271 -
Everything posted by agronk
Connect both drives to PC, Linux boot (Windosen helps Knoppix on), do not mount both drives, now find out which disk is under which path to achieve (ie / dev / hda or / dev / sda, depending on the connection). Is it 100% sure which disk where depends, you can start mirroring, mutatis mutandis, with the following command: Code: dd if = / dev / hda bs = 512 of = / dev / hdb Explanation: - / Dev / hda is here the source disk, so the original - / Dev / hdb is the second disk is written to which Mistaken terms of the disk's about that and the original is irrevocably gone! If anything is unclear, please ask first. Good Luck!
Ko ima iskustva, koji model? sta treba da se zna prije kupovine...
Ne vidim da ovo ti je brzija bilo u Wifi ili Lan-om ako tebi ovo odgovara onda nisi trebao niti pokrenuti temu oko NAS-a!!! ovo ti je adapter nista vise...
Koji format ima disk koji hoces da napravis "Mirror" ?
Ne nisam, namerno nisam koristio RAID u jedan HDD idu torrenti u drugi backup svega sto mi je bitno.
Muzi�ki server sa digitalnim izlazom (a da nije USB) a da nije ra�unar
agronk replied to Филип's topic in Šta da kupim?
"jel to sa prodavanjem muda za bubrege iz licnog iskustva"? jer vidim da uglavnom prodajes limene kutije sa ostrva punjenje vazduhom -
Nit manje Nit vise nije PC! nego "muzicki server sa digitalnim izlazom" http://designwsound.com/dwsblog/wp-content/gallery/aurender-w20/ces-2013-070.jpg -
http://www.aurender.com/products.html -
http://www.my-hiend.com/vbb/showthread.php?7357
http://www.catbank.jp/event/2013/ias2/dyna/index.html
http://www.catbank.jp/event/2013/ias2/linn/index.html
http://www.catbank.jp/event/2013/ias2/esoteric/index.html
http://www.catbank.jp/event/2013/ias2/accu/index.html
Tokyo Hi-End http://www.catbank.jp/event/2013/ias2/TAD/index.html
SACD player: http://tad-labs.com/en/consumer/d1000/ DAC: http://tad-labs.com/en/consumer/da1000/
McIntosh se rimuje sa bezkintos
McIntosh mvp-891 je u osnovi isto sto i ranije pominjani Marantz ud-9004 ili Denon dvd-a1ud, ali sa dodatkom 3d-reprodukcije bd-diskova ! I pride dekoduje hdcd/super hdcd cd-ove u punom kvlaitetu... http://www.mcintoshlabs.com/us/Products/pages/ProductDetails.aspx?CatId=blurayplayers&ProductId=MVP891
Kada cete dobiti MA silver seriju i koje su razlike u odnosu na staru seriju MA? http://www.whathifi.com/news/monitor-audio-announce-new-silver-series-line-of-speakers
Da! to su mi trazili i moderatori ali nisam sacuvao nazalost! jer za tvrdnju treba samo "dokaz" A taj "besni paja patak" je prosao kao i accu zbog istog trola, kojem administracija ne staje na put, a to sto je nesto "bilo pre dve godine" iz istih razloga je nebitno jel tako ?
Ti si bio saucesnik u tim gadostima, i bio si "prividno banovan", a accu nije "prividno"" nego je trajno ! Ako to nisu dvostruki arsini onda ne znam sta je, i mislim da nikako nije u redu.
Tako je Accuphase je trajno banovan zbog prepiske sa trolom, koji ga je izludjivao i nikakve molbe nisu pomogle da mu ga skinu s vrata ! A sta si ti uradio sem sto si trola podrzavao i pride "sammo malo" imao protiv "siptarske muzike", to je u redu i treba da ti sluzi na cast ? Koliko vidim taj trol i dalje izludjuje ljude, a ti si i dalje tu bez ikakvih posledica, za razliku od accu-a... I sve je to u redu i posteno ?
To sto je Accuphase Srbin a sto ima stav kakav ima, nema veze sa svim ovim ! Ono sto jeste PROBLEM je da je covek molio da ga ostave na miru, pa molio administraciju, i na kraju kraju krajeva sta ??? Da digne ruke, da pusti da ga ni krivog ni duznog razvlace na sve strane, jel bi ste i vi to uradili ?
