Engine Posted November 13, 2020 Report Share Posted November 13, 2020 Isto na KP, samo kupi od provjerenog prodavca da ne bude falš.Послато са SM-G960F помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
CoyoteKG Posted November 13, 2020 Report Share Posted November 13, 2020 Hvala hvala kakav je to konektor? Daj link da znam sta da trazim Quote Link to comment Share on other sites More sharing options...
bogdan63 Posted November 14, 2020 Report Share Posted November 14, 2020 Te Naimove bananice koje se dobijaju uz pojačalo su prilično jadnog kvaliteta i nepraktične (moraju da se leme). Meni se jedna iskrivila i pri pokušaju da je ispravim vrlo lako je pukla. Materijal od kog je nepravljena izgleda kao neki jeftini špijater. Pojavljuju se s vremena na vreme na KP po ceni od 10-15 evra. Sebi sam uzeo Qed Airloc 4mm Banana Plug. Skuplje su ali mi deluju mnogo kvalitetnije U Stražilovskoj uz kupovinu ide i montaža (krimpovanje) Quote Link to comment Share on other sites More sharing options...
bogdan63 Posted November 14, 2020 Report Share Posted November 14, 2020 Ovo su Naim bananice Quote Link to comment Share on other sites More sharing options...
Oknarb Posted November 14, 2020 Report Share Posted November 14, 2020 Ima i ovakvih Quote Link to comment Share on other sites More sharing options...
Oknarb Posted November 14, 2020 Report Share Posted November 14, 2020 I ovakvih Quote Link to comment Share on other sites More sharing options...
Oknarb Posted November 14, 2020 Report Share Posted November 14, 2020 Just now, Oknarb said: I ovakvih Quote Link to comment Share on other sites More sharing options...
Oknarb Posted November 14, 2020 Report Share Posted November 14, 2020 Dupliran post bez slike molim obrisite Quote Link to comment Share on other sites More sharing options...
Oknarb Posted November 14, 2020 Report Share Posted November 14, 2020 Quote Link to comment Share on other sites More sharing options...
Oknarb Posted November 14, 2020 Report Share Posted November 14, 2020 Ovi zadnji su mi višak i ako ti trebaju pošalji mi adresu. Imaš ih kao poklon. Quote Link to comment Share on other sites More sharing options...
sondek Posted November 14, 2020 Author Report Share Posted November 14, 2020 Odlican steker(taj Oknabov na 90 stepeni) koji sprecava da ti se desi neki kurslus,kratki spoj i razmrdavanje konektora.Pritom od lemljenja nema bolje.Kad sam ga prvi put probao,skinuvsi originalne Mitchell bananice,zvuk je bio bolji na prvi ton.Kabl pritom ima i direktni kontakt sa konektorom jer jako tesno ulazi u predvidjen zljeb. Zalemi se odozgo da nebi bilo ispadanja. Quote Link to comment Share on other sites More sharing options...
Engine Posted November 14, 2020 Report Share Posted November 14, 2020 Te Naimove bananice koje se dobijaju uz pojačalo su prilično jadnog kvaliteta i nepraktične (moraju da se leme). Meni se jedna iskrivila i pri pokušaju da je ispravim vrlo lako je pukla. Materijal od kog je nepravljena izgleda kao neki jeftini špijater. Pojavljuju se s vremena na vreme na KP po ceni od 10-15 evra. Sebi sam uzeo Qed Airloc 4mm Banana Plug. Skuplje su ali mi deluju mnogo kvalitetnije U Stražilovskoj uz kupovinu ide i montaža (krimpovanje)Naim tvrdi da su originalni konektori od istog materijala kao i ulazi kod npr Supernaita, tako da ne postoji bolja konekcija za njega. Za drugu stranu, prema SF može i drugi konektor, ali kad je bal...nabavi i njega original Naim.Послато са SM-G960F помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
CoyoteKG Posted November 14, 2020 Report Share Posted November 14, 2020 @Oknarb hvala, necu propustiti priliku :]. Mozda bih mogao i da se provozam do Backe Topole. Sto se tiče Supernaita, čuo sam kod Bogdana u sistemu i sjajno se čuje, ali ipak je njegov sistem top i nešto što ja neću ni za 100 godina napraviti :D. na fotografijama i recenzijama pre toga dok sam čitao, ova Naimova pojačala su mi izgledala ultra ružno, bezlično. Ali sad kad ga gledam ovako (pošto ne mogu da slušam ) sve mi lepše i sviđa mi se taj minimalistički dizajn. Na dodir tek (žena me zeza da ga mazim ) osećaj je da je sigurno top kvalitet. Tako da ispod šasije tek mora da je vrh. Ovaj moj primerak je očuvan kao iz fabrike da je izašao, jednu tačkicu nigde nisam vido kao neki “dokaz” da je korišćen. Inače Bogdan je jedna divna osoba, drago mi je što sam ga upoznao i baš od njega kupio. Ova kupovina je bila baš “yolo” nisam nikad ni planirao da imam skuplje pojačalo od 300-500E, ali poznajući sebe, sviraće kod mene dugo Quote Link to comment Share on other sites More sharing options...
