Bato - hi - fi Posted November 22, 2012 Report Share Posted November 22, 2012 još malo slika............... prelijep.....jos da nije braon.... Quote Link to comment Share on other sites More sharing options...
Bokkie Posted November 23, 2012 Report Share Posted November 23, 2012 Ja sam danas udomio Technics DV-DA10 Quote Link to comment Share on other sites More sharing options...
profesor Posted November 23, 2012 Report Share Posted November 23, 2012 Ja sam danas udomio Technics DV-DA10 Svaka cast BOKKIE. Quote Link to comment Share on other sites More sharing options...
ognjen Posted November 24, 2012 Report Share Posted November 24, 2012 Ja sam danas udomio Technics DV-DA10 DA te DA 10 dugo sluzi Quote Link to comment Share on other sites More sharing options...
Bokkie Posted November 24, 2012 Report Share Posted November 24, 2012 Hvala momci, super je DAT, jedino sto ne moze da radi kao DAC bez kasete, ali obzirom da vec imam DAC i nije strasno Quote Link to comment Share on other sites More sharing options...
Bokkie Posted November 24, 2012 Report Share Posted November 24, 2012 Eh da, samo da napomenem da ovaj DAT lepo radi sa digitalijom 24/48 kao source-om, probano i optikom i coaxom Quote Link to comment Share on other sites More sharing options...
tobra Posted November 24, 2012 Report Share Posted November 24, 2012 Eh da, samo da napomenem da ovaj DAT lepo radi sa digitalijom 24/48 kao source-om, probano i optikom i coaxom Većina DAT-a radi 24/48 ako podigneš na veće 24/88.2 ili 24/96 onda blokada. Čestitke na nabavci, uživaj u digitaliji.... Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted November 24, 2012 Report Share Posted November 24, 2012 Taj Technics DA 10 je fantastican uredjaj, imao ga par godina i radio je odlicno i pouzdano...ima tihu i brzu mehaniku...btw moj studer ima tu istu mehaniku posudjenu od Tehnisca tj Panasonica..Evo moje stare snimke dok sam ga jos imao Quote Link to comment Share on other sites More sharing options...
uzvarb Posted November 27, 2012 Report Share Posted November 27, 2012 Moj mali skromni doprinos ovoj temi...no coment https://www.youtube.com/watch?v=MEM6yqMzjRU Quote Link to comment Share on other sites More sharing options...
naum011fm Posted December 1, 2012 Report Share Posted December 1, 2012 Pre par dana nabavljena nova rezervna DAT glava, za moje dve DAT-masine Sony DTC-1000ES. Inace jako tesko dostupna, i izuzetno skupa! Oznaka glave je: Sony DOH-01A-R Quote Link to comment Share on other sites More sharing options...
steve_pan Posted December 1, 2012 Report Share Posted December 1, 2012 Pre par dana nabavljena nova rezervna DAT glava, za moje dve DAT-masine Sony DTC-1000ES. Inace jako tesko dostupna, i izuzetno skupa! Oznaka glave je: Sony DOH-01A-R naum011fm Kako i za koliko si nabavio- posto imam isti DAT - Moze na PP ! Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 6, 2012 Report Share Posted December 6, 2012 Pre par dana nabavljena nova rezervna DAT glava, za moje dve DAT-masine Sony DTC-1000ES. Inace jako tesko dostupna, i izuzetno skupa! Oznaka glave je: Sony DOH-01A-R GDE, GDE OVO moze da se nabavi...cena? Bubreg ili oba? Ima li mozda za DTC-59ES Quote Link to comment Share on other sites More sharing options...
yugaja Posted December 7, 2012 Report Share Posted December 7, 2012 Vredi probati ovde: http://proaudio-revival.weebly.com/index.html Ne znam za DTC1000ES glavu konkretno (mada je ista i na mojim Luxman-ima, mozda "poludim" pa i ja potrazim rezervnu...), ali je Sebastian jako korektan i usluzan. Meni je pomogao oko nekih tehnickih stvari i mojih neverovatnih pitanja. Ako nema glave na stanju, verovatno moze da uputi na adresu gde ima... Sve u svemu korisna adresa + sto je u komsiluku. Quote Link to comment Share on other sites More sharing options...
