WD TV Posted November 17, 2014 Report Share Posted November 17, 2014 Ako može neko da napiÅ¡e iskustva o povezivanju WDTV Gen2 i zvuÄnika. Koja je najbolja kombinacija da bi se 100% iskoristile audio mogućnosti ovog plejera? Da li je potrebno da se uz zvuÄnike dodaju i pojaÄalo/risiver da bi se dobio najbolji mogući zvuk?Malo sam se raspitivao u posvećenim audio prodavnicama (player.rs) i oni su mi dali neke predloge:ONKYO HT S3505 - 5.1 zvuÄnici + risiver 47.880 din.TANNOY TFX 5.1 - zvuÄnici 59.880 dinONKYO TX SR 313 - risiver 32.280 dinONKYO TX SR 333 - risiver 35.880 dinMARANTZ NR1504 - risiver 47.880 dinONKYO TX NR 535 - risiver (WiFi) 41.880 dinWD TV je direktno povezan na TV preko HDMI, a sada hoću da napravim home theatre pa me interesuje kakva su iskustva i Å¡ta je najbolje uzeti.Hvala unapred. Quote Link to comment Share on other sites More sharing options...
WD TV Posted November 19, 2014 Author Report Share Posted November 19, 2014 Evo malo detaljnijih podataka u TV-u i plejeru: Panasonic TH-42PV80 Plasma TV 42 inch Technical details Manufacturer Panasonic Model TH-42PV80 Type Plasma Diagonal 42 inch (107 cm) Width 40 inch (1020 mm) Height 28.5 inch (727 mm) Depth 12.8 inch (327 mm) Weight 57.3 lbs (26 kg) 3D Support No Screen Resolution 1024x768 Image Aspect Ratio 16:9 Total Pixels 786432 Contrast 15000:1 Dynamic Contrast 1000000:1 LED Backlight No Frame Rate 100 Hz Viewing angle 178 ° Sequential Scanning Yes Image Optimization Yes Video HDTV support Yes HDTV modes 720p Supported Digital TV Resolutions 480i, 480p, 576i, 576p, 720p, 1080i Support Audio/Video Formats MP3, JPEG Zoom Yes Support TV Standarts PAL, SECAM, NTSC Picture in picture mode No Audio System Support Stereo Sound Yes Surround Mode No Sound Power 20 W (2x10 W) Acoustic System 2 Speakers Headphones Jack Yes Features Power Consumption 255 W Wall Mount Yes Teletext Support Yes Teletext Pages 1000 Connectors Type 1 x AV, 3 x audio, 1 x S-Video, 1 x Component video, 2 x SCART, 1 x RGB, 1 x VGA, 3 x HDMI Outputs Audio Channels Count 100 Sleep Timer Yes Parental Lock Yes Card Reader Yes Support Flash Cards SD Specifications for the WD TV HD Media Player device (Gen 2) Product Specifications Interfaces USB 2.0 (input) HDMI (output) Composite A/V (output) RoHS Compliant1 Yes Warranty2 Varies by region Media File Format Support (Based on Firmware Version 1.01.01) Movie -- AVI (Xvid, AVC, MPEG1/2/4), MPG/MPEG, MKV (h.264, x.264, AVC, MPEG1/2/4, VC-1), TS/TP/M2T (MPEG1/2/4, AVC, VC-1) MP4/MOV (MPEG4, h.264), M2TS, WMV9 MPEG2 MP@HL up to 1920x1080p24, 1920x1080i30, or 1280x720p60 resolution. MPEG4.2 ASP@L5 up to 1280x720p30 resolution and no support for global motion compensation. WMV9/VC-1 MP@HL up to 1280x720p60 or 1920x1080p24 resolution. VC-1 AP@L3 up to 1920x1080i30, 1920x1080p24, or 1280x720p60 resolution. H.264 BP@L3 up to 720x480p30 or 720x576p25 resolution. H.264 [email protected] and [email protected] up to 1920x1080p24, 1920x1080i30, or 1280x720p60 resolution. Picture -- JPEG, GIF, TIFF, BMP, PNG Compressed RGB JPEG formats only and progressive JPEG up to 2048x2048. Single layer TIFF files only. Uncompressed BMP only. Audio -- MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, AIF/AIFF, OGG, Dolby Digital, DTS An audio receiver is required for multi-channel surround sound digital output. For specific details, please refer to the user manual. Playlists -- PLS, M3U, WPL Subtitle -- SRT, ASS, SSA, SUB, SMI Dakle hteo bih da kompletiram kućni bioskop, a trenutno imam plejer i TV. Koji zvuÄnici i risiver bi bili odgovarajući u skladu sa tehnikom koju sada imam. Za budžet nisam baÅ¡ siguran, samo mi je bitno da zvuÄnici i risiver budu neki optimalni, da ne budu neki koji ne mogu da iskoriste mogućnosti TV-a/plejera ili da dam velike pare za neÅ¡to Å¡to je mnogo bolje od komponenti koje sada imam, pa da ne mogu da iskoristim u potpunosi te nove zvuÄnike i risiver. Quote Link to comment Share on other sites More sharing options...
