uzvarb Posted November 29, 2009 Author Report Share Posted November 29, 2009 @gvlada Maticna MSI K9N Neo V2 nvidia nForce 520 chipset AMD Athlon X2 4000+ sa hladnjakom cooler master Gemin II 4GB RAM memorije HDD WD 160 GB Graficka ATI HD4870 Zvuk 7.1 integrisan DVD LG rezac Klasicno napajanje 500w Wnidows 7 Svi ventilatori usporeni keramickim otpornicima 82 oma 9W osim procesorskog koji hladi i chipset sa 41 om. Sve je vrlo tiho i prakticno je najglasniji hard. P.S. sa novim drajverima bi i stream trebao da radi preko hdmi kabla. Probao sam na brzaka i dobio DTS ES i Dolby digital. Stereo odavno radi. Ali mi samo malo vremena fali. Ako ne uspe nabavicu neku bolju zvucnu. Quote Link to comment Share on other sites More sharing options...
Zvuchniak Posted November 29, 2009 Report Share Posted November 29, 2009 nabavicu neku bolju zvucnu Ovo i mene uskoro Äeka... Quote Link to comment Share on other sites More sharing options...
gvlada Posted November 29, 2009 Report Share Posted November 29, 2009 Max za HD4xxx je stereo, DD&DTS bitstream i 7.1 LPCM. Samo HD5xxx moze raditi bitstream HD zvuka. Za filmove to je vrh.. Za muziku sa kompa ili nesto poput Xonar Essence STX ili ext DAC. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted November 29, 2009 Author Report Share Posted November 29, 2009 Max za HD4xxx je stereo, DD&DTS bitstream i 7.1 LPCM. Samo HD5xxx moze raditi bitstream HD zvuka. Za filmove to je vrh.. Za muziku sa kompa ili nesto poput Xonar Essence STX ili ext DAC. Hvala na informacijama. Ja bi najradije onu varijantu sto je spomenuo siroma usb>spdif>avr Quote Link to comment Share on other sites More sharing options...
gvlada Posted November 30, 2009 Report Share Posted November 30, 2009 Pa ta varijanta je za muziku, do ext DAC. Ne znam da li bi mogao da propustis DD&DTS kroz to. 7.1 LPCM ionako moze samo kroz HDMI, HD audio jedino krzo HDMI 1.3. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted November 30, 2009 Author Report Share Posted November 30, 2009 Da znam za muziku i mislim. Sto se tice MKV on ima ili DD ili DTS ali ionako ce to biti konvertovano i reprodukovano u 90% slucajeva sa blu ray plejera. Tako da me to ne opterecuje mnogo. Ovih dana cu se igrati malo sa hdmi vezom izmedju hd4870 i AVR pa cu javiti kako to zvuci. Quote Link to comment Share on other sites More sharing options...
gvlada Posted November 30, 2009 Report Share Posted November 30, 2009 Sto se tice muzike Xonar Essence STX zvuci bolje nego DAC u AVR te klase. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 13, 2009 Author Report Share Posted December 13, 2009 Probao sam da izeksperimentisem sa analognom vezom i preko HDMI za zvuk. Analogna je eto da ima zvuka. Nista narocito, najveca falinka je u bas obsegu. Vrlo tanko zvuci. A visoki tonovi reski, srednji jos i boze pomozi. E onda sam povezao grafiku i zvik sa HDMI vezom. Zvuk je postao daleko bolji, bolje receno neuporedivo bolji, ali se javio stari problem sa slikom. Isti se manifestuje sa osetnim poboljsanjem slike kada je u pitanju video, fotosi ama sve osim fonta. Pisao sam o tome vec ranije. I sta god podesavao i stelovao isti djavo. E onda ni je sinula ideja da sliku prosledim klasicnim VGA kablom a zvuk sa HDMI sa drugog prikljucka graficke. Kao da su dva monitora povezana a ustvari oba kabla zavrsavaju u istom, jedan na vga drugi hdmi. To je radilo super ako se izuzme komplikovanost upotrebe. I nakraju sam skontao da ploca ima s/pdif konekciju ali samo u vidu dve iglice koje strce sa iste. Znaci ima mesto za konektor koji bi ga odveo do cinca kojeg nema. Iz nrkog starog DVD plejera sam iscupao konektor zenski cije rastojanje je odgovaralo razmaku pinova na ploci, skratio ga po sirini da ima samo 2 kontakta na koje sam direktno zalemio jedan kraj interkonekta kojem je skinut muski cinc. U podesavanjima podesio kao playing device S/PDIF i sve je proradilo. Zvuk je isti. Kao i sa hdmi vezom, prosledjuje i DD i DTS. Dovoljno. Podrzava sve do 192 khz 24 bit. E sad ostaje da se sacekaju noviji drajveri koji ce resiti zezanciju sa fontom. Pozdrav. Quote Link to comment Share on other sites More sharing options...
