acazr Posted February 17, 2016 Report Share Posted February 17, 2016 Ima nešto slično na kp. Quote Link to comment Share on other sites More sharing options...
acazr Posted February 17, 2016 Report Share Posted February 17, 2016 i jedan zanimljiv dupli dek sa troglavom kombinacijom, isto ima na kp. https://youtu.be/GYZLMZNUwHA Quote Link to comment Share on other sites More sharing options...
aiwa Posted February 17, 2016 Report Share Posted February 17, 2016 http://1001hifi.blogspot.rs/2015/02/compact-cassette-changers.html Quote Link to comment Share on other sites More sharing options...
laky Posted February 17, 2016 Report Share Posted February 17, 2016 Odlican sajt,hvala Quote Link to comment Share on other sites More sharing options...
sladjan marinkovic Posted February 20, 2016 Report Share Posted February 20, 2016 Potreban mi je potenciometar za volume za aiwa adf 800 ako neko ima neka se javi porukom. Moze i neispravan dek pa cu sam da ga skinem Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 20, 2016 Report Share Posted February 20, 2016 35 minuta ranije, sladjan marinkovic said: Potreban mi je potenciometar za volume za aiwa adf 800 ako neko ima neka se javi porukom. Moze i neispravan dek pa cu sam da ga skinem. Цимни колегу Сафет-а. Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted February 23, 2016 Report Share Posted February 23, 2016 Na stolu mi se nasao Onkyo TA-2360... kao deo veceg projekta pokazne vezbe sklapanja kvalitetnog HiFi sistema uz minimalna ulaganja, ono o cemu malo ko pise - vise o tome u nekoj od sledecih tema. Uglavnom, masina je stigla dugo nekoriscena I u vrlo dobrom stanju, ali (uslovno receno) neispravna, upravo onako kako ju je opisao vlasnik - glavna pogonska gumica se skoro istopila. Inace, TA-2360 je bio top model u seriji sredinom osamdesetih godina. Poseduje autokalibraciju (Accubias) sa pet prepodesenih vrednosti koje se biraju pre autokalibracije - malo komplikovano, ali sluzi za biranje prema ukusu slusaoca - hocete li autokalibraciju sa vise ili manje visokih tonova. Po meni lepo, ali nepotrebno. TA-2360 na gornjoj slici: necackan, malo prasnjav, sklonjeni gornji I donji poklopac. Sve u svemo, odlicno za pocetak. Sankyo tromotorna mehanika sa jednim zamajcem. Nazalost, nije ona najbolja, nosac osovine zamajca je plastican, a sve ostalo lim i plastika. No, bolje od slicnih Aiwa I nekih Technics-a, losije od JVC-a itd. Zamajac koji je iznutra... supalj!!! Spolja ima tragove dinamickog balansiranja ali... moglo je to I bolje, kao kod Nak BX100, npr. Mehanika sa prednje strane: fino vesanje glave, sistem predzatezanja trake (fali gumica, skoro se istopila, slikano pre stavljanja nove). Zupcanici, hvala Bogu, umesto dosadnog idlera. Mehanika posle pranja, podmazivanja, zamene rolera, sklapanja... Evo malo I sa druge strane... Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted February 23, 2016 Report Share Posted February 23, 2016 Po cuvenom Marfijevom zakonu, problem ce se javiti tamo gde ga je najteze otkloniti. Kada sam stavio dek na test, bez poklopaca I prednje ploce... otkrio sam da ne radi potenciometar za balans ulaznog signala. Tesko dostupan, naravno. Srecom on kada ne radi ne remeti ulaz, tj. ne prekida ga, vec samo ne radi balans. Ciscenje kontakt sprejom nije dalo nikakav rezultat. Mrzelo me je, ali zelja da dek radi kako treba je nadjacala: skinuo sam I rasklopio pot. Popravio sam sta je trebalo I vratio ga nazad. Sada je sve OK. Oprao sam sprejom I neke preklopnike koji su prekidali od stajanja. Dek na prvom testu, pre kacenja na racunar... provera funkcionalnosti. Vise slika nemam Ovako izgleda - ali je slika sa neta, bila je noc kada sam zavrsio I nije imalo smisla slikati ga, ne bi licio ni na sta, pa sam pozajmio sliku. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 23, 2016 Report Share Posted February 23, 2016 1 sat ranije, ZoranBG said: Vise slika nemam Ма и ово је сасвим довољно. Quote Link to comment Share on other sites More sharing options...
