Aoxomoxoa Posted July 12, 2017 Report Share Posted July 12, 2017 Trenutna postavka sistema: CD plejer- QUADRO DVD, predpojacalo -Vukusic, pojacalo snage DIY klasa A, zvucnici- HARBETH P3ers. Kupovinom zvucnika dobio sam zvuk koji mi odgovara u potpunosti(a u skladu sa mogucnostima).Do kraja godine ulozio bih do 400e za najslabiju kariku sistema,tj. izvor. Znaci,predstoji mi nekoliko meseci slusanja i probe,iskljucivo u mom okruzenju,ali da bi suzio potragu,zanima me sledece:sta bi donelo bolji zvuk 1.Quadro dvd(ili neki drugi jevtini transport) + DAC ili 2. CD plejer(ako je stariji model,da postoji nabavljiv laser). Unapred hvala na sugestijama. Quote Link to comment Share on other sites More sharing options...
nino69 Posted July 12, 2017 Report Share Posted July 12, 2017 Ako ćeš i dalje slušati samo CD-e bolje kupi pošteni player, za 400€ se može naći dosta toga. Nekako mi taj Quadro kao transport ne ulijeva povjerenje. Quote Link to comment Share on other sites More sharing options...
TurboMaximus Posted July 12, 2017 Report Share Posted July 12, 2017 Ni meni. Quote Link to comment Share on other sites More sharing options...
trotter Posted July 12, 2017 Report Share Posted July 12, 2017 Nov plejer, DAC i strimer za ~400 evrovahttp://shop.4audio.rs/shop/cd-plejeri/yamaha-cd-nt670/Jedino mu fali par centimetara u sirinu da bi se mogao smatrati audiofilskom komponentom, sto tebi mozda moze biti nebitno, je li...Sent through walls Quote Link to comment Share on other sites More sharing options...
ab Posted July 12, 2017 Report Share Posted July 12, 2017 http://www.audiophonics.fr/fr/dac-avec-volume/furutech-adl-gt40a-alpha-dac-adc-24bit192khz-preampli-phono-ampli-casque-p-10135.html Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 12, 2017 Author Report Share Posted July 12, 2017 1 sat ranije, trotter said: Nov plejer, DAC i strimer za ~400 evrovahttp://shop.4audio.rs/shop/cd-plejeri/yamaha-cd-nt670/ Neka bude opcija. Ali tezina 2.9kg? Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 12, 2017 Author Report Share Posted July 12, 2017 31 minuta ranije, ab said: http://www.audiophonics.fr/fr/dac-avec-volume/furutech-adl-gt40a-alpha-dac-adc-24bit192khz-preampli-phono-ampli-casque-p-10135.html Ako treba da bude DAC,neka bude klot ,tako da ne odvlaci novac za dodatne opcije.Neka i njega na listi. Quote Link to comment Share on other sites More sharing options...
ab Posted July 12, 2017 Report Share Posted July 12, 2017 http://www.kupujemprodajem.com/M2Tech-HiFace-EVO-Combo-47904652-oglas.htm?filter_id=147 Uokviru budzeta, moze i samo dac sto bi bilo daleko ispod budzeta. Quote Link to comment Share on other sites More sharing options...
trotter Posted July 12, 2017 Report Share Posted July 12, 2017 Neka bude opcija. Ali tezina 2.9kg?Što jes jes, kako plejer dac strimer od 2 kila sa zvucnicima od po 6 kila komad Sent through walls Quote Link to comment Share on other sites More sharing options...
den!s Posted July 12, 2017 Report Share Posted July 12, 2017 Ako u neko dogledno vreme ipak kreneš ka računaru kao izvoru onda je možda bolja opcija DAC posebno i neki jeftiniji CD player kao transport (neki Philips ili Marantz koji imaju CDM 12.1 transport, od nekih 2.000 dinara, a radi odlično) koji se može naći za 40-50 evra. Taj player nije skup, tako da uvek može da ti bude tu kao transport. A takođe dajem glas za predlog @ab, za M2Tech Evo DAC za 200 evra. off: Mada se uvek može naći neko ko će te preporuke svrstati pod „uvaljivanje“. Ali se nadam da nema mnogo toliko pametnih. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 12, 2017 Author Report Share Posted July 12, 2017 50 minuta ranije, ab said: http://www.kupujemprodajem.com/M2Tech-HiFace-EVO-Combo-47904652-oglas.htm?filter_id=147 Hvala,i on dolazi u obzir. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 12, 2017 Author Report Share Posted July 12, 2017 14 minuta ranije, den!s said: off: Mada se uvek može naći neko ko će te preporuke svrstati pod „uvaljivanje“. Ali se nadam da nema mnogo toliko pametnih. Nema uvaljivanja,za to vreme dok skupim pare,zaboravice na mene. Quote Link to comment Share on other sites More sharing options...