gvlada Posted December 13, 2009 Report Share Posted December 13, 2009 Ima li tvoj tv uopste 1:1 pixel mapping? Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 14, 2009 Author Report Share Posted December 14, 2009 @gvlada Ima, ali uopste ne mogu da skontam sta se desava. Cak je i moj kum, koji me je gledao kao ludaka dok sam mu objasnjavao problem, rekao daj ja cu srediti. E posle sat vremena digao je ruke. Rezolucija tv je 1366x768 (hd ready) znaci probao sam i 720p i 1080i i isti djavo. Quote Link to comment Share on other sites More sharing options...
gvlada Posted December 14, 2009 Report Share Posted December 14, 2009 Jedini nacin je da izaberes 1360x768 ako zelis 1:1. 720p ili 1080p uvek idu kao skaliranje. Mozda u custom mozes namestiti rez od 1368x768 i da gubis 2 pixela (po 1 sa strane) tj ne vidis nego da imas po 3 pixela koja su crna. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 14, 2009 Author Report Share Posted December 14, 2009 Hm. Da sve je ok dok je vga kabl u upotrebi. Medjutim kad je hdmi veza nema podesavanja rezolucije. Ima samo hd standardi. Nista kad budem imao vremena novi eksperimenti. Izasli su i novi driveri za grafiku pa cu probati. Pozdrav. Quote Link to comment Share on other sites More sharing options...
gvlada Posted December 14, 2009 Report Share Posted December 14, 2009 Koji OS koristis? Vec sam ranije postovao ali ja preko HDMI mogu izabrati mnogo razlicitih rezolucija. Quote Link to comment Share on other sites More sharing options...
Golum Posted December 14, 2009 Report Share Posted December 14, 2009 Pozdrav i hvala na komentarima. AVR se greje malo vise nego sto bi to bilo ocekivano , ali nista alarmantno, ocigledno su mu zvucnici legli ko budali samar...ustvari kad sam ga pratio da vidim koliko je zagrevanje primetio sam da se izlazni stepen skoro i ne greje. Glavni izvor grejanja potica sa sasvim druge strana AVR-a i to sa zadnje desne strane gledano sa spreda, gde se nalaze HDMI ulazi i izlazi, tu se u dnu nalazi poveci hladnjak koji se greje daleko vise od onog na kome se nalaze izlazni tranzistori. Sve sam ovo pratio bez otvaranja uredjaja tako da nisam kroz rebra bas najbolje osmotrio cemu sluzi deo koji se greje. Cak i posle celodnevnog rada kad zavucem ruku izmedju AVR-a i cd-a nije temperatura alarmantna. Malo da se vratim unazad po pitanju postova cisto informacije radi - u tom zadnjem desnom delu ti se nalazi procesor za procesiranje/obradu slike mislim da je u tvom slucaju Farudja (u mom Reon) koji se poprilicno greje u toku rada. Inace sistem ti je ! Uzivaj i pozdrav; G. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 15, 2009 Author Report Share Posted December 15, 2009 @gvlada Koristim Windows 7 @golum Hvala. Predpostavio sam da je to u pitanju. Mnogi se zale na grejanje Onkyoa ,medjutim uopste nema problema. Al da se ne ponavljam pricao sam o tome. Uglavnom kod mene je u zadnje vreme u upotrebi po ceo dan. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted April 18, 2010 Author Report Share Posted April 18, 2010 Pozdrav forumasima, evo nekih izmena u mom sistemu. Iako sam mislio da do istih nece dolaziti duzi vremenski period. Jednostavno nisam mogao da odolim. Novina su dve stvari, odnosno tri. Novinu predstavlja AV risiver, CD player i naprave koje sam napravio za upijanje zvuka. (apsorberi). Risiver koji je zamenio Onkyo-a je Sony STR-VA555ES. Zasto bas taj, razlog je to sto vec sigurno 10 god ima od kad sam blenuo u sony katalog gde je ovaj risiver bio top model. Znaci lecenje neceg od ranije. E sad kako on radi u odnosu na Onkyo je prosto neverovatno. Daleko bolja kontrola zvucnika, sa stereo slikom koja je daleko realnija. Iskreno iznenadila me je pozitivna promena. Sa obzirom da sam imao vrlo gadno iskustvo sa jednim sony risiverom u zvucnom smislu (str-de675) zbog kojeg sam i kupovao Onkyo. 555ES svira definitivno bolje i od integrisanog pojacala koje sam posedovao (onkyo integra A-8870). E ovom promenom je poceo da strci cd player Onkyo integra DX-6870 koji je siri od ostalih komponenata za nepunih 2 cm. U ponudi sam imao CDP-X333ES i CDP-557ESD. Posle vise casovnog uporedjivanja Onkyo-a i oba sony-a odluka je pala na X333ES. Najbolji je definitivno bio 557ESD koji jednostavno ostavlja iza sebe oba plejera, medjutim sta je prevagnulo na stranu 333ES... Jednostavno uredjaj je noviji (laser manje potrosen samim tim) besprekorno ocuvan bez i najmanje tackice na sebi, uzet od prvog vlasnika, i nadsvirao je onkyo. Ovom nisam mogao da se nacudim ali usi ne lazu, bas daleko nize svira, a visoki tonovi prirodniji i detaljniji. Ovo mi je bilo dovoljno , znaci ima pomaka na bolje. 557ESD svira bolje od 333, ali nisam siguran da li je vredno dati jos toliko novca za tu razliku. Mada bio sam spreman uzeti ga, i po njega sam i otisao, ali njegovo fizicko stanje je bilo dosta losije od ove trojke. Ko zna mozda se i predomislim.... Apsorbere sam napravio kad sam shvatio da jos uvek u sobi postoji odjek duzi nego sto bi trebalo. Napravljeni su od stiropora 10cm debljine ,koji je rezan ugrejanom cekas zicom. Izrezane oblike sam polepio na stiropor od 1 cm i kad se sve osusilo ofarbao bojom za beton na vodenoj bazi. Namera mi je bila napraviti 4 ovakva apsorbera ali sam se zaustavio posle 2 jer je i 1 toliko smanjio odbijanje da je to neverovatno. Postavio sam ih na mesta gde imam velike povrsine zida paralelne sa drugim zidom, a da na njima nema nicega sto bi upilo odbijeni zvuk. Jednostavan eksperiment udaranja dlanom o dlan detektuje ta mesta. evo malo slicica.. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted May 3, 2010 Author Report Share Posted May 3, 2010 Stigla zamena za X333es... Quote Link to comment Share on other sites More sharing options...
Golum Posted May 3, 2010 Report Share Posted May 3, 2010 Sve vrlo cool . Ja se licno kod tih Sony spravica lozim na fosne sa strane i zao mi je sto ih kod tebe nema. Mislim da bi ti to vizuelno doprinelo mnogo ali i ovako je OK . Poz., G. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted May 3, 2010 Author Report Share Posted May 3, 2010 Ma fosne su poseban gust, ali risiver i dat su stigli bez njih. Na X555ES su bile, ali sam ih skinuo zbog uklapanja u sistem i prebacio na X333ES koji je otisao zajedno sa njima. Nije iskljuceno da cu angazovati nekog da mi po meri napravi iste za sve uredjaje. Quote Link to comment Share on other sites More sharing options...
