1,875 -
6
Everything posted by vdzele
Please Note: There are particular operating systems known to have problems with Micromega Mydac Usb Audio: Windows 7 Professional Windows XP Media Center Edition 2003 Windows XP 64-bit Edition If you encounter problems with the direct download for these operating systems, please consult the driver download manager for the specific Micromega Mydac Usb Audio model. http://semantic.gs/micromega_mydac_usb_audio_driver_download ------------------------------------------- My 2 week experiment with the Micromega MyDac hasn't been without issues. Connected to my Windows 7 Thinkpad, there is occasional stuttering (usually happens during first few songs of new listening session), occasional tiny clicks/pops during playback and sometimes the system just stops working. For some reason, sometimes Windows just stops recognizing the MyDac and hence there is no playback from foobar/iTunes (unknown output device error). This gets solved by disconnecting the MyDac, shutting down the music player apps and trying connecting again (quite a pain). http://forums.stevehoffman.tv/threads/entry-level-dac-wars-any-opinion-or-suggestion.316210/page-2 ----------------- Sve gore navedene opcije treba probati. Ukljucujuci I od Aleksandra75, od SonicHamera,...i ostalo
Stav po kome "Ne moze da bude nikakav sukob drajvera, sistem vrlo dobro zna koji drajver je gde potreban." je netačan. Ovo pričam iz ličnog iskustva, iskustva prijatelja i onog što su mnogi pisali po internetu. Ukucajte recimo u google "audio driver conflict" i naći ćete mnogo primera. Ako svi znamo da se preporučuje da uvek u sistemu postoji samo jedan driver za grafičku kartu, zašto to ne bi važilo i za audio uređaje? Naravno, sve ovo su ređi slučajevi ali ne treba ih isključiti. Problem oko drivera je siguran. Ja sam imao jednom problem sa mojim laptopom da nisam mogao da podesim moju NI Traktor Audio 2 i DAC koji je radio preko XMOS-a. Traktor kartica je pucketala preko njihovog ASIO drivera, dok DAC nije. Čim sam izbacio XMOS driver Traktor Audio 2 je proradio normalno. Drugi primer je moj postojeći DAC koji radi sa Amanero je bio u konfliktu sa XMOS-om od DAC koji je bio na probi kod mene. Itd... Drop-outs o kojima Willi piše je više problem koji je vezan za laptopove nego desktop konfiguracije. Kod laptopa je problem što je sav hardver veoma stešnjen i tu nastaju problemi. Pogotovo nastaju problemi kad se na laptop nakači spoljni audio uređaj. USB 2 linija zna da pravi problem kod ovih uređaja. Microsoft je izbacivao zakrpe za USB driver koji su nekima rešavali problem pucketanja laptop + audio uređaj. Ovaj problem je opet i vezan sa dropout-ima koje češće daje laptop. Postoje programi koji detektuju oprterećenost konfiguracije, vi zaustavite te procese i onda Win USB driver patch može da proradi. Treba probati i sa driverima tipa Wasapi i Asio, dali i preko njih ima pucketanja. Pa onda probati i sa drugim ulazima tipa optički. Siguran sam da preko optike neće biti problema. Po svemu sudeći problem nije vezan za operativni sistem već za driver i mislim da ovo što je Zexx napisao će najverovatnije da uradi posao. Ja bi pre napisao jedan email proizvođaču šta raditi nego davao nekom majstoru.
Vlajo - Ja sam napisao da se odpanje skoro do kraja, tu negde bi trebalo da počne zujanje (huk), prisloni uvo na zvučnik.
Ako se tiho zujanje javlja na potenciometru skoro do daske onda je to normalno, na pauzi ili bez pesme. To ima svaki amp.
Jesi posle brisanja reset kompa?
Ako si na svom kompjuteru instalirao 2 ili više drajvera za DAC onda može biti da imaš sukob drajvera. Drajveru od Micromege smeta drajver od nekog drugog DACa. Sve ih obriši i ostavi samo Micromegin Ovo nije nikakav problem, ako je ovo uzrok.
