Retro-Man Posted December 31, 2012 Report Share Posted December 31, 2012 ZnaÅ¡ da si uvijek dobrodoÅ¡ao i samo se javi (a i da vidiÅ¡ prinovu) Pa kad si to dobio prinovu, jeli curica ili deÄko :) , znam ja na koju ti to prinovu misliÅ¡ Sony SDP-XA30ES, doÄiÄu svakako pa moramo mu nazdraviti za dug i zdrav život. Quote Link to comment Share on other sites More sharing options...
SuperFi Posted December 31, 2012 Report Share Posted December 31, 2012 Evo kako izgleda unutrasnjosto Pioneer CTS910...Iako mi je ADF990 najomiljeniji dek, ovaj Pioneer (naravno to se tek odnosi na CTS920 i CT95) su po mom (laickom) misljenju vrhunac...kvalitet upotrebljenih delova, konstrukcija...Podsecaju me po svojoj dual mono konstrukciji na Sony 950-990 seriju... Malo cemo se igrati sa promenom OP-ampa, 910 ima cini mi se samo jedan OP u PB sekciji... Inace, Zoki je skoro extra lepe utiske imao sa CT959, evo nekih osnovnih razlika izmedju 959 i 910: CT-910S and CT-959 have the same playback and recording section. On playback both should have exact the same performance. The are differences in BIAS, 106 KHz for 959 and 210 KHz for 910S. CT-959 calibration is fully manually and for 910S is auto with possibility to overwrite the bias within + or - 20% range. On recording the differences depends on how good calibration is done on 959. I am the owner of a CT-959 deck. CT-93 (best european Pioneer model 1991) is similar to 959 (best european Pioneer 1990 model). Both have exact the same playback and recordig section. The BIAS for CT-93 is 160 KHz and can be set fully manually or auto i jos razlika (sem dolby S) izmedju 95/920 i 910: CT-95/CT-920S is the best deck built by Pioneer with improved design in both rec and playback sections. On playback section can be see the best opamp (at that time) inside of a deck. No other deck from others have a better opamp. Bias frequency is set to 210 KHz and work like in 910S. Lako ce Impuls da promeni op-amp, hahaha. Danas ima vrhunskih op za sicu love. PS ako neko ima viska CTS920, neka se javi Quote Link to comment Share on other sites More sharing options...
SuperFi Posted December 31, 2012 Report Share Posted December 31, 2012 Za usporedbu kako izgleda serija (dve?) ispod serije 9: (slika Elite CT43) Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 31, 2012 Report Share Posted December 31, 2012 Kod mene novogodisnji ponov u vidu Sony TC-KA6ES Kao i duplog autoreversnog TC-WR770, koji je inace i prvi dupli dek kojeg posedujem. Uvek sam ih smatrao neozbiljnim napravama i igrackama. Medjutim ovaj me je malo dao u razmisljanje. Prvenstveno nabavljen za delove, jer ima mehaniku zasnovanu na cuvenoj sonijevoj koja se nalazi u svim boljim masinama ovog proizvodjaca. Medjutim iz dosade sam ga servisirao i prijatno se iznenadio njegovim mogucnostima. Sve najbolje u novoj godini i mnogo novih spravica Vam zelim. Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted January 1, 2013 Report Share Posted January 1, 2013 Evo kako izgleda unutrasnjosto Pioneer CTS910...Iako mi je ADF990 najomiljeniji dek, ovaj Pioneer (naravno to se tek odnosi na CTS920 i CT95) su po mom (laickom) misljenju vrhunac...kvalitet upotrebljenih delova, konstrukcija...Podsecaju me po svojoj dual mono konstrukciji na Sony 950-990 seriju... Malo cemo se igrati sa promenom OP-ampa, 910 ima cini mi se samo jedan OP u PB sekciji... Inace, Zoki je skoro extra lepe utiske imao sa CT959, evo nekih osnovnih razlika izmedju 959 i 910: CT-910S and CT-959 have the same playback and recording section. On playback both should have exact the same performance. The are differences in BIAS, 106 KHz for 959 and 210 KHz for 910S. CT-959 calibration is fully manually and for 910S is auto with