parabolis Posted December 29, 2014 Report Share Posted December 29, 2014 Naime problem je poceo od skoro da se desava, konfiguracija je sledeca: komp-externa zvucna karta(asus xonar U7)-pojacalo(cambridge audio)-zvucnici, plejer je foobar, kada slusam muziku i surfam ili otvaram prozore zvuk prekida ili krcka, neprijatno za slusanje, proc je intel e6600 dual core, 4 gb rama, int grafa, ploca neka asusova, srednjeg kvaliteta, komp kupljen nov 2011god, zvucna je preko usb porta povezana sa kompom......pomoc!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
arnage Posted December 29, 2014 Report Share Posted December 29, 2014 Ako imaš mogućnost na Xonar U7 povećaj buffer, a ako ne, povećaj u podešavanjima Foobara. Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 29, 2014 Author Report Share Posted December 29, 2014 ^ Evo odradio i ne pomaze........ Quote Link to comment Share on other sites More sharing options...
arnage Posted December 29, 2014 Report Share Posted December 29, 2014 Na koliko si odvrnuo i gde? Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 29, 2014 Author Report Share Posted December 29, 2014 ^ Ides na preference-output , bufer je na 16000ms. Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 29, 2014 Author Report Share Posted December 29, 2014 Ai na advance plyback bufer na 200000. Quote Link to comment Share on other sites More sharing options...
arnage Posted December 29, 2014 Report Share Posted December 29, 2014 A na zvuÄnoj imaÅ¡ neki panel gde može da se uveća buffer? Ovako neÅ¡to: Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 29, 2014 Author Report Share Posted December 29, 2014 ^ Podesio na asusu latenciju na 50ms, mislim da nije do toga posto i na integrisanoj zvucnoj pravi isti problem. Quote Link to comment Share on other sites More sharing options...
gfx Posted December 29, 2014 Report Share Posted December 29, 2014 Skini LatencyChecker (mali exe fajl, ne instalira se, samo ga pokrenes), proveri latenciju... Pusti muziku (foobar), pokreni taj programcic, i prati desavanja na ekranu... ako ti pikovi prelaze u crveno, bice ti jasno sta je u pitanju.DobroNe valja http://www.thesycon.de/deu/latency_check.shtml Pozz Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 29, 2014 Author Report Share Posted December 29, 2014 ^ ok, probam pa javljam..... Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 30, 2014 Author Report Share Posted December 30, 2014 Evo inst sam latency checker, pikuje u crveno kada otvorim novi prozor i windowsu, ili novi tabulator u pretrazivacu, e sad sta ciniti dalje....... Quote Link to comment Share on other sites More sharing options...
gfx Posted December 30, 2014 Report Share Posted December 30, 2014 Jedna od stavki koja generalno moze dosta da pomogne kod problema sa visokom latencijom je i iskljucivanje (disable) CPU EIST Function u BIOSU. Na zalost, nisi nigde naveo koju plocu imas, pa nisam siguran da li uopste imas mogucnost ovog podesavanja, ali u svakom slucaju to mozes i sam da proveris ulaskom u BIOS, pa u Advanced Bios Features. Ako imas, iskljuci to, sacuvaj BIOS podesavanja, resetuj masinu, pa ispocetka... foobar + latency checker i prati grafik... i javi ima li promene. Lako se moze desiti da je to bio ili jedan od, ili cak i JEDINI uzrok problema Pozz Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 30, 2014 Author Report Share Posted December 30, 2014 ^ ploca je asus p5g41t-mlx. Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 30, 2014 Author Report Share Posted December 30, 2014 Evo pratim, , opsija u biosi : C1E Suport je denabled,ide latencija do 2000ms za sada je dobro, ali i pre se desavalo da posle restarta radi neko vreme bez kasnjenja, evo javljam sve novosti, u svakom slucaju hvala puno na pomoci. Quote Link to comment Share on other sites More sharing options...
gfx Posted December 30, 2014 Report Share Posted December 30, 2014 Pa i tih 2000 je previse, to jednostavno MORA da se cuje Sledece sto mozes da uradis je da vidis konkretno da li ti i koji od drajvera, ili procesa, pravi probleme... Skini i instaliraj LatencyMon. Link: http://www.resplendence.com/latencymonKada to uradis, pusti foobar lagano da svira, pokreni program, i pusti TEST (oznaceno sa 1.). Pusti ga neka radi pola sata - sat i zaustavi.Posle toga, ne gaseci program, jednostavno izlistaj "kartice" PROCESSES (oznaceno sa 2.), i DRIVERS (oznaceno sa 3.), i videces (izlistace ti vrednosti) koji ti procesi, i drajveri prave probleme sa latencijom. Imas kompletno uputstvo i objasnjenje na samom sajtu, nije tesko za razumeti, a defintivno otklanja svaku sumnju po pitanju dijagnostike uzroka tvog problema. Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 31, 2014 Author Report Share Posted December 31, 2014 Ne mogu nikako da uplodujem slike na web stranicu, onda bi bilo jasnije sta se desava, uglavnom u procesima, u koloni hardpagefile najvise vrednosti ima svchost.exe. U opciji drivers najvece vrednosti ima usbportdrivers....Izgleda da usbportdrivers pravi probleme......sta dalje..... Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 31, 2014 Author Report Share Posted December 31, 2014 Kada sam iskljucio mrezu, tj sbb modem latencija pala na sveha 100ms, izgleda je to problem, stada radim...... Quote Link to comment Share on other sites More sharing options...
gfx Posted December 31, 2014 Report Share Posted December 31, 2014 Pa sve ti se odgovorilo samo... iskljucuj modem kad zelis da slusas muziku, i nema problema Kao sto i u ova dva programa preporucuju, sve se svodi na probu... ...to isolate this misbehaving driver use Device Manager, and disable/re-enable various device, one at a time. Try network and W-LAN adapters, modems, internal sound devices, USB host controllers, etc... Pozz p.s. mozes eventualno da proveris da li taj USB port na koji ti je nakacen Asus ne deli hub sa jos nekim uredjajem, i da to raskacis po ovom uputstvu (skroluj dole na deo pod imenom USB PORT)...http://www.thewelltemperedcomputer.com/SW/Windows/Win7/USBDAC.htm Quote Link to comment Share on other sites More sharing options...
parabolis Posted December 31, 2014 Author Report Share Posted December 31, 2014 Ok, hvala puno. Quote Link to comment Share on other sites More sharing options...
parabolis Posted January 4, 2015 Author Report Share Posted January 4, 2015 Ok, hvala puno. Quote Link to comment Share on other sites More sharing options...
parabolis Posted January 4, 2015 Author Report Share Posted January 4, 2015 evo posle zamene antivirusnog programa za sada je sve ok, umesto avasta stavio sam avg..... Quote Link to comment Share on other sites More sharing options...
