dj.nik Posted January 8, 2018 Report Share Posted January 8, 2018 Proverio obe verzije Oppo USB drajvera, 1.61 i najnoviji 3.26, oba nude podrsku za asinhroni USB prenos i Kernel Streaming. Quote Link to comment Share on other sites More sharing options...
prophet Posted January 8, 2018 Report Share Posted January 8, 2018 Oppo instalira samo asio driver a ovako bez oppoovog OEM drivera, nema nijedan output sa KS: Oppo nesto... Nema veze i onako USB 2.0 radi perfektno u Win10. Hvala u svakom slucaju. Iskreno ne instalira mi se ponovo oppoov driver jer je definitivno losije radio od ovog na DSD: WASAPI Push... Da li imas instaliranu kernel komponentu na f2k? Quote Link to comment Share on other sites More sharing options...
Father Posted January 8, 2018 Report Share Posted January 8, 2018 Imam instaliranu Kernel komponentu u foobaru, ali ne vidi oppo i ne pojavljuje se u output listi. Nisam instalirao oppo driver. Quote Link to comment Share on other sites More sharing options...
Father Posted January 8, 2018 Report Share Posted January 8, 2018 39 minuta ranije, DJ.NIK said: Proverio obe verzije Oppo USB drajvera, 1.61 i najnoviji 3.26, oba nude podrsku za asinhroni USB prenos i Kernel Streaming. Znaci treba mi oppo driver instaliran da bi radio kroz kernel stream. Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 8, 2018 Report Share Posted January 8, 2018 Tako je. I nista nemoj da de-instaliras (M$ Njinjdous USB drajver) pa vrati na DSD WASAPI push ako ti ne odgovara zvuk. Licno misljenje, WASAPI ti je najlosija opcija. KS pa original ASIO pa (ako se mora) WASAPI drajver. Da KS radi kako treba vidis i po tome da slajder za jacinu fuJbar ne radi, sto je znak da se zaobilaze posrednici. Kod DSD i ne postoji nacin regulacije jacine interno vec svakako mora spolja, u nekoj predpojacavackoj sekciji. Quote Link to comment Share on other sites More sharing options...
Father Posted January 8, 2018 Report Share Posted January 8, 2018 Hvala! Probacu driver, pa cu sutra poslusati kako radi. Javljam utiske. Svima hvala. Quote Link to comment Share on other sites More sharing options...
Zexx Posted January 8, 2018 Report Share Posted January 8, 2018 1 sat ranije, DJ.NIK said: EDIT na gornji post: Citajuci uputstvo sa Oppo sajta, ti bi Morao da imas i KS opciju za Oppo 103 & 105! Clanak ovde: http://wiki.oppodigital.com/index.php?title=BDP-105_Asynchronous_DAC_FAQ Imaće. U Windows XP... Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 8, 2018 Report Share Posted January 8, 2018 Nemo' zbunjujes co'eka. Radice fujbar KS komponenta i na W10. Ona slicica moja jeste iz paketa drajvera 3.26 a moze da proba i kako rade stariji drajveri. A kad malo poslusa KS kroz fuJbar, ondaK cu da ga kratko uputim da instalira pravi audio softver. Ako nudi pivo, jelte Quote Link to comment Share on other sites More sharing options...
Father Posted January 8, 2018 Report Share Posted January 8, 2018 Nudim pivo u svakom slucaju. Zexx je u pravu ne radi u win10. Intalirao sam i oppo 3.26 i pojavila su se dva KS outputa jedan cisto KS, a drugi DSD:KS: oppo.... Oba su mi davala error u reprodukciji. Ne radi. Mozda probamo kada me posetis. Neka za sada, ne mogu vise da se akam sa driverima. Ovaj windows-ov radi ekstra. Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 8, 2018 Report Share Posted January 8, 2018 I kod mene je W10 (x64 Pro) sa sve najnovijim apdejtima na koji prikjucujem Light Harmonic GeekOut USB konverter sa istim, Ess Sabre9018 chip-om i sve radi (KS) sasvim normalno. Tu je i PCI kartica Infrasonic Quartet i ona radi normalno. DakleM, nesto si fujbar preterano setovao ili u prozoru Oppo drajvera nisu sve kockice na broju. Ako bafer recimo stoji na Minimum, podesi ga na Extra Safe ili Safe i slicno pa idi nanize. Nemam Oppo pa ne mogu da vidim prave opcije drajvera. Pozz. Quote Link to comment Share on other sites More sharing options...