ognjen Posted February 23, 2016 Report Share Posted February 23, 2016 Prinova za 450din.,s'tim da je sa prevozom izasao na 1100din.Technics Rs-B78R,trebalo bi da je to njihov najbolji reversni deck.Deck daje znake zivota.Potrebno kompletno ciscenje mehanike, kao i celog deck-a.Estetski nije u losem stanju Quote Link to comment Share on other sites More sharing options...
ognjen Posted February 23, 2016 Report Share Posted February 23, 2016 Mane,neotvara vrata,fali poluga ili sta vec, koja pokrece mehanizam za otvaranje.Posto posedujem Rs-B100 moram proveriti sta je u pitanju.Inace rucno kada se pokrene vrata se otvaraju Quote Link to comment Share on other sites More sharing options...
ognjen Posted February 23, 2016 Report Share Posted February 23, 2016 Druga mana je glava,prilikom rotiranja neokrene se do kraja ostanje u nekom medjupolozaju kao na slici. Predpostavljam kada se opere i podmaze mehanizam da ce glava poceti da se rotira kako treba. Quote Link to comment Share on other sites More sharing options...
ognjen Posted February 23, 2016 Report Share Posted February 23, 2016 Evo jos koja slika iznutra,stanje nije lose.Malo cemo se zanimati pa cemo videti sta ce biti na kraju . Sa cim je najbilje podmazati mehanizam posle ciscenja masinsko ulje ili neka mast? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 23, 2016 Report Share Posted February 23, 2016 39 minuta ranije, ognjen said: Sa cim je najbilje podmazati mehanizam posle ciscenja masinsko ulje ili neka mast? Зависи шта нешто са уљем а нешто с мас' . Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted February 23, 2016 Report Share Posted February 23, 2016 Imao sam vise puta B78R... evo testa koji sam napisao, da se ne ponavljam: http://zokiaudio.com/?p=1690&lang=sr Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted February 24, 2016 Report Share Posted February 24, 2016 Pre nedelju dana kupio sam Denon DR-M33, sa oglasa. Taj model je bio drugi u ponudi (ispod DR-M44) I pravio se u kasnijoj verziji sa HX Pro sistemom kao DR-M33HX. Interesantno je da je nemacki StereoPlay DRM33 I 44 svrstao u najvisu kategoriju dekova, sa Sony TCK700, 777, Nakamichi dekovima itd. Rekao bih da su to plastikanci jakog srca, pretece DR-M800, po meni nesto bolji. DRM33, za pocetak koliko sam ga cuo, divno svira. Uglavnom, prodavac je rekao da je dek stigao iz Svajcarske (uvek uzimati sa rezervom) I da radi malo sporije nego sto treba, ali da nije cackan. Odmah da kazem da mislim da je bio skroz posten: dek je maltene potpuno cist iznutra, nisam nasao apsolutno nikakve tragove prethodnog otvaranja niti rada a sam uredjaj je veoma, veoma malo koriscen. Evo slike: Jednostavno prirucno podesavanje brzine "na uho" je resilo problem sporije reprodukcije, ali sam primetio jedva, ali zaista jedva cujno podrhtavanje zvuka. To hoce da se desi od starog remena koji se deformisao od stajanja ili je fabricki neispravan. No, ovo je bilo malo drugacije I registrovao sam ga slusnim testom tek sporadicno, toliko je malo bilo. Prakticno, nisam bio siguran da li umisljam. Evo deka na radnom stolu: Tu je I sasvim solidna tromotorna mehanika sa dva zamajca u zatvorenoj petlji. Mehanika spreda: Toliko je cista da bukvalno nije bilo potrebe za ciscenjem a kamoli pranjem, uradio sam samo podmazivanje. A zatim je na red dosla zamena remena - trebalo bi da je najjednostavnija stvar. Mehanika je potpuno pristupacna za ovu operaciju - cetiri zavrtnja I gotovo: Ispod se kriju dva lepa zamajca, sasvim prikladna za cenovnu kategoriju deka (mislim da je bila oko 1.200 DEM). A zatim... iznenadjenje. Nisam mogao da verujem sta vidim: Remenica glavnog motora je izmazana necim. To, naravno, ne potice od remena, nije nikakva smola. Pomislio sam da se material raspada nekako od starosti ali ne - sve je cvrsto I okolo nema nikakvih tragova otpadaka. Meni ovo lici na nekakav tinol, kalaj, rastopljen na samoj remenici. Kao sto rekoh, apsolutno nikakvih tragova ranijeg rasklapanja mehanizma nema. Remen je vrlo star I najverovatnije fabricki, jos moze malo da tera. Razlog zbog kojeg bi ovo neko namerno