den!s Posted July 12, 2017 Report Share Posted July 12, 2017 Naravno. Imam takav konverter. Sa laptopom MacBook Pro kao izvorom se odlično pokazao. Upoređivao sam ga sa 4-5 konvertera slične i više klase i bio je bolji. Platio sam ga, čini mi se, 250 tada polovnog, a poredio sa klasom do otprilike 500 evra. A za slušanje diskova, optičkim kablom sam ga povezao sa Marantz CD playerom CD 5001. I to radi vrlo korektno. Quote Link to comment Share on other sites More sharing options...
ab Posted July 12, 2017 Report Share Posted July 12, 2017 Koji opticki je dobar za tu svrhu? Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 12, 2017 Author Report Share Posted July 12, 2017 3 minuta ranije, den!s said: A za slušanje diskova, optičkim kablom sam ga povezao sa Marantz CD playerom CD 5001. I to radi vrlo korektno. U stvari,to me interesuje,kolika je razlika u zvuku Marantz vs Marantz+DAC,u odnosu na ulozeno. Quote Link to comment Share on other sites More sharing options...
trotter Posted July 12, 2017 Report Share Posted July 12, 2017 Kakve veze sad kablovi imaju sa ovom temom? Sent through walls Quote Link to comment Share on other sites More sharing options...
den!s Posted July 12, 2017 Report Share Posted July 12, 2017 2 minuta ranije, Aoxomoxoa said: U stvari,to me interesuje,kolika je razlika u zvuku Marantz vs Marantz+DAC,u odnosu na ulozeno. Velika. Sad zavisi od kriterijuma, ali se razlika bez problema uočava na promenu uređaja u većem vremenskom intervalu, tj. ne mora da se koristi AB test da bi se razlika čula. Kada se kao DAC koristi M2Tech zvuk je muzikalniji, detaljniji, zvonkiji, dinamičniji… Lično smatram da vredi uložiti 200 evra za tu razliku u kvalitetu reprodukcije. Plus što je taj Marantz CD 5001 ocenjen kao odličan player, sa odličnim DA konverterom. Znači da bi sa nekim lošijim razlika bila verovatno veća. Nema tu nekog uklapanja, sinergije, i ne znam ti ja šta slično. Jednostavno ta kombinacija eksternog DACa daje bolji zvuk na istom „tehničkom“ poređenju. Pre tog Marantza sam koristio (i dalje ga imam) Pioneer DVD player. Ni za njega ne mogu reći da je loš kao transport, ali je on baš pravljen „mekano“ i plastično… Quote Link to comment Share on other sites More sharing options...
den!s Posted July 12, 2017 Report Share Posted July 12, 2017 10 minuta ranije, trotter said: Kakve veze sad kablovi imaju sa ovom temom? Pomenuo sam optički kabel jer mi je koaksijalnim vezan laptop... Quote Link to comment Share on other sites More sharing options...
ab Posted July 12, 2017 Report Share Posted July 12, 2017 Nema, mene interesuje zbog daca koji Den!s ima, smeta? Quote Link to comment Share on other sites More sharing options...
den!s Posted July 12, 2017 Report Share Posted July 12, 2017 Nismo se možda razumeli? Ni ja ne shvatam poentu pitanja. A ja koristim jeftini Audioquest Forest od 1,5 m. Quote Link to comment Share on other sites More sharing options...
trotter Posted July 12, 2017 Report Share Posted July 12, 2017 Koja zavrzlama dok se menjaju postovi...@denis AB je pitao malopre za opticki kabl, vidi iznad, post #14.@ABSmeta, kao i uvek kad je tema jasna a ekipa kablomana je raspline posle trece strane do neraspoznatljivosti...Sent through walls Quote Link to comment Share on other sites More sharing options...
ab Posted July 12, 2017 Report Share Posted July 12, 2017 Ja sam dobio odgovor, nema potrebe da se obazires na to. Quote Link to comment Share on other sites More sharing options...
trotter Posted July 12, 2017 Report Share Posted July 12, 2017 Ovo je tvoj privatni forum?Sent through walls Quote Link to comment Share on other sites More sharing options...
ab Posted July 12, 2017 Report Share Posted July 12, 2017 Trolujes, vise prostora zauzimas nego moje jedno pitanje i odgovor koji sam dobio. Quote Link to comment Share on other sites More sharing options...
Aoxomoxoa Posted July 12, 2017 Author Report Share Posted July 12, 2017 10 minuta ranije, den!s said: Velika. Sad zavisi od kriterijuma, ali se razlika bez problema uočava na promenu uređaja u većem vremenskom intervalu, tj. ne mora da se koristi AB test da bi se razlika čul Hvala na odgovoru.Molim i ostale dobronamerne kolege da,ako imaju konkretno iskustvo da ga prezentuju. Quote Link to comment Share on other sites More sharing options...
