skomirendalica Posted June 1, 2014 Report Share Posted June 1, 2014 Pozdrav. Ima jedan majstor audiofil mnogo dobar poznavalac koji mi je predlozio da u moje mission m72 zamijenimo kondenzatore i rekao mi je da ce se dobiti sira zvucna slika i generalno poboljsanje zvuka. Cijenu ne znam jer ga jos nismo otvarali pa mi nije mogao reci. Zanimaju me misljenja iskusnih ljudi , da li se i koliko dobija time , da li se moze dobiti na jacini bassa i je li to bas samo neka nijansa razlike i do koliko para bi mi se isplatilo to da radim ? Hvala puno unaprijed Quote Link to comment Share on other sites More sharing options...
impuls Posted June 1, 2014 Report Share Posted June 1, 2014 Jacinu basa ce poboljsati samo zavojnica bez ferita sa dovoljno debelom zicom. Kondovi u skretnici uticu na visoki Quote Link to comment Share on other sites More sharing options...
skomirendalica Posted June 2, 2014 Author Report Share Posted June 2, 2014 Hvala . evo izgleda da si jedini kome nije muka da napise neki post Quote Link to comment Share on other sites More sharing options...
Kaiser Posted June 2, 2014 Report Share Posted June 2, 2014 Ima samo dva kondica po skretnicu pa ne skodi probati. Jeftin je to tvik. Probajte Visaton MKP kao zamena za zuti NPE i Elna Silmic II za plavi Elytone elektorlit. Quote Link to comment Share on other sites More sharing options...
空也 Posted June 3, 2014 Report Share Posted June 3, 2014 ... i Elna Silmic II za plavi Elytone elektorlit. Za skretnicu ti je potreban bipolarni kondenzator, sto Elna Silmic nije.http://www.hificollective.co.uk/pdf/elna_rfs_data.pdf Jedino da spajas dva komada, bese "+" na "+"? Ako hoces bas Elnu, imaju RBD kondove namenjene za skretnice: http://www.hificollective.co.uk/pdf/elna_rbd_data.pdfhttp://www.hificollective.co.uk/components/elna_capacitors.htmlhttp://www.madisoundspeakerstore.com/restore-vintage-speakers Quote Link to comment Share on other sites More sharing options...
Kaiser Posted June 3, 2014 Report Share Posted June 3, 2014 Ah steta, nisam znao da nema Silmic bipolarac. Quote Link to comment Share on other sites More sharing options...
zek Posted June 3, 2014 Report Share Posted June 3, 2014 Jedino da spajas dva komada, bese "+" na "+"? ÄŒini mi se da se spaja "-" na "-" od kondova. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 3, 2014 Report Share Posted June 3, 2014 ÄŒini mi se da se spaja "-" na "-" od kondova. По мени нема везе како Ñпојиш + на + или - на -. Ршто га не заменити блоком? Quote Link to comment Share on other sites More sharing options...
空也 Posted June 3, 2014 Report Share Posted June 3, 2014 ÄŒini mi se da se spaja "-" na "-" od kondova. Sasvim je moguce, nikad nisam imao potrebe za tom vrstom budzenja, samo sam negde davno cuo da se moze i tako nesto uraditi.EDIT:Sada vidim na diaydio.com da neki kazu da je svejedno, da moze i + na +, kao i - na - ...samo nas zbunjuju! you can indeed make a bipolar electrolytic capacitor from two normal ones with the double capacitance connected in anti-series, + to + or - to -. The total capacitance is given by the equation for series connections of capacitors, Ctot=C1*C2/(C1+C2). The voltage rating of the electrolytic capacitors should be greater than or equal to the peak to peak signal voltage, which for a sine wave is 2*sqrt(2) times the RMS voltage.There are several disadvantages compared to a proper bipolar capacitor intended for cross-over networks. To name a few, firstly, the effective series resistance could be somewhat higher, especially for low capacitance values. Secondly, the distortion generated by a normal electrolytic capacitor is higher than that generated by a bipolar capacitor. Thirdly, normal electrolytics are usually less accurate. Quote Link to comment Share on other sites More sharing options...
Kaiser Posted June 3, 2014 Report Share Posted June 3, 2014 По мени нема везе како Ñпојиш + на + или - на -. Ршто га не заменити блоком? Da se ne kvari folklorna avtenticnost zvuka. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted June 3, 2014 Report Share Posted June 3, 2014 Е то ће да ÑпаÑи Ñтвар, убило Ñе Quote Link to comment Share on other sites More sharing options...
