den!s Posted December 29, 2015 Report Share Posted December 29, 2015 Trebalo bi mi malo saveta , pa je svaki dobronameran pozeljan... Promenio sam automobil, pa bih se na prolece malo posvetio muzici. Umesto fabrickog, ubacio bih Pioneer DEH-4200SD, jer ga vec imam. A i prednost mu je sto ima tri para RCA izlaza - prednji, zadnji i subwoofer. Imam 4-kanalno pojacalo Alpine MRV-F405 (na 12V 40W po kanalu). Napred bih stavio komponentni sistem. Tu imam Focal Acces 6A1 midbaseve sa Focal skretnicama i visokotonce Infinity Reference 1021t. Pozadi (u zadnjim vratima) bih stavio Pioneer TS174 sirokopojasne zvucnike. Njih sam kupio jer su bili jeftini i pominju ih po forumima da idu dosta nisko (?). Pokusao bih da izbegnem subwoofer. Podaci za Pioneer su: Coaxial, 2-way RMS: 30 W, 120 watts (maximum) Sensitivity: 91 dB Frequency response: 30-28.000 Hz Podaci za Infinity su: 1" textile dome tweeters 2,500 Hz passive in-line crossovers Power handling: 2-50 watts RMS (150 watts peak power) Impedance: 2 ohm Frequency response: 2.500-21.000 Hz Sensitivity: 93 dB A podaci od visokotonaca Focal TN44 koji su bili deo Focal komponent sistema su: Magnet: Neodymium Cone: Aluminum Surround: Cloth Nom Power: 15W Max Power: 100W Sensitivity: 94 dB Nom. Impedance: 4 Ohms DC Resistance: 3.7 Ohms Pitanja su: da li Infinity visokotonci odgovaraju Focal skretnici i midbasevima? Da li da menjam Alpine pojacalo za neko kvalitetnije/jace? Da li ce to sve moci da zvuci korektno bez subwoofera? Nisam bas-freak, ali nisam ni da zvuci suplje i nepotpuno… Dodao bih da cu vrata da dampiram jeftinom verzijom Alubutyl-a http://www.audiopower.rs/zvucne-kutije/oprema-zvucne-kutije/dumping-materijal/gzdm-3700/ Unapred hvala! Quote Link to comment Share on other sites More sharing options...
den!s Posted December 31, 2015 Author Report Share Posted December 31, 2015 Bljump... Quote Link to comment Share on other sites More sharing options...
