acazr Posted June 5, 2010 Report Share Posted June 5, 2010 Furnir je cista avangarda. Quote Link to comment Share on other sites More sharing options...
ska62 Posted June 5, 2010 Report Share Posted June 5, 2010 Finiš im je strava . Quote Link to comment Share on other sites More sharing options...
uzvarb Posted June 5, 2010 Author Report Share Posted June 5, 2010 Hvala. Uzivo izgleda mnogo bolje. Slika to bas ne moze verno da prenese. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted June 23, 2010 Author Report Share Posted June 23, 2010 Nije neka high end polica, ali se suprodstavlja sili gravitacije...ne klima se.. Kombinacija metal staklo, moze i peskom da se napuni, sto ja nisam uradio jer sam gledao da je sto pre postavim..pa da mogu . Sve u svemu u odnosu na cenu je ,a i bolja je od onih betonskih blokova. Pozdrav... Quote Link to comment Share on other sites More sharing options...
uzvarb Posted July 5, 2010 Author Report Share Posted July 5, 2010 Betonski blokovi ponovo u akciji, ovaj put na sebi nose mrcinu od 26kg. Sony TA-N80ES. Prikacen na izlaze predpojacala sa av risivera i pogoni prednje zvucnike. Poboljsanje je vise nego ocigledno. Svetliji zvuk za nijansu koji je davao sam risiver je nestao, dinamika se poboljsala. Sve u svemu vrlo snazno pojacalo koje kontrolise Visatone bez po muke. Quote Link to comment Share on other sites More sharing options...
Melvin Posted July 5, 2010 Report Share Posted July 5, 2010 Sony ES ergela se umnozava, nice Quote Link to comment Share on other sites More sharing options...
Lines Posted July 6, 2010 Report Share Posted July 6, 2010 Milina za oci, a verujem i za usi Quote Link to comment Share on other sites More sharing options...
uzvarb Posted July 6, 2010 Author Report Share Posted July 6, 2010 Hvala, umnozava se postepeno. Raste i napreduje zvucno svakom novinom. Sad sam stvarno ekstra zadovoljan i sto se tice novih dodataka bice u pogledu komponenata koje nedostaju u sistemu. Pozdrav.. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted July 18, 2010 Author Report Share Posted July 18, 2010 Pozdrav svima. Evo da rezimiram ceo sistem koji je trenutno u aktivan. Ima manjih promena , ali o tome usput. Prvo tu je Akai CD-57 koji mi sluzi iskljucivo za reprodukciju CD-RW medija. Zatim Risiver STR-VA555ES koji pogoni centralni i surround kanale. Za prednje je u funkciji Preampa. Tu su i neizbezan DAT DTC-55ES i Blu ray player BDP-S550 Za kasete je trenutno zaduzen TC-K561S dok se upgrade za njega kompletira. O tome ako zazivi... CD plejer je CDP-X555ES Eksrtra masina.... Mini disk je slabiji model al meni veoma drag jer sam prvi vlasnik od sad vec davne 1998godine, radi perfektno i bez greske do dan danas. MDS-JE520 E sad novina...na cokoladni kolac ( crne komponente ) najbolje leze beli slag...Konacno i gramofon Technics SL-3300 Glava je Stanton 5xx neznam tacno koja , otpala nalepnica...ako je neko prepoznaje nek napise da znam sta imam... Zbog vec manjka mesta jos jedna polica je morala da ugosti kompjuter u Thermaltake kucistu DH-101...ko god ga vidi kaze sta ceti 2 risivera..... Snagu za pokretanje Visaton VOX252 zvucnika isporucuje Sony TA-N80ES Leva strana sistema na kojoj se vidi i aktivni sub Jamo SW-410E. Koji radi samo za filmove, i stereo rezimu nema sta da trazi, ne zato sto je los nego pored visatona.....smesno je i objasnjavati.... I na kraju jedna fotka kompletne skalamerije.... Eto to je otprilike to sad cu da se smirim malo, neko vreme . Bar se nadam da hocu. Ono sto 100% nece ici iz sistema je VOX252, ali nema sanse, kao ni CD , isto se odnosi i na snagasa. Pozdrav svima svaki komentari i sugestije su dobro dosli. Ja sad odoh da uzivam u .... Quote Link to comment Share on other sites More sharing options...
gvlada Posted July 18, 2010 Report Share Posted July 18, 2010 Sistem je odlican, u zdravlje da se sluzis Pitanje jer sad imas bolji signal za kablovsku jer ti D3 na posebnim podloscima? Jedino da, ipak, zamenis tv. Pored ostatka sistema deluje kao da si komp monitor nakacio na zid. Koliko si udaljen od zida? Quote Link to comment Share on other sites More sharing options...
uzvarb Posted July 18, 2010 Author Report Share Posted July 18, 2010 Pa nekako mi se cini da je crna malo crnja, a bela malo pocinje da bledi.... sala, naravno to su nogice od rashodovanog deka ,a tu su samo zbog ventilacije oba uredjaja. Daljina gledanja varira kad je komp u upotrebi tj. kad tv radi kao monitor oko 1,5 metara . A varijanta tv/video je oko 2,70 do 3 metra zavisi koju pozu zauzmes Quote Link to comment Share on other sites More sharing options...
