1,931 -
16
Everything posted by zoranzu
Kada se vec spominje ta linarnost,akademski... Uvazeni clan i dragi drug Mica Grozni ,mi je rekao da je u poseti fabrici Siemens cuo zvucnik Flat od 20 do 20 i da je to zvucalo kao g***no na kvadrat Kamo srece kada bi nas sluh bio toliko linearan i da nam ne treba DSP chipovanje da bi linearno culi
Neko sto finije i u sto tanjem sloju,ako imas nekog casovnicara u gradu,neka ti pozajmi jednu kap,mini spric za zubare i tanka igla Meni je proradilo citanje diskova na Sony RadioCd Playery,posle podmazivanja Atrix kremom za ruke ,nisam imao nista pametnije u tom trenutku
Ocisti i podmazi sinu po kojoj klizi laser
Kada na kutiji aspirina napisu cemu sluzi,pomaze ili sprecava,da li je to marketing?
Ene iznad,nadam se da ti engleski dobro ide,da ja nesto ne izgubim u prevodu
NETWORK WITH ANSUZ LAN SWITCH & CABLES The Ansuz PowerSwitches are LAN/Ethernet switches which epitomize a pioneering approach to both noise cancellation and signal distribution in High End streaming networks. The quality of musical streaming performance – either from a storage unit or from one of the streaming services is not only contingent upon the quality of your individual network streamer integrated in your audio system but also on the upstream network technology. Via the World Wide Web, the network streamer is exposed to all kinds of noisy electronics such as computers, routers, switches, etc. – where the noise floor does not matter in the same way as it does in audio streaming. And, since the Ethernet is a floating network, there is no ground connection to drain out the noise floor. So, the challenge is to get the audio data stream as clean and low noise as possible before it gets into the actual streamer. The new Ansuz PowerSwitches take an unprecedented approach to tackle the issue of noise suppression. They are all equipped with Ansuz’s innovative grounding circuitry that cancels out a large amount of all these noise disturbances. To lower this disturbing noise level to an absolute minimum, Ansuz has endowed their PowerSwitches with further innovative and remarkably effective noise suppressing technologies. Higher quantities and the latest, even more advanced versions of the Ansuz Tesla Coils define the range of network switches starting from the Ansuz X-TC entry level up to our D-TC Supreme flagship model. Since network switches are extremely sensitive to the quality of their power supply, all Ansuz PowerSwitches are equipped with their own internal power supply that boasts a particularly stable resonance mode. The noise cancelling technologies inside the Ansuz PowerSwitches work hand in glove with all the technological innovations used in all the other Ansuz products like the Mainz8 Power Distributor - a mains and ground distribution unit - or the PowerBoxes. Through the mains network and the powercords, the effects of these technologies are able to unfold both up- and down-stream, and form a mutually re-enforcing alliance when it comes to cleaning the audio data streaming from signal induced fluctuations and lowering the noise floor throughout the whole audio/video system. Ansuz PowerSwitches also feature a built-in PowerBox with 10 low power outputs - located below the eight LAN-ports - designed for Ansuz actively shielded Internet cables. These outputs can also be used to shield other active Ansuz digital cables. For Ansuz analog cables, we recommend using one of the Ansuz PowerBoxes separately.
Koliko kosta filter za vodu,koji ce makisku cesmusu da pretvori u izvorsku?
Kada nam postar bude donosio fajlove sa Tidala na kucni prag,uredno zapakovane i ciste od svega i svacega,audiofilski svic ide na otpad
Dobio bi samo bolji prikaz babe,mora devojka da bude na pocetku da bi video devojku na kraju
MP3 u najavi
Ono sto sam cuo od resoa sa manjom ringlom,oshurilo je Mos samo misliti kako ce tek ovaj da shuri
Koji lusteri su bili unutra? Ako su bili From Russia with love,zaboravi...
http://www.audiodrom.net/en/digital-sources Jos info,ima i SACD
Verovatno nisi nikada cuo M&D AMT
Ciroza u najavi
Naravno,kad na njemu pise Bullet 2803 bolje radi sa srebrnim WW,ako sme da napise kolega koji je poskidao sva ogledala u stanu
Bilo je toga u MKabel-u,pozlaceni francuski ili nemacki
PoP CoRn i Corn ..... Neko to i ovako vidi “Signal is inherently a plasma. Ionic plasma, or a [sic] electron cloud, with a pressure differential, with respect to the variant we call an ‘audio signal’.” Wire is a very imperfect medium
Samo Kanibal Napomena: odredjeni uredjaji ne mogu ostvariti protok signala na vecoj duzini od 5m bez extendera (pojacivaca)
I zasto nam ovo nisu rekli profesori u Tesli ili na ETF-u? LFD interkonekt the Raptor Interconnect Mk2 Uses 20 individual pure silver hand pulled silver conductors all of differing diameters some which are very large, with multiple satellite smaller conductors. The precise silver conductor diameter values are very important particularly of the smaller ones. Even a difference of 0.01mm has a major influence on the sound. The principle is that each diameter acts like a sharp filter and has to be combined within the cable to produce the correct subjective frequency and time domain response.
