Bozzam Posted August 17, 2011 Report Share Posted August 17, 2011 Revox B-215 Nisam mogao da odolim Quote Link to comment Share on other sites More sharing options...
Bozzam Posted August 17, 2011 Report Share Posted August 17, 2011 Evo i jedne loÅ¡e sliÄice. Quote Link to comment Share on other sites More sharing options...
acazr Posted August 17, 2011 Report Share Posted August 17, 2011 Evo i jedne loÅ¡e sliÄice. Ebes sliku bitna je masina. Quote Link to comment Share on other sites More sharing options...
stivbmw Posted August 21, 2011 Report Share Posted August 21, 2011 Sjajne kutije, koliko su ruznjikave toliko dobro sviraju Quote Link to comment Share on other sites More sharing options...
stivbmw Posted August 21, 2011 Report Share Posted August 21, 2011 Posto sam zaboravio da napisem sta je u pitanju evo sad cu. Ovo su Revox AX4-3 B. Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted August 27, 2011 Report Share Posted August 27, 2011 Iako imam kompletan sistem ovag prekrasnog Mitchubishija uvijek ima mjesta za još koju komponentu, uh najgore je kad sam sebe lažem ali što mogu bolest je bolest Quote Link to comment Share on other sites More sharing options...
sule Posted August 27, 2011 Report Share Posted August 27, 2011 Retro kakav je taj Mitchubishi Amp posto razmisljam o nabavci bas tog modela???? Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted August 27, 2011 Report Share Posted August 27, 2011 Sule to je amp iz doba long-life razdomlja, napravljen kao tenk, nazubljeni poteciometri, selektor ima kuglicu od 4mm, kad ga se jednom podmaže radi dugo bez krckanja, zvuÄno je meni odliÄan, probao sam ga na Megovima, Aerima, JBL, Grundinzima i još gomili zvuÄnika, a sad znate kako se kaže o ukusima se ne raspravlja zato je najbolje ako se može poslušati prije kupovine , vidio sam jedan na KP mislim da je bio 60 Eura što stvarno nije puno za takav amp. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 27, 2011 Report Share Posted August 27, 2011 Ја безуÑпешно тражим Micubishi DA-P30. Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted August 27, 2011 Report Share Posted August 27, 2011 Tjuner lepo izgleda.Koliko vredi. Quote Link to comment Share on other sites More sharing options...
ZoSo Posted August 27, 2011 Report Share Posted August 27, 2011 Ma sve lepo, izgleda! Retro svaka cast i hvala na ovim divnim slikama Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted August 27, 2011 Report Share Posted August 27, 2011 Koliko vrijedi, pojma nemam, meni sve pare, nije za prodaju jer je davno bio moj, onda je moj kum dugo patio za njim i dobio ga je za roÄ‘endan na poklon od mene, zamislite facu žene u cvjeÄarnici kad sam je zamolio da mi ga upakuje u veliku mašnu, za to dvoje sam mu dao neku digitaliju 6.1 od Yamahe, on sretan a ja još više. Quote Link to comment Share on other sites More sharing options...
alex67 Posted August 30, 2011 Report Share Posted August 30, 2011 Proslo je prilicno vremena od kada sam nabavio nesto ( niti imam nesto volje da jurim, jer sve manje vidim neku svrhu da kada se izigram aparatura zavrsi u sporednom sobicku i cuci tamo ), ovo je jedna mini linija sa velikim zvukom - ostala mi je u secanju jos iz mladjih dana. Na zalost nisam uspeo da je nabavim kompletnu , naime dolazi bez zvucnika, samo glavna jedinica . Posto je inace retka kao i zdrav zub u babe ( ja je do pre neki dan ne videh bilo gde da se prodaje ) resio sam ipak da je uzmem jer znam da i normalne zvucnike moze da potera bez velikih problema a ko zna kada ce sledeca da naleti. Ako se ipak desi kupujem i drugu pa ce bar jedna biti kompletna. Inace je retkost da su na ovakvim linijama zvucnici bili izradjeni od drveta iako na slici / stvarnosti/ slikama izgleda plastika). Quote Link to comment Share on other sites More sharing options...
stivbmw Posted September 5, 2011 Report Share Posted September 5, 2011 Nisam mogao da odolim ovam monstrumu, zaista zanimljiva sprava. Vizuelno pojava da ostanes bez teksta a i odlican tonski. Quote Link to comment Share on other sites More sharing options...
