Sonichammer Posted July 5, 2020 Report Share Posted July 5, 2020 Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted April 24, 2021 Report Share Posted April 24, 2021 Šuška se da stize zamena za famoznu 3010 seriju. Stay tuned! Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted June 3, 2021 Report Share Posted June 3, 2021 Stigla zamena! Quote Link to comment Share on other sites More sharing options...
VU metar Posted June 3, 2021 Report Share Posted June 3, 2021 Biće li cd plejera / transporta u ovoj seriji? Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted August 25, 2021 Report Share Posted August 25, 2021 Malo komentara o novoj Exposure 3510 seriji na PFM forumu. https://pinkfishmedia.net/forum/threads/new-exposure-3510-amplifier.256440/ Quote Link to comment Share on other sites More sharing options...
Wizard Of Gore Posted November 10, 2021 Report Share Posted November 10, 2021 Exposure 2010 S2 cd plejer videh na oglasima (dakle polovan, u odlicnom stanju) za 430€ - vredi li uzimati? Da li neko ovde ima iskustva sa ovim plejerom? Utisci? 🍻 Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted January 5, 2022 Report Share Posted January 5, 2022 You Tube kanal “British audiophile” koji broji preko 40.000 pratilaca tvrdi da je Exposure 2510 najbolje pojacalo 2021. godine! Quote Link to comment Share on other sites More sharing options...
dule75 Posted March 21, 2022 Report Share Posted March 21, 2022 Pre desetak dana postao sam vlasnik Exposure 3010S2D integralnog pojačala i zaljubio se u zvuk. Rekao bih na verovatno neko duže vreme. U međuvremenu je pristigao i CD iz iste serije tako da je sada uživanje upotpunjeno. Jedino tuner fali. Slušao sam ga na B&W CDm7SE, KEF LS 50Meta... TDL RTL3.. Monitor Audio Silver 100 i najviše mi se dopada kako zvuči na "sliveru" mada i tu imam zamerke na same kutije... Naime malo mi je svetliji i oštriji visoki (dok je na LS50 povučeniji ali mi se ne dopada srednji... Sve u svemu više leži silver od LS50 ali bih ja nešto bolje. Ima li iskusnih koji su slušali neke zanimljive kutije sa ovim ampom i CD-om? Ne zanimaju me teorije već konkretno da je neko poslušao ili imao u sistemu ovaj amp i određeni zvučnik koji ima prirodniju boju zvuka gde instrumenti zvuče realnije nego na silveru 100 a da imaju dovoljno brz odziv basa to jest da se kontrabas čuje kao kontrabas... da se bubanj čuje konkretno... da ima onaj tvrdi udarac doboša ni više ni manje od tog zvuka a da visoki imaju definiciju, da nisu zatupljeni a opet da ne sikću.. da boja zvuka bude prirodna.. što prirodnija i tako dalje i tako dalje. Sva iskustva dobrodošla... Preferiram engleske kutije jer mi one nekako najviše leže mada može i nešto drugo što bi lepo leglo... Quote Link to comment Share on other sites More sharing options...
Delija Posted March 21, 2022 Report Share Posted March 21, 2022 Cek, cek, polako... Pa ti rece da je LS50 Meta najbolji zvucnik u uzem i sirem univerzumu. Otkud sad ovo? Quote Link to comment Share on other sites More sharing options...
Scorpio(DDMF)! Posted March 21, 2022 Report Share Posted March 21, 2022 Prepucavanje je uklonjeno, za sada bez sankcija. Zamolio bih da se suzdrzite od toga u daljoj diskusiji. Hvala. Quote Link to comment Share on other sites More sharing options...
ab Posted March 21, 2022 Report Share Posted March 21, 2022 Кажњавали сте и за мање Quote Link to comment Share on other sites More sharing options...
Thecoki Posted March 21, 2022 Report Share Posted March 21, 2022 Baš tako,čak i za “lupetanje”….. Bando! Quote Link to comment Share on other sites More sharing options...
KorteZ Posted March 22, 2022 Report Share Posted March 22, 2022 Ako imaš mogućnosti poslušaj ATC zvučnike zavisno od veličine prostorije i finansijskih mogućnosti. Meni se sa 3010S2D svideo ATC SCM11, sledeći model SCM19 nisam slušao jer je bio izvan mojih finansijskih mogućnosti. Sve ovo pod uslovom da voliš zvuk "zatvorenih" kutija. PozdravSent from my STK-LX1 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Father Posted March 22, 2022 Report Share Posted March 22, 2022 17 sati ranije, dule75 said: ...da imaju dovoljno brz odziv basa to jest da se kontrabas čuje kao kontrabas... da se bubanj čuje konkretno... da ima onaj tvrdi udarac doboša ni više ni manje od tog zvuka a da visoki imaju definiciju, da nisu zatupljeni a opet da ne sikću.. da boja zvuka bude prirodna.. što prirodnija i tako dalje i tako dalje. Sva iskustva dobrodošla... E sa ovom zadnjom rečenicom će se baš usrećiš, pogotovo u kontekstu prirodnosti. Da ti čika Father kaže, to u audiofiliji ne postoji. Svako čuje prirodnost na svoj način uz preference prema "začinima". Ako već imaš pojam prirodnog zvuka, onda "use i u svoje kljuse". Ako uspeš da poslušaš kod sebe u slušaonici bar 1/3 predloženog ti si srećan čovek i smatraj da si imao širok izbor u potrazi za svojom referencom prirodnog. Svaki zvučnik koji se čuje van sopstvene slušaonice predstavlja veliku zagonetku kako će se ponašati u tvom slušnom okruženju. Quote Link to comment Share on other sites More sharing options...
