lazyman Posted November 2, 2014 Report Share Posted November 2, 2014 I joÅ¡ da dodam, znaÄi na njima uglavnom svira elektronika, neki fanky recimo, neÅ¡to electro pop zvuka, pokoji jazz, to otprilike. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 2, 2014 Report Share Posted November 2, 2014 Treba mi preporuka ili gde da nađem zamensku iglu, pošto je ne vidim u ponudi domaćih prodavaca, ili preporuku koju iglu bih mogao koristiti. За коју главу? Quote Link to comment Share on other sites More sharing options...
lazyman Posted November 2, 2014 Report Share Posted November 2, 2014 Concorde Pro, napisao sam iznad, nisam našao zamensku iglu po meni poznatim prodavnicama. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 2, 2014 Report Share Posted November 2, 2014 Изнад Ñу наведене три главе. Погледај у МГ електроник-у http://www.mgelectronic.rs/product.php?action=view&code=AUIG-D10&group_id=3376 AUIG-D10 IGLA ZA GRAMOFON 10/CL10 Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 2, 2014 Report Share Posted November 2, 2014 Ta mi liÄi na zamensku, idi na original. Pitaj u Playeru, imaju ostale modele, verovatno mogu da ti nabave i srebrni. http://www.player.rs/igle-i-delovi-za-gramofone/cat/107?page=2 Quote Link to comment Share on other sites More sharing options...
lazyman Posted November 2, 2014 Report Share Posted November 2, 2014 Za player znam da drže Ortofon program, sad koliko imaju volje da nabave drugu iglu ne znam. Koja od ponuđenih bi bila najadekvatnija zamena ? Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 3, 2014 Report Share Posted November 3, 2014 Sa Ortofon sajta: Physically, each series of stylus, except for S-120, will fit on alternate cartridge bodies. However, these combinations are not supported by Ortofon, as they have not been tested. Each cartridge series is designed with a synergistic combination in mind - that is, each stylus is made to compliment the magnet and coil configuration of each cartridge body. For instance, using a DigiTrack stylus with a Scratch body will not provide the full benefit of either product, and might even provide undesired results, including (but not limited to) differences in output, unbalanced sound reproduction, etc. Ako neće Player pitaj Korato ili poruÄi sam. Ako ti je svejedno koju stavljaÅ¡ uzmi plavu. Quote Link to comment Share on other sites More sharing options...
lazyman Posted November 4, 2014 Report Share Posted November 4, 2014 JoÅ¡ jedno pitanje. Da li na toj Concorde pro glavi treba da postoji onaj gumeni prsten tu gde se montira na ruÄku? Imam ga na svim nosaÄima ali ga ovde nemam. Quote Link to comment Share on other sites More sharing options...
lazyman Posted November 4, 2014 Report Share Posted November 4, 2014 I joÅ¡ jedo pitanje, primetio sam da na pojedinim starijim izdanjima Audio Tehnica AT-95e ima detaljniji zvuk u visokima, Å¡to je logiÄno, na ploÄama sa manjim rezom. Da li bih taj detaljniji zvuk dobio i kad bih iglu za ortofon OM 5e stavio na concorde telo, lakÅ¡e mi je menjati iglu nego stalno odvrtati i zavrtati noÅ¡aÄ glave kakko menjam ploÄu. Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 4, 2014 Report Share Posted November 4, 2014 JoÅ¡ jedno pitanje. Da li na toj Concorde pro glavi treba da postoji onaj gumeni prsten tu gde se montira na ruÄku? Imam ga na svim nosaÄima ali ga ovde nemam. Koliko se sećam Concorde nema takav prsten. Da li bih taj detaljniji zvuk dobio i kad bih iglu za ortofon OM 5e stavio na concorde telo, lakÅ¡e mi je menjati iglu nego stalno odvrtati i zavrtati noÅ¡aÄ glave kakko menjam ploÄu. Mogućnost za odvrtanje - zavrtanje nosaÄa glave je tu upravo da bi se izbeglo Äesto menjanje samo igle koje ne treba da se radi. Å to se tiÄe kompatibilnosti OM5E igle i Concorde Pro tela nisu mi poznata konkretna iskustva, inaÄe fiziÄki pasuje. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 4, 2014 Report Share Posted November 4, 2014 JoÅ¡ jedno pitanje. Da li na toj Concorde pro glavi treba da postoji onaj gumeni prsten tu gde se montira na ruÄku? Imam ga na svim nosaÄima ali ga ovde nemam. Зар је проблем пребацити? Quote Link to comment Share on other sites More sharing options...