WD TV Posted December 18, 2014 Author Report Share Posted December 18, 2014 PokuÅ¡avam da sklopim sistem za kućni bioskop. Za sada sam doÅ¡ao do nekog izbora: - risiver MARANTZ NR1504 - zvuÄnici TANNOY TFX 5.1 Da li neko ima iskustva sa ovom audio opremom ili možda ima neke bolje predloge. Hvala. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 21, 2014 Report Share Posted December 21, 2014 Pa, risiver ok, al.ovi zvucnici...NE. Ja bi razmisljao da prednji zvucnici budu veliki, ne moras ( iako je najbolje) kupovati sve od jednom i iz iste serije. Kupi multikanalni risiver i sto bolje prednje zvucnike, posle dodaj jedno po jedno..centralni, surr, sub i samo menjaj setap risivera. Tako ces na kraju imati " pravi " kucni bioskop. Sa ovim tanojima ce biti kao da si postavio 5 tranzistora u coskove sobe. Quote Link to comment Share on other sites More sharing options...
WD TV Posted December 21, 2014 Author Report Share Posted December 21, 2014 Hvala na savetu. Hocu da sklopim pristojan kucni bioskop, znam neke osnovne stvari ali mi je misljenje nekoga ko se razume velika pomoc. Znaci AV risiver Marantz je ok, da li ima neko predlog koji zvucnici idu dobro u paru? Sistem nameravam da koristim za Bluray filmove sa dts audiom (1500 kbps) ili neki malo bolji remuxi. Na AV risiver bi prikljucio i Xbox 360 i SBB D3 dogitalni/HD risiver (kada RTS HD prenosi Ligu sampiona ispod logoa RTS HD stoji 5.1 pa bi to pokusao da dobijem). Dakle ako neko ima predlog koji zvucnici se preporucuju uz Marantz NR 1504 AV risiver? Quote Link to comment Share on other sites More sharing options...
gvlada Posted December 21, 2014 Report Share Posted December 21, 2014 СББ риÑивер не шаље 5.1 Ñа РТС, који кориÑти Долби Дигитал + Ñтандард. ТВ Ñа двб-ц тјунером и подршком за е-ац3 може преко Ñвог диг излаза дати 5.1 ац3 звук Ñа РТС ХД канала. Quote Link to comment Share on other sites More sharing options...
Bokkie Posted December 21, 2014 Report Share Posted December 21, 2014 Taj WD-TV HD player radi downsampling na 48KHz, 24bit preko optickog izlaza i to pakuje u PCM stream. Nisam siguran da li preko HDMI-a da gura multichannel audio untouched/DTS ili i tamo radi downsampling. Quote Link to comment Share on other sites More sharing options...
uzvarb Posted December 22, 2014 Report Share Posted December 22, 2014 Jako davno sam koristio jedan WD TV live plejer i na digitalnom izlazu je imao DD, za DTS se ne secam, al DD je imao...al ogradjujem se da sam sanjao. Quote Link to comment Share on other sites More sharing options...