dule75 Posted March 22, 2022 Report Share Posted March 22, 2022 Na primer TDL RTL 3 mi se jako dopada u basu i malo manje u visokim tonovima ali mi se ne dopada srednji spektar. Zvuči dosta hladno za moj ukus i često smeta neprirodnost vokala kao i instrumenata koji se čuju u srednjem spektru dok ove iste kutije sa Regom elex zvuče mnogo lepše i imaju taj neki rock fazon koji mi se jako dopada, KEF LS50 Meta je jako blizu onome što mi odgovara ali mi isto srednji u kombinaciji sa 3010 nisu baš po meri jer zvuče zatvorenije od očekivanog i onda kao da se srednji meša sa mid basom pa vokali zvuče mnogo "debelo" što mi opet nije prirodno. Silver 100 mi je po svim parametrima kompletniji ali ima opet tu neku određenu hladnoću u zvuku mada ne uvek, što pripisujem i samim snimcima koji su možda izvorno takvi kakvi jesu. Silver deluje sa nekim numerama kao odlično uklapanje a onda natrči materijal gde mnogo vuče na hladnu stranu zvuka... Do duše kada je izvor sam Exposure CD tu je hladnoća manje izražena a kada se pušta sa Arcama ST60 izraženija je ta neusklađenost u zvuku kada natrči određena numera. Što se tiče kvaliteta i punoće zvuka po mom skromnom mišljenju Exposure CD daleko prevazilazi Arcama ST60. Arcam prema njemu deluje kao neka solidna sprava za preslušavanje materijala i ništa više od toga. Kada to isto pustiš na Exposure plejeru e onda tek počinje pravo uživanje podignuto na viši nivo. Nikako ne mogu da se otmem utisku kako često u vokalima jasno čujem rad svičerskog napajanja u Arcamu. Prosto se čuje i verovatno to ne može da se eliminiše... a šteta jer je Arcam jako praktičan i ima potencijala ali su ga baš zeznuli sa napajanjem od 5e. Tužno. Ako budem u prilici poslušaću i ATC ali teško da se može izvesti u ličnom okruženju pošto ne verujem da je neko baš toliko voljan da ustupi kutije na slušanje pa da mu ih vratiš čak i uz neku naknadu za petodnevni boravak kutija u kućnom sistemu Inače sistem radi u sobi od 22 kvadrata i više volim manje kutije, mada i podne mogu da uđu u obzir ako su bas drajveri do 6.5". Sve preko toga mi se ne uklapa u ukus zbog previše basa koji ume da ode van kontrole i da bude prenaglašen što mi jako smeta. Do 6.5" za podne i 8" za bookshelf... to mi je neka referenca za prostor. Quote Link to comment Share on other sites More sharing options...
sergio025 Posted March 22, 2022 Report Share Posted March 22, 2022 ...TDL Studio 0.5 ili 1.0,poslusajte ove kutije s obzirom da ste culi TDL RTL3 sto je kud i kamo slabiji model od modela Studio. Nisu za dzabe u KultNom Statusu kod audiofila !!!!!! just a think about them Quote Link to comment Share on other sites More sharing options...
nickname Posted June 8, 2022 Report Share Posted June 8, 2022 Zdravo svima, Trenutno imam MA Gold 100 koje pogoni 2010S Bez da primećujem neku manu ovom setup-u, "svrbi" me kako li bi to sve sviralo sa 3010S2D. Kako bi ste opisali, koja bi bila razlika između ova dva? Šta bi dobio/izgubio u zvuku? Izvor je HifiBerry Dac2HD. Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted July 11, 2022 Report Share Posted July 11, 2022 3010s2D je mnogo bolje pojacalo. Pozornica je veca po svim parametrima, zvuk autoritativniji, “misicaviji”... prosto visa klasa. Da bi sve to mogao da cujes, trebace ti i bolji izvor. U stvari, vec ti treba po mom misljenju. Quote Link to comment Share on other sites More sharing options...
nickname Posted October 5, 2022 Report Share Posted October 5, 2022 Pazario sam 3010S2D, jeste ovo je za klasu viši autoritet. Sad u potragu za novom Streamer/DAC kombinacijom. Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted November 3, 2023 Report Share Posted November 3, 2023 Prvi gramofon iz Exposure! 😍 Exposure turntable 360 Quote Link to comment Share on other sites More sharing options...
zflazar Posted November 4, 2023 Report Share Posted November 4, 2023 najs, nekako se čudno piše Rega? Quote Link to comment Share on other sites More sharing options...
Sonichammer Posted November 4, 2023 Report Share Posted November 4, 2023 3 sati ranije, zflazar said: najs, nekako se čudno piše Rega? I lepše! 😀 Quote Link to comment Share on other sites More sharing options...
Delija Posted November 4, 2023 Report Share Posted November 4, 2023 3 sati ranije, zflazar said: najs, nekako se čudno piše Rega? Dok je Rega, a ne raga - dobro je 🙃 Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted November 4, 2023 Report Share Posted November 4, 2023 On 3. 11. 2023. at 8:46, Sonichammer said: Prvi gramofon iz Exposure! 😍 Exposure turntable 360 Vidi se iz aviona da je ovo napravila Rega za Exposure, ali to je potpuno okay, ne treba svako da izmišlja rupu na saksiji, pogotovo što izgleda da Exposure ima cilj da proširi ponudu sa gramofonima, a ne da izvodi neke egzibicije. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted November 4, 2023 Report Share Posted November 4, 2023 Мене је зеленило у позадини одушевило Послато са M2006C3MNG помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