CoyoteKG Posted November 14, 2020 Report Share Posted November 14, 2020 @Enginepredomišljam se za SF. htedoh da kupim ove https://www.kupujemprodajem.com/audio/zvucnici/sonus-faber-venere-wood-1-5/oglas/104425471?filter_id=773776698 sa stalcima, ili crne isto od njega. ali ne mogu da ih poslušam pre kupovine, on bi ih dovezao iz Banja Luke do BG.Hteo sam te zvučnike zbog izgleda, a i zbog toga što je SF kvalitetan brend, ali ispade da su Venere prva serija pravljena u Kini, i po recenzijama ili ih hvale ili kude... takodje izmedju te staklene crne gornje ploce ima par mehurica, ne znam da li je to znak za izbegavanje, kako li su mogli da nastanu... Tako da cu pratiti ovde oglase i kupiti od nekog clana foruma nesto kad naleti sto je i na oko lepo (zbog zene) i sto je kvalitetno. Do tada slusam moje Kef, nadam se da ce mozda ono bubnjanje basa koje sam pominjao u drugoj temi sad mozda malo i prestati Quote Link to comment Share on other sites More sharing options...
sondek Posted November 14, 2020 Author Report Share Posted November 14, 2020 Moj predlog za zvucnike za Snait bi bio Neat ,mozes poneti amp kod zastupnika da probas kombo,ja sam u dva navrata cuo i to sjajno radi.Cak 5-6 pari razlicitih zvucnika sam slusao sa jednim naimom u istoj sobi i sa istim ostatkom sistema.Neat je tu najbolje legao. Quote Link to comment Share on other sites More sharing options...
Engine Posted November 14, 2020 Report Share Posted November 14, 2020 Ma polako, slušaj KEF-ove dok ne iskiče zvučnici dostojni SN. Nije ni čudo da ga maziš, nimalo nisi pogriješio, dobio si strašno pojačalo, dac...Slušao sam to pojačalo (doduše noviji model) sa Harbert Monitor 40.2, pogledaj im cijenu:https://audioplus.rs/proizvod/698/Harbeth 40th Anniversary Editon – WalnutGuraju ih kao od šale, a zvuk...Zato se ne boj da će i ove SF gurati, samo bih ipak prije čuo kombinaciju, nije dobro samo zbog izgleda birati zvučnik.Od novih bi ti preporučio Warfedale Linton, al sumnjam da će se svidjeti tvojoj ljepšoj polovini Послато са SM-G960F помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
baal Posted November 14, 2020 Report Share Posted November 14, 2020 36 minuta ranije, CoyoteKG said: @Enginepredomišljam se za SF. htedoh da kupim ove https://www.kupujemprodajem.com/audio/zvucnici/sonus-faber-venere-wood-1-5/oglas/104425471?filter_id=773776698 sa stalcima, ili crne isto od njega. ali ne mogu da ih poslušam pre kupovine, on bi ih dovezao iz Banja Luke do BG.Hteo sam te zvučnike zbog izgleda, a i zbog toga što je SF kvalitetan brend, ali ispade da su Venere prva serija pravljena u Kini, i po recenzijama ili ih hvale ili kude... takodje izmedju te staklene crne gornje ploce ima par mehurica, ne znam da li je to znak za izbegavanje, kako li su mogli da nastanu... Tako da cu pratiti ovde oglase i kupiti od nekog clana foruma nesto kad naleti sto je i na oko lepo (zbog zene) i sto je kvalitetno. Do tada slusam moje Kef, nadam se da ce mozda ono bubnjanje basa koje sam pominjao u drugoj temi sad mozda malo i prestati Čestitke na kupovini, ali polako sa zvučnicima, kao što rekoše kolege. Imaš vremena, natenane biraj šta ti se najviše dopadne. 