Donkey Posted February 13, 2010 Report Share Posted February 13, 2010 Imam samo jednu Maxell XL II-S. Zaista jako zavisi na cemu se snima na cemu se slusa. Tako da je materijal koji mi je trenutno na njoj osrednje kvalitete snimka. Tj jos sam pod utiskom obicne Ferro Normal trake TDK A90. I fantasticnog snimka Jean Michell Jarre - Essential. Quote Link to comment Share on other sites More sharing options...
acazr Posted February 13, 2010 Report Share Posted February 13, 2010 Tj jos sam pod utiskom obicne Ferro Normal trake TDK A90. I fantasticnog snimka Jean Michell Jarre - Essential. Na njoj pozadi pise best used with boombox Quote Link to comment Share on other sites More sharing options...
accuphase Posted February 13, 2010 Author Report Share Posted February 13, 2010 Sony Metal Master(sa 2x magnetnim layer-om), kao i Sony Super Metal Master(sa Äak 5x magnetnim layer-om), su po svoj prilici neÅ¡to najbolje, Å¡to je ikada proizvedeno u svetu kompaktnih audio kaseta... Ali, sve ima svoje mane i nedostatke... Naime, oba modela imaju ubedljivo najveće parametre za SOL(nivo zasićenja visokih tonova), ali je izgleda cena toga vrlo nezgodna Äinjenica, da bias na deku, na kome se snima mora toliko mnogo da se "odvrne" u desno, da mnogo maÅ¡ine nemaju toliki opseg podeÅ¡avanja... ili da pride imaju i EQ podeÅ¡avanja !!! Quote Link to comment Share on other sites More sharing options...
accuphase Posted February 13, 2010 Author Report Share Posted February 13, 2010 Dve odliÄne kasete, iz Basf, kasnije Emtec chrome/metal programa... izuzetnog zvuka, ali i trajnosti... uz to, priliÄno (ne)zahtevne, prilikom kalibracije, dovoljan je samo bias, standardnog opsega podeÅ¡avanja. Quote Link to comment Share on other sites More sharing options...
TapeMan Posted February 14, 2010 Report Share Posted February 14, 2010 BASF je radio Äak i 120 minutne metal kazete! Quote Link to comment Share on other sites More sharing options...
PrekoBare Posted February 14, 2010 Report Share Posted February 14, 2010 Iz mog ugla insistiranje na metal trakama je preterano jer ne opravdavaju odnos ulozeno / dobijeno. Najbolja iskustva su mi sa Maxell XL II S trakama - odlican snimak , perfektno zadrzava snimak tokom godina . Govorim o onoj zutoj gore levo, snimljena negde 1985 , 1986 , uvek kada ih pustim iznenadim se kako se jos dobro cuje. Radije bih nju kupio nego TDK MAXG , ali ih je tesko naci. Poticu iz 1983 ili 4 i mislim da Maxell nikad bolju traku nije napravio. TDK MA na slici nije losa ali vremenom gubi visoke ( kao i vecina TDK traka koje sam do sada isprobao iako su lakse za snimanje na dekovima bez detaljne kalibracije (BX 300 npr) u odnosu na Maxell). Alex, XL-IIS je bio perfektan dok nisu presli na blackmagneshit formulu koja je muljava u visokima. To je prakticno druga losija kaseta pod istom etiketom Nikad nisam voleo MA. MA-X je neuporedivo bolja. Danas mislim da je najbolje praviti zalihu SA-X jer su skoro sve serije odlicne a jos ih ima po razumnoj ceni. Pre neki dan naletim na traku koju nikada ranije nisam video. TDK AR-X. Fenomenalna normal traka. Quote Link to comment Share on other sites More sharing options...
accuphase Posted February 14, 2010 Author Report Share Posted February 14, 2010 Vrhunske normal-kasete, koje su toliko dobre, kao da nisu "normalne", za svaku preporuku: U svakom pogledu izvrsni modeli... skoro da vam i ne treba hx-pro prilikom snimanja, jer imaju SOL bolji od dobrih hrom-traka, nivo Å¡uma je isto tako za neverovati koliko mali !!! Quote Link to comment Share on other sites More sharing options...
PrimozS Posted February 17, 2010 Report Share Posted February 17, 2010 Evo, nova godina i mali novi score Quote Link to comment Share on other sites More sharing options...