possibility to overwrite the bias within + or - 20% range. On recording the differences depends on how good calibration is done on 959. I am the owner of a CT-959 deck. CT-93 (best european Pioneer model 1991) is similar to 959 (best european Pioneer 1990 model). Both have exact the same playback and recordig section. The BIAS for CT-93 is 160 KHz and can be set fully manually or auto i jos razlika (sem dolby S) izmedju 95/920 i 910: CT-95/CT-920S is the best deck built by Pioneer with improved design in both rec and playback sections. On playback section can be see the best opamp (at that time) inside of a deck. No other deck from others have a better opamp. Bias frequency is set to 210 KHz and work like in 910S. Lako ce Impuls da promeni op-amp, hahaha. Danas ima vrhunskih op za sicu love. PS ako neko ima viska CTS920, neka se javi El mi moze netko objasniti zasto bakrena folija na odredjenim elementima kad ista nije spojena na nijedan nacin na masu? Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted January 1, 2013 Report Share Posted January 1, 2013 BTW sretns nova!!!! Quote Link to comment Share on other sites More sharing options...
llalla Posted January 1, 2013 Report Share Posted January 1, 2013 BTW sretns nova!!!! Srećna Nova godina dragim forumaÅ¡ima i Äestitke za 200 stranica uživanja! Quote Link to comment Share on other sites More sharing options...
blackjack Posted January 1, 2013 Report Share Posted January 1, 2013 Kad sam bio klinac moja i zelja svih ostalih hi fi klinaca je bila Nakamichi Dragon.Sad moze da se kupi dzabe al vise nikog ne interesuje. Quote Link to comment Share on other sites More sharing options...
drtomaki Posted January 1, 2013 Report Share Posted January 1, 2013 Svim ljubiteljima dekova sretnu Novu Godinu i još puno lepih Hi Fi spravica želi audiofil zvani Lajavi krelac Quote Link to comment Share on other sites More sharing options...
ognjen Posted January 1, 2013 Report Share Posted January 1, 2013 Sretna 2013 god.svim forumasima i 2-stota stranica knjige o DECK-ovima koja ce se jos dugo pisati Quote Link to comment Share on other sites More sharing options...
vlado78 Posted January 1, 2013 Report Share Posted January 1, 2013 SrecnaVam nova godina, ponavljajte se sa kasetama i dekovima kvalitetno u zdravlju. Quote Link to comment Share on other sites More sharing options...
judge Posted January 1, 2013 Report Share Posted January 1, 2013 Bakrena folija služi za eliminiranje EM zraÄenja na pojedine elektroniÄke elemente . Quote Link to comment Share on other sites More sharing options...
uzvarb Posted January 1, 2013 Report Share Posted January 1, 2013 Kad sam bio klinac moja i zelja svih ostalih hi fi klinaca je bila Nakamichi Dragon.Sad moze da se kupi dzabe al vise nikog ne interesuje. Pa da je dzabe i nije. Mozda možeš da ga nadjes dzabe, ako je tako onda si sretnik. Osimm ako ne mislis da je cena od gotovo 1000eur dzabee. E tek si onda sretnik. Quote Link to comment Share on other sites More sharing options...
judge Posted January 1, 2013 Report Share Posted January 1, 2013 dragon dzabe?Dragon teško da se više uopće i može kupiti,a kamoli da ga ima za "dzabe". Quote Link to comment Share on other sites More sharing options...
profesor Posted January 1, 2013 Report Share Posted January 1, 2013 Svim forumasima sretna Nova godina,i da sto pre nabave ono sto zele. Quote Link to comment Share on other sites More sharing options...
sule Posted January 1, 2013 Report Share Posted January 1, 2013 Kad se vec pominje Dragon trenutno se razmisljam o kupovini istog ali neispravnog,nesto sa glavom nije u redu,bar po tvrdnji prodavca mada i on je daleko od Dzabe Quote Link to comment Share on other sites More sharing options...