Golum Posted May 3, 2010 Report Share Posted May 3, 2010 Ma fosne su poseban gust, ali risiver i dat su stigli bez njih. Na X555ES su bile, ali sam ih skinuo zbog uklapanja u sistem i prebacio na X333ES koji je otisao zajedno sa njima. Nije iskljuceno da cu angazovati nekog da mi po meri napravi iste za sve uredjaje. to mi reci!! Pogledaj kod tovarisa Gerchy-a kako cuce fosne na nekom uredjaju koji ima konture kao tvoj receiver - vrlo su lepo legle. Kod njega mislim da ima i spisak koje fosne se kombinuju sa kojim uredjajem, a u svakom slucaju neki majstor moze da ti odradi to vrlo lepo ako ne nadjes originale. Poz., G. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted May 3, 2010 Author Report Share Posted May 3, 2010 Gerchy-jev sistem je izuvanje iz nanula...Video sam kako su na Bly Ray player sele od mini disc-a, ko dupe na nonu. Covek koji mi je pravio zvucnike moze to odraditi bez problema. Samo da se finansijski oporavim od poslednjih kupovina, moram i policu resavati....nikad dosadno i nikad kraja... Quote Link to comment Share on other sites More sharing options...
pekka68 Posted May 5, 2010 Report Share Posted May 5, 2010 to mi reci!! Pogledaj kod tovarisa Gerchy-a kako cuce fosne na nekom uredjaju koji ima konture kao tvoj receiver - vrlo su lepo legle. Kod njega mislim da ima i spisak koje fosne se kombinuju sa kojim uredjajem, a u svakom slucaju neki majstor moze da ti odradi to vrlo lepo ako ne nadjes originale. Poz., G. Ja sam uvek za originale. Sony "fosne" na e-bay-u znaju da kostaju od 60-80 eura, u zavisnosti za koji uredjaj su namenjene. Uzvarb, nadam se da si postigao dobru cenu za 333 ES, nakon sto si mu montirao "fosne". Quote Link to comment Share on other sites More sharing options...
uzvarb Posted May 5, 2010 Author Report Share Posted May 5, 2010 Uzvarb, nadam se da si postigao dobru cenu za 333 ES, nakon sto si mu montirao "fosne". X555ES sam uzeo od istog coveka od kog sam uzeo i X333ES ,a on se opet i vrato istom vlasniku, posle svega moze se reci da je bio kod mene na probi, a to je moj dobar drugar tako da su fosne otisle vise kao gratis ...nek stoje na cd-u bolje nego iza mog ormara Quote Link to comment Share on other sites More sharing options...
