markodl Posted June 8, 2014 Report Share Posted June 8, 2014 Jel moze neko da proceni realnu vrednost ovog gramofona: https://www.kupujemprodajem.com/Thorens-TD320-13041924-oglas.htm?filter_id=132 Moze i neki utisak, mada mislim da se, generalno, radi o jako dobrom modelu. Vec neko vreme listam gramofone na kp, mada bez nekog odredjenog cilja (ne znam da li hocu danas da kupim gramofon od 300 ili za godinu dana gramofon od 1300 eura)... Ovaj mi je, nekako, pao za oko - kao nov, odrzavan... Sta vi mislite ? Quote Link to comment Share on other sites More sharing options...
zbrujic Posted June 8, 2014 Report Share Posted June 8, 2014 Je li to zaista TP16 mkII? Na 320 bih oÄekivao mkIV, a i liÄi mi na mkIV. Quote Link to comment Share on other sites More sharing options...
markodl Posted June 8, 2014 Author Report Share Posted June 8, 2014 Lici na ono sto gugl pokazuje za tp 16 mkII. Sem sto je skroz crna. Inace, ja ne znam - zato sam se i obratio ovde. Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted June 9, 2014 Report Share Posted June 9, 2014 To bi trebala biti upravo TP-16MKIV - barem po slikama T320ce i rucke koji se mogu naci po Internetu, tj. nije u pitanju neka aftermarket (ili "egzoticna") kombinacija. Realna cena, cini mi se u rasponu od 250-300e? Pozdrav! Quote Link to comment Share on other sites More sharing options...
Infidel Posted June 9, 2014 Report Share Posted June 9, 2014 Realna cena, cini mi se u rasponu od 250-300e? Ne volim TP16, ali i vdh kabl vredi neÅ¡to. Nekako mi se Äini da bi dobra cena bila bliža 250€. Obzirom na stanje na tržiÅ¡tu, pretpostavljam da će prodavac tražiti (solidno) preko 300? Quote Link to comment Share on other sites More sharing options...
zbrujic Posted June 9, 2014 Report Share Posted June 9, 2014 Verujem da je i 350e prihvatljiva cena. Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted June 9, 2014 Report Share Posted June 9, 2014 Ne volim TP16, ali i vdh kabl vredi neÅ¡to. Nekako mi se Äini da bi dobra cena bila bliža 250€. Obzirom na stanje na tržiÅ¡tu, pretpostavljam da će prodavac tražiti (solidno) preko 300? To je i razlog zasto sam naveo raspon - gornja vrednost je zbog (eventualnog) prilagodjavanja trzistu... Pozdrav! Quote Link to comment Share on other sites More sharing options...
markodl Posted June 9, 2014 Author Report Share Posted June 9, 2014 Hvala svima na odgovorima! Upravo zbog ovoga sa ruckom sam i postavio pitanje - ja ne bih imao pojma da je to rucka koja mozda nije to sto pise u oglasu. Mozete li neko da me uputi kako da proverim koja je rucka (dok gledam gramofon) - recimo, da li bi nesto trebalo da pise na rucki ukoliko jeste tp16 mkii (ili tp 16 mkiv)? I ja sam razmisljao da dam nekih 270-280, ali mi je bilo potrebno jos necije misljenje.. PS Jos jedno pitanje - sta mislite - da li ovaj gramofon ne bi bio "ispod" ostatka sistema (tj. znatno losiji) - ostatak sistema je UR Unico Secondo i PMC TB2i. Imam i Tascamov cd 601 (koji sam sredio i fino svira), ali mislim da je on za ovo pitanje irelevantan. Quote Link to comment Share on other sites More sharing options...
markodl Posted June 10, 2014 Author Report Share Posted June 10, 2014 Imam jos jedno, po malo debilno pitanje: Kako da znam da li Unison ima phono stage ugradjen? Posto sam ga kupio polovnog pojma nemam, a internet kaze da ima opciju phono stage-a. Probao sam da "ubodem" cd u phono ulaze i on svira, ali krci. Da li to znaci da phono stage postoji ? Quote Link to comment Share on other sites More sharing options...
