14 -
sax's Achievements
Zek, muka mi je (citaj, omatorilo se) od jurcanja, citanja karakteristika... Imao sam lepe KEF zvucnike, gramofon, (prodao, moralo se, sada bih pojeo d.pe). Ostalo mi je Pioneer pojacalo, ovi zvucnici, par Sony (nikakvih) kutija i gore pomenuti Technics SA-AX730. Hocu, da bar pristojno zvuci npr: Take Five - Dave Brubeck Ili sto bi Ladovina rekao: " Ја сам презадовољан и бољи ми нису потребни."
ДЕ12/8 = http://www.diyaudio.rs/topic/420-skretnica/ ili visokotonac? Nemam gde da ih spakujem, preveliki su. DIY - otpada, jer nemam pojma o tome. U prastare SONY kutije, ne mogu da stanu.
Za neki iole pristojan par kucne verzije zvucnika.
Mozda neka zamena za ovo? B&C 10 NW 64 LF Drivers 10.0 inches Specifications Nominal diameter 250 mm (10.0 in) Nominal impedance 8 O Minimum impedance 6.5 O Nominal power handling 300 W Continuous power handling 600 W Sensitivity (1W/1m) 96.0 dB Frequency range 50 - 2500 Hz Voice coil diameter 64 mm (2.5 in) Winding material Copper Former material Glass Fibre Winding depth 16 mm (0.62 in) Magnetic gap depth 8 mm (0.31 in) Flux density 1.25 T Design Surround shape Double Roll Cone shape Exponential Magnet material Neodymium Inside Slug Spider Single Pole design Straight Pole Woofer cone treatment TWP Waterproof Both Sides Recommended enclosure 26.0 dm3 (0.92 ft3) Recommended tuning 53 Hz Parameters Fs 50 Hz Re 5.2 O Qes 0.27 Qms 4.5 Qts 0.26 Vas 27.5 dm3 (0.95 ft3) Sd 320.0 cm2 (50.0 in2) ?0 1.3 % Xmax 8.0 mm Xvar 10.0 mm Mms 47 g Bl 17.5 Txm Le 0.47 mH EBP 185 Hz Mounting And Shipping Info Overall diameter 261 mm (10.3 in) Bolt circle diameter 245 mm (9.6 in) Baffle cutout diameter 230.0 mm (8.8 in) Depth 113 mm (4.4 in) Flange and gasket thickness 13 mm (0.5 in) Air volume occupied by driver 1.5 dm3 (0.05 ft3) Net weight 2.9 kg (6.4 lb) http://www.bcspeakers.com/products/lf-driver/10-0/8/10nw64 http://www.lautsprecherteile.de/B-C-10-NW-64-8-Ohm_1
sax changed their profile photo
Samo gore navedena muzika. Ma, budzet :/ 100-150.
Imate li neki predlog, koje zvucnike upariti sa risiverom Technics SA-AX730? Muzika koja se vrti je pretezno dzez, bluz...
Jedino sto pise (osim oznaka elemenata) je kod tih crvenih zica ustampano na plocu - AC50A
E xxx, onda je japanska trafo-stanica (naravno mini). Hvala.
Najpribliznije je to, izgleda. Zar ne moze to da se utvrdi po nekom specificnom delu za napajanje?
@ivanp propustih sansu da pitam Konuzina. Na drugoj slici iznad tog crnog (trozilnog) kabla je bravica za kljuc? Ispod kabla je nalepnica na kojoj pise MODEL: LA-09102...(dopisano rucno).