sola Posted January 8, 2018 Report Share Posted January 8, 2018 Pozdrav Ako moze pomoc imam skin Darkone4 mod v1 i sa leve strane imam listu muzike.e problem je sto je text toliko sitan da jedva razaznajem sta pise.bas me smara da nabadam sta trazim.skinuo sam text tools i povecao text ali se u plej listi nista nemenja.dali postoji nacin da povecam slova tj nazive albuma. Quote Link to comment Share on other sites More sharing options...
garson Posted January 8, 2018 Report Share Posted January 8, 2018 @DJ.NIK Koja je prednost KS u odnosu na ASIO? Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 8, 2018 Report Share Posted January 8, 2018 Jednostavo receno KS je najdirektniji put audio signala - direktno kroz kernel OS-a ka izlazu sa najvisim (iliti najnizim) nivoom prioriteta procesa (Thread Priority). Sve ostalo (ASIO, WASAPI, DS ...) podrazumeva dodatne procese sto usporava i degradira reprodukciju. KS nije nikakva novina. Na W7 mislim da mozes jos uvek da isprobas 'cics Memory Player' (cMP2) koji je originalno bio namenjen potpuno ogoljenom Win XP-u (svega ~130MB). Pocetak PC audio revolucije, zauvek besplatan. Quote Link to comment Share on other sites More sharing options...
garson Posted January 8, 2018 Report Share Posted January 8, 2018 Da, secam se KSa jos iz vremena XPa mada ga nikad nisam koristio. Za WASAPI i DS mi je jasno, ali kako to da ASIO ne ide direktno do hardvera? :| Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 9, 2018 Report Share Posted January 9, 2018 Ja sam samo (napredniji) korisnik audio softvera, ne mogu reci da sam poznavaoc svih Win OS detalja. Upravo i ja malo rascitavam o KS-u na M$oft stranicama al' necu biti nista pametniji u odgovorima i da sve ono naucim napamet. Ipak je to teren za softver i hardver kreatore a na meni je da sto vise audio softvera dobavim i isprobam. Natenane, koristeci sve opcije i varijante. Malocas pomenuh davno korisceni pa zaboravljeni CMP2 pa se vratih da iscitam i podsetim da je i on ASIO baziran SW. E zato se setih mocnog a besplatnog ruskog softvera pod imenom AlbumPlayer, aktuelna verzija 2.110 koji podrzava sva tri moda pa se rezultati (zvucni) mogu direktno porediti . Naravno ako i hardverska strana podrzava sve tri opcije. Koliko vidim zadnju verziju treba instalirati / pokretati pod admin pravima a ako to nije moguce, vratiti se na verziju 2.105 (procitati readme pdf). Quote Link to comment Share on other sites More sharing options...