vdzele replied to TurboMaximus's topic in Hi-Fi audio
B C - Koliko te razumem ti predlažeš da za basove idu apsorberi a za srednje i visoke difuzori? -
Problem kod te kosine će biti basovi. Iz razloga što se oni kreću sferno oni će udarati u tu kosinu i možeš dobiti buumi zvuk. Tu je stišnjen prostor pa ćeš dobiti dosta više basa nego da ti je vertikala slobodna. Zato bi ja stavio tu difuzore - neka pravila oko njihovog pozicioniranja sam već opisao gore. Difuzori ne moraju biti onakvi kako ih WWallace pravi, može biti neka izlomljena polica, sa puno pregrada, za knjige i džidžabidže.... - samo nešto što će lomiti basove. Preporuka je drvo kao materijal. -
Po meni bolje je 1. Ovo iz razloga što je duža strana između tebe i zvučnika. Zvučnike gledaj da izvučeš što više od zida u kombinaciji 1. Primetićeš kad budeš sve sredio da će ti biti bolje i kad otvoriš vrata iza mesta sedenja. Ako se budeš odlučio da akustički sređuješ prostoriju u ovoj temi imaš sve opisano. -
@Ciki - Osvetoljubivost nije dobra ljudska osobina. Ona najviše govori o ljudima koji je koriste. Ja izbegavam takve ljude. Inače, dali znaš nekog ko je školovan da pravi zvučnike? Gde se izučava taj predmet? Po tebi ispada da samo ljudi koji su savladali elektrotehničke škole imaju pravo ovde nešto da pišu o samogradnji. Možda su čak oni jedini merodavni da ocenjuju HI FI uređaje?
Ovo je postalo jako odvratno. Pozivam moderaciju da učine nešto po pitanju ovih napada na nečiju ličnost. Koga briga što neka slika nije strogo u vinklu? Sem za ove isfrustrirane i dokone mrzitelje.
Nešto se nosim mišlju da postavim ove difuzore na plafon http://www.rfacoustics.com/proizvod/epsen-pro/ Zalepio bi 8 komada između zvučnika i gde se sluša, na sredini. U pitanju je stirodur (XPS) 46cm x 50cm x 6,5cm. Da li neko ima iskustva u radu sa ovim difuzorima? Vaše mišljenje i ako nemate. -
Ja sam napisao da sam vlasnik ovih kutija, među prvima sam ih kupio. Tu ima još ljudi koji su ih čuli, prođi kroz temu.
Odmah da napomenem da nisam ekspert za zvučnike. Vidim da ti toga dosta više znaš pa bi hteo neko pojašnjenje. Koja od ovih opcija je tačna: 1. Generalno se ni jedan zvučnik ne može tjunirati naspram ostatku sistema? Ovaj izraz je potpuno deplasiran kad je u pitanju odnos zvučnika i ostatak HI FI sistema? Ono što važi u auto industriji se ne može preneti na nivo HI FI-a? 2. Samo Bokijevi zvučnici se ne mogu tjunirati prema postojećem sistemu? Verovatno poznaješ sve karakteristike sistema pa znaš da je to nemoguće uraditi u datim okolnostima. 3 Boki nema dovoljno znanja i iskustva da tako nešto uradi. Opet, poznaješ ga lično pa znaš. 4. Tuning je jedan fiktivan, izmišljen, izraz koji nema nikakvu osnovu na relacijama rada HI FI komponenti - on samo služi u marketinške svrhe da bi neuki naseli i kupili spravu. 5. Možda ne vidim tako dobro kao ti, te nije ni jedna od gore četiri, pa ti ovde možeš dati svoje stručno objašnjenje: ___________________________........... Molim te, koja opcija je od ovih tačna?
BokiTokiVoki - Da li se mogu znati osnovni podaci o zvučniku: dimenzije, masa, koji su drajveri, impedansa,....?
Distributer sebi čini medveđu uslugu svojim ponašanjem - prepiranjem sa članovima foruma.
Kad završiš pozovi me da čujem opet. Doneću ti tada jednu simpatičnu igračku, mislim da češ se posle nje tek onda smiriti.
Dobar HI FI sistem bez difuzije je isti kao kad kupite Poršea i vozite ga po poljskim putevima., Mnoge će ovo iznervirati, ali što bi rekli globalisti - treba da prihvate realnost da je tako.
