spark Posted December 3, 2011 Report Share Posted December 3, 2011 mene optika radi bez kratkospojnika al za coax mora biti stavljen Quote Link to comment Share on other sites More sharing options...
okibokis Posted December 3, 2011 Report Share Posted December 3, 2011 Jumper je bio u pitanju sad sve radi ... Quote Link to comment Share on other sites More sharing options...
pera451 Posted December 3, 2011 Author Report Share Posted December 3, 2011 Jos jedna . Quote Link to comment Share on other sites More sharing options...
okibokis Posted December 3, 2011 Report Share Posted December 3, 2011 Opet nesto nije kako treba povezao sam crveni analognu zicu na crvenu ,belu na belu,a crnu posto je jedna sam spojio na oba cinca,da bude zajednicka,da li je to u redu?Inace ovako na prvu se cuje bolje od moje zvucne kartice,cak i sa tankim kablom, Quote Link to comment Share on other sites More sharing options...
Aciko Posted December 3, 2011 Report Share Posted December 3, 2011 Opet nesto nije kako treba povezao sam crveni analognu zicu na crvenu ,belu na belu,a crnu posto je jedna sam spojio na oba cinca,da bude zajednicka,da li je to u redu? У реду је. Quote Link to comment Share on other sites More sharing options...
pera451 Posted December 3, 2011 Author Report Share Posted December 3, 2011 Samo jos jedna mala provera. Molim Vas da se upisete ako ste nabavili trafo iz GB. Pocecu ja. 1. Pera 451 Quote Link to comment Share on other sites More sharing options...
boskogit Posted December 3, 2011 Report Share Posted December 3, 2011 Samo jos jedna mala provera. Molim Vas da se upisete ako ste nabavili trafo iz GB. Pocecu ja. 1. Pera 451 2. Chuck Norris Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted December 3, 2011 Report Share Posted December 3, 2011 Samo jos jedna mala provera. Molim Vas da se upisete ako ste nabavili trafo iz GB. Pocecu ja. 1. Pera 451 Great Britain? Svakako. 1. Pera 451 2. Chuck Norris 3. Bujodrag Quote Link to comment Share on other sites More sharing options...
okibokis Posted December 3, 2011 Report Share Posted December 3, 2011 У реду је. Jeste imao sam jednu licnu kratak spoj Quote Link to comment Share on other sites More sharing options...
Leonardo Posted December 3, 2011 Report Share Posted December 3, 2011 Molim Vas da se upišete ako ste nabavili trafo iz GB. 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo Quote Link to comment Share on other sites More sharing options...
Aurelijano Buendija Posted December 3, 2011 Report Share Posted December 3, 2011 Molim Vas da se upišete ako ste nabavili trafo iz GB. 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland Quote Link to comment Share on other sites More sharing options...
okibokis Posted December 3, 2011 Report Share Posted December 3, 2011 Molim Vas da se upišete ako ste nabavili trafo iz GB. 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6.Okibokis Quote Link to comment Share on other sites More sharing options...
okibokis Posted December 3, 2011 Report Share Posted December 3, 2011 Evo ja da se javim i iznesem svoje utiske.Sklopio sam privremeno da vidim da li sve radi ,i posto sam porodicu evakuisao iz kuce,pustio sam sve u rad.Lampucera definitivno dobro radi,bolje od moje zvucne kartice koja ima cak dva clock-a u sebi i tri op-ampa,odnosno 2x2604,i jedan 2132,koje sam naknadno stavljao ne bi li poboljsao zvuk.Ovo se u ovakvoj probi cuje sasvim korektno,mada sam primetio da se zvuk menja,sada posle 2 sata mog slusanja(jos se nisam zapalio),zvuk je puniji,i bolje pravi vazduh izmedju instrumenata,i vokala.Ja ne bih menjao ove op-ampove na njemu,jer sam vecinu isprobao sem op 627 koji je skup,i nije mi bilo interesantno da dajem velike pare,samo radi probe.Ovde mislim da ne bi trebalo da imam,slabiji ton jer je moj opticki kabl 5 metara,ali definitivno cu da zamenim Onaj famozni kablic,koji je beda bedna:)Cini mi se da sam vidjao neke providne hibrid kablove od slusalica,ali to cu vec da se setim gde i kad.Moj utisak je da ovajD/A konverter,zasluzuje lepu kutiju i da je zadovoljio!Meni licno je najveci upgrade,jedna stvarno lepa kutija,i 10cm najskupljeg ozicenja,pa kolko kosta nek kosta:)) Quote Link to comment Share on other sites More sharing options...
garson Posted December 3, 2011 Report Share Posted December 3, 2011 Molim Vas da se upišete ako ste nabavili trafo iz GB. 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6. Okibokis 7. garson Quote Link to comment Share on other sites More sharing options...
