ska62 Posted April 21, 2011 Report Share Posted April 21, 2011 Lepo ali i skupo . Quote Link to comment Share on other sites More sharing options...
ska62 Posted April 21, 2011 Report Share Posted April 21, 2011 I ova nije loša . Quote Link to comment Share on other sites More sharing options...
ska62 Posted April 21, 2011 Report Share Posted April 21, 2011 SimpatiÄno postolje-baza za ureÄ‘aje . Quote Link to comment Share on other sites More sharing options...
ska62 Posted July 2, 2011 Report Share Posted July 2, 2011 NeobiÄan model svakako zaslužuje pažnju . Quote Link to comment Share on other sites More sharing options...
accuphase Posted July 2, 2011 Report Share Posted July 2, 2011 NeobiÄan model svakako zaslužuje pažnju . Ovo sjajno izgleda, plus Å¡to ima rekao bih vrlo efektno reÅ¡enje "za skrivanje kablova" !!! Quote Link to comment Share on other sites More sharing options...
accuphase Posted July 2, 2011 Report Share Posted July 2, 2011 Ipak... ova polica, u "Simaudio" brošuri je nekako "prava stvar"... - http://www.simaudio.com/pdf/MOON_Andromeda+P-8+W-8_Lit.pdf Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 2, 2011 Report Share Posted July 2, 2011 Лепо изгледа али је мали размак између полица. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted July 10, 2011 Report Share Posted July 10, 2011 PoÅ¡to je tema "Police", turiću ovde ove koje sam upravo zavrÅ¡io. Služe za držanje ploÄa, a razmak izmeÄ‘u polica je sasvim nestandardan, za danaÅ¡nje pojmove. Dole će biti ploÄe od 10", a gore singlovi i EP (7"). Na slikama izgledaju solidno, dok bi pažljivije oko uoÄilo da su moje stolarske veÅ¡tine priliÄno ograniÄene. U svakom sluÄaju, njihov doprinos uvoÄ‘enju nekog reda u kući će biti ogroman. Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted July 10, 2011 Report Share Posted July 10, 2011 Izgledaju odliÄno, meni se svidja takva "gruba" izrada.Samo, ja ne bih stavio ta silna vrata, smetalo bi mi da ih otvaram svaki put kad hoću da uzmem ploÄu a smetalo bi mi i da su stalno otvorena.A ni ploÄe se ne vide. Evo moje police: Hteo sam da sklepam neÅ¡to jednostavno i na brzaka i tako i izgleda ali ne mojom nego "zaslugom" neverovatno aljkavih radnika u Tihos-u koji su uspeli da svaki rez upropaste. Planiram da od jeftinih Äamovih dasaka koje prodaju u Merkuru napravim neÅ¡to sliÄno tvojoj polici umesto ove skalamerije: Gramofon je na zidnoj polici a Audiolab nije preterano težak. Na tu policu ću staviti vrata, verovatno. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted July 10, 2011 Report Share Posted July 10, 2011 Na tu policu ću staviti vrata, verovatno. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted July 10, 2011 Report Share Posted July 10, 2011 Planiram da od jeftinih Äamovih dasaka koje prodaju u Merkuru napravim neÅ¡to sliÄno tvojoj polici umesto ove skalamerije: Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted July 10, 2011 Report Share Posted July 10, 2011 Улазна? Quote Link to comment Share on other sites More sharing options...
Vlajo Posted July 10, 2011 Report Share Posted July 10, 2011 Nikako daske za muziku samo univer, kakve crne daske - smola je neizbežna (od nje leka nema) Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted July 10, 2011 Report Share Posted July 10, 2011 Nisu crne. Quote Link to comment Share on other sites More sharing options...
den!s Posted July 10, 2011 Report Share Posted July 10, 2011 Ali bi vrlo brzo mogle da budu… Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted July 10, 2011 Report Share Posted July 10, 2011 Nikako daske za muziku samo univer, kakve crne daske - smola je neizbežna (od nje leka nema) Quote Link to comment Share on other sites More sharing options...