civi Posted September 5, 2011 Report Share Posted September 5, 2011 Uh dobro je zavrsio je kod ljubitelja.... Quote Link to comment Share on other sites More sharing options...
grnca Posted September 6, 2011 Report Share Posted September 6, 2011 KonaÄno, krcka levi zvuÄnik ali sa obzirom na godište nije loše. Naćićemo adekvatnu zamenu - nadam se. Quote Link to comment Share on other sites More sharing options...
accuphase Posted September 7, 2011 Report Share Posted September 7, 2011 OPA Äika @grnca... Sonab old egzotika !!! Quote Link to comment Share on other sites More sharing options...
mmilovan Posted September 7, 2011 Report Share Posted September 7, 2011 Nisam mogao da odolim ovam monstrumu, zaista zanimljiva sprava. Vizuelno pojava da ostanes bez teksta a i odlican tonski. Pretpostavljam da veoma dobro zvuÄi, ali me po izgledu (kao što je sluÄaj i sa još nekim Technics Äudima) podseća na registar kasu u samoposluzi... Quote Link to comment Share on other sites More sharing options...
stivbmw Posted September 7, 2011 Report Share Posted September 7, 2011 Nisi jedini sa takvim misljenjem, ali stvarno je izuzetna sprava. Quote Link to comment Share on other sites More sharing options...
mrcelavi Posted September 7, 2011 Report Share Posted September 7, 2011 KonaÄno, krcka levi zvuÄnik ali sa obzirom na godište nije loše. Naćićemo adekvatnu zamenu - nadam se. Bravo Grnca , ovde kod mene ih ima na svakom ćošku, naravno domaći proizvod, i mogu ti reći da su jako traženi. Cene se kreću od 100 eura pa bogami i do 600. Živo me interesuju tvojji zvuÄni utisci i koji su im dometi pošto još nisam Äuo ni jedan par. Javi koji je taÄno model pa ću pogledati po forumima ovde koje su adekvatne zamene. Pozdrav i prijatno slušanje http://www.carlssonplanet.com/oa116.php Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted September 9, 2011 Author Report Share Posted September 9, 2011 Mozda nije mesto, ali da ipak priupitam: Ovde ima bas vrsnih poznavalaca materije, ali da li ste nekada culi da je Samsung napravio neku high end audio kombinaciju? Secam se da sam u nekom od britanskih casopisa krajem devedesetih (mislim da je tako bilo), nasao test u kojem je stajao opis Samsungovog preampa i snagasa, a cena je bila, koliko se secam... oko 10.000 funti (davno je bilo, nisam siguran ali znam da je bila grozomorna). Englezi su ga ocenili sa pet zvezdica i rekli da je izuzetno pojacalo. Nisu mogli da veruju svojim usima. Posle toga nista - muk... kao da se pravilo u vrlo, vrlo maloj seriji. Da mi je to neko rekao par godina kasnije i da nisam video clanak u casopisu - ne bih verovao. Isto tako sam sreo i neke LG vokmene da se smrznete. Tanki, skroz logicke komande, sve super moderno, metalno kuciste, bili jedno kratko vreme da se nadju u Beogradu i bili su vrlo skupi. Nemam pojma kako su zvucali niti sam ista slicno ikada kasnije video. Koreanci pokazali da mogu i... dovidjenja. Da li ste ikada naisli na nesto od ovoga? Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted September 9, 2011 Report Share Posted September 9, 2011 Zoki i ja sam Äitao nešto o tome ali vjerujem da je to bilo kao što kažeš samo za demonstraciju a ako su i proizvodili neke manje serije to sigurno nije bilo za ova tržišta veÄ za Japan ili Ameriku. Quote Link to comment Share on other sites More sharing options...
civi Posted September 9, 2011 Report Share Posted September 9, 2011 http://www.thevintag...sung-M-30S.html http://www.thevintag...msung-C-01.html http://www.thevintageknob.org/samsung-SP-01.html Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted September 10, 2011 Author Report Share Posted September 10, 2011 Civi, care! Hvala najlepse! Nekako mi je ovo skroz promaklo na TVK sajtu Divno izgledaju. Quote Link to comment Share on other sites More sharing options...
branaR Posted September 10, 2011 Report Share Posted September 10, 2011 Plavo VS Narandzasto Quote Link to comment Share on other sites More sharing options...