Aciko Posted December 4, 2011 Report Share Posted December 4, 2011 Molim Vas da se upišete ako ste nabavili trafo iz GB. 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6. Okibokis 7. garson 8. Aciko Quote Link to comment Share on other sites More sharing options...
okibokis Posted December 4, 2011 Report Share Posted December 4, 2011 Mali svira sve bolje:) Quote Link to comment Share on other sites More sharing options...
cceda Posted December 4, 2011 Report Share Posted December 4, 2011 Äisto da i ja potvrdim da ovo malo cudo svira bas ok za ove parice...... jos uvek preslusavam omiljene diskove tako da mi cak bolje zvuci nego na cd playeru,jer konstantno proveravam na pojacalu oba inputa opt./cd uradicu mu samo drugo napajanje za op ampove i to ce biti to,poceracu ih sa +/-15v mada razmisljam i o 18v. jel kontrolisao neko ad827 osciloskopom i dali se vidi nesto izmedju dva stepena pojacanja 1x827 i 2x827 mozda ova dva treba' smiriti'. jedno vece sam zaspao a dac je ostao celu noc da radi bez, pozara u stanu Quote Link to comment Share on other sites More sharing options...
boskogit Posted December 4, 2011 Report Share Posted December 4, 2011 Mali svira sve bolje:) Kakav ti je ovo izložbeni salon? Quote Link to comment Share on other sites More sharing options...
skrstic Posted December 4, 2011 Report Share Posted December 4, 2011 Molim Vas da se upišete ako ste nabavili trafo iz GB. 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6. Okibokis 7. garson 8. Aciko 9. skrstic Quote Link to comment Share on other sites More sharing options...
laky Posted December 4, 2011 Report Share Posted December 4, 2011 Molim Vas da se upišete ako ste nabavili trafo iz GB. 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6. Okibokis 7. garson 8. Aciko 9.laky Quote Link to comment Share on other sites More sharing options...
perodeformero Posted December 4, 2011 Report Share Posted December 4, 2011 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6. Okibokis 7. garson 8. Aciko 9. skrstic 10. laky 11.Perodeformero Quote Link to comment Share on other sites More sharing options...
Pelac Posted December 4, 2011 Report Share Posted December 4, 2011 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6. Okibokis 7. garson 8. Aciko 9. skrstic 10. laky 11.Perodeformero 12. Pelac Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted December 4, 2011 Report Share Posted December 4, 2011 Mali svira sve bolje:) ma zamisli kako bi tek svirao da umesto 4 imas 1, ali posten, par zvucnika. Quote Link to comment Share on other sites More sharing options...
nikstev2000 Posted December 4, 2011 Report Share Posted December 4, 2011 Evo jedne pozajmljene kod mene...U poÄetku AKM4420 iz Toucha nije niÅ¡ta slabije svirao...U meÄ‘uvremenu,Äini mi se da je bas postao malo utegnutiji,a visoki manje prÅ¡te...Pratićemo situaciju...Da li je isplativ upgrade (ne mislim finansijski),ili ići na neÅ¡to ozbiljnije...Neki 1702,1704 ili možda Äak i Aya (neda mi mira odkad sam reÅ¡io da se pozabavim DAC-om) Quote Link to comment Share on other sites More sharing options...
marisol Posted December 4, 2011 Report Share Posted December 4, 2011 1. Pera 451 2. Chuck Norris 3. Bujodrag 4. Leonardo 5. Woland 6. Okibokis 7. garson 8. Aciko 9. skrstic 10. laky 11.Perodeformero 12. Pelac 13. marisol Quote Link to comment Share on other sites More sharing options...