Donkey Posted February 17, 2010 Report Share Posted February 17, 2010 Dobro , AI90 su za boombox , a AR 90? Ima odlicnih normal traka, HF-ES koje je pomenuo accuphase su bile sjajne. Steta sto nemam ni jednu Quote Link to comment Share on other sites More sharing options...
acazr Posted February 17, 2010 Report Share Posted February 17, 2010 TDK AR Magnetic Particle: NP Avylin Coercivity: 380 Oe Remanence: 1800 Gauss Squareness Ratio: 0.86 Operating Bias: 0.0dB MOL 315Hz: +6.5dB MOL 10kHz: -6.0dB Sensitivity at 315Hz: +1.0dB Sensitivity at 3.15kHz: +1.0dB Sensitivity at 10kHz: +1.0dB Sensitivity at 16kHz: +1.0dB Bias Noise: -56.0dB TDK AR was a top type I cassette. Known for good bass performance. http://vintagecassettes.com/tdk/tdk_files/tdk_type/tdk_ar.htm Quote Link to comment Share on other sites More sharing options...
PrimozS Posted February 22, 2010 Report Share Posted February 22, 2010 Njanoviji find u duÄanu: Akcija 3pack za 1,99EUR pa sam tako uzeo 3x5kom: A za test uzeo sam joÅ¡ par kom ovih: JoÅ¡ najviÅ¡e mi se sviÄ‘a, kaj na oba dva modela piÅ¡e "Made in Japan", kaj mislim da je dandanas sve manje za dobiti u duÄanima a da nije NOS ... Jel tko ima bilokakva iskustva sa bilokojim od tih dvih modela kaseta? Quote Link to comment Share on other sites More sharing options...
Lakedemon Posted February 22, 2010 Report Share Posted February 22, 2010 Primoz, o sadisticki, o nemilosrdni brate. Stavljam te na ignore listu. Quote Link to comment Share on other sites More sharing options...
Tutti Posted February 22, 2010 Report Share Posted February 22, 2010 Ovaj put je bas jeftino prosao. Quote Link to comment Share on other sites More sharing options...
Lakedemon Posted February 22, 2010 Report Share Posted February 22, 2010 Ovaj put je bas jeftino prosao. Gde si bre Tutti, sunce ti kalajisano! Ovaj brat Primoz ima vise kaseta nego celi Priboj, o brate moj. Quote Link to comment Share on other sites More sharing options...
accuphase Posted February 22, 2010 Author Report Share Posted February 22, 2010 Gde si bre Tutti, sunce ti kalajisano! Ovaj brat Primoz ima vise kaseta nego celi Priboj, o brate moj. Eeee... a ovde se priÄalo, kako će ljudi in SLO skapati od gladi, poÅ¡to su nas svojedobno napustili !!! Samo se zaboravili jedna malu, malecku sitnicu... da tamo in SLO, vredno rade, i nekada, i tada, i sada... Quote Link to comment Share on other sites More sharing options...
Lakedemon Posted February 22, 2010 Report Share Posted February 22, 2010 Eeee... a ovde se priÄalo, kako će ljudi in SLO skapati od gladi, poÅ¡to su nas svojedobno napustili !!! Samo se zaboravili jedna malu, malecku sitnicu... da tamo in SLO, vredno rade, i nekada, i tada, i sada... Pa propali su, brat Primoz je izuzetak. Propao je ceo liberalni kapitalisticki svet, o braco moja. Back to the roots! Quote Link to comment Share on other sites More sharing options...
Tutti Posted February 22, 2010 Report Share Posted February 22, 2010 Nedam se ja, kupujem. Neke nisu NOS, ali boze moj. Nekada sam imao maniju da kupujem modele kaseta koje nemam, pa sad bas zavidim Primozu sto je naleteo na ovu ezoteriju. Sto se Slovenije tice - sve najbolje. Nigde nisam sreo predusretljivijih ljudi. Napravio sam i dokumentarac u trajanju od pola sata, cisto da se vidi kako pametni ljudi rade. Ma nisu propali daleko od toga, u ekonomiji su sasvim prirodne recesije koje se javljaju periodicno, ali "truli" kapitalizam uvek nadje nacin da prezivi. Quote Link to comment Share on other sites More sharing options...
