giZ_Mo Posted April 28, 2017 Report Share Posted April 28, 2017 Ако нешто крене по злу немој се секирати. НОС(NOS) Quote Link to comment Share on other sites More sharing options...
mutayu Posted April 28, 2017 Author Report Share Posted April 28, 2017 E to! 48 u originalnom stanju! Rezervni plan uvek mora da postoji. Cim spalim ovaj moj stari javljam ti se da se dogovorimo! Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 28, 2017 Report Share Posted April 28, 2017 Ма нема проблема, Иначе плочице су извађене из 100% исправног уређаја јер се "Прелепа" кутија једноставно распала и није јој било помоћи. Quote Link to comment Share on other sites More sharing options...
mutayu Posted April 28, 2017 Author Report Share Posted April 28, 2017 Inace se vec neko vreme nosim mislju da jedan risiver pretvorim u pojacalo koristeci ove komponente po ugledu na pojacalo Ei HSP 40. Inace upravo sam primetio u semi za pojacalo HSP40 da je vrednost mirne struje tamo data 35mA . Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 28, 2017 Report Share Posted April 28, 2017 Лепо Ја написах. Quote Link to comment Share on other sites More sharing options...
mutayu Posted April 28, 2017 Author Report Share Posted April 28, 2017 Sad bar znamo koliko treba da bude. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 28, 2017 Report Share Posted April 28, 2017 Ма знао сам то одма' ал' нисам 'тео да издам ЕИ . Quote Link to comment Share on other sites More sharing options...
mutayu Posted April 28, 2017 Author Report Share Posted April 28, 2017 Ne treba tek tako odavati podatke. Neprijatelj ne spava i zato ga mozemo prepoznati po velikim podocnjacima! Quote Link to comment Share on other sites More sharing options...
空也 Posted April 28, 2017 Report Share Posted April 28, 2017 49 minuta ranije, mutayu said: Inace se vec neko vreme nosim mislju da jedan risiver pretvorim u pojacalo koristeci ove komponente po ugledu na pojacalo Ei HSP 40. Nemoj! Šteta bi bilo! Ja tražim da kupim odlično očuvan HSR 40, iz sentimentalnih razloga. Nabavio sam njegove originalne zvučne kutije, one sa drvenim frontom sa vertikalnim prorezima. Ako ćeš da ga kasapiš, bolje ga prodaj meni. Quote Link to comment Share on other sites More sharing options...
mutayu Posted April 28, 2017 Author Report Share Posted April 28, 2017 Necu da diram HSR40 on mi je ispravan i lep, imam i te kutije ZK40 ( isto kopija Duala) u tehnicki besprekornom stanju. HSR48 mi je smrljav, za izlomljenim potenciometrima pa sluzi kao skolski uredjaj, on ce mozda da postane pojacalo. Trazim i HSR48V u dobrom stanju a voleo bih da nadjem i RIZ 7150 ali to je vec gotovo nemoguca misija. Quote Link to comment Share on other sites More sharing options...
Корњача Раде Posted April 29, 2017 Report Share Posted April 29, 2017 Ja koristim HSR 48 De Luxe, a izvor mi je Pioneer CLD. Quote Link to comment Share on other sites More sharing options...
