shomi22 Posted June 29, 2021 Report Share Posted June 29, 2021 Angus & Julia Stone - Draw Your Swords sa albuma Down The Way Quote Link to comment Share on other sites More sharing options...
shomi22 Posted June 29, 2021 Report Share Posted June 29, 2021 Tom Petty And The Heartbreakers - Breakdown Quote Link to comment Share on other sites More sharing options...
shomi22 Posted June 29, 2021 Report Share Posted June 29, 2021 Baba Blues - Glimmer of Gold Quote Link to comment Share on other sites More sharing options...
nesone Posted June 29, 2021 Report Share Posted June 29, 2021 Quote Link to comment Share on other sites More sharing options...
NL. Posted June 29, 2021 Report Share Posted June 29, 2021 22 sati ranije, sondek said: Ejs ...pa to nabavi na originalu,vredi svaku paru onim kome nije dojadilo...nekad ke sreca kad kasno cujes za neki CD.Nesto mi se cini da to kod Delije nije bas nekakav snimak bio.Ja sam to imao na CD,i mislim da imam negde jos kopiju sa tog diska na CDr, pa ti mogu poneti da cujes. Već sam bezecovao na Doscogsu vinil u mint stanju, poslao mi je Delija link, samo ga nisam odmah poručio jer neću biti tu, pa ću da poručim čim se vratim Meni se čuo dobro, isto kao kod mene... ali pošto slušam isti materijal kao Delija, moguće da se tvoj cd čuje bolje. U svakom slučaju uporediću kad mi stigne vinyl, pa javljam. btw preko sajta Clearaudia može da se naruči novi vinil https://www.analogshop.de/en/Pop/Rock/Friends-of-Carlotta/LP83035, jedino što izgleda ne šalju u Srbiju Quote Link to comment Share on other sites More sharing options...
NL. Posted June 29, 2021 Report Share Posted June 29, 2021 8 sati ranije, sondek said: ...a Nikola na vinilu pa da slusa ko čovek Quote Link to comment Share on other sites More sharing options...
NL. Posted June 29, 2021 Report Share Posted June 29, 2021 22 sati ranije, Delija said: Ja ga koristim iz razloga koji sam ti pomenuo - meni je cela kolekcija u formatu image + CUE za ripove CD-a, a ISO image za DSD ripove SACD-a. To nijedan drugi server ne podrzava. Pored toga u foobar-u i jako lako skriptujem putanje na kojima se nalaze album cover-i. Instalirao sam Foobar2000, ukapirao sam okvirno kako radi, dodatno sam instalirao dodatak za UPnP browser, server i conntroler. Ali opet ne kapiram kako da otvorim SACD ISO image? Kada idem na open i označim putanju do foldera gde se nalazi, Foobar jednostavno ne vidi ISO fajl... ...negde sigurno grešim? Inače sam uspeo da pokrenem streaming preko Foobara, prepoznaje i Linn DSM i Arcam AVR jer su oba na mreži i bez problema pokreće stream na oba uređaja. Ali kao što si već napisao, nema razloga da muziku puštam iz Foobara, već on samo treba da "servira" egzotične formate Kazoo plejeru koji koristim za Linn ili MusicLife-u za Arcam. Quote Link to comment Share on other sites More sharing options...
Delija Posted June 29, 2021 Report Share Posted June 29, 2021 I za SACD ISO (kao i za DSDIFF, DSF i DSD fajlove) ti treba plugin: https://sourceforge.net/projects/sacddecoder/ Mozes da stream-ujes direktno iz foobar-a tako sto gadjas neki renderer (Linn, Arcam) - tada ga koristis kao obican plejer sa odgovarajucim output device-om ili da podignes UPnP server. Za ovo drugo ti treba ovaj plugin - koji si po napisanom vec skinuo: https://www.foobar2000.org/components/view/foo_upnp Onda koristis UPnP aplikaciju za tvoj Linn/Arcam ili BubbleUPnP i za library izaberes foobar. Fino je organizovano - imas pristup svim playlist-ama i media library-ju (koji treba da podesis - koje foldere i tipove fajlova da ukljuci) po albumima / izvodjacima / folderima... Album arts kako podesis u foobar-u kada radi kao plejer vidi i UPnP server. Napomena: kada menjas playlist-e ili nesto u media library-ju da bi ih refresh-ovao UPnP server (ili foobar) mora da se restartuje. Nazalost, ta foobar komponenta je ostala u beta fazi i abandonware je jos od 2015. godine, a niko to nije preuzeo u medjuvremenu da odrzava. I kao takav je sasvim ok - ima samo par nedostataka i bug-ova. Quote Link to comment Share on other sites More sharing options...
Delija Posted June 29, 2021 Report Share Posted June 29, 2021 A mozda ti je bolje da ISO fajl podelis na pojedinacne track-ove u DSDIFF / DSF / DSD formatu. Njih vecina UPnP/DLNA servera zna da host-uje. Ovaj programcic moze da posluzi za to: https://www.sonore.us/iso2dsd.html Quote Link to comment Share on other sites More sharing options...
misko1989 Posted June 29, 2021 Report Share Posted June 29, 2021 mozda takodje koristan link ako se koristi foobar: https://www.monkeymote.com/home Quote Link to comment Share on other sites More sharing options...
garson Posted June 29, 2021 Report Share Posted June 29, 2021 Ako moze da pusti DSD fajlove, po meni je to way to go. DSF podrzava i ID3 v2 tagove. Posto mahom slusam cele albume, SACD ISO fajlove konvertujem u single DFF fajl, pa kompresujem u (single) Wavpack DSD (kompresija je preko 50%). I to super sljaka sa cue fajlom, a wavpack podrzava i APE tagove. Quote Link to comment Share on other sites More sharing options...
