Aoxomoxoa Posted December 29, 2017 Report Share Posted December 29, 2017 Potreban mi je preamp za gramofon. Pa se nesto pitam:u rangu 100e,da li da kupim poseban preamp,ili,sto bih radije,vintage pojacalo sa phono sekcijom? Nedoumica se ogleda u sledecem: 1. turnable > phono preamp > preamplifier > power amplifier 2. turntable > amplifier(with phono) > preamplifier > power amplifier Da li ce druga kombinacija degradirati zvuk u odnosu na prvu (pod predpostavkom da su oba phono istog kvaliteta)? Ako nece,odakle izvlacim kablove: tape out ili pre out (pojacalo ima mogucnost pre out/main in). Quote Link to comment Share on other sites More sharing options...
Kuršum Posted December 29, 2017 Report Share Posted December 29, 2017 Idi na prvu kombinaciju, pošto ovo kako si iskombinovao u drugoj, mislim da niko u svetu nema. I koji ti je taj preamp bez phono sekcije koji tako ljubomorno čuvaš u sistemu? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 29, 2017 Report Share Posted December 29, 2017 3 minuta ranije, Kuršum said: I koji ti je taj preamp bez phono sekcije koji tako ljubomorno čuvaš u sistemu? Лампаш. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted December 29, 2017 Author Report Share Posted December 29, 2017 Da,ja volim da malo iskomplikujem stvari.Mislio sam da ako moze pod 2,ostaje mi amp kao rezerva. Moj preamp ne cuvam ljubomorno,nego nemam para za nesto bolje. Quote Link to comment Share on other sites More sharing options...
Kuršum Posted December 29, 2017 Report Share Posted December 29, 2017 Ko ga je radio? Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 29, 2017 Report Share Posted December 29, 2017 Vukusic Quote Link to comment Share on other sites More sharing options...
zek Posted December 29, 2017 Report Share Posted December 29, 2017 Dogradi taj preamp sa phono sekcijom isto sa lampama i eto rešenja. Quote Link to comment Share on other sites More sharing options...
Kuršum Posted December 29, 2017 Report Share Posted December 29, 2017 Što ne zamoliš nekog da ti doda phono u taj preamp? Nije svemirska nauka. @edit preteče me zekonja. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 29, 2017 Report Share Posted December 29, 2017 Nije to los preamp uopste samo treba uzeti u obzir kako je radjen i koje su mu jake strane prilikom uklapanja u sistem. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted December 29, 2017 Author Report Share Posted December 29, 2017 Molim konkretno,moze li pod 2? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 29, 2017 Report Share Posted December 29, 2017 Ево нешто за размишљање: https://www.ebay.com/itm/ref-DUAL-circuit-MM-Phono-for-LP-turntable-Phono-Amplifier-board-OPA2111-ZHI/142573873503?hash=item213210a95f:g:qwEAAOSwLJ9aBS4q https://www.ebay.com/itm/Douk-Audio-6J1-Vacuum-Tube-Phono-RIAA-MM-Turntable-Pre-Amplifier-HiFi-AUX-Preamp/272259586931?hash=item3f63ef9b73:g:e3QAAOSw7U5Y-aVw Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted December 29, 2017 Author Report Share Posted December 29, 2017 Imam ja dosta strpljenja.Nemam dovoljno vremena(mislim na jos desetak kvalitetnihgodina zivota),pa bi ponovo postavio pitanje (ovog puta sa primerom): 1. Technics sl 150/Rega rb303/Ortofon m2blue > Rega phono > Audio Tube Labs preamp > power amp 2. Technics sl150/Rega rb303/Ortofon m2blue > Yamaha ca 810 > Audio Tube Labs preamp > power amp Da li kombinacija pod 2. degradira zvuk zbog dva predpojacivaca i odakle da vucem konekte iz Yamahe: iz tape out,ili pre out? Quote Link to comment Share on other sites More sharing options...
sondek Posted December 29, 2017 Report Share Posted December 29, 2017 39 minuta ranije, Aoxomoxoa said: Molim konkretno,moze li pod 2? Moze naravno.Signal Izvuces iz tape out-a.Ne mora da bude rdjavo.Danasnji preampi od sto evra su obicno ocajno napravljeni pa ce biti verovatno bolje od njih.Probao sam to sa mojim jednom prilikom i zvucalo je ok Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted December 29, 2017 Author Report Share Posted December 29, 2017 Hvala najlepse na konkretnom odgovoru.A za isti novac koji bi dao za poseban phono,dobicu rezervni amp,koji i bolje izgleda. Quote Link to comment Share on other sites More sharing options...
