Krca44 Posted January 8, 2018 Report Share Posted January 8, 2018 Aha ! Video sam kod kolege sa foruma onu od kozije dlake, kod njega je radila jako dobro, mada koliko znam te su duplo skuplje od carbon fiber cetki Quote Link to comment Share on other sites More sharing options...
空也 Posted January 8, 2018 Report Share Posted January 8, 2018 Knosti Disco Antistat ima dve četke od kamilje dlake koje su vrlo efikasne u "iskopavanju" prašine iz brazdi. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted January 8, 2018 Report Share Posted January 8, 2018 Znaci tako se u stvari radi mokro pranje sa cetkom... Vrlo cesto na reklamama za mokro pranje prikazuju obicne karbon fiber cetke... imao sam sumnje da bi one bile stvarno efikasne za takav posao ( ja skidam fleke pomocu mikrofiber krpice al to nije isto ) Hvala za info ! Quote Link to comment Share on other sites More sharing options...
Aurelijano Buendija Posted January 8, 2018 Report Share Posted January 8, 2018 može mokro i bez četke Quote Link to comment Share on other sites More sharing options...
Krca44 Posted January 10, 2018 Report Share Posted January 10, 2018 Da li je ovo infra sonicna kada ? Bogami voleo bih da imam ovakav komad industrijskog postrojenja kod sebe Quote Link to comment Share on other sites More sharing options...
Zexx Posted January 11, 2018 Report Share Posted January 11, 2018 16 sati ranije, Krca44 said: Da li je ovo infra sonicna kada ? Bogami voleo bih da imam ovakav komad industrijskog postrojenja kod sebe Misliš, ultrasonična? Quote Link to comment Share on other sites More sharing options...
Krca44 Posted January 11, 2018 Report Share Posted January 11, 2018 5 hours ago, Zexx said: Misliš, ultrasonična? Da, vidis sta cine godine ( jos razmisljam dok sam pisao da li sam napisao dobro sinoc... ) Quote Link to comment Share on other sites More sharing options...
Father Posted August 15, 2018 Report Share Posted August 15, 2018 Kako mu je samo ovo palo na pamet!?? WD40 počinje negde na 3:00 min Quote Link to comment Share on other sites More sharing options...
Spachek Posted October 16, 2018 Report Share Posted October 16, 2018 Ne znam da li je bilo na prethodnim stranama, no, cini se kao fina sprava https://www.analogplanet.com/content/cleanervinyl-another-ultrasonic-record-cleaning-alternativeSent from my SM-A500FU using Tapatalk Quote Link to comment Share on other sites More sharing options...
Father Posted October 29, 2018 Report Share Posted October 29, 2018 Preko vikenda sam odvojio malo vremena da izvučem zaključke vezane za proveru WD40 čišćenje/podmazivanje brazdi koju sam započeo tokom prošle nedelje. Uzeo sam 2 pamučne krpice jednu filcanu podlogu (krep krpa), jedan devastirani vinil i WD40 sprej. Odabrao sam izuzetno oštećenu i staru ploču Demisa Rusosa koju je verovatno pre nego sam ja došao u njen posed puštalo gomila drugih ljudi. Dakle krckanje, puckanje, šumovi zvuk prepun badnjačke vatarice donekle matirana, šarena. Čišćenje je ne samo uklonilo neočekivano veliku količinu pucketanja i vratilo sjaj, već je sonično unapredilo reprodukciju da sam ostao vrlo iznenađen. Čišćenje: Jednu pamučnu krpicu sam naprskao sprejem i započeo trljanje u svim pravcima i napred/nazad i kružno i cirkularno kao kada se polira i poprečno, kako bih iz svih pravaca izvukao što više štroke ali i utrljao što ravnomernije WD40 u brazde. Nije potrebna prevelika količina WD-a niti pritiskati kao manijak, tek toliko da se ploča zasija. Treba trljati oko 7 min svaku stranu, menjajući poziciju na krpici da se ne vraća izvučeno natrag u brazde. Nakon uljenja, čišćenja i trljanja obe strane, uzeo sam drugu pamučnu krpicu i krenuo u isušivanje površine ploče. Istim pokretima trljanja i promenom površine krpe na čistiji deo. Trudio