14 minuta ranije, Engine said: Ma polako, slušaj KEF-ove dok ne iskiče zvučnici dostojni SN. Nije ni čudo da ga maziš, nimalo nisi pogriješio, dobio si strašno pojačalo, dac... Slušao sam to pojačalo (doduše noviji model) sa Harbert Monitor 40.2, pogledaj im cijenu:https://audioplus.rs/proizvod/698/Harbeth 40th Anniversary Editon – Walnut Guraju ih kao od šale, a zvuk... Zato se ne boj da će i ove SF gurati, samo bih ipak prije čuo kombinaciju, nije dobro samo zbog izgleda birati zvučnik. Od novih bi ti preporučio Warfedale Linton, al sumnjam da će se svidjeti tvojoj ljepšoj polovini Послато са SM-G960F помоћу Тапатока Slažem se sa kolegom Engine-om da ne treba birati zvučnike po izgledu. Mada, to nekad može da bude važan faktor... Kad smo već kod tog važnog faktora, meni se strašno dopadaju ti Warfedale Linton zvučnici baš po izgledu. Kupio bih ih sa onim stalcima da ne trepnem... Čak se i mojoj ženi dopadaju i nagovara me da ih kupimo! Da li ih je iko od forumaša poslušao makar na kratko, da čujemo bilo kakav sud o njima? Quote Link to comment Share on other sites More sharing options...
sondek Posted November 14, 2020 Author Report Share Posted November 14, 2020 23 minuta ranije, Engine said: Naim tvrdi da su originalni konektori od istog materijala kao i ulazi kod npr Supernaita, tako da ne postoji bolja konekcija za njega. Za drugu stranu, prema SF može i drugi konektor, ali kad je bal...nabavi i njega original Naim. Послато са SM-G960F помоћу Тапатока Upravo tako.Ne daje naim te konektore uz amp bez veze.Ne koristim vise naim,ali jedna stvar im se mora priznati...vode racuna o detaljima,obezbedjuju adekvatne kablove,konektore.Vecina od toga ide bez doplate uz uredjaj.Jednostavno znaju da se sa nekim pogresnim izborom moze uprskati stvar na naglupljem mestu.Na usluzi su kupcu i kad ih pitas i ga nesto sto nije njihovo...nije im interes mismatch koji kupci naprave,cega ima dosta.Za razliku od njih odgovori nekih drugih proizvodjaca bili su u stilu "nasi uredjaji su odlicni,uparuju se sa svim". Recimo za konektor za gramofonski ulaz su dosli do zakljucka da se BNC pokazao kao najbolji.Nazvao sam ih i pitao sta da stavim umesto da uzmem sta mi prvo padne pod ruku i rekli su mi da stavim 50ohmski ...naletao ma 75ohmske svukuda.Naravoucenije ko pita ne skita.Poslali mi link gde da porucim i poslali uputstvo u Pdf kako da spojim ,2 funte cijena.Malo truda oko kupca nikad previse.Pritom sam im mail poslao u nedelju i odgovorili na moje iznenadjenje za sat vremena. Quote Link to comment Share on other sites More sharing options...
Engine Posted November 14, 2020 Report Share Posted November 14, 2020 Kad smo već kod tog važnog faktora, meni se strašno dopadaju ti Warfedale Linton zvučnici baš po izgledu. Kupio bih ih sa onim stalcima da ne trepnem... Čak se i mojoj ženi dopadaju i nagovara me da ih kupimo! Da li ih je iko od forumaša poslušao makar na kratko, da čujemo bilo kakav sud o njima?Nebih ih preporučio da nisam slušao. Sa Naimom se dobro slažu, odlični zvučnici. Iako je cijena malo iznad 1000€ zvuk je "skuplji". Zvučnici koji se slušaju sa mrežicama.I bez orginalnog stalka bi bilo glupo, markentiška je fora da ih prodaju odvojeno. Još pozlaćeni logo na stalcima (stalak za ploče) .Послато са SM-G960F помоћу Тапатока Quote Link to comment Share on other sites More sharing options...
baal Posted November 14, 2020 Report Share Posted November 14, 2020 3 minuta ranije, Engine said: Nebih ih preporučio da nisam slušao. Sa Naimom se dobro slažu, odlični zvučnici. Iako je cijena malo iznad 1000€ zvuk je "skuplji". Zvučnici koji se slušaju sa mrežicama. I bez orginalnog stalka bi bilo glupo, markentiška je fora da ih prodaju odvojeno. Još pozlaćeni logo na stalcima (stalak za ploče) . Послато са SM-G960F помоћу Тапатока Dakle, ocene su pozitivne i od kolege forumaša. Hvala na odgovoru. Uopšte, sve recenzije govore da se dobija više nego što koštaju. Tako je, sa stalcima izgledaju neverovatno. Quote Link to comment Share on other sites More sharing options...
nkrgovic Posted November 14, 2020 Report Share Posted November 14, 2020 6 sati ranije, Oknarb said: Na te sam mislio,da . Quote Link to comment Share on other sites More sharing options...