Najkritičniji deo je pojas od jednog basa do drugog. Počni da ih ređaš od dole tako da donja ivica difuzora bude na liniji donje ivice basa. Možeš staviti razmak između difuzora tako da oni obuhvate što veću površinu. I taj razmak predstavlja difuzioni prostor. Greška koju je napravio ovaj slici je ta što su difuzori otišli mnogo gore, tu gore se ništa ne dešava, niko nije toliko visoko da čuje šta se dešava gore. Trebao je sve spustiti dole za nekih 30-40cm. Difuziona ili apsorbciona visina treba da je do visine domaćina sistema, reda nekih 180-200cm. Gornji red bi ja skinuo i stavio sa strane tako rade posao od jedne vertikale zvučnika do druge. Nema ni neki tepih dole što je bez veze, doduše gore ima nešto. Ne treba zaboraviti da se bas zvuk prostire sferno što znači da oni idu i iza zvučnika. Zato je bitno da se difuzija stavi od jedne do druge vertikalne ose zvučnika, ako se može naravno. Za difuziju iza glave nije bitno da imaju toliko duboka ispupčenja jer će najkritičniji basovi biti sređeni tvojim gredicama od 15 i 20 cm između zvučnika. Za sve koji nameravaju da grade difuzore jedna bitna napomena. Ne treba ići sa ispupčenjima većim od 20cm. Posle 18-19cm svi kalkulatori pokazuju da rapidno opada difuziono zahvatanje u donjem spektru. Tako da ako želite da vam difuzor radi posao ispod 200Hz trebaće vam gredice mnoooogo duboke. Biće ovo najbolja difuzija na forumu. -
Zar neće biti neki live feed?
Ako bi morali da poštujemo to "pravilo od 3m" onda bi difuzori imali smisla u samo velikim sobama - što je besmisleno. Naprotiv, iz razloga što ljudi ne mogu da imaju velike sobe se stavljaju difuzori. Ovo ti iz ličnog istustva pričam dok mi je NN postavljao kod mene omnifjuzere. Prvo su stavljeni iza troseda gde se sedi i sluša, kauč je naslonjen na zid. Odmah po postavljanju su dobijeni jako dobri rezultati. Potom se stavljeni između zvučnika. Ovakvih primera ima bezbroj na internetu. Ja bi uzeo gredice dužine 5 i 10cm i napravio jedan 60x60 i stavio ga iza ti gde sediš. Može i neka druga dimenzija po volji. Ovim bi naravno proredio one koji idu između zvučnika ali ti i tako ostaju oni najbitniji od 15 i 20 i nešto od 5 i 10. Gledao bi da imam više sa 0cm izbočina (ravno). Ili bi pak uzeo gotov koji sam naumio da stavljam između zvučnika i prvo njega radi probe stavio iza glave - sa nečim ga privremeno podigao. Po iskustvu NN, po njemu, difuzori koji idu između zvučnika čine od prilike 60% posla, dok oni iza glave 30%. Ostalo su apsorberi sa strane. Kod NN stoje dva velika zvučnika od po 160kg, 2m visoki u prostoriji od prilike oko 15-16m2. To jako dobro radi jer su svuda difuzori, limit od 3m bi zvuk uništio. Ja bi kao zadnju stranu difuzora uzeo brezov šper 8-9mm zbog njegovih akustičnih osobina. Nemoj ničim gredice da mažeš, već sam ti napomenuo jednom da time ubijaš sonične osobine drveta - samo ih lepo išmirglaj. Svako mazanje veštačkim sredstvima se menja relativna gustina površine drveta a ona je najbitnija da ostane kako jeste. Ako namažeš posao je izgubio na smislu. Da li je akustična gitara iznutra sa nečim premazana? -
Svaka čast Wallace. Da li si možda merio koliko bi bio težak jedan? Naravno bez ploče. Koji je materijal u pitanju te gredice? Kad sam bio kod tebe preporučio sam ti da staviš dva komada iza mesta gde sediš [malo iznad]. Možda ćeš kasnije staviti? -
Slušao sam pre nekoliko godina u Voxu kod Mladje male desktop Dynaudio zvučnike, koštale su 1000 eura. Čini mi se da su napolje bile još skuplje. Bile su nešto manje od KSN. Kad se setim tog zvuka iz tih malih kutija onda bi KSN trebalo da budu daleko skuplje nego 1000 eura. Ali avaj... Ovde su ljudi paljevine za brand i to ti je to.
Ups Pero je već odgvorio
Da to izvođenje je bilo na drugo mesto da ga prihvatim. Japanac je uneo dosta improvizacije koje meni smetaju, ono na sredini pesme je prava katastrofa (1:30). Ako si pažljivo preslušao kako drugi diriguju oni takve hirove ne prave. inače je tehnički bolje urađeno izdanje. Dinamički raspon je 14 u odnosu na moj odabir 13. Šteta, ima mnogo osobenjaka u tom svetu klasike. Ja slušam muziku ipak, pa tek onda tehniku. Uzgred: da li znate da se album Supertramp - Breakfast in America, SACD izdanje, jako loše čuje? Neko mlađi bi se zaleteo i skinuo misleći da što to je snimak visoke rezolucije, [što i jeste], da je to garancija uživanja. Kad bi mu pustio neki dobar vinili rip ili CD first print - smorio bi se živ.