garson Posted January 9, 2018 Report Share Posted January 9, 2018 10 sati ranije, DJ.NIK said: Ja sam samo (napredniji) korisnik audio softvera, ne mogu reci da sam poznavaoc svih Win OS detalja. Upravo i ja malo rascitavam o KS-u na M$oft stranicama al' necu biti nista pametniji u odgovorima i da sve ono naucim napamet. Ipak je to teren za softver i hardver kreatore a na meni je da sto vise audio softvera dobavim i isprobam. Natenane, koristeci sve opcije i varijante. Malocas pomenuh davno korisceni pa zaboravljeni CMP2 pa se vratih da iscitam i podsetim da je i on ASIO baziran SW. E zato se setih mocnog a besplatnog ruskog softvera pod imenom AlbumPlayer, aktuelna verzija 2.110 koji podrzava sva tri moda pa se rezultati (zvucni) mogu direktno porediti . Naravno ako i hardverska strana podrzava sve tri opcije. Koliko vidim zadnju verziju treba instalirati / pokretati pod admin pravima a ako to nije moguce, vratiti se na verziju 2.105 (procitati readme pdf). Nisam cuo AlbumPlayer. Zvuci interesanto, probacu, sto da ne? Kad kazete da je mocan softver, na sta tacno mislite? Tj u cemu se ogleda njegova moc? Mislim ako ste probali. Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 9, 2018 Report Share Posted January 9, 2018 @garson Po svemu sto je ugradjeno u njega a ne vidi se ispod skromnog osnovnog prozora. Vrlo lako nadsvirava foobar. Ima jos predloga sto se tice besplatnog audio softvera. Medju njima je i Bughead (Infinity Blade HQ) koji nazalost u zadnjim verzijama zahteva izuzetno jake masine (PC) nove generacije sa 32GB RAM, CPU sa integrisanom podrskom AVX2.0 i SSE4.1 (i5 i i7 Sandy Bridge, Ivy, Haswell, Skylake, KabyLake, CofeeLake ...) Od komercijalnih: XXHighEnd, JPlay, HQPlayer Quote Link to comment Share on other sites More sharing options...
garson Posted January 9, 2018 Report Share Posted January 9, 2018 Hvala za predloge, za Bughead sam cuo i odustao kad sam video koliko je zahtevan. Foobar mi i nije neka referenca, koristim XMPlay godinama unazad (veoma lagan, ali i mocan plejer). AlbumPlayer deluje kao plejer slicne filozofije. Quote Link to comment Share on other sites More sharing options...
Zexx Posted January 9, 2018 Report Share Posted January 9, 2018 13 minuta ranije, DJ.NIK said: @garson Po svemu sto je ugradjeno u njega a ne vidi se ispod skromnog osnovnog prozora. Vrlo lako nadsvirava foobar. Ima jos predloga sto se tice besplatnog audio softvera. Medju njima je i Bughead (Infinity Blade HQ) koji nazalost u zadnjim verzijama zahteva izuzetno jake masine (PC) nove generacije sa 32GB RAM, CPU sa integrisanom podrskom AVX2.0 i SSE4.1 (i5 i i7 Sandy Bridge, Ivy, Haswell, Skylake, KabyLake, CofeeLake ...) Od komercijalnih: XXHighEnd, JPlay, HQPlayer Barem tri plejera od ovih koje si pomenuo žestoko koriste EQ i DSP, pa zato i zahtevaju takvo ludilo od računarske konfiguracije, što je potpuni nonsens, s obzirom da je za bit-perfect plejbek bilo kog PCM ili DSD fajla sasvim dovoljan i jedan "bedni" ARM procesor na 1200 MHz kakav se recimo može naći u RPI 3... Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 9, 2018 Report Share Posted January 9, 2018 Zexx, znam da dobro poznajes baze podataka ali nisam znao da si i (audio) programer Nema tu nikakvog EQ ni DSP. A dodatnog procesiranja ima, to je tacno. Procesiranje u tom smislu da se recimo obicni CD zapis (HiRes se retko i koristi jer je vecina prevara, ograda od MQA) apsempluje 16 puta i prosiruje na zapis od 32 bita (dodaju nule, nista posebno). Ovakav fajl sada ima osnovu da se primeni digitalna atenuacija bez gubitka i najmanjeg detalja informacije sto nije slucaj kod uoobicajene, digitalne atenuacije. Zatim se na ovako visoko semplovani uzorak primenjuje filtracija posebno kreiranim algoritmom ali daleko vise od Nyqvist-Shanon zahteva (44.1K ili pola od toga za jedan kanal) na visokih 705.6K. Po zelji se dalje radi i normalizacija nivoa reprodukcije pa nema potrebe za skakanjem dugme glasnoce