Kuršum Posted June 10, 2014 Report Share Posted June 10, 2014 Pa ako piÅ¡e da je phono in, onda ima. Koji te Ä‘avo terao da ubadaÅ¡ cd u taj ulaz, naravno da krÄi, phono ulaz je 2.5mV a ulaz za cd 500mV recimo, dakle ovaj za phono je 200x osetljiviji. OćeÅ¡ da ga spržiÅ¡? Quote Link to comment Share on other sites More sharing options...
markodl Posted June 10, 2014 Author Report Share Posted June 10, 2014 Ups.. necu vise da eksperimentisem! Pise da svaki Secondo ima phono ulaz, ali da je plocica opciona. Quote Link to comment Share on other sites More sharing options...
Kuršum Posted June 10, 2014 Report Share Posted June 10, 2014 Pa sad gledam specifikaciju tog pojaÄala, piÅ¡e da ima 5 nebalansiranih ulaza (phono opciono) i jedan balansirani. E sad Å¡ta znaÄi to opciono, pojma nemam. Da li ti neki od tih 5 treba da uÄiniÅ¡ da bude phono nekim podeÅ¡avanjem ili se to prilikom kupovine traži kao opcija. Ajde uslikaj ga pozadi, pa stavi fotku. Edit: Evo fotke, ima brate phono ulaz jasno obeležen, tako da ne znam Å¡ta znaÄi to opciono. To bi trebalo da bude to, ima i uzemljenje pored. Quote Link to comment Share on other sites More sharing options...
markodl Posted June 10, 2014 Author Report Share Posted June 10, 2014 Kursume, hvala! To je to! I ima jasno obelezen phono ulaz sa sve uzemljenjem, to i ja vidim na mom! A bila bi fora da uzmem gram za sve pare sto imam i donesem ga kuci i shvatim da nemam phono sekciju. Evo ga citat koji me buni (sa sl. linka): http://www.analogueseduction.net/unison-research/unison-research-unico-secondo-hybrid-amplifier.html "A MM/MC phono stage board is optional". 'Bem li ga, videcemo. Quote Link to comment Share on other sites More sharing options...
sondek Posted June 10, 2014 Report Share Posted June 10, 2014 Ako si zveknuo cd u phono ulaz možda ga sad viÅ¡e nemaÅ¡,a imao si ga.ukinuo opciju sam.možes i visokotonce da ukines tako kao opciju.postajemo uzbudljiv forum,gura se cd u snagas,cd u phono sekciju,sa da joÅ¡ neko ne uÅ¡teka zvuÄnike u struju.Biće "curiosity kill the cat." Quote Link to comment Share on other sites More sharing options...
markodl Posted June 10, 2014 Author Report Share Posted June 10, 2014 Ako si zveknuo cd u phono ulaz možda ga sad viÅ¡e nemaÅ¡,a imao si ga.ukinuo opciju sam.možes i visokotonce da ukines tako kao opciju.postajemo uzbudljiv forum,gura se cd u snagas,cd u phono sekciju,sa da joÅ¡ neko ne uÅ¡teka zvuÄnike u struju.Biće "curiosity kill the cat." Kuku... To je sto je! Sa zvucnicima nije nista (visokotoncima). Takodje, to krcanje uopste nije bilo jako, a i pustio sam neki disk koji je slabije snimam (neki Claptonov cudan album) - tako da se nadam da nisam nista zeznuo. A ako jesam... prezivecu, sta da radim... Videcemo kad stigne jednom gramofon! Uzdam se u to da nista nije zasmrdelo! Quote Link to comment Share on other sites More sharing options...
markodl Posted June 10, 2014 Author Report Share Posted June 10, 2014 PS - ako taj signal stvarno jeste 200 puta jaci, zar onda nije trebalo da mi zvucnici "eksplodiraju" (mislim da se cuje ultra-jako), a ne da se jedva cuje? Ili je jednostavno bilo skroz smanjeno, ne secma se... Quote Link to comment Share on other sites More sharing options...