erich Posted December 17, 2012 Author Report Share Posted December 17, 2012 Ljudi imam jedno pitanje, znam da sony dat recorderi imaju moguÄnost provijere koliko su sati radili. E sad da li to ima i moj dat (DTC 57es) i kako doÄi do toga da ispiÅ¡e na displayu. Quote Link to comment Share on other sites More sharing options...
naum011fm Posted December 17, 2012 Report Share Posted December 17, 2012 Ljudi imam jedno pitanje, znam da sony dat recorderi imaju moguÄnost provijere koliko su sati radili. E sad da li to ima i moj dat (DTC 57es) i kako doÄi do toga da ispiÅ¡e na displayu. Pozdrav, Koliko ja znam DTC-57-cs, nema tu opciju! Nedavno sam se raspitivao za moj Sony DTC-77ES, ali nazalost ni on nema tu opciju. Mada, sam dobio podatak od Gox.co sa foruma, da je tako nesto ipak moguce dobiti za DTC-77ES, ali je poprilicno komplikovano, ali sam odustao od te opcije. Tu opciju imaju samo Profi-Sony DAT modeli, kao sto su PCM-2700, PCM-7030, PCM-7040 itd. Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted December 17, 2012 Report Share Posted December 17, 2012 svi profesionalni uredjaji imaju mogucnost provjere....ako ti standardni imaju, onda pise u servisnom uputstvu. Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted December 17, 2012 Report Share Posted December 17, 2012 probajte ovo ako imate skriveni gumb http://www.silentway.com/recording-tricks-sony-dtc-700-dat-recorder Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 17, 2012 Report Share Posted December 17, 2012 probajte ovo ako imate skriveni gumb http://www.silentway...00-dat-recorder Tako je ovom metodom se iz svih sony kucnih dat masina iscitava vreme rada glave, kao i error rate po glavama, broj otvaranja i zatvaranja vrata. svaka funkcija ima sifru. Medjutim treba paziti jer se na ovaj nacin mogu menjati i neki parametri, pa ne treba napamet lupati sifre nego samo one proverene. Quote Link to comment Share on other sites More sharing options...
erich Posted December 17, 2012 Author Report Share Posted December 17, 2012 Hvala momci na pomoÄi, sutra Äu to isprobati (valjda neÄu pasti u nesvjest) Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted December 17, 2012 Report Share Posted December 17, 2012 Hvala momci na pomoÄi, sutra Äu to isprobati (valjda neÄu pasti u nesvjest) hehehe udomit cu ga ja inace sony ima osjetljive glave i prenjeznu mehaniku, kad radi-radi kad pocne zezati, zeza do smrti Quote Link to comment Share on other sites More sharing options...
erich Posted December 18, 2012 Author Report Share Posted December 18, 2012 evo prva stvar koju am jutros uradio (osim Å¡to sam gospoÄ‘u odvezo na posao i dijete u vrtić) sjebo sam si daljinski od dat-a. Da je barem bilo korisno, ali nije............daljinc ima pun kofer skrivenih dugmiÄa ali niti jedan ne reagira..................možda i bolje da ne znam koliko je radio. evo i slika Quote Link to comment Share on other sites More sharing options...
steve_pan Posted December 18, 2012 Report Share Posted December 18, 2012 sjebo sam si daljinski od dat-a. erich, objasni kako si to uspeo pa da ti nekako pomognemo. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 18, 2012 Report Share Posted December 18, 2012 erich, objasni kako si to uspeo pa da ti nekako pomognemo. Вероватно је поломио плаÑтичне копче од поклопца и данцета оклопа даљинÑког. Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted December 18, 2012 Report Share Posted December 18, 2012 bile baterije spojene dok si probao? probao svaki skriveni mozda sa kombinacijom da ga drzis i upisujes sifru? ako procitas na stranici vidjet ces da su ljudima radile razlicite kombinacije...sifra pa skriveni gumb etc. Quote Link to comment Share on other sites More sharing options...
erich Posted December 18, 2012 Author Report Share Posted December 18, 2012 pod "s Вероватно је поломио плаÑтичне копче од поклопца и данцета оклопа даљинÑког. da toÄno tako ston, ma ko ga ****...........ja sam njega kupio ne on mene radi on i dalje sve normalno ali mu treba malo selotejpa......hahahah Quote Link to comment Share on other sites More sharing options...