Kuršum Posted December 29, 2017 Report Share Posted December 29, 2017 Zar već nisi imao takvu budževinu (samo što su čini mi se bila dva preampa vezana) i isto ovo ti je rečeno, sad opet pitaš? Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted December 29, 2017 Author Report Share Posted December 29, 2017 Imao sam ,ali to nije radilo nikako,pa ako ovo moze, znaci da taj moj preamp sa phono ne radi dobro.Moram da budem siguran,imam samo jedan pokusaj kupovine. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 29, 2017 Report Share Posted December 29, 2017 Ako uzmes signal sa Tape Outa trebalo bi da preskocis linijski deo Yamahe. Barem je tako izvedeno kod mene na Luxmanu i koliko znam tako su radili Japanci. Kad snimas sa gramofona tonske kontrole i linijski deo nemaju uticaj u ovom slucaju. Ako bas zelis Yamahu, mozda ce ona da ti radi zadovoljavajuce i solo a mozes i na lampaski preamp. Ako je moguce pokusaj da cujes kod sebe. Ako hoces ja mogu opet da donesem phono pa da slusamo ploce a ti kombinuj kako ce ici signal posle phono preampa... da li ce ici u lampasa ili ce ici u linijsku sekciju tranzistorskog preampa. Ako nesto znaci makar informativno ja mogu doci. Neka se javi i neko drugi sa phono preampom. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 29, 2017 Report Share Posted December 29, 2017 Е комбинације су сачувај боже. @Aoxomoxoa пазари нешто са ибеја и угради у постојећи преамп, какви црни тејп аути и обрнуто. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted December 29, 2017 Author Report Share Posted December 29, 2017 Yamahu sam imao,a sada mi se cini dosta primamljivom za moje trenutno stanje.Nemam phono preamp,Yamaha ima dobar preamp.Imam pojacalo snage,a Yamaha ima pre out/main in,pa mogu da je probam kao snagasa.I sve to za razumnu cenu. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted December 30, 2017 Author Report Share Posted December 30, 2017 43 minuta ranije, Krca44 said: Ako hoces ja mogu opet da donesem phono pa da slusamo ploce a ti kombinuj kako ce ici signal posle phono preampa... Hvala Krco,kad ovo resim,slusacemo ploce sa zadovoljstvom. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 30, 2017 Report Share Posted December 30, 2017 Nema na cemu, bitno da resis. Ne bih da forsiram svoje resenje ali velim ako bi nesto znacilo tu sam. Quote Link to comment Share on other sites More sharing options...
sondek Posted December 30, 2017 Report Share Posted December 30, 2017 ma ova varijanta preko tape monitora je "hevi djuti",dok se ne pristedi za nesto bolje.Svakako mislim da je bolje nego uzeti neko tesko budzet resenje pa zaglaviti s njim.Fali tu jos svasta pomalo u sistemu ali zvucnici su tu kao konstanta i na kraju bi i na izvoru trebalo da se nadje nesto zglavno.Gledajuci polovnjake po ebay iz nesto vise klase dynavector 75nalazim za vrlo hvaljen preamp.Ima li ga neko kod nas? Quote Link to comment Share on other sites More sharing options...
zoranzu Posted December 30, 2017 Report Share Posted December 30, 2017 Ocekivati od fono pre ampa do 100€ ili kineskih pracki sa e baya od 50$ da sviraju ....fail Uz postojeci gram/ruka/glava kombo, ide nesto mnogo skuplje i ozbiljnije Douk clone EAR 834 recimo za pocetak Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted December 30, 2017 Report Share Posted December 30, 2017 10 minuta ranije, zoranzu said: Douk clone EAR 834 recimo za pocetak Јес' када би дотични члан хтео да се отвори за 100$ и то у кит варијанти (са ибеја) без мрежног трансформатора. Quote Link to comment Share on other sites More sharing options...
Krca44 Posted December 30, 2017 Report Share Posted December 30, 2017 Sindricev phono je 250 eu. Kako svira za te pare neka kazu drugi, ja necu da hvalim svoga konja. Znaci to mu dodje skoro isto kao kit varijanta od 100$, carina, rad, trafo i kutija ako je ne daju Kinezi. Solaja je najavio phono u Sedra seriji, to je valjda oko 300 plafon 350 Eu, ne znam tacno cene. To je za gotove proizvode od nasih ljudi. Nesto sam malo googlao za Douk Clone EAR 834.... iz ovlas pregleda, neka me molim ispravi neko ko zna vise, vidim da dobijes jeftinu kinesku robu koja radi a koju mnogi poboljsavaju i dodatno modifikuju da radi bolje. Aox ako ti bas treba nesto sto ce da radi dok ne kupis dobar phono ja ti nudim na upotrebu Luxman L2 pojacalo, isto kao na Yamahi uzmes signal sa tape outa. Ne trazim ti nista, ako hoces dodji po njega i vrati mi ga do 1. Juna 2018. godine, tada pocinje tropikalija pa mi treba. Subsonic Filter se drzi upaljen da membrana levog zvucnika ne talasa i to je sve. Ja sam koristio tako gramofon simultano Luxman sa Akai kutijama ili preko tape outa na Lampas i B&M zvucnike. Posle sam kupio lampaski phono i oterao ove Japose iz sobe. Quote Link to comment Share on other sites More sharing options...