Kuršum Posted June 10, 2014 Report Share Posted June 10, 2014 Nemoj da izvodiÅ¡ te vratolomije viÅ¡e, skupa je to igraÄka. NaÄ‘i neki gramofon, pa probaj. Verovatno ds je sve ok. Ako nemaÅ¡, pojaÄalo pod miÅ¡ku, pa doÄ‘i kod mene, da probamo (ako si iz Bg). Quote Link to comment Share on other sites More sharing options...
Kuršum Posted June 10, 2014 Report Share Posted June 10, 2014 PS - ako taj signal stvarno jeste 200 puta jaci, zar onda nije trebalo da mi zvucnici "eksplodiraju" (mislim da se cuje ultra-jako), a ne da se jedva cuje? Ili je jednostavno bilo skroz smanjeno, ne secma se... Gledao sam specifikaciju tvog pojaÄala, ulazi su 375mV, ali niÅ¡ta ne piÅ¡e za phono ulaz. On je za mm zvuÄnice obiÄno 2,5. - 5mV, za mc joÅ¡ osetljiviji. Pa ti sad izraÄunaj koliko je to osetljivije. Quote Link to comment Share on other sites More sharing options...
markodl Posted June 10, 2014 Author Report Share Posted June 10, 2014 Ma ne diram nista, samo se sada malo sekiram. ProstaÄki reÄeno - ****. Quote Link to comment Share on other sites More sharing options...
Kuršum Posted June 10, 2014 Report Share Posted June 10, 2014 Da ne držimo druge u neizvesnosti, a pokretaÄ teme i ja smo razmenili par pp, pomenuto pojaÄalo ima opciju phono-a, samo ako se poruÄi takvo. I na onom koje nema phono stage, postoji ulaz phono. E sad na Å¡ta je on vezan, boga pitaj. Quote Link to comment Share on other sites More sharing options...
sondek Posted June 10, 2014 Report Share Posted June 10, 2014 PiÅ¡e lepo da je phono ploÄica opciona,kad je nemaÅ¡ to je verovatno joÅ¡ jedan line ulaz.Tako je i kod mene sliÄno u preampu ako stavis straight true board ili jumpere umesto phono ploÄica,kod mene su svi ulazi dual mono moduli.Verovatno imaÅ¡ i posebno mm ili mc board. Quote Link to comment Share on other sites More sharing options...
markodl Posted June 10, 2014 Author Report Share Posted June 10, 2014 Odrsrafio sam poklopac pojacala (citaj-krov) i - postoji phono board u njemu. Jumperi su za mm i mc, po 2 za svaki kanal! Misterija resena! Quote Link to comment Share on other sites More sharing options...
Kuršum Posted June 10, 2014 Report Share Posted June 10, 2014 E sad se samo nadamo da ga nisi spržio. Quote Link to comment Share on other sites More sharing options...
markodl Posted June 19, 2014 Author Report Share Posted June 19, 2014 I zvaniÄno - gramofon nije kupljen. Bio sam da ga posluÅ¡am i razoÄarao se - manje u to Å¡to nogice ne idu uz njega, a viÅ¡e u sam zvuk i to sa dosta skupljom glavom od ove meni ponuÄ‘ene (mada u tuÄ‘em sistemu, ali Å¡ta je - tu je). Jednostavno sam oÄekivao viÅ¡e na prvu loptu. Umesto gramofona - Unison će na poklon dobiti fta strujni kabal (koji je kod mene na probi i koji svira dooostaa bolje od fabriÄkog unisonovg kabla), dok će Tascam cd 601 verovatno dobiti na poklon FTA Route 66 interkonekt (to joÅ¡ nisam prelomio, ali sluÅ¡am ga i blizu sam). Ovim putem se zahvaljujem i prodavcu gramofona koji je bio jako korektan, a takoÄ‘e i Zoranu iz FTA od koga sam dobio kablove na probu! Gramofon će doći na red, ali kada budem bio spreman da u isti uložim ozbiljnije novce! Za sada sam i ovime Å¡to imam "omaÄ‘ijan" (pogotovu sa novim kablovima)! Quote Link to comment Share on other sites More sharing options...
