje mi mnogo manji ?? .... bar na ovoj slici? https://www.rtings.com/tv/reviews/by-size/size-to-distance-relationship Quote Link to comment Share on other sites More sharing options...
pollux Posted April 13, 2018 Author Report Share Posted April 13, 2018 1 minut ranije, Father said: Prosto ne verujem da je ovaj TV 55inch? Deluje mi mnogo manji ?? .... bar na ovoj slici? https://www.rtings.com/tv/reviews/by-size/size-to-distance-relationship Televizor je 55 incha curved polica ispod njega 3.80m zvucnici 127 cm slika je malo iz nezgodnog ugla pa sve izgleda manje Quote Link to comment Share on other sites More sharing options...
Father Posted April 13, 2018 Report Share Posted April 13, 2018 Da u pravu si, proverio sam u Photoshopu. Širokougaoni objektiv baš suzi centar slike, a raširi periferiju. Quote Link to comment Share on other sites More sharing options...
Father Posted April 13, 2018 Report Share Posted April 13, 2018 Skoro pa tačno visina boxa kutija kao širina ekrana. Quote Link to comment Share on other sites More sharing options...
pollux Posted April 13, 2018 Author Report Share Posted April 13, 2018 3 minuta ranije, Father said: Da u pravu si, proverio sam u Photoshopu. Širokougaoni objektiv baš suzi centar slike, a raširi periferiju. Naravno da sam u pravu ili su me ozbiljno prevarili kad sam kupovao televizor Quote Link to comment Share on other sites More sharing options...
Father Posted April 13, 2018 Report Share Posted April 13, 2018 Ne bi me iznenadilo da u budućnosti daju info za dimenzije ambalaže većim brojevima nego za uređaje. Kako stvari u tgovinama idu. Quote Link to comment Share on other sites More sharing options...
pollux Posted April 13, 2018 Author Report Share Posted April 13, 2018 21 minuta ranije, pera451 said: Hvala, imas li neki izvor za taj podatak? Da li on podrazumeva odredjen oblik "stolice", odnosno naslona? Ne zaboravimo da je naslon sofe obicno suvise nizak da bi obezbedio bilo kakav adekvatan oslonac za vratni deo kicme... Nemam izvor za oblike stolica i naslona ovo je preporuka Americke filmske akademije koja se koristi za projektvanje najboljih sedista u bioskopima koja su doduse za drugaciji format ekrana Quote Link to comment Share on other sites More sharing options...
pera451 Posted April 13, 2018 Report Share Posted April 13, 2018 OK, pretpostavio sam. Ali je to ipak za situaciju koja se bitno razlikuje od dnevne sobe... Hvala! Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted April 13, 2018 Report Share Posted April 13, 2018 2 sati ranije, pera451 said: Prema onome sto sam do sada imao prilike da procitam, anatomski polozaj za gledanje u monitor (TV) bi trebao da bude takav da covek gleda nanize. (....) 2 sati ranije, Father said: (....) Danas su na neki način TV-i dosta dominanti u dnevnim sobama, pa je i njihov dizajn i značaj potrebno adekvatno "ispoštovati", zato sam naveo u prethodnom postu blago uzdignut manir gledanja podražavajući bioskop u funkciji kućnog bioskopa kao sveprisutnijoj pojavi u enterijerima. Ponukala me je ova tema da obratim pažnju na položaj u kojem sedim ( u kojem sedim strogo uspravno ili sam zavaljen u svim mogućim varijantama jer sticajem okolnosti, u poslednjih godinu i po skoro ceo dan provodim na istom mestu. Soba je cela podredjena položajima zvučnika i fotelje. Tevelizor nikada nisam imao ali imam monitor na stalku sa točkićima pa mogu da ga pomeram gde hoću (do kreveta kad legnem) I tek sad sam primetio, visina monitora je praktično ista kao izabrana idealna visina zvučnika. Dakle, gledam monitor blago naniže. S razdaljine od cca 1m. Nit me bole oči nit me boli vrat. Za sad 21 minuta ranije, pera451 said: OK, pretpostavio sam. Ali je to ipak za situaciju koja se bitno razlikuje od dnevne sobe... Hvala! Zato je moja fotelja beržera Quote Link to comment Share on other sites More sharing options...