lazyman Posted November 4, 2014 Report Share Posted November 4, 2014 Зар је проблем пребацити? Nije problem prebaciti, nego da li treba da postoji tu ili ne ? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 4, 2014 Report Share Posted November 4, 2014 Nije problem prebaciti, nego da li treba da postoji tu ili ne ? По мени да. Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 4, 2014 Report Share Posted November 4, 2014 Nije problem prebaciti, nego da li treba da postoji tu ili ne ? Ne treba. Niti jedan concorde ih nema, stavljaju ih samo na headshellove. Quote Link to comment Share on other sites More sharing options...
Play_Select Posted November 4, 2014 Report Share Posted November 4, 2014 JoÅ¡ jedno pitanje. Da li na toj Concorde pro glavi treba da postoji onaj gumeni prsten tu gde se montira na ruÄku? Imam ga na svim nosaÄima ali ga ovde nemam. Gumeni prsten se ne isporuÄuje uz svaki Ortofon Concorde. U originalnom pakovanju Ortofon nightclub II isporuÄen je prsten i gumena navlaka koja se navlaÄi na ruÄicu konkorda. Zanimljiva stvar vezana za concorde seriju je i overhang koji je 51,5mm. Sa dodatkom gumenog prstena dobijaÅ¡ taÄno 52mm. Quote Link to comment Share on other sites More sharing options...
Play_Select Posted November 4, 2014 Report Share Posted November 4, 2014 Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 4, 2014 Report Share Posted November 4, 2014 Ршта је на Ñлици? Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 4, 2014 Report Share Posted November 4, 2014 Zanimljivo. 2m PnP je taÄno 52mm i nema prsten, koliko se može videti na nekim slikama. Quote Link to comment Share on other sites More sharing options...
lazyman Posted November 4, 2014 Report Share Posted November 4, 2014 JoÅ¡ jedna zanimljiva stvar, proÄitao sam negde da kantaliver na ovoj DJ seriji nije iste dužine kao na OM seriji, jel to istina ? Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 4, 2014 Report Share Posted November 4, 2014 http://audio.innerurban.com/2008/09/tonar-banana-with-ortofon-om5e-stylus_10.html Quote Link to comment Share on other sites More sharing options...
Play_Select Posted November 4, 2014 Report Share Posted November 4, 2014 Zanimljivo. 2m PnP je taÄno 52mm i nema prsten, koliko se može videti na nekim slikama. Nisam znao da se gumeni prsten isporuÄuje uz neke modele Concord serije dok nisam kupio Nightclub 2 ( prsten nije bio namontiran ) Možda se isporuÄuje i uz 2m PnP ??? Quote Link to comment Share on other sites More sharing options...
Play_Select Posted November 4, 2014 Report Share Posted November 4, 2014 JoÅ¡ jedna zanimljiva stvar, proÄitao sam negde da kantaliver na ovoj DJ seriji nije iste dužine kao na OM seriji, jel to istina ? OM serija se montira na headshell dok je concorde integrisan, sve ostalo je identiÄno ( važi za isti model om i concorde ) Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 4, 2014 Report Share Posted November 4, 2014 Nisam znao da se gumeni prsten isporuÄuje uz neke modele Concord serije dok nisam kupio Nightclub 2( prsten nije bio namontiran ) Onda ću proveriti moje kutije za svaki sluÄaj, mada radi se o drugom modelu... OM serija se montira na headshell dok je concorde integrisan, sve ostalo je identiÄno ( važi za isti model om i concorde ) Misli na nedidžejski OM, kao na linku gore. Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 4, 2014 Report Share Posted November 4, 2014 Bilo bi zanimljivo usporediti razliÄite Concorde modele postavljanjem na overhang gauge-u, sa i bez prstenom. Quote Link to comment Share on other sites More sharing options...