ili na daljinski upravljac kod sledece numere, pogotovu ako je plej lista sacinjena od vise albuma razlicite produkcije i nivoa zapisa signala. Ovako obradjen signal se slobodno salje D/A chip-u (ovima) koji na svom izlazu nema nikakav filter, inace obavezan i onaj koji kvari svu zabavu - nema dobrog filtera. Ovakvo procesiranje nije u stanju da uradi ni jedan fizicki 'chip' vec jak CPU. Koristi se CPU sa sto vise jezgara (+ hipertreding) jer softver korisiti i multi-treding, svaki audio zapis se obradjuje u posebnom jezgru (tredu) procesora. Da nije toga, pri kreiranju liste od 30-40-50 pesama bi se Bogami nacekalo dok muzika krene. Sam PC je usporen do krajnjih granica i radi na nekih 340-360MHz (!) da bi se maksimalno smanjile smetnje izazvane velikim brojem elektronskih komponenti na maticnoj ploci, pre svega raznih stabilizatora napona koji su i dalje neophodni, CPU i ostali IC-i ne rade na visim naponima od 1,2V do 1,5V ali sa ogromnim strujama. Prica tu nije gotova jer se npr i sam audio plejer pokrece sa virtuelnih diskova u memoriji a u poslednje vreme se i kompletan OS podize u RAM. Tvrdi disk vise nije potreban do trenutka kada zelimo da neka setovanja trajno snimimo ili pozelimo da ugasimo racunar, do sledece audio sesije. Nesto sam verovatno i preskocio ali u osnovnim crtama, ovo je nacin kako se dolazi do vrhunske reprodukcije, gde gramofon nema sta da trazi, sem onog lepog osecaja drzanja vinila u ruci Quote Link to comment Share on other sites More sharing options...
Zexx Posted January 9, 2018 Report Share Posted January 9, 2018 22 minuta ranije, DJ.NIK said: Zexx, znam da dobro poznajes baze podataka ali nisam znao da si i (audio) programer Nema tu nikakvog EQ ni DSP. A dodatnog procesiranja ima, to je tacno. Procesiranje u tom smislu da se recimo obicni CD zapis (HiRes se retko i koristi jer je vecina prevara, ograda od MQA) apsempluje 16 puta i prosiruje na zapis od 32 bita (dodaju nule, nista posebno). Ovakav fajl sada ima osnovu da se primeni digitalna atenuacija bez gubitka i najmanjeg detalja informacije sto nije slucaj kod uoobicajene, digitalne atenuacije. Zatim se na ovako visoko semplovani uzorak primenjuje filtracija posebno kreiranim algoritmom ali daleko vise od Nyqvist-Shanon zahteva (44.1K ili pola od toga za jedan kanal) na visokih 705.6K. Po zelji se dalje radi i normalizacija nivoa reprodukcije pa nema potrebe za skakanjem dugme glasnoce ili na daljinski upravljac kod sledece numere, pogotovu ako je plej lista sacinjena od vise albuma razlicite produkcije i nivoa zapisa signala. Ovako obradjen signal se slobodno salje D/A chip-u (ovima) koji na svom izlazu nema nikakav filter, inace obavezan i onaj koji kvari svu zabavu - nema dobrog filtera. Ovakvo procesiranje nije u stanju da uradi ni jedan fizicki 'chip' vec jak CPU. Koristi se CPU sa sto vise jezgara (+ hipertreding) jer softver korisiti i multi-treding, svaki audio zapis se obradjuje u posebnom jezgru (tredu) procesora. Da nije toga, pri kreiranju liste od 30-40-50 pesama bi se Bogami nacekalo dok muzika krene. Sam PC je usporen do krajnjih granica i radi na nekih 340-360MHz (!) da bi se maksimalno smanjile smetnje izazvane velikim brojem elektronskih komponenti na maticnoj ploci, pre svega raznih stabilizatora napona koji su i dalje neophodni, CPU i ostali IC-i ne rade na visim naponima od 1,2V do 1,5V ali sa ogromnim strujama. Prica tu nije gotova jer se npr i sam audio plejer pokrece sa virtuelnih diskova u memoriji a u poslednje vreme se i kompletan OS podize u RAM. Tvrdi disk vise nije potreban do trenutka kada zelimo da neka setovanja trajno snimimo ili pozelimo da ugasimo racunar, do sledece audio sesije. Nesto sam verovatno i preskocio ali u osnovnim crtama, ovo je nacin kako se dolazi do vrhunske reprodukcije, gde gramofon nema sta da trazi, sem onog lepog osecaja drzanja vinila u ruci Slatko me nasmeja... Quote Link to comment Share on other sites More sharing options...