mutayu Posted June 19, 2017 Author Report Share Posted June 19, 2017 Zavrsio sam i teski remont na HSR 48 i uradio odgovarajuca merenja i podesavanja. Pojacalo na ovom uredjaju je integrisano, kvazi komplementarno pojacalo koje radi u AB klasi. Trimerom P804 se podesava simetricnost tj. polovina napona napajanja. Prema semama ta polovina treba da iznosi 17,5V. Meri se na + nozici kondenzatora C818. Nema mogucnosti za podesavanje mirne struje trimerima. Uredjaj je sada na intenzivnom sviranju ne bi li pokazao eventualne nedostatke. Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 23, 2017 Author Report Share Posted August 23, 2017 Evo opet malo da odgovorim sam sebi ! Doterao sam uredjaje u tehnicki ispravno stanje, intenzivno ih slusam a rad na njima mi predstavlja pravo zadovoljstvo. Sada bih voleo da mi preporucite neka proverena tehnicka unapredjenja koja bih mogao da izvedem na HSR48. Procitao sam negde preporuke pok.Bore Jagodica i dodao kondenzatore paralelno diodama u Grecu i velikom elektrolitu u napajanju. Interesuje me sta bi jos moglo da se odradi na napajanju i pojacalu i da se iz starog "kolosa socijalisticke misli" izvuce jos kvaliteta? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 23, 2017 Report Share Posted August 23, 2017 1 sat ranije, mutayu said: Interesuje me sta bi jos moglo da se odradi na napajanju i pojacalu i da se iz starog "kolosa socijalisticke misli" izvuce jos kvaliteta? Замени само главни електролит који је у напајању новим и то би била једина промена која би требало да се уради. Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 24, 2017 Author Report Share Posted August 24, 2017 Evo umesto velikog debelog ugradjen je mali debeli i paralelno sa njime ( po Borinom receptu) mali cetvrtasti. Efekti su neverovatni, basovi su masniji, visoki su otvoreni u struku, fagot je istaknut a pevacica u sredini. Salim se, naravno! Radi normalno, nista se ne greje i ne dimi, peva kao slavuj. Citao sam mnogo o ovom uredjaju i svi se hvale kako su svojevremeno radili svakakve zahvate na svojim HSR-ovima ali nijednog konkretnog predloga ni resenja. Voleo bih da mi preporucite sta moze jos da se odradi, ovaj uredjaj mi je rezervni, ne rizikujem nista a vreme provedeno u radu na njemu mi mnogo znaci. Nasao sam na jednom drugom forumu komentar coveka koji je spomenuo da je na izlaznom tranzistoru, izmedju emitera i kolektora ugradjivao diodu. Ne razumem sta je hteo da kaze i sta je dobio time pa bi bilo lepo da neko prokomentarise ako razume o cemu se radi. Autor tog posta vec godinama nije online pa ne mogu da ga pitam a tako nesto nigde nisam video u literaturi. Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 24, 2017 Author Report Share Posted August 24, 2017 Izvinjavam se covek je napisao: " Prva ozbiljnija modifikacija - HSR48 sa diodom u PNP grani semi-komplemetarnog izlaza, pa poneki film kondenzator paralelno sa elektrolitima (IMHO) donosi preporod za ovaj cesto potcenjivan uredjaj " Ali ja i dalje ne razumem sta je hteo da kaze! Evo i slike ugradjenog elektrolita u napajanju i paralelno sa njime manjeg kondenzatora od 680nF. Quote Link to comment Share on other sites More sharing options...
Gox co. Posted August 25, 2017 Report Share Posted August 25, 2017 Na ovo je mislio... I u NPN i u PNP grani... Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 25, 2017 Author Report Share Posted August 25, 2017 Zastitna dioda? Nije mi bas jasno njeno mesto i uloga u ovom sklopu? Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 25, 2017 Report Share Posted August 25, 2017 Додавањем диода неће се баш променити карактер звука. Quote Link to comment Share on other sites More sharing options...
Gox co. Posted August 25, 2017 Report Share Posted August 25, 2017 Malo poveca damping faktor jer sece pikove kontraelektromotorne sile koja se pojavljuje u vracanju membrane zvucnika u srednji polozaj... Prosto, zar ne? Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 25, 2017 Author Report Share Posted August 25, 2017 To bi donelo nesto bolju kontrolu basova? Koliki je je uopste damping faktor na HSR-u? Kako ovo izvesti u praksi, kako dimenzionisati diodu? Jel postoji neki primer prakticnog resenja? Nije mi tesko da probam, najgore sto moze da se desi je da spalim izlazne tranzistore a i to tesko da bi moglo da se desi. Idem ja da upalim lemilicu a vi dajte neke prakticne predloge! Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 25, 2017 Author Report Share Posted August 25, 2017 Vidim u semama APEX pojacala da konstruktor rado koristi ove diode. Moracu da ga pitam za misljenje i nalaz. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted August 25, 2017 Report Share Posted August 25, 2017 6 sati ranije, mutayu said: Idem ja da upalim lemilicu a vi dajte neke prakticne predloge! Не дирај ништа, тако како је добро је. Quote Link to comment Share on other sites More sharing options...
mutayu Posted August 25, 2017 Author Report Share Posted August 25, 2017 Odlicno je kad malo bolje pogledas! Quote Link to comment Share on other sites More sharing options...
Корњача Раде Posted September 2, 2017 Report Share Posted September 2, 2017 Na mom HSR-u 48 De Luxe nije ništa menjano osim sijalica koliko ja znam. Može li neko da me uputi šta bi trebalo da se menja, ko bi to mogao da uradi i koliko bi otprilike koštalo. Risiver je ispravan, falinke su mu krčanje potenciometara i ponekad blago krčanje desnog zvučnika nakon nekih pola sata rada. Quote Link to comment Share on other sites More sharing options...
