LINN & NAIM republika
sondek
Ubrzavam koliko mogu, ali mislim da nije realno pre kraja septembra... :mellow:
Mada brinem i za kraj septembra, ako se rasplamsa korona, pitanje je da li je i kraj septembra realan...
Potrebna mi je preporuka za "audiofilske" mrežne kablove, ako tako nešto uopšte ima smisla? :) Računam ako se prave audiofilski svičevi, sigurno ima i audiofilskih mrežnih kablova :D
Evo šta o tome kažu u Linnu:
Exakt cabling
ALL FOUR pairs of the cables are used in the Exakt-Link cable. This is NOT an ethernet transport cable but an Exakt transport cable. These pairs are used to transmit the audio data, power triggers and a master timing control to ensure that the audio from all channels are in perfect sync.
The Exakt-link has been designed to operate with the CAT-5 cable electrical specifications for signal timings. There have been NO changes to this design for any other CAT cable standards. (updated 2019)
We recommend using the 100Base-T4 / 568B ethernet cable pairing
Exakt Link uses readily available network cables:
  • CAT 5 UTP/FTP
  • CAT 6 UTP/FTP
Note: There is no change in the audio performance of the Exakt Link between Cat 5 or Cat 6 Cables.
Cat-7 and Cat-8 cables may not work well with an Exakt system. For a trouble-free, reliable, high performance installation, we recommend use of Cat 5 or Cat 6.
Typical Ethernet 100Base-T length restrictions guide:
Patch cable < 30M
Solid core cable < 100M
Naimasi prijavljeno mi je ovo kao odlican match uz naim, proverite. Moze se cuti zajedno u Plejeru. Trazite obavezno da probate i uz drugi amp, recimo Ec da vidite koliko ustvari zvucnici dobro legnu uz Naim. Odlicna je i cena, tesko za te pare nov trosistemac. Pritom odlicno izgleda. Ja sam solidno izazvan, narocito sto drugar nije naimas i bas je bio iznenadjen.
https://www.whathifi.com/reviews/wharfedale-linton
Ima sad u player-u. Drugar poslusao, i nekako jedva obuzdao zenu da ne kupi 😄
Meni se svidja old skul look.Zaista je heritage ...iscezli su polako zvucnici trosistemci tih srednjih dimenzija na stalcima...osim Harbeth , ali to je sasvim druga cenovna kategorija. Za oko 1200 sa stalcima stvarno nema neku konkurenciju medju novim spravama. Interesantno mu bilo i sto kad se sklonio Naim i ubacio Ec u igru nestao dobar zvuk. Ucifrali da englez radi sa englezom.
Nisam nikad bio u plejeru, pozvacu bas ove iz NS da li imaju ako uhvatim vremena...a sto jeste velik problem.Cak ni Linn u NS kod audio plus nisam otisao da poslusam. Novi Majik moze biti jako interesantna naprava. Ovaj Dsm 3 me odusevljava, iskljucio sam EAR snagas i ne fali mi.
Jeste, Meni se izgled svideo nenormalno. Pogotovo ti stalci.
Da su ih imali kupio bih ih mozda cak i na slepo. Tada sam planirao na Supernaita.
Cekao sam par meseci da ih plejer nabavi da poslusam. Na kraju naleteli Naim Ariva pa sam odustao od njih.
Nego mi nesto u secanju da su tada bili 1000E sa stalcima, ili gresim? Poskupeli?
Evo moja iskustva sa Lintonima- ozbiljno dobri zvučnici. Sa Naimom su na TI, slušao na dva setapa, u dvije različite prostorije, teško da u tom cjenovnom rangu ima bolje. I nikako ne uzimati bez postolja, šteta bi bilo.
Ali...
Možda je i to karakteristika ozbiljnih zvučnika, Lintoni su VEOMA osjetljivi na dimenzije prostorije, pozicioniranje, tretman.
U kompletno tretiranom show room-u, odmaknuti po 1,5m od zida u svim pravcima, svira za desetku, pomislili biste da se radi o nekim preskupim Harbeth-ima u najmanju ruku.
Nakon toga slušanje u real okruženju, setap Naim, velika dnevna soba od zida 50cm, između TV komoda, ne baš previše vazduha. Svirka -blago razočarenje. I dalje je to dobar zvuk ali osjetno slabije nego u kompletno tretiranom show room-u. Trebalo bi zaratiti sa suprugom pa ih izvući na pola sobe, izbaciti TV, tretirati sobu itd...
Послато са SM-G960F помоћу Тапатока
Ne g. @NL, našalio sam se na Sondekov post, u smislu da korišćenje LP12 je svakoga prolepšalo osim mene.
Nisam stavio u funkciju LP12 (ručicu sam kupio davno ali još uvek nisam cartridge nabavio).
Suština je da još nisam načisto koju glavu da kupim.
“Linn Sondek LP12” je planiran za rad u sistemu sa “Naim Supernait 3” koji, verujem da mnogi znaju, ima u sebi MM phono preamp koji zahteva da kapacitivnost glave bude 470 pF.
Takvih novih MM glava, koliko sam shvatio čitajući forume, nema (nove MM glave su valjda 100-200 pF), pa još uvek razmišljam koju glavu da kipim.
Naravno mogao bih da kupim novi (znacajno bolji phono preamp) i da tako jednostavno rešim problem no ne želim još jednu kutiju u sistemu (ovaj sistem mi je u dnevnoj sobi i između ostalog zato sam i kupio “Naim SN3”-integrisani pojačavač).