CoyoteKG Posted November 14, 2020 Report Share Posted November 14, 2020 Dobio ih od Oknarb, danas preuzeo Quote Link to comment Share on other sites More sharing options...
Srecko Posted November 15, 2020 Report Share Posted November 15, 2020 Jako je teško naći (barem meni podatke) o Naim proizvodima npr. električne karakteristike ulaza i izlaza bilo RCA bilo DIN. Gledam nešto slike Naim Supernait 3. RCA ulaznih konektora ima 6 sa priključkom za sub. 1. Prvi sa leve strane RCA in je za Sub. 2. Drugi RCA je jasan, za gramofon, ali mi nije jasan DIN ulaz iznad gde je potpisano Aux&pwr. Da li je to aux1 samo u DIN varijanti. 3. Treći RCA je jasan, za AV. 4. Četvrti RCA je za stream. Šta sve Naim podrazumeva pod stream? Da li u stream uređaj spadaju samo strimeri npr. NDX2 ili je stream (bilo bi logično) i klasičan DAC sa RCA izlazima priključen na PC pa da li preko DAC slušate internet radio ili slušate flakove je nebitno.5.6 Poslednja 2 RCA priključka nisu sporni-tjuner i CD. Zašto ovo pitam. Ako se pogledaju tipke za izbor izvora zvuka na prednjoj pločiPostoji tipka Aux koja nema potpisan RCA konektor. Šta ona bira? Da li je ona izborna tipka za uređaj koji smo prikačili na DIN priključak drugi sa leva ispod koga je jedino potpis Aux&pwr?Zašto mi je ovo neobično (nemam takoreći nikakvo iskustvo sa Naim iako trenutno slušam Naim Supernait 2) jer taj Aux priključak je kroz istoriju sluzio za priključivanje uređaja koji nemaju dedicated ulaz i za koji ne znate izlaz da biste mogli da eventualno napravite bolji izbor ulaza.Obično se DAC-ovi prikljucuju na taj ulaz jer obično nemaju dedicated ulaz.GDE KONKRETNO TREBA PRIKLJUČITI DAC NA "SUPERNAIT 3" KOJI NIJE NAIM DAC (već sa priključcima RCA)? Pretpostavljam NA STREAM ULAZ (bilo bi logično) da bi kvalitet reprodukcije bio najbolji? Verovatno bi DAC radio priključen i na DIN Aux&pwr ulaz samo bi trebalo imati i interkonekcijski kabl RCA-Din)? Quote Link to comment Share on other sites More sharing options...
nkrgovic Posted November 15, 2020 Report Share Posted November 15, 2020 Vecina ulaza ima i RCA i DIN konektor, ima u uputstvu kako se bira koji je aktivan. Pojacalo nema pojma da li je na CD ulaz zakacen CD ili Streamer i potpuno mu je sve jedno. Vezuje vlasnik kako mu je zgodno. Meni je strimer vezan na "tuner" ulaz, zgodno mi je jer je pored CD-a. Jedino specificno je sto jedan od dva AUX-a ima i napajanje, ako se tu veze eksterno gramofonsko pretpojacalo - StageLine (ili Prefix unutar Sondeka). Taj Aux po pravilu nema RCA ekvivalent. Ono sto, mozda, ima uticaja na kvalitet je konektor, po pravilu je DIN bolji nego RCA. U svakom slucaju, da li je neki uredjaj vezan na "cd", "tuner" ili "stream" nece nikako promeniti zvuk - sve dok je u pitanju isti kabl i ista terminacija. Quote Link to comment Share on other sites More sharing options...
nkrgovic Posted November 15, 2020 Report Share Posted November 15, 2020 Da, AV ulaz treba da ima opciju da se odabere unity gain. On je isto specifican.... Quote Link to comment Share on other sites More sharing options...
