DejanM Posted September 17, 2017 Report Share Posted September 17, 2017 Za konvertovanje audio formata mogu da preporucim XRECODE 3. Kosta 10 eura (godinama sam koristio verziju 1 i ona je bila besplatna.) Medjutim kada sam video sta sve moze ova verzija 3, mislim da to vredi 10 eura. Ne samo sto mozete da konvertujete sve u sve (podrzani su i DSD formati 64, 128, 256, 512), nego mozete i da raspakujete ISO files ili recimo da upsamplujete PCM u zeljenu rezoluciju. Postoji i Tag Editor ako zelite da dobro dokumentujete svoju muzicku kolekciju i jos dosta toga. Postoji 30 dana besplatni test period - svakako vredi probati ... Quote Link to comment Share on other sites More sharing options...
Kuršum Posted September 17, 2017 Report Share Posted September 17, 2017 Hvala, već danima razmišljam kako da konvertujem neke ISO fajlove koje mi čita samo Albumplayer.ru, a lepi albumi su mi na njima. Baš ću da probam sa ovim. Quote Link to comment Share on other sites More sharing options...
perodeformero Posted September 17, 2017 Report Share Posted September 17, 2017 Iso fajlove je najbrže konvertovati u winRARu, što novija verzija, to bolje. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 17, 2017 Report Share Posted September 17, 2017 18 minuta ranije, perodeformero said: Iso fajlove je najbrže konvertovati u winRARu, što novija verzija, to bolje. SACD ISO? Ne mere to... Quote Link to comment Share on other sites More sharing options...
perodeformero Posted September 17, 2017 Report Share Posted September 17, 2017 E, ali Kuršum je pomenuo samo ISO fajlove. t,j, neke Quote Link to comment Share on other sites More sharing options...
Kuršum Posted September 17, 2017 Report Share Posted September 17, 2017 SACD da. Quote Link to comment Share on other sites More sharing options...
空也 Posted September 17, 2017 Report Share Posted September 17, 2017 Ako nisi picajzla, i nećeš da se baviš alatima iz komandne linije za izvlačenje dsd fajlova iz iso i naknadno koverziju Weiss Saracon-om, Foobar (uz plugin) omogućava konverziju SACD iso fajlova u PCM. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 17, 2017 Report Share Posted September 17, 2017 7 minuta ranije, 空也 said: Ako nisi picajzla, i nećeš da se baviš alatima iz komandne linije za izvlačenje dsd fajlova iz iso i naknadno koverziju Weiss Saracon-om, Foobar (uz plugin) omogućava konverziju SACD iso fajlova u PCM. Ne mora baš tako nekomforno, Sonore alat ISO2DSD "čupa" DSF/DFF fajlove kroz GUI. Sledeći korak može da bude Saracon, ili recimo KORG AudioGate, kome čak dajem malu prednost jer ima mogućnost automatske normalizacije DSD fajlova koji su standardno tiši u proseku 6 dB. Normalizacija može da se uradi i u Saraconu, naravno, s tim da DSD fajlovi prethodno moraju da se provuku kroz neki softver koji je u stanju da izmeri dinamički opseg. Foobar je jednostavan za upotrebu, ali ograničenih mogućnosti, mislim da je krajnji domet 24/44.1 pri konverziji DSD u FLAC, recimo, a ne postoji ni mogućnost normalizacije. Quote Link to comment Share on other sites More sharing options...
空也 Posted September 17, 2017 Report Share Posted September 17, 2017 Ako me sećanje dobro služi, sa nekim plugin-om koji sam davno probavao u Foobar-u nije bilo ograničenja sample rate-a, dobijao sam 24/88.2 fajlove, a bilo je moguće i zadati korekciju glasnoće u dB. Foobar odavno ne upotrebljavam pošto primarno koristim Mac, a za brzu SACD iso to FLAC konverziju tu je XLD koji radi odličan posao - nisam uspeo da čujem razlike između njegovih konverzija i onih koje sam dobijao uz pomoć Saracon-a, a postupak je neuporedivo komforniji. Quote Link to comment Share on other sites More sharing options...
DejanM Posted September 18, 2017 Author Report Share Posted September 18, 2017 Jedino sto nisam uspeo da pronadjem kod XRECODE 3 jeste raspakivanje velikog FLAC file-a uz pomoc CUE file-a. Za to sam morao da instaliram Medieval Cue Splitter. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 18, 2017 Report Share Posted September 18, 2017 2 sati ranije, DejanM said: Jedino sto nisam uspeo da pronadjem kod XRECODE 3 jeste raspakivanje velikog FLAC file-a uz pomoc CUE file-a. Za to sam morao da instaliram Medieval Cue Splitter. Files, Add, ili Ctrl+O. Quote Link to comment Share on other sites More sharing options...
DejanM Posted September 18, 2017 Author Report Share Posted September 18, 2017 16 minuta ranije, Zexx said: Files, Add, ili Ctrl+O. Ali kada sam rekao extract - nista se ne desava. Quote Link to comment Share on other sites More sharing options...
Zexx Posted September 18, 2017 Report Share Posted September 18, 2017 1 minut ranije, DejanM said: Ali kada sam rekao extract - nista se ne desava. Pa šta da ti kažem, il' nije ptičar, il' ga ti prenisko bacaš... Šalim se malo, treba ti Encode, a ne Extract, pa Start, i to je to. Quote Link to comment Share on other sites More sharing options...
DejanM Posted September 18, 2017 Author Report Share Posted September 18, 2017 Hvala. To mi nije palo na pamet ... Quote Link to comment Share on other sites More sharing options...
WTF Posted September 18, 2017 Report Share Posted September 18, 2017 Meni Foobar radi sve: SACD iso u wav/flac (sample rate odaberem u SACD pluginu - od 88,2 do 352,8 kHz), sva ostala konvertovanja, čak i povremeno friziranje zvuka pri konverziji (uneo sam neke omiljene vst plugine). Jedino što za up/downsampling koristim Korg ili RBrain vst (besplatan) a SACD iso (zbo tagova) konvertujem u .dsf pomoću besplatnog SACDExtract koji ima jednostavno prozorče u koje se prevuče iso, izabere stereo/multichannel i gotovo. Za tagove Tag&Rename koji podržava dsf. Quote Link to comment Share on other sites More sharing options...