NL. Posted July 1, 2021 Report Share Posted July 1, 2021 Prvo sa se zahvalim svima na dodatnim sugestijama i pomoći. Instalirao sam Foobar, radi kao mi server, moj strimer ga “vidi”, mogu da ga koristim prakticno umesto Minim i Kazoo servera, radi bez greške… jedino što su mi pomenuta dva servera podignuta na NAS-u i rade non-stop, a Foobar je vezan za PC. Ali sve jedno, Ok mi je i to, ako želim da slušam SACD snimke. Međutim, i pored upornog pokušavanja da izmenim sva moguća podešavanja, Foobar mi pretvara SACD ISO u 192/24 WAV i tako ga šalje strimeru. Pokušao sam sa raznim ISO-ima, isto se dešava. Zvuk je dobar, ali me nervira što nije DSD (DSF) fajl. Sa druge strane, iso2dsd radi super, kada sve raspakujem ove fajlove vide i moji stari serveri. Ali sam primetio nešto sto me je smorilo - ovako pripremljeni dsd fajlovi imaju jako naglašeno bas područje, kao kada u svom sistemu ne uključim DSP (space optimisation). Zatim sam krenuo malo da čitam po forumima, kažu da na Linn strumerima ne radi space optimisation kada se reprodukuju dsd fajlovi Sad sam u ćorsokaku… Quote Link to comment Share on other sites More sharing options...
Iron man Posted July 1, 2021 Report Share Posted July 1, 2021 Quote Link to comment Share on other sites More sharing options...
Delija Posted July 1, 2021 Report Share Posted July 1, 2021 5 sati ranije, NL. said: Prvo sa se zahvalim svima na dodatnim sugestijama i pomoći. Instalirao sam Foobar, radi kao mi server, moj strimer ga “vidi”, mogu da ga koristim prakticno umesto Minim i Kazoo servera, radi bez greške… jedino što su mi pomenuta dva servera podignuta na NAS-u i rade non-stop, a Foobar je vezan za PC. Ali sve jedno, Ok mi je i to, ako želim da slušam SACD snimke. Međutim, i pored upornog pokušavanja da izmenim sva moguća podešavanja, Foobar mi pretvara SACD ISO u 192/24 WAV i tako ga šalje strimeru. Pokušao sam sa raznim ISO-ima, isto se dešava. Zvuk je dobar, ali me nervira što nije DSD (DSF) fajl. Sa druge strane, iso2dsd radi super, kada sve raspakujem ove fajlove vide i moji stari serveri. Ali sam primetio nešto sto me je smorilo - ovako pripremljeni dsd fajlovi imaju jako naglašeno bas područje, kao kada u svom sistemu ne uključim DSP (space optimisation). Zatim sam krenuo malo da čitam po forumima, kažu da na Linn strumerima ne radi space optimisation kada se reprodukuju dsd fajlovi Sad sam u ćorsokaku… Foobar UPnP plugin-ovi ne podrzavaju native DSD - ali i da podrzavaju, imao bi isti problem sa Linn-om i SO. Zaboravih da ti pomenem to - jer meni to nije bitno Devialet podrzava DSD samo preko Roon-a ili USB-a, sto ne koristim, a u svakom slucaju ne podrzava native DSD i radi internu konverziju u PCM (384/40), tako da se nisam time ni zanimao. Saljem mu PCM 176.4/24 i to dobro radi. A sto se tice tog "problema" sa Linn-om - to je u neku ruku i dobro, jer govori da najverovatnije ne radi internu konverziju u PCM i da zbog toga ne moze da primeni DSP. Sa druge strane ti to pravi problem - jer je to kod tebe skoro pa neupotrebljivo Za sada ce ipak biti PCM, rekao bih... Quote Link to comment Share on other sites More sharing options...
NL. Posted July 1, 2021 Report Share Posted July 1, 2021 Uz izvinjenje kolegama na off-u u prethodnim porukama, evo da predstavim veoma zanimljiv materijal koji slušam ovih dana! Quote Link to comment Share on other sites More sharing options...
Klops Posted July 2, 2021 Report Share Posted July 2, 2021 Odlican album.Svaka preporuka Quote Link to comment Share on other sites More sharing options...
shomi22 Posted July 3, 2021 Report Share Posted July 3, 2021 Beck - Paper Tiger Quote Link to comment Share on other sites More sharing options...
shomi22 Posted July 3, 2021 Report Share Posted July 3, 2021 John Campbell - Down In The Hole (Written By Tom Waits) sa albuma Howlin Mercy Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted July 4, 2021 Report Share Posted July 4, 2021 Quote Link to comment Share on other sites More sharing options...
Father Posted July 4, 2021 Report Share Posted July 4, 2021 https://tidal.com/browse/album/22955031 Quote Link to comment Share on other sites More sharing options...
nesone Posted July 5, 2021 Report Share Posted July 5, 2021 Svima zelim da otputuju u 2021. Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted July 10, 2021 Report Share Posted July 10, 2021 Quote Link to comment Share on other sites More sharing options...
Mosi Posted July 11, 2021 Report Share Posted July 11, 2021 Preporuka za Industrial music? Quote Link to comment Share on other sites More sharing options...
shomi22 Posted July 12, 2021 Report Share Posted July 12, 2021 Joe Bonamassa, Tommy Emmanuel & Josh Smith https://youtu.be/s78WCIJD734 Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted July 12, 2021 Report Share Posted July 12, 2021 Nenoguce naci na vinilu Farm is a blues/psychedelic/southern rock band from Mt. Vernon, Illinos, USA, that was formed in 1969. The band split up in 1973. sjajna muzika. Quote Link to comment Share on other sites More sharing options...