Kaiser Posted June 3, 2014 Report Share Posted June 3, 2014 Quote Link to comment Share on other sites More sharing options...
jager Posted June 3, 2014 Report Share Posted June 3, 2014 Ja sam to radio na moje zvuÄne kutije i zamjenio elna sa mundorf blok kondezatorima i nisam osjetio neku veliku razliku jer mi izgleda skretnica nije konstruisana kako valja , izgleda da ću morat na novo da je radim samo neznam nikoga ko bi mi to izraÄunao kako valja.. dok sam kod druga koji je poruÄio zajedno sa mnom preko ovog sajta ( http://www.hificollective.co.uk/components/m_cap.html ) zaista Äuo nevjerovatnu razliku u detaljima i Å¡irini zvuÄne slike , u pitanju su bili mission al zaboravih model , kod trećeg drugara koji ima model v 20 od visatona takoodje zamjenjeni kondezatori sa mudorf ali skuplja varijanta koja ga je izaÅ¡la cirka oko 400 eura zvuk je nevjerovatan, neÅ¡to bolje nikad nisam Äuo .Kutije reaguju na svaki promjenjeni kabel bilo zvuÄni ili interkonekt , zaista nisam vjerovao da su razlike toliko Äujne. treba provati svakako. Quote Link to comment Share on other sites More sharing options...
trotter Posted June 3, 2014 Report Share Posted June 3, 2014 ...kod trećeg drugara koji ima model v 20 od visatona takoodje zamjenjeni kondezatori sa mudorf ali skuplja varijanta koja ga je izaÅ¡la cirka oko 400 eura zvuk je nevjerovatan, neÅ¡to bolje nikad nisam Äuo .Kutije reaguju na svaki promjenjeni kabel bilo zvuÄni ili interkonekt , zaista nisam vjerovao da su razlike toliko Äujne. treba provati svakako. SvaÅ¡ta. Quote Link to comment Share on other sites More sharing options...
jager Posted June 3, 2014 Report Share Posted June 3, 2014 SvaÅ¡ta. BaÅ¡ svaÅ¡ta Äovek je extremista i jednostavno voli i traži dobar zvuk i uspio je u tome ...naravno ulog nije mali . i neće da se zaustavi na tome jer za b sistem stiže iz amerike pioneer hpm 100 . Barem ću se nasluÅ¡at pravog zvuka ako niÅ¡ta drugo Quote Link to comment Share on other sites More sharing options...
trotter Posted June 3, 2014 Report Share Posted June 3, 2014 Hpm 100, veri najs Opet, kondenzatori od 400 evra i savet da treba probati svakako... Ne slazem se. Valjda ne treba da objasnjavam zasto. Takodje, ako ti zvucnici reaguju na svaku promenu kablova to je, po meni, loša stvar i nije baš za pohvalu. Quote Link to comment Share on other sites More sharing options...
jager Posted June 3, 2014 Report Share Posted June 3, 2014 Hpm 100, veri najs Opet, kondenzatori od 400 evra i savet da treba probati svakako... Ne slazem se. Valjda ne treba da objasnjavam zasto. Takodje, ako ti zvucnici reaguju na svaku promenu kablova to je, po meni, loša stvar i nije baš za pohvalu. Vjerujem da na hpm 100 nema šta da se dira ... al poznavajući druga ne bih garantovao da neće bit nekih hiruških zahvata ... Quote Link to comment Share on other sites More sharing options...
jager Posted June 3, 2014 Report Share Posted June 3, 2014 OdliÄan izvor, odliÄno pojaÄalo, skupi kablovi itd itd su osnova a ovo Å¡to je uradio sa visatonom mislim da je vrhunac ... Razliku sam Äuo i na mission ali ovaj v 20 je trenutno baba roga Quote Link to comment Share on other sites More sharing options...