gvlada Posted July 18, 2010 Report Share Posted July 18, 2010 Tu ce 50" da legne bez problema Nemam kuci ali sam kod rodjaka uporedjivao. 3m je taman Quote Link to comment Share on other sites More sharing options...
uzvarb Posted July 18, 2010 Author Report Share Posted July 18, 2010 Slazem se sa tobom u potpunosti. Cak i 42ka bi bila bolja. Zasad mora ovako da ostane....ako donesem nov tv kuci prelicu casu i WAF faktor ce preuzeti maha....ovako jos sve drzim pod kontrolom . Znas ono u jednoj ruci gramofon, a u drugoj sandale....a za tv neznam kako bi prosao... Quote Link to comment Share on other sites More sharing options...
gvlada Posted July 18, 2010 Report Share Posted July 18, 2010 Onog trenutka kad bi joj pustio omiljenu seriju u HD formatu, trust me, bili bi svi zadovoljeni Quote Link to comment Share on other sites More sharing options...
uzvarb Posted July 18, 2010 Author Report Share Posted July 18, 2010 Dobra tehnika...iskusno... nema sta , ne bih se toga setio. U svakom slucaju to ce i zbog finansija malo da saceka. I HD ready radi posao zasad. A za kasnije cemo vec smisljati neke ludosti. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted October 12, 2010 Author Report Share Posted October 12, 2010 Stigla je nova masina DAT DTC-59ES. Nije namena da zameni vec postojeci DTC-55ES nego da se on rastereti. S' obzirom da mi je DAT jedan od omiljenih formata moram se na vreme obezbediti....jer ipak se vrte svakodnevno. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 18, 2010 Author Report Share Posted December 18, 2010 S' obzirom da je sad i zvanicni deo sistema , da dodam i njegovu sliku...K970ES Quote Link to comment Share on other sites More sharing options...
civi Posted December 18, 2010 Report Share Posted December 18, 2010 Imamo maltene isti dat , el mozes da ga slikas otvorenog poz Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 19, 2010 Author Report Share Posted December 19, 2010 Imamo maltene isti dat , el mozes da ga slikas otvorenog poz Cu da ga slikam, sto necu. Slikaj i tvoju makinu pa da uporedimo dzigerice. Trebali bi da se razlikuju samo po koaksijalnom konektoru viska kod mog.... Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 19, 2010 Author Report Share Posted December 19, 2010 Evo ga DTC-59ES razgolicen, posle cu staviti i 55ES da se vidi razlika. Ali prvo da Civi stavi svog radi poredjenja. Quote Link to comment Share on other sites More sharing options...
civi Posted December 19, 2010 Report Share Posted December 19, 2010 Nemam objektiv da nakacim na alphu moraces da pricekas par dana al odokativno je to to Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 19, 2010 Author Report Share Posted December 19, 2010 Nemam objektiv da nakacim na alphu moraces da pricekas par dana al odokativno je to to No problemo. Quote Link to comment Share on other sites More sharing options...
edvard Posted December 19, 2010 Report Share Posted December 19, 2010 @gvlada Koristim Windows 7 @golum Hvala. Predpostavio sam da je to u pitanju. Mnogi se zale na grejanje Onkyoa ,medjutim uopste nema problema. Al da se ne ponavljam pricao sam o tome. Uglavnom kod mene je u zadnje vreme u upotrebi po ceo dan. onkyo ima problem imaju lose trimere za stelovanje struja.Tokom prenosa i tumbanja lako se rasteluju i zato se i greju posle.to nije nikakav problem srediti.Skines service manual za dati uredjaj,unimer u ruke i za deset minuta gotov posao:-) Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 19, 2010 Author Report Share Posted December 19, 2010 onkyo ima problem imaju lose trimere za stelovanje struja.Tokom prenosa i tumbanja lako se rasteluju i zato se i greju posle.to nije nikakav problem srediti.Skines service manual za dati uredjaj,unimer u ruke i za deset minuta gotov posao:-) Moj Onkyo je odavno otisao iz mog sistema, i nije se grejao, imao je izgleda srece pri transportu. Zamenio ga je VA-555ES koji je zvucno kilometrima ispred Onkyo-a ( naravno mog modela ), grejao se on ili ne. Dekoderi koje poseduju moderni risiveri su prolazna stvar. Bitno je postojanje multi kanalnih ulaza ( analognih ), u ovom slucaju podrzava 7.1 na njih direkt iz plejera ili ext. dekodera koji je u trenutnoj modi ,i znaci ne zaostaje za onkyom. VA555ES bolje zvuci sa dolby digitalom od hd mastera na onkyo-u. A o stereo reprodukciji nema govora. Interesantno je da TAN80ES nije promenio skoro nista u zvuku, neverovatno je neutralan, ali je zato snagu podigao visestruko, a tim i kontrolu zvucnika. Pozzz... Quote Link to comment Share on other sites More sharing options...
Koko Bil Posted December 21, 2010 Report Share Posted December 21, 2010 S' obzirom da je sad i zvanicni deo sistema , da dodam i njegovu sliku...K970ES Iako su ti i ostale igraÄke lepe, ova mi se najviÅ¡e sviÄ‘a! Quote Link to comment Share on other sites More sharing options...
