Delija Posted December 18, 2005 Report Share Posted December 18, 2005 Vrlo uskoro druze... Za koji dan... U fazi sam sredjivanja prikupljenog materijala. "Nocas" sam do 8 zaglavio viseci na internetu i trazeci imena pesama i slicna cuda... Hocu da SVE bude u formatu jedan veliki APE fajl + sredjen CUE + lista pesama, a zahvaljujuci plugin-ovima to moze direktno da se reze iz Nero-a, da se pusta iz WinAMPa, a skinuo sam i jedan koji izlistava sadrzaj CUE fajla (ostali su od Vampire-a, koji je dao softver na svojim diskovima ), tj. deli disk na pesme, tako da je funkcionalnost na vrhunskom nivou. Link to comment Share on other sites More sharing options...
Che Guevara Posted December 18, 2005 Report Share Posted December 18, 2005 @ peca_ns @ delija Pozdrav novosaÄ‘anima, može li da padne neko druženje zbog razmene tih diskova kasnije dok sredite kompilacije, možda u januaru. Imam važe brojeve tel. pa se Äujemo. Pozdrav iz Apatina.... Link to comment Share on other sites More sharing options...
Delija Posted December 18, 2005 Report Share Posted December 18, 2005 Naravno! Link to comment Share on other sites More sharing options...
Borko Posted December 18, 2005 Report Share Posted December 18, 2005 I jos: 1. Alan Parsons&Stephen Court-SoundCheck 2. Best Of Chesky Classics and Jazz and Audiophile Test Disc Vol.1 3. Best Of Chesky Classics and Jazz and Audiophile Test Disc Vol.3 4. Deep Forest - Boheme 5. Deep Forest - Music Detected 6. Enigma - The Cross Of Changes 7. Stereophile test3 8. Vaya Con Dios - Vaya Con Dios Link to comment Share on other sites More sharing options...
peca_ns Posted December 18, 2005 Report Share Posted December 18, 2005 Nije radjena normalizacija...Zvuk na nekim jeste tih ali je takav..ja imam Dire Straits album, donesen iz Londona i ima isto tako tih zvuk... Link to comment Share on other sites More sharing options...
Borko Posted December 19, 2005 Report Share Posted December 19, 2005 Nije radjena normalizacija...Zvuk na nekim jeste tih ali je takav..ja imam Dire Straits album, donesen iz Londona i ima isto tako tih zvuk... Link to comment Share on other sites More sharing options...
Delija Posted December 19, 2005 Report Share Posted December 19, 2005 Napanji ti pojacalo, pa ces imati dinamiku! Hifish mi je malo demonstrirao svoj sistem koji je jos sa vellikim znakom "radovi na putu" , al' i "tihi" i "glasni" CD-i isto zvuce, samo treba pojacati! BTW, taj njegov sistem mi i ovakav kakav je sada zvuci mozda i bolje od svega sto sam cuo na Show-u, a mogu samo da zamislim kako ce zvucati... Link to comment Share on other sites More sharing options...
Delija Posted December 19, 2005 Report Share Posted December 19, 2005 BTW, niko nije lud da radi normalizaciju, posto se time unistava originalni kvalitet... Link to comment Share on other sites More sharing options...
turbo Posted December 19, 2005 Report Share Posted December 19, 2005 Evo i ja da se zahvalim svima koji su ucestvovali u tzv. "slobodnoj razmeni"... Malo sam preleteo oko DVD-ova i bogami ima STRASHNIH stvari, jos samo malo vremena da se sve to na miru preslusa... A i jedno pitanje... Kada korsitim APE+CUE u Nero, nero mi javi nesto u stilu error opening file from source line 3 (line 3 u cue fajlu je zapravo ima .ape fajla i tu sve stima, ali ipak nece da nareze)? Da li mi nesto fali or what? Foobar svira odlicno i APE i FLAC, ali ja bih zeleo da sve to narezen na CD-e, samo kad bi nero bio poslusniji... Poz, i HVALA jos jednom svima na ulozenom trudu, Deliji na organizaciji... Dobro slusanje! Turbo Link to comment Share on other sites More sharing options...
peca_ns Posted December 19, 2005 Report Share Posted December 19, 2005 Obavezno raspakuj .ape u .wav...Kad je .flac u pitanju Nero zna prilikom rezanja da raspakuje, ali .ape ne zna....Verovatno ti se u trecoj linije u cue fajlu nalazi Filename="CDImage.wav" WAVE ...Da bi raspakovao treba da skines Monkey's Audio sa neta... Link to comment Share on other sites More sharing options...