dj.nik Posted January 9, 2018 Report Share Posted January 9, 2018 Smeje se i gomila ljudi sirom sveta ali sa pravim osmehom, osmehom iskrenog zadovoljstva ovakvom 'digitalijom' Quote Link to comment Share on other sites More sharing options...
Father Posted January 9, 2018 Report Share Posted January 9, 2018 @DJ.NIK A ja mislio da je protraktor kamen mudrosti u HiFi-ju. Sad znam da ništa ne znam. Pa kakav džepni tranzistor ja zapravo slušam kući? Gde su mi bile uši svo ovo vreme, ??? Ja zapravo ni ne znam šta je prirodna reprodukcija. Sve vreme se tešim i pravdam sopstveni sistem kako radi nadrealno transparentno, jer je današnja produkcija nadrkala snimke do nadrealnosti, a ustvari ja nisam čuo ni pola od toga .... Najiskrenije izvini, nisam hteo da omalovažavam što si rekao, samo počinjem da se pitam ... Čemu sve to!? Na kraju skromno ću prihvatiti, sada kada sam ovo pročitao i kritiku na svoj račun, da sam debelo neiskusan i gluv kada može običan Microsoft-ov USB Class 2.0 driver da mi otvori ceo novi univerzum zvuka. EDIT: Ne rekoh da se meni plače. Quote Link to comment Share on other sites More sharing options...
Zexx Posted January 9, 2018 Report Share Posted January 9, 2018 1 minut ranije, DJ.NIK said: Smeje se i gomila ljudi sirom sveta ali sa pravim osmehom, osmehom iskrenog zadovoljstva ovakvom 'digitalijom' Smejem se pre svega što kažeš "nema nikakvog DSP", a već u sledećoj rečenici "ima dodatnog procesiranja", kao i što hvališ MQA, koji radije ne bih komentarisao... A to da ne postoji čip koji je moguće implementirati u DAC, a da radi takav ili sličan posao, naravno nije tačno, i to ne da radi takav, nego mnogo kompleksniji i zahtevniji posao. Potraži malo informacije o XILINX Spartan čipu primenjenom u Chord uređajima i tričavih milion+ linija koda koje taj čip izvršava, i sve to u kućištu upola manjem od jednog standardnog napajanja za PC... Quote Link to comment Share on other sites More sharing options...
Father Posted January 9, 2018 Report Share Posted January 9, 2018 U stvari, odoh u osamu na nedelju dana da se udavim u alkoholu i tugi svoje zablude i sejanju dezinforamcija po forumu koju sam tako poetično i nadahnuto u dubokoj zabludi iznosio pred cenjeno članstvo. Možda se i samokaznim nekim prekorom u cilju pokajanja. Quote Link to comment Share on other sites More sharing options...
