civi
1,396 -
1
About civi
- Birthday 01/01/1970
Gender
Not Telling
civi's Achievements
- Rare
Kutije koje su dobile naziv ritam masina zbog izuzetno brzih i malih drajvera cije membrane imaju samo 5g , nove kostale oko 1300e , zicani i instrumenti generalno se cuju savrseno a za divno cudo imaju sasvim dovoljno dinamike i za klasiku ili elektronsku muziku , punjene kvarcnim peskom , fabricki odvojene gumenom suspenzijom od postolja tezina jedne preko 25 kg samo licno preuzimanje uz probu naravno(dolazim i za Beograd i mogu da ih ponesem ali samo ako ste ozbiljni) . . . Power handling: 175 Watts Impedance: 4 Ohms Frequency response (+/- 3 dB): 40 - 35.000 Hz Sensitivity (1W, 1m): 90 dB Crossover (24 dB/oct. 😞 700 / 3000 Hz Dimensions (W x H x D) cm: 13 x 105 x 27,7 Woofers: 4 x 4"
Canton uses a The equalization causes a significantly enhanced electronic equalization low bass reproduction. (SC filter) in the form of a 4th order bass filter The conversion to him a system of the 8th order has several advantages: Zurn one expands the usable frequency range clearly downwards (see upper diagram), for others decreases the necessary membrane without SC filter with SC fiber 20 Hr 100 Hz The SC filter leads to significantly reduced cone excursions. Frequency response uncorrected fiber The RC all-range equalization linearizes the entire listening range and thus ensures a smoother frequency response. deflection very clear. The reason: the bass reflex opening emits more levels, and the cone remains practically stationary at its tuning frequency (recognisable by the minimum movement), avoiding unnecessary reactive power. In addition to expanding the low-bass reproduction, the "Black Box" corrects amplitude fluctuations in the entire frequency spectrum (lower diagram). Subtraction of the calculated and uncorrected frequency response With the help of the two level controls (low and high) it is also possible to adapt to the listening room and its acoustics The small box is easy to loop in between the preamplifier and the power amp, or via a tape monitor in the case of integrated amplifiers that cannot be separated. CANTON RC
izvor samsung TV Sony MDS-JB 730 QS MD-Rekorder kao DAC Onkyo A-9555 kao amp Elac Edition One II kao zvucnici Fine Arts TT1 gramofon
najslabija karika ali radi jako lepo
lepo
kako god pozz
poredis dve dijametralno suprotne koncepcije kutija a nesto osetljivija ?? ergo 90 88,3 dB Karat 40 92,6 dB
imao sam i kutijie i pojacalo ne u isto vreme ali imam dovoljno iskustva da znam da se nebi slozilo
ja bih na tvom mestu jurio neku jacu yamahu ax serije sa cd direct ulazom ja sam imao ax 830 i to je teralo slicne kutije fantazija napominjem u cd direct modu tad obilazi preamp imao uporedo taj denon i sta da ti kazem...
po meni je mnogo svetao na tim kutijama a i zna da se pomucui na 4 oma na 8 radi prelepo
kutije su poprilicno teske za kontrolu tako da po meni taj 650 otpada kao i dosta komercijalnih ampova