Vampire Posted December 19, 2005 Report Share Posted December 19, 2005 Samo udji u neki txt editor i prepravi u Cue file liniju gde ti je naziv image file xxx.wav u xxx.ape i nero ce ti narezati Druga varijanta je da ga raspakujes u wav, sta ves uraditi je na tebi ali ako vec imas plugin za nero zasto ga ne iskoristiti... Pozdrav! v. Link to comment Share on other sites More sharing options...
Delija Posted December 19, 2005 Report Share Posted December 19, 2005 Meni je Nero 6.x prvo radio OK, a onda je poceo bez razloga da izbacuje tu poruku, nevezano da li je WAV, APE ili FLAC, tj. na bilo koji .CUE fajl... ??? .CUE fajlovi su 100% OK, al' jednostavno je otkazao poslusnost. Instalirao sam Nero 7.x i u njemu radi k'o zmaj... Cisto za preview u winamp-u skinite CUE Player plugin i dace vam spisak numera iz CUE fajla, kad ga ubacite, tj. podelice ape/wav/flac na track-ove, sa sve imenima numera iz .CUE fajla... @Turbo, Sto bre nisi ti raspakovao te DTS diskove, izgubih 3 sata na sredjivanju toga? Takodje, onaj HiFi News Test 2 je nazalost neupotrebljiv posto ima glitch na pocetku skoro svakog track-a... Cime si to skidao? @Vampire Svaka cast! MNOGO dobrih stvari si stavio, al' sam i tu potrosio skoro 10 sati da skinem podatke o diskovima (tracklist) sa neta i da ih prebacim sve u isti format: jedan APE fajl + sredjen .CUE fajl + Info.txt... Pozdrav svima! Link to comment Share on other sites More sharing options...
Delija Posted December 19, 2005 Report Share Posted December 19, 2005 @peca_ns I za APE postoji plugin za Nero... Link to comment Share on other sites More sharing options...
Vampire Posted December 19, 2005 Report Share Posted December 19, 2005 J.... ga nesto je sa neta, nesto sam ja skidao, ali ne stigoh sve da sredim sta da kazem bice bolje drugi put kad se bude imalo dovoljno vremena Inace i vas deo je odlican kao i suboticki tako da sve pohvale od mene... Za ostale iz BG koji budu hteli da pokupe DVD nek mi bace PM pa cemo se organizovati... Pozdrav! v. Link to comment Share on other sites More sharing options...
Delija Posted December 19, 2005 Report Share Posted December 19, 2005 Ma odlicno je bre, drugari, ne moze ni bas sve da bude "na tacni"! Nadam se samo da su ti diskovi koji su svuceni sa neta kvalitetno skidani i sa kvalitetnih diskova... Ja sam stavio napomenu gde disk nije skidan sa originala, vec sa kopije, na Pantino insistiranje... Moramo samo da nabavimo ili napravimo .CUE fajlove za DTS izdanja Alan Parsons Project: I Robot i Jethro Tull: Aqualung, da ne bude sve odjednom, vec da bude podeljeno na track-ove... @Turbo Sta bese onaj Diatonis Ambient Music? Jel imas toga jos? Jos jedno pitanje, da ne jurcam po netu... Koja je to fora sa obicnim audio CD-ima na koje nakace SACD "nalepnicu"? Link to comment Share on other sites More sharing options...
Vampire Posted December 19, 2005 Report Share Posted December 19, 2005 Znaci da je skidano sa SACD izdanja, naravno deo sa normalnim zapisom Inace sto se tice kvaliteta CDova sa neta ne brini sve je iz pouzdanih izvora sto se kvaliteta tice, do sad sve sto sam sebi rezao na CDA je bilo OK. Inace uglavnom imas EAC log file tako da mozes da vidis sa cime je skidano i kvalitet track-ova. E da imas i mali prog zove se Tau analyzer cini mi se koji analizira da li su CDA ili CDA konvertovan iz mp3. Link: http://www.true-audio.com Pozdrav! v. Link to comment Share on other sites More sharing options...