trotter Posted June 3, 2014 Report Share Posted June 3, 2014 Sto bi reko moj komsija "nije silikon za lepu sisu". Promena kondenzatora na starim kutijama ima smisla u pravcu zamene starih, istrošenih elemenata novim. Svako preterivanje u tom smislu nema nikakvog smisla imajuci u vidu starost najbitnijih komponenata u kutiji a to su drajveri. To vazi i za silovanje sa kablovima. Nece taj pioneer bolje zvucati ni ako mu se stavi vertere od xxx funti, to je istorija hifija i ako ga neko kupuje, kupuje ga zbog toga a ne da bi izvlacio nesto sto ni oni koji su ga konstruisali nisu imali na umu. Quote Link to comment Share on other sites More sharing options...
jager Posted June 3, 2014 Report Share Posted June 3, 2014 Kad budu stigli znat će se nešto više o njima ,ovako naslijepo i o tudjem sistemu i previše a o zamjeni kondezatora moj glas je za Quote Link to comment Share on other sites More sharing options...
jager Posted June 3, 2014 Report Share Posted June 3, 2014 Ja sam to radio na moje zvuÄne kutije i zamjenio elna sa mundorf blok kondezatorima i nisam osjetio neku veliku razliku jer mi izgleda skretnica nije konstruisana kako valja , izgleda da ću morat na novo da je radim samo neznam nikoga ko bi mi to izraÄunao kako valja.. dok sam kod druga koji je poruÄio zajedno sa mnom preko ovog sajta ( http://www.hificollective.co.uk/components/m_cap.html ) zaista Äuo nevjerovatnu razliku u detaljima i Å¡irini zvuÄne slike , u pitanju su bili mission al zaboravih model , kod trećeg drugara koji ima model v 20 od visatona takoodje zamjenjeni kondezatori sa mudorf ali skuplja varijanta koja ga je izaÅ¡la cirka oko 400 eura zvuk je nevjerovatan, neÅ¡to bolje nikad nisam Äuo .Kutije reaguju na svaki promjenjeni kabel bilo zvuÄni ili interkonekt , zaista nisam vjerovao da su razlike toliko Äujne. treba provati svakako. Da ispravim greÅ¡ku zamjenjeni su elco glatt visaton sa mundorfom ... Quote Link to comment Share on other sites More sharing options...
trotter Posted June 3, 2014 Report Share Posted June 3, 2014 Kakogod... Ti missioni iz prvog posta teme nisu toliko stari da je neophodna zamena kondenzatora. Ne verujem da je isplativo bilo kakvo ulaganje u tom smislu, pogotovo sto ne znamo ostatak sistema. Ako je ostatak sistema na nivou tih zvucnika ja bih to zaobisao i novac sklonio u stranu za upgrade sistema u drugom pravcu. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 3, 2014 Report Share Posted June 3, 2014 http://eu.mouser.com/Passive-Components/Aluminum-Electrolytic-Capacitors/_/N-75hqt?Keyword=nichicon+db&FS=True http://eu.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw?Keyword=nichicon+gb&FS=True Quote Link to comment Share on other sites More sharing options...
sondek Posted June 3, 2014 Report Share Posted June 3, 2014 Ja sam veÄeras saznao da mogu po porudzbini od naima dobiti nove skretnice za moje zvucnike(sbl) Å¡to je sjajna stvar kad imaÅ¡ zvuÄnike koji imaju 20g.Skretnice su inace spolja usrafljene tako da se zvuÄnici ne otvaraju.To će biti jedan od narednih servisa u sistemu na koje treba da si spreman ako si vintage fan.InaÄe postoji odredjena struja fanova koja koristi pasivne skretnice od narednog modela Sl koji ima skuplje kondove i to opisuju kao znatan apgrejd.Bilo je zanimljivo pratiti u nekoliko nedelja faze od razoÄarenja u odnosu na staru skretnicu pa do konaÄnog prosviravanja usled burn in perioda na jednom stranom forumu.Ta ab poredjenja u inaÄe vrlo jednostavna jer se skretnica jednostavno montira tj. PrikljuÄuje obiÄnim speaker bananicama,posao od 1min.jednostavno za igranje,ujedno tako se i zvuÄnik prebacuje i u aktivu i multi amping. Quote Link to comment Share on other sites More sharing options...
skomirendalica Posted June 3, 2014 Author Report Share Posted June 3, 2014 Ostatak sistema Harman Kardon 3390 , audioquest interkonekt to lap topa , chord carnival zvucnicki kablovi. Samo nemam .. tj SAMO audio karticu za komp to moram da uzmem .. Quote Link to comment Share on other sites More sharing options...