uzvarb Posted May 30, 2010 Author Report Share Posted May 30, 2010 U sistemu ima promena, godine zelje za ovim zvucnicima su se zavrsile. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted June 5, 2010 Author Report Share Posted June 5, 2010 Pozdrav svima... Proslo je neko vreme od kad je doslo do promene zvucnika, onomad sam samo okacio slike i vratio se 16 casovnom trovanju muzikom dnevno. Sad sam malo ohladio glavu , preslusao gomile muzike na njima pa mogu i koju rec napisati o tome. U pitanju su Visaton zvucnici, model je VOX 252. Iste je napravio Sava Velikinac iz Ravnog Sela. Vecini na forumu je poznato da on izradjuje zvucnike po Visaton projektima, i naravno svojim licno. Kako to radi zna se VRHUNSKI sto je u vise navrata i dokumentovano na forumu. Zvucnici koje sam posedovao do skoro su takodje bili njegov rad, kao i oni pre njih... VOX 252 je podnostojeca trosistemska bas reflex kutija sa bas zvucnikom postavljenim sa strane, ova koncepcija ima svoje mane i prednosti. Prednost je ta sto je omogucena manja povrsina prednje ploce, samim tim i olaksano pozicioniranje u prostoru. Mane su jer zahteva nize secenje na skretnici sto automatski zahteva skuplju skretnicu i kvalitetne mid/bas drajvere. Ova koncepcija, odnosno bilo koja, a da nije bas napred se pokazala kao odlicna u mojoj sobi. Akustika moje prostorije je cudna i sa bas drajverom postavljenim na prednjoj ploci tacno na mestu slusanja dogadjaju se neprijatne pojave po usi...Probao sam i Quadral AURUM 9 koji ima 2 bas zvucnika sa zadnje strane zvucnika i ovo je takodje postiglo odlicne rezultate. Za ove zvucnike sam se odlucio iz vise razloga od kojih je i glavni resavanje problema sa bas opsegom na mestu slusaoca, izgled, i cena koja je smesna u odnosu na onu koju je potrebno dati za fabricki gotove kutije ovih zvucnih kvaliteta. Tehnicke karakteristike preuzete sa sajta su: Rated power 200 W Maximum power 350 W Nominal impedance Z 4 Ohm Frequency response 28 - 25000 Hz Mean sound pressure level 84 dB (1 W/1 m) Cut-off frequency 200 / 3000 Hz Principle of Housing Bassreflex Net volume 70 l + 4 l Outer dimension height 1150 mm Outer dimension width 235 mm Outer dimension depth 400 mm Neko ce primetiti odmah osetljivost od 84dB, zvuci malo, medjutim u praksi ja ne primecujem ikakve probleme. Cak za isti nivo jacine zvuka sa prethodnim kutijama pot stoji na manjoj poziciji. Naravno da je to delimicno i zbog impedanse koja je ovde 4 a na prethodnim 8 Ohm. Zvucnici su finisirani prirodnim furnirom i to Mazerom Italijanskog Pticijeg Javora. U principu to je prirodan furnir dobijen na vestacki nacin, sta ovo znaci i tacnu proceduru oko toga mozda neko drugi moze detaljnije da opise. Zvuk u odnosu na zvucnike koje su zamenili je bolji naravno ,mada ima i mana... Poboljsanje se najvise primeti u bas opsegu koji je sad cvrsci i definisaniji, Dubina je podjednaka, ali je na prethodnicima nedostajala ta energija koju poseduju VOX, mada sto je cudno u drugim prostorijama nije tako. Ali lakse je zameniti zvucnike nego zivotni prostor. Srednjetonsko i visokotonsko podrucje je bilo bezkompromisno na obe zvucne kutije, Sviraju one razlicito i cisto je stvar ukusa kome ce sta lezi. I na jednoj i drugoj su za ovaj posao bili zaduzeni vrhunski Visaton drajveri tako da je i rezultat vrlo slican. VOX svira malo ugladjenije i izbalansiranije od prethodne kutije, dok je ona imala direktniji zvuk, za trunku cistijih visokih ( verovatno zbog ribona ) koji je podsecao na monitorski. Meni i mojim usima odgovara vise VOX i zato je i tu. Sto se tice mana nisu vezane za zvuk nego boju, sad me zena tera da kupim nov stolic koji ce se uklopiti u boju novih zvucnika Za dogledno vreme zamenama zvucnika je dosao kraj, ima boljih zvucnika od ovih naravno, ali ove u potpunosti zadovoljavaju moja ocekivanja u svim oblastima koje se traze od njih. Moguce je u dogledno vreme neki snagas koji bi nakacio na pre outs od risivera za njih, mada otom potom. Ima ovaj SONY snage podosta i bez problema se bori sa VOX-om. Za neke clanove foruma znam da su ih slusali kod Save na Boulder amp i pretpojaÄalu PS Audio sa x555es cd plejerom. Njihova misljenja i sugestije su dobro dosi. Za kraj link ka fabrickom sajtu i jos par slicica. http://www.visaton.de/en/bauvorschlaege ... index.html Quote Link to comment Share on other sites More sharing options...