turbo Posted December 19, 2005 Report Share Posted December 19, 2005 @Delija - nemam pojma o kojim glitchevima je rec, kod mene sljaka sve kako treba... Onih Diatonisa ima jos na netu, dosta sporo mi je silazilo pa nisam skidao ostale pesmice (mislim da ima jos 5-6... kucaj Diatonis u Google... Neznam da li sam ja nesto promasio, ali ne vidim nigde Deep Forest i Enigmu i jos par stvari sa prethodnih spiskova... BTW danas mi je frend doneo jedan STRASAN DVD, Oupost FX: The Calibrator 6.1, interesantna stvarcica za kalibraciju slike i zvuka preko DVD-a, a razlog vise za sledecu "slobodnu razmenu" A kao sto sam ranije vec napomenuo i kolekcija DTS diskova je u razvoju, pa do sledeceg puta se nadam da cu imati barem jos ovoliko albuma (u fazi skidanja su Doors, Queen, Pink Floyd, Simply Red) Poz svima! Turbo Link to comment Share on other sites More sharing options...
Delija Posted December 19, 2005 Report Share Posted December 19, 2005 Mount-uj test 2 i pusti ga. Na samom pocetku svakog track-a se cuje "CAK"... BTW, Enigma i Deep Forest su iz Pecine kolekcije, a on je dosao u BG kad si ti otisao... Link to comment Share on other sites More sharing options...
Delija Posted December 20, 2005 Report Share Posted December 20, 2005 @Vampire Slucajno sam provalio pri preslusavanju muzike da je JVC XRCD Audiophile Sampler (1996) ostecen CD, tj. pola 8. numere i sam pocetak 9. su totalno corrupted... Nadam se da toga nema i na drugim mestima... Link to comment Share on other sites More sharing options...
rrapaic Posted December 20, 2005 Report Share Posted December 20, 2005 Delijo, poznato je da je najbolje rezanje - sporadicno rezanje. Veljko je uradio najbolje sto je mogao, obzirom na kratak rok, i obzirom da niko od nas nema profesionalni rezac (?). Ja sam znao za jadac, pa sam rezanje sveo na najmanju mogucu meru : od onih CD-ova koje sam ti predao, samo su 2 (ili 3? ) rezani pred sajam, ostali su odranije (za mene licno), i to direktno sa lossless formata. Diskovi koji nisu sa lossless-a (kopije kopija) su "Nigel Kennedy & The Kroke Band" i "Audiophile voices" (ovaj ste dobili i od Veljka). Rajko P.S. Treba dati masini da predahne, i nema da brines... Link to comment Share on other sites More sharing options...
Vampire Posted December 20, 2005 Report Share Posted December 20, 2005 E bas taj nemam narezan u svojoj kolekciji Moguce da je image bio los posto je sa net-a, provericu svakako, izvinjenje sta da kazem 1 od 30 Mada steta ako nije dobar posto se radi o XRCD izdanju U svakom slucaju ce ga skinem ponovo Pozdrav! v. Link to comment Share on other sites More sharing options...
Delija Posted December 20, 2005 Report Share Posted December 20, 2005 Image je los... Ma jos jednom svaka cast, znam bre da smo svi dali sve od sebe, nego je poenta u tome da se svasta kaci na net, pa ne mozemo biti sigurni u kvalitet onoga sto skidamo... Vampire, jos jednom moram da kazem da me ne shvatis pogresno, SVAKA CAST NA TRUDU!!! p.s. Iseckao ja taj deo i malo sredio, i tako cu da saljem dalje... Ostatak diska je OK. Link to comment Share on other sites More sharing options...
Vampire Posted December 20, 2005 Report Share Posted December 20, 2005 Ma naravno, da je bilo vremena ne bi bilo ni gresaka no vazno je da se nesto desava Dobro da nismo zatrudneli od truda Sto se tice neta u pravu si mada zaista do sada nisam imao problema, ali bitno da si se snasao Pozdrav! v. Link to comment Share on other sites More sharing options...
vlada24 Posted December 20, 2005 Report Share Posted December 20, 2005 @ Vampire Onaj link je super, "Tau-analizer" je straÅ¡no koristan softverÄić, baÅ¡ takvo neÅ¡to mi je trebalo ! Hvala ! Link to comment Share on other sites More sharing options...
Zare Posted December 21, 2005 Report Share Posted December 21, 2005 E da imas i mali prog zove se Tau analyzer cini mi se koji analizira da li su CDA ili CDA konvertovan iz mp3. Link: http://www.true-audio.com v. Link to comment Share on other sites More sharing options...