sam se da izvučem i isušim što više ostataka WD40 iz brazdi. Takođe je potrebno oko 5-7min po strani za ovaj proces. Nakon sušenja, na gramofonu sam ploču dodatno prošao nekoliko krugova u oba smera sa Analogis-ovom duplom Carbon/ Silk Brush 2 četkom koja između dve karbonske četke poseduje svileni filc. Izuzetna četka za skidanje elektrostatskog naelektrisanja i naj finijih čestica prašine. Obzirom da je ploča već prethodno dobro sasušena pamučnom krpicom, na četki se nije primećivalo da je WD40 navlažio. Neku izuzetno malu količinu WD-a su četke zajedno sa filcom ravnomerno rasporedile u brazde, a višak, ako ga je i bilo izvukle. Ploča ne miriše na WD40 nakon procesa. Istu ploču sam proveravao u tri dana nakon čišćenja i zvuk je uvek ostao nepromenjen ili čak za nijansu bolji, što pripisujem subjektivnom utisku jer sam već popamtio sve tonove i deonice... Testom od nekoliko dana sam utvrdio da se miris WD40 ne zadržava na vinilu niti u plastičnoj kesi u koju se ploča odlaže niti da WD40 ima bilo kakva degradirajuća dejstva na vinil ili menja zvučni utisak kako isparava ili se suši nakon konačnog isčetkavanja, sa neželećim povratkom na staro krckavo i puckavo. Šta više sonični boljitak nakon WD40 tretmana čak i na relativno čistim pločama donosi vrlo osetan napredak u smislu bolje tonalne slojevitost i separacije detalja što sam se uverio na RTB Karl Orf - Karmina Burana albumu, gde se dodatno izbistrio i jasnije prikazao, po meni jako lošen snimljen ženski deo hora. Instrumenti, muški solisti i muški deo hora je izvanredan i izuzetno prenešen. Ovde sam poslušao u originalnom stanju A stranu do pola i onda prebrisao ploču samo sa krpicom kojom sam sušio prethodni vinil. Dakle krpica koja na sebi ima jako malu količinu već isparenog WD-a, pročetkao malo na gramofonu i pustio ponovo. Uočljiva razlika u definiciji tonova i separaciji, praćena bogatijom detaljnošću suptilnijih tonova. Pretpostavljam da je WD40 lubrikant u izvesnoj meri smanjio površinki šum (smanjio trenje vrha) dopuštajući tonovima da se jasnije istaknu. Toliko o tome, mislim da je izuzetno interesantno, ali opet treba biti i izrazito oprezan, jer za početak, ova preporuka nema jasnu hemijsku potvrdu da WD40 vremenom neće naškoditi vinilu. Ja sam uzeo jednu od svojih najuništenijih ploča i jednu koja najbolje odslikava pucketavost RTB vinila, pa ću pratiti da li im se stanje menja kako vreme prolazi. Pozdrav! Quote Link to comment Share on other sites More sharing options...
anubisgrau Posted October 29, 2018 Report Share Posted October 29, 2018 ne smem ni da zamislim sta ti je ostalo na igli posle prolaska kroz rilne nakon takvog ciscenja. ovakvu metodu bih se usudio da preporucim samo ako nakon nje plocu stavis u UZ kadicu koja istera i ocisti iz brazdi svu stroku koju je rastvorio WD40. Quote Link to comment Share on other sites More sharing options...
Father Posted October 29, 2018 Report Share Posted October 29, 2018 Da to sam zaboravio da pomenem. Prvi put nisam brisao sa duplom četkom jer sam mislio da će se nauljiti pa sam posle procesa isušivanja odmah puštao. Osim ultra finih pamučnih dlaka ništa gnjecavo ili plastelinasto nije se hvatalo na igli. Obična četkica je lako uspevala da svuče sa vrha, posmatrao sam i to. Ranija iskustva sa starim pločama, koje je ko zna kako čistio ili nikada nije, dakle sumnjivog porekla, umeju da nalepe neke masne plastelinaste naslage koje samo magičnim sunđerom mogu da se odlepe. U ovom procesu je vrh čist ako se pre puštanja prečetka duplom četkom. Quote Link to comment Share on other sites More sharing options...
microfarad Posted October 29, 2018 Report Share Posted October 29, 2018 Bravo, na hrabrosti. Ja se ne bih usudio. Quote Link to comment Share on other sites More sharing options...
