Aoxomoxoa Posted August 7, 2013 Report Share Posted August 7, 2013 e dimensions : W=18½ in(470 mm) x H=30 in(758 mm) x D= 13½ in(342 mm) Enclosed volume: 80 Litres Frequency response: DIN 45 500 25-20,000 Hz Weight: 80 lb (36Kg) Resonance frequency 30 Hz Sensitivity*. DIN 45 500 6 Watts Max sine wave driving power. DIN 45 500 100 Watts Music power. DIN 45 500 160 Watts Impedance: 8 Ohms Size of speakers: Woofer 12in (300mm) Mid-range 2in (50mm) dome Tweeter 2 x 1in (25mm) dome *Driving power to reach a sound level of 96dB measured at a distance of 1 metre from speaker Nisam se do sada susretao sa ovakvim prikazom osetljivosti zvucnika.Konkretno me zanima da li pojacalo od 2x8wrms moze da pokrene ove zvucnike Quote Link to comment Share on other sites More sharing options...
prophet Posted August 8, 2013 Report Share Posted August 8, 2013 Nije osetljivost jedini faktor ( u ovom sluÄaju mislim da je sigurno ispod 90db/w/m). TakoÄ‘e zavisi i sa kakvih 8w raspolažeÅ¡ i koliko glasno želiÅ¡ da sluÅ¡aÅ¡. Najbolje probaj. Quote Link to comment Share on other sites More sharing options...
Å¡ale Posted August 8, 2013 Report Share Posted August 8, 2013 Koja vekiÄina prostorije? Po tvojoj snazi i da je rastijanje do kutija oko 5 m će da zadovolji a to je u povrÅ¡ona oko 25 m2 to je neki jazz i laka svirka. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted August 8, 2013 Report Share Posted August 8, 2013 Mislim da ne, iz dva razloga: prvo, ovaj zvuÄnik ima nisku osetljivost kao većina studijskih monitora (oko 88dB); drugo, pod pretpostavkom da je pojaÄalo u pitanju cevno, treba imati u vidu da cevi ne vole iole složenija opterećenja u anodnom kolu u vidu skretnica, a ovo je trosistemski zvuÄnik. Quote Link to comment Share on other sites More sharing options...
Å¡ale Posted August 8, 2013 Report Share Posted August 8, 2013 Gledao sam na netu dati kabinet,ima samo jedan bas od 30 cm Å¡to znaÄi da i nije zahtevan za pogon treba 15-20 W pojaÄalo a nije bass refleks Å¡to će reći da je komprekiona kutija verovatno oko 86-88 db/W/m.osetljivosti. Molio bi axomoa...da upotpuni podatke veliÄina prostorije vrsta muzike koju sluÅ¡a kako bi mu dali pravi savet,ja sam pretpostavio da su podaci taÄni? P.S.Gledao sam i Infinyty SM 115 studio monitor imaju osetljivost od 100 db,Å¡to će reći da je moguće da je osetljivost Tandberga isto u redu tj taÄna pa bi moj savet mogao u praksi i da se primeni,neka dotiÄni proba da li je osetljivost velika tj 96 db? Milosav G. je ranije jednom prilikom dao krive rezonantne kar. osetljivosti kutije i odnosa sa veliÄinom basa pa bi molio ako neko zna da izbaci tu tabelu pa ćemo da to reÅ¡imo. Npr Dao je 6" bas osetljivost 90 db i frekvencija od 50 hz Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted August 8, 2013 Report Share Posted August 8, 2013 P.S.Gledao sam i Infinyty SM 115 studio monitor imaju osetljivost od 100 db,Å¡to će reći da je moguće da je osetljivost Tandberga isto u redu tj taÄna pa bi moj savet mogao u praksi i da se primeni,neka dotiÄni proba da li je osetljivost velika tj 96 db? Osetljivost je 96dB/6W/1m, Å¡to znaÄi da je negde 87-88dB/1W/1m. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted August 8, 2013 Author Report Share Posted August 8, 2013 Soba je 4x4m,rastojanje do kutija je 3m.Pojacalo je sa 300b cevima,dva monobloka po 11kg svaki.Vrlo nezahvalno za poneti(tu je jos i pre-amp).Slusa se jazz,stari rock i klasika.Ali ,ako Willi kaze da je to ta osetljivost,onda samo neka cudna sinergija moze da upari ove komponente.Znam da samo slusanje daje pravi odgovor,ali ne moze pod misku,mozda kad zahladni. Hvala svima na pomoci. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted August 10, 2013 Author Report Share Posted August 10, 2013 Citam recenziju za Tannoy Canterbury,osetljivosti 96db,i taman se obradujem kako ce se lepo uklopiti sa 300b pojacalom,kad se ispostavilo da je minimalna snaga pojacala potrebna da se pobudi zvucnik 50w,a preporucena od cak 200w i vise.Toliko o tome da se samo putem citanja karakteristika moze sklopiti sistem. Quote Link to comment Share on other sites More sharing options...
dvv Posted February 17, 2014 Report Share Posted February 17, 2014 Pa Tannoy je i stara, i jako ozbiljna kuća, sa njima nema Å¡ale. ÄŒak i za njihove obiÄno dosta efikasne kutije 50W se smatraminimumom, realnije, za punu dinamiku zvuka, treba poÅ¡tenih 100W po kanalu.Lepo te cevi sviraju, nema spora, ali su dinamiÄki straÅ¡no ograniÄene sa takvim smeÅ¡nim izlaznim snagama. To je pilo vodu kada su firme kao ltec Lansing pravile kutije koje su imale efikasnost od 108 dB/2,83V/1m, ali su zato bile i papreno skupe i pakleno velike. A tvrdio sam i tvrdim da je dinamika bar 50% ukupnog zvuka. Quote Link to comment Share on other sites More sharing options...
nkrgovic Posted February 18, 2014 Report Share Posted February 18, 2014 Dejane, zasto odgovaras na post star preko pola godine? Quote Link to comment Share on other sites More sharing options...
prophet Posted February 18, 2014 Report Share Posted February 18, 2014 ÄŒovek iÅ¡Äitava forum, polako ali temeljno Quote Link to comment Share on other sites More sharing options...
dvv Posted February 18, 2014 Report Share Posted February 18, 2014 Dejane, zasto odgovaras na post star preko pola godine? Da li je to problem? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted February 18, 2014 Report Share Posted February 18, 2014 Svaka Äast na visokom nivou posvećenosti u ispunjenju misije. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 18, 2014 Report Share Posted February 18, 2014 Svaka Äast na visokom nivou posvećenosti u ispunjenju misije. Ðије ваљда поÑлат по задатку? Quote Link to comment Share on other sites More sharing options...