Vlajo Posted July 10, 2011 Report Share Posted July 10, 2011 Veruj mi da uvek postoji šansa za smolu, doduše uglavnom ako su na suncu (to obavezno procuri, mada nikad se ne zna) Quote Link to comment Share on other sites More sharing options...
zbrujic Posted August 17, 2011 Report Share Posted August 17, 2011 Hteo bih praviti policu poput ove na slici: 1. Ako bi raspon bio oko 180cm, koje ploÄe bi valjalo koristiti da bi ugib ostao neprimetan? Možda neÅ¡to ovakvo, debljine 44mm? Ili Å¡per-ploÄa 40mm, poput ovih. Ili je, ipak, neohodno, za taj raspon, "sakrivati" neke ÄeliÄne profile? 2. Ima li predloga kako reÅ¡iti detalj Å¡iljaka? Kakva veza drvo-metal? Treba li razmiÅ¡ljati o nekom dampirajućem materijalu izmeÄ‘u? Svako razmiÅ¡ljanje/iskustvo je dobrodoÅ¡lo. Hvala Quote Link to comment Share on other sites More sharing options...
pera451 Posted August 17, 2011 Report Share Posted August 17, 2011 @zbrujicu, nedostajuci faktor u prici o ugibu je i opterecenje koje deluje na plocu. Kolike tezine stavljas? Moj licni utisak je da bi neka od kvalitetnijih "sperki" mogla da istrpi "normalno" opterecenje bez nekih ukrucenja i orebrenja, pogotovo ako je materijal (tj. vlakna) "ukrsten". Sto se siljaka tice, tu je moguca relativno standardna stvar. Postoje oni cilindri sa "kandzom" i unutrasnjim navojem koji se nabiju duboko u nogicu i u njih onda ulazi siljak. Treba samo naci neki dovoljno dubok (tj. dugacak). Imao sam prilike da vidim u akciji neke "pijacne", koji se lako iscupaju, sa neprijatnim posledicama. Ja bih u svakom slucaju kontaktirao onaj Leov izvor i pitao ih za mehanicka svojstva sperki. Quote Link to comment Share on other sites More sharing options...
zbrujic Posted August 17, 2011 Report Share Posted August 17, 2011 nedostajuci faktor u prici o ugibu je i opterecenje koje deluje na plocu. Kolike tezine stavljas? Pa, možda i preko 50kg po polici. Svakako bi podatak o modulu elastiÄnosti "materijala" koristio, ali niko ga ne navodi. Probaću s nekim "generiÄkim", pa javljam. Quote Link to comment Share on other sites More sharing options...
pera451 Posted August 17, 2011 Report Share Posted August 17, 2011 @z, to je vec ozbiljnije opterecenje. Javi pocetne rezultate, pa da (za pocetak) sracunamo gredu na dva oslonca. Quote Link to comment Share on other sites More sharing options...
beatgoeson Posted August 17, 2011 Report Share Posted August 17, 2011 Na toliki raspon, 50kg? Ja sam malo skeptiÄan, vreme Äini svoje... Na tu dužinu, ni vibracije nisu iskljuÄene. Mada ovako lepÅ¡e izgleda, ja bih udario nogice i po sredini. Quote Link to comment Share on other sites More sharing options...
pera451 Posted August 17, 2011 Report Share Posted August 17, 2011 I raspon i tezina su poveliki. Doduse, zavisi i od toga kako ce biti rasporedjeno opterecenje - ako je skoro kontinualno, ili blize krajevima, mozda je i laksi slucaj. Ako bude koncentrisano (neko mono-blokce u A-klasi), onda cemo da vidimo. Naravno, ostaje pitanje da li bi ipak moglo da se stavi neko ukrucenje, a da bude diskretno. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 17, 2011 Report Share Posted August 17, 2011 Ako bi raspon bio oko 180cm, koje ploÄe bi valjalo koristiti da bi ugib ostao neprimetan? Што да не, на Ñваку полицу додати у преÑеку дијагонала по још један шиљак. Ионако је полица 1,80 м широка. Значи укупно 3 комада. Quote Link to comment Share on other sites More sharing options...
Bujodrag Posted August 17, 2011 Report Share Posted August 17, 2011 Za raspon od 180 cm ja bih obavezno stavio jednu nogicu po sredini(u preseku dijagonala), makar ploÄa bila debela i Äetiri cm. Ili bih napravio dve police od po 90 cm. Quote Link to comment Share on other sites More sharing options...