Father Posted October 29, 2018 Report Share Posted October 29, 2018 Radoznalost ubila mačku. Valjda neće biti tako... Quote Link to comment Share on other sites More sharing options...
Krca44 Posted October 29, 2018 Report Share Posted October 29, 2018 Proveri sastojke WD40. Isopropyl alkohol je jedini koji potpuno isparava a da ne ostavi nesto iza sebe. Ja bih posle WD40 ( ne znam napamet hemijski sastav ) oprao plocu ( isto tako detaljno ) destilovanom vodom da se ukloni bilo kakav moguci ostatak prljavstine i WD40 ( ako od njega ostaje nesto bez obzira sto ne mirise ). Quote Link to comment Share on other sites More sharing options...
Father Posted October 29, 2018 Report Share Posted October 29, 2018 Ja bih je eventualno oprao sa sapunicom za sudove i isprao destilovanom vodom pred sušenje, ali ipak neka ostane ovako pa ću da vidim kada se ponovo sretnem sa Demisom Rusosom na kafi. Inače danas sam kupio 50x140cm Turskog najkvalitetnijeg pliša za buduće trljanje sa WD40 sprejem, jer imam još 4 Demis-ova albuma u istom stanju, pa da trljanje podignem na viši nivo. Quote Link to comment Share on other sites More sharing options...
microfarad Posted October 29, 2018 Report Share Posted October 29, 2018 Kolega Father, jel si probao sa stolarskim lepkom, to jest tutkalom? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted October 29, 2018 Report Share Posted October 29, 2018 Možda Tigar bolje reši štroku. Quote Link to comment Share on other sites More sharing options...
Spachek Posted October 29, 2018 Report Share Posted October 29, 2018 Ne sumnjam da je probao, jednostavno voli covek da eksperimentiseSent from my SM-A500FU using Tapatalk Quote Link to comment Share on other sites More sharing options...
Father Posted October 29, 2018 Report Share Posted October 29, 2018 51 minuta ranije, microfarad said: Kolega Father, jel si probao sa stolarskim lepkom, to jest tutkalom? Jesam i dobro je bilo, ali nije delotvorno na matore ploče kao ova fora sa wd-om. Mislim da sam imao epizodu u adekvatnoj temi. Uspešno se završilo, al je daleko duži proces. Onako opsesivno čiščenje bi bilo... pranje, lepak, WD40 i opet pranje ... i onda te ostavi žena posle 10 ploča kada vidi svinjac po kući. Quote Link to comment Share on other sites More sharing options...
ivcha1976 Posted November 11, 2018 Report Share Posted November 11, 2018 Posle par godina iskustva sa UZ kadom - jos nisam otkrio bolji sistem za ciscenje ploca! Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted November 11, 2018 Report Share Posted November 11, 2018 Mislim da ni ne postoji. Svaka čast lepkiranju i tergitolu, ali UZ je majka mara za štrokave ploče. Quote Link to comment Share on other sites More sharing options...
ivcha1976 Posted November 11, 2018 Report Share Posted November 11, 2018 I za ciste - da skine sve ono ato pokupi ploca tokom bitisanja u omotu i na gramofonu. Quote Link to comment Share on other sites More sharing options...
shon3i Posted November 14, 2018 Report Share Posted November 14, 2018 @Father Moje iskustvo sa WD40 je isto pozitivno, i mislim da je WD40 must have u situacijama kada se radi neko digitalizovanje, a ploca nije u najboljem stanju ( a alterantive u tom trenutku nema tj druga ploca/kaseta itd.). Ako stignem za vikend probacu da napravim novu kopiju.. da vidim, da li se dogodila neka degradacija u zvuku nakon par meseci.. Quote Link to comment Share on other sites More sharing options...
VU metar Posted November 14, 2018 Report Share Posted November 14, 2018 WD40? Ste vi normalni? To sadrži neki lubrikant koji ne verujem da se može sprati destilovanom vodom. Kad dođe u kontakt sa iglom ako je vrh lepljen može da rastvori lepak. I sl. https://www.wd40.com/faqs Quote Link to comment Share on other sites More sharing options...
