trendafil
Novi Ĩlanovi-
3 -
trendafil's Achievements
Razumem Da li mogu dobiti informaciju gde da odnesem uredjaj u Nisu, to mi je najblize?
Pa hteo bih da saznam da li je to problem, naravno da imam dobar servis u mestu otisao bih bez razmisljanja. Sto se tice releja, cuju se.
Postovani, dosao sam u posed pojacala koje je od samog starta imalo problem sa jednim kanalom, u smislu da se cuo tise, nekad se to pretvaralo u sum i posle nekog vremena se situacija popravljala. Sada vec dva dana na desnom kanalu se ne cuje nista. Takodje sustanje postoji i na levom ali povremeno. Ono sto sam uspeo da vidim jeste po nekim forumima da je ovo generalno cest problem sa ovim Pioneer-om. Pominju se neke diode, ne razumem se, pa ako moze pomoc da li ovo moze da resi problem? I was reading a thread on another forum where a member was also having trouble with his A-77X, although with noise in one channel. He was advised to check zener diodes 1-4 on the board labeled by the service manual "gwh-171" as well as two (C3 and C5) 100uf 25v electrolytic caps. Would this be well advised in my situation? It cured his issue. The diodes are only 22v half-watt parts- seems a little on the light side. Hvala unapred.