PrimozS Posted February 23, 2010 Report Share Posted February 23, 2010 @Tutti - sa ezoterijom misliÅ¡ na Konico? Skoro niÅ¡ta ne naÄ‘em na netu ifnormacijo o toj kaseti ... ZnaÅ¡ kaj viÅ¡e? Ma ajmo, nije sve tako lijepo tu kod nas ... Sve polako ide u ... EUR je donesao samo veliki porast cjena (a vidi, plate ostale su praktiÄki na isti razini, samo su jih prekonvertirali u novu valutu). A Å¡to me najviÅ¡e nervira - sve manje je domaÄih proizvoda u duÄanima - pa kako je moguÄe, da se trgovcima viÅ¡e isplati kupovati luk u Kini a ne da ga kupe od domaÄeg kmeta :-S Itd. A Å¡to se kaseta tiÄe - pravi raj su SAD (kao i za npr vintage sprave od NAKa ili Sansui). Samo kaj kad je tu carina i priliÄno visoka poÅ¡tarina i tako ... pa se onda totalno ne isplati. MA da ne odemo preduboko u neke rasprave. Samo da naÄ‘em malo vremena, da: - poservisiram ZX-7 - s njime stestiram neke od ovih kaseta - pa da napiÅ¡em neke utiske Ali kad Äe bit to? Bbb. Nadam se da Å¡to prije ... Quote Link to comment Share on other sites More sharing options...
Donkey Posted February 23, 2010 Report Share Posted February 23, 2010 ja imam 10-ak Konica normal kaseta kupljenih pre 10-ak godina. Vrlo zadovoljan snimkom. Onako, fin sofisticiran zvuk. Srednji tonovi pomalo neupadljivi. Sumova nema, a nista , naravno nije snimano na profi opremi. Quote Link to comment Share on other sites More sharing options...
PrekoBare Posted February 23, 2010 Report Share Posted February 23, 2010 A Å¡to se kaseta tiÄe - pravi raj su SAD (kao i za npr vintage sprave od NAKa ili Sansui). Samo kaj kad je tu carina i priliÄno visoka poÅ¡tarina i tako ... pa se onda totalno ne isplati. Primoz, predlazem ti da potrazis nekog prodavca u NYC koji prodaje na veliko i da kupis 200 kaseta odjednom. Em ces dobiti kolicinski popust, em kad podelis shipping po kaseti izadje beznacajno. 200 kaseta = 20kg. Nek je shipping i $100 (a nije) to mu dodje $1.5 za kasetu i $0.5 za shipping. Nemoj samo da guglas, koristi i Yahoo i bing.com da nadjes prodavca. Moja preporuka za Nak je SA-X. To je ista traka koju je i Nakamichi prodavao pod svojim imenom (doduse sa boljom kontrolom kvaliteta) i neznatno je losija od MA-X. U Torontu vise SA-X nema, mislim da sam pokupovao sve sto je preostalo po kojekakvim opskurnim mestima. Maxell XL-IIS Made in England je onako, nikad ne znas sta si kupio dok ne probas. Medju onima koje sam kupio pre dve-tri godine bilo je dosta felericnih. Kad sam skoro naleteo na specijalna pakovanja u celofanu (7xXL-IIS C-90 + jedna C100 poklon) dogovorio sam se sa prodavcem da mi sacuva lot dok ne isprobam. Uzeo sam dva paketa nasumce, snimio i sve su bile dobre. Opet, macka u dzaku. Sony metal su takodje neujednacenog kvaliteta, UX nista ne valjaju a drugih Sony vise nigde i nema. Maxel XL_II i UR (mexico), TDK D, B, i slicne ne preporucujem. Kupovanje na parce se ne isplati, das vise para za postarinu nego za trake. Quote Link to comment Share on other sites More sharing options...
BRKA-65 Posted February 24, 2010 Report Share Posted February 24, 2010 Evo,videh ovo na KP,pa reko` mozda ce nekom da znaci. http://www.kupujemprodajem.com/TDK-vrhu ... -oglas.htm Quote Link to comment Share on other sites More sharing options...
Tutti Posted February 24, 2010 Report Share Posted February 24, 2010 Video, poslao poruku, ali se niko ne javlja. Moram kasnije nazvati. Za ljubitelje metal kaseta izuzetna prilika. Quote Link to comment Share on other sites More sharing options...
acazr Posted February 24, 2010 Report Share Posted February 24, 2010 Kasete su bruka stvarno vrhunska kolekcija,jedino me Brkin potpis zeza Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted February 24, 2010 Report Share Posted February 24, 2010 Јел неко звао за цену? Да организујемо Групну набавку зеоÐ_Ридер Quote Link to comment Share on other sites More sharing options...
BRKA-65 Posted February 24, 2010 Report Share Posted February 24, 2010 Kasete su bruka stvarno vrhunska kolekcija,jedino me Brkin potpis zeza Ma Aco,ce se skrpimo za koju... Quote Link to comment Share on other sites More sharing options...