Pavlaka Posted January 1, 2013 Report Share Posted January 1, 2013 Kad sam bio klinac moja i zelja svih ostalih hi fi klinaca je bila Nakamichi Dragon.Sad moze da se kupi dzabe al vise nikog ne interesuje. Gde to ima za dzabe,oma da odem da zemim bar jedan.Mene mućo zanima! Quote Link to comment Share on other sites More sharing options...
SandroNS Posted January 1, 2013 Report Share Posted January 1, 2013 Svima svako dobro i sve najbolje u novoj 2013. godini, da nas mašine služe, nove da udomimo i još puno stranica u ovoj temi da napišemo! Vezano za Pioneer, meni je želja da nabavim ct-9d,a,x bilo koji od njih a pošto je to malo verovatno, sledeći na listi za odstrel su 910/920/95. Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted January 1, 2013 Report Share Posted January 1, 2013 Bakrena folija služi za eliminiranje EM zraÄenja na pojedine elektroniÄke elemente . Micek ja sam ipak nekakav audio veteran, ali neznam sve....moje pitanje nije bilo za sta sluzi bakar na elementima, nego za sto sluzi, ako nije spojen na masu etc?..... Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted January 1, 2013 Report Share Posted January 1, 2013 Svima svako dobro i sve najbolje u novoj 2013. godini, da nas mašine služe, nove da udomimo i još puno stranica u ovoj temi da napišemo! Vezano za Pioneer, meni je želja da nabavim ct-9d,a,x bilo koji od njih a pošto je to malo verovatno, sledeći na listi za odstrel su 910/920/95. Ima ovdje jedan clan 7x na bubnju pa, ako te zanima.... Quote Link to comment Share on other sites More sharing options...
SandroNS Posted January 1, 2013 Report Share Posted January 1, 2013 Hvala IdlerTire, ipak me devetka zanima, to je potpunija mašina, a7 nema nikakvu kalibraciju. Quote Link to comment Share on other sites More sharing options...
ScepanBG Posted January 1, 2013 Author Report Share Posted January 1, 2013 Hvala IdlerTire, ipak me devetka zanima, to je potpunija mašina, a7 nema nikakvu kalibraciju. Prodavao se jedan CT-A9X kod nas.Mislim da ga je imao kolega Dekofil Bozzam ako ne gresim. Quote Link to comment Share on other sites More sharing options...
ScepanBG Posted January 1, 2013 Author Report Share Posted January 1, 2013 Srecnu Novu Godinu Zelim Svim Dekofilima,zivi bili i ostvarite sve svoje Dekovske zelje . Meni u ponedeljak(najverovatnije) stize Technics RSB-965 . Quote Link to comment Share on other sites More sharing options...
ScepanBG Posted January 1, 2013 Author Report Share Posted January 1, 2013 Kad sam bio klinac moja i zelja svih ostalih hi fi klinaca je bila Nakamichi Dragon.Sad moze da se kupi dzabe al vise nikog ne interesuje. Jeste bio najveca zelja.Dragon ima cenu i ne moze da se kupi za dzabe,ipak je Dragon Dragon.Pogotovo ako je u odlicnom stanju. Quote Link to comment Share on other sites More sharing options...
IdlerTire Posted January 1, 2013 Report Share Posted January 1, 2013 Srecnu Novu Godinu Zelim Svim Dekofilima,zivi bili i ostvarite sve svoje Dekovske zelje . Meni u ponedeljak(najverovatnije) stize Technics RSB-965 . Nisam dugo imao 965... volio bi ga imati ponovo.... Quote Link to comment Share on other sites More sharing options...
