Da li bi bilo okej nesto ovako?
Pioneer GM-X334
Specifications
Continuous Power (20Hz-20kHz, 0.08% THD)
4 ch: (4 Ohm) 30Wx4
4 ch: (2 Ohm) 35Wx4
2 ch: (4 Ohm) 70Wx2
Maximum Power (EIAJ)
4 ch: (4 Ohm) 60Wx4
2 ch: (4 Ohm) 140Wx2
Frequency Response: 10Hz - 45kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4ohm )
Signal-to-Noise Ratio: 106dB (IHF-A Weighted, at 1kHz)
Dimensions: 8-1/8" x 2" x 10-5/8"
Features
Bridgeable 2/3/4 Channel Capability
PWM MOSFET Power Supply
Balanced Isolator Input Circuit
Screw-Type Power/Ground Terminals
Screw-Type Speaker Terminals
RCA Inputs (4 Channel)
Hi-Volt Input Level Control (400mV-4.5V)
Speaker Level Inputs (4 Channel)
Selectable Crossover: 80Hz, -18dB/oct. LPF or 80Hz, -12dB/oct. HPF (A,B Ch.)
Bass Boost (60Hz, 0 to +12dB)