uradio ne verujem da postoji - jedini bi mogao biti povecanje obima remenice ali zaista nema smisla... onaj ko bi znao da demontira pedantno mehanizam, te da ga rastavi I uradi pomenuto, znao bi I da se brzina podesava na motoru a ne na remenici. Na kraju sam nasao rezervnu, slicnu ali plasticnu remenicu - nikada ih nisam cuvao, nasao sam je u kutiji koju cuvam od pre 20 I kusur godina, nikada mi nije zatrebala remenica na glavnom motoru. Jedino logicno objasnjenje koje imam jeste da je ovaj sloj metala na remenici nanet u fabrici, greskom, aljkavoscu ili slicno. Dek je, inace, pravljen u Japanu. Mozda je neko u brzini ostavio lemilicu I sa nje je kalaj presao na dovoljno zagrejanu remenicu I tu ostao... ako je tako nesto uopste moguce. Taj sloj je bio I izvor podrhtavanja koje sam jedva primetio. Ako neko ima neku drugu ideju u vezi ovoga... voleo bih da cujem. Mislim da ce servis ovog deka biti uskoro gotov, ostaje ciscenje potenciometara I jednog preklopnika. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 24, 2016 Report Share Posted February 24, 2016 14 minuta ranije, ZoranBG said: Meni ovo lici na nekakav tinol, kalaj, rastopljen na samoj remenici. Kao sto rekoh, apsolutno nikakvih o u brzini ostavio lemilicu I sa nje je kalaj presao na dovoljno zagrejanu remenicu I tu ostao... ako je tako nesto uopste moguce. Taj sloj je bio I izvor podrhtavanja koje sam jedva primetio. Ako neko ima neku drugu ideju u vezi ovoga... voleo bih da cujem. Мени то није логично јер је сама ременица направљена од месинга и потребно је подоста загревања да би се тинол разлио по целој површини, можда је то ременица од неког другог дека прилагођена за баш тај модел. Quote Link to comment Share on other sites More sharing options...
judge Posted February 24, 2016 Report Share Posted February 24, 2016 26 minuta ranije, stoN_Cold said: Мени то није логично јер је сама ременица направљена од месинга и потребно је подоста загревања да би се тинол разлио по целој површини, можда је то ременица од неког другог дека прилагођена за баш тај модел. Tesko objasnjivo,nisam takvo nesto do sada vidio.. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 24, 2016 Report Share Posted February 24, 2016 34 minuta ranije, judge said: Tesko objasnjivo,nisam takvo nesto do sada vidio.. Ма и они изгледа буџе. Quote Link to comment Share on other sites More sharing options...
judge Posted February 24, 2016 Report Share Posted February 24, 2016 1 sat ranije, stoN_Cold said: Ма и они изгледа буџе. I to sto kazes Quote Link to comment Share on other sites More sharing options...
tobra Posted February 24, 2016 Report Share Posted February 24, 2016 8 sati ranije, ZoranBG said: ... nisam nasao apsolutno nikakve tragove prethodnog otvaranja niti rada a sam uredjaj je veoma, veoma malo koriscen. 8 sati ranije, stoN_Cold said: Мени то није логично јер је сама ременица направљена од месинга и потребно је подоста загревања да би се тинол разлио по целој површини, можда је то ременица од неког другог дека прилагођена за баш тај модел. Pa Zoran lepo napisao da nije otvaran i sad ste krenuli u izmisljanje tople vode. Quote Link to comment Share on other sites More sharing options...
ZoranBG Posted February 24, 2016 Report Share Posted February 24, 2016 Pomenuta remenica, inace, nije od mesinga, kao kod vecine dekova. Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted February 24, 2016 Report Share Posted February 24, 2016 Zoki čestitam na prinovama i trudu koji ulažeš da ponovo ožive. Imam tog Denona ali želja mi je nabaviti DR-M44. screen capture freeware Quote Link to comment Share on other sites More sharing options...
Retro-Man Posted February 24, 2016 Report Share Posted February 24, 2016 Moguče je da je remenica jednostavno od lošeg materijala ili se neki čarobnjak poigrao sa njom. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 24, 2016 Report Share Posted February 24, 2016 2 sati ranije, ZoranBG said: Pomenuta remenica, inace, nije od mesinga, kao kod vecine dekova. Наравно да није. Quote Link to comment Share on other sites More sharing options...
