zookarma Posted January 9, 2015 Report Share Posted January 9, 2015 Hvala Digital za verziju Foobar-a Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted January 9, 2015 Report Share Posted January 9, 2015 Nema na chem . Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 11, 2015 Report Share Posted January 11, 2015 Nema shanse da mi proradi nijedan remote control app za foobar na androidu.Moze li mi neko pomoci ? Hvala ! Quote Link to comment Share on other sites More sharing options...
fege Posted January 11, 2015 Report Share Posted January 11, 2015 Koje si aplikacije probao. Meni Foobar 2000 controller radi savrseno https://play.google.com/store/apps/details?id=com.cav.foobar2000controller&hl=sr I kupicu Pro verziju programa (autor trazi 1.07$), da podrzim autora. Uputstvo za instalaciju: http://foobar2000controller.blogspot.com.es/p/how-to-start.html Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 11, 2015 Report Share Posted January 11, 2015 Pa nekoliko,a poslednjeg bas Foobar2000controller.stalno mi na aplikaciji izbaci ''can't connect with specified IP and port''. U foobaru sam u listen i u remote IP ubacio 192.168.1.2 (moju PC IP adresu),port 8888 u credentials ubacio tacan username i password,kliknuo na start server - kaze '' foobar2000 controller is properly installed'' Gde gresim ? Quote Link to comment Share on other sites More sharing options...
fege Posted January 11, 2015 Report Share Posted January 11, 2015 Da li si instalirao ovo na PCju: http://www.mediafire.com/download/nd1nbsue5173oc4/foobar2000+controller+%5BPC-side+setup%5D+v2.0.1.exe ? Ako jesi, probaj da pustis kontroler da sam detektuje mrezu. Cini mi se da i kod mene nije radilo kada sam probao da mu sam ubacim moj IP. Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 11, 2015 Report Share Posted January 11, 2015 Jesam,instalirao sam. Ali kad ga pustim sam da trazi on kaze doslovce :''cannot determine your IP or can't find any server with the default settings .Please write your IP here and change the port number if it's set to a different number in foobar2000''. Da udjem u podesavanja rutera,apsolutno mi nije jasno.Da ukucam IP adresu rutera,PC-ja ili telefona.Koliko se ja razumem treba ukucati IP od PC-ja. Hvala na strpljenju. Quote Link to comment Share on other sites More sharing options...
fege Posted January 11, 2015 Report Share Posted January 11, 2015 Kod mene stoji IP isti kao u Local Area Connection za IPv4 Adress (192.168.0.10). Firewall ti ne pravi problem? (Optional) Set needed exceptions in firewall or antivirus. (foobar2000.exe should accept connections from any IP address at port 8888) Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 11, 2015 Report Share Posted January 11, 2015 IP je ok,Firewall ni ne koristim.MAda sam i to pregledao sada.Apsolutno ne znam koji mu je klinac. Quote Link to comment Share on other sites More sharing options...
trotter Posted January 11, 2015 Report Share Posted January 11, 2015 Foobar2000controller i kod mene radi bez greske. Probaj da deinstaliras app sa telefona i ponovo ga instaliraj, pa unesi ip adresu ponovo. U medjuvremenu, restartuj racunar i ponovo pokreni foobar. Quote Link to comment Share on other sites More sharing options...
fege Posted January 11, 2015 Report Share Posted January 11, 2015 Windows firewall? Neki antivirus? Ruter? To su 3 potencijalna uzroka problema,(Posto ti ni drugi slicni programi ne rade). Mozda ce neko imati jos neku ideju. Quote Link to comment Share on other sites More sharing options...
trotter Posted January 11, 2015 Report Share Posted January 11, 2015 Koji OS je na racunaru? Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 11, 2015 Report Share Posted January 11, 2015 WIN7 Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 11, 2015 Report Share Posted January 11, 2015 Sve sam odradio ponovo ,deinstalirao i instalirao .Mozda je do telefona ?Da li neko moze (i hoce) korak po korak da mi pokaze kako je kod sebe namestio.Nisam uopste laik za kompjutere ali mi apsolutno nije jasno sta se ovde dogadja. Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 11, 2015 Report Share Posted January 11, 2015 Hvala svima koji su mi pomagali (hteli a pomognu ili samo citali postove).Uspeo sam ! Greska je bila u tome sto sam u podesavanjuu foobaru u poljima listen on i remote IP upisivao moju IP adresu a trebao sam ostaviti sve nule. Quote Link to comment Share on other sites More sharing options...
arnage Posted January 11, 2015 Author Report Share Posted January 11, 2015 Taj sam, jedan od onih koji je samo Äitao. Nažalost jer ne koristim te opcije, ali eto, sada je ukazano i na tu zaÄkoljicu ako neko naiÄ‘e na to... Quote Link to comment Share on other sites More sharing options...
vukashin Posted January 11, 2015 Report Share Posted January 11, 2015 Ja sam imao isti problem pre mesec dana i odustao sam bio, tacnije nisam imao vremena da se bakcem,ali probacu pa javljam da li se i kod mene na taj nacin resava. Quote Link to comment Share on other sites More sharing options...
fege Posted January 11, 2015 Report Share Posted January 11, 2015 Autor je lepo napisao u uputstvu, treba ga samo pratiti: 1 - Installation (Steps to be done in computer side) Stop foobar2000 execution. Download and execute computer setup. (Optional) Set needed exceptions in firewall or antivirus. (foobar2000.exe should accept connections from any IP address at port 8888) Start foobar2000. Leave HTTP Control settings by default. Leave both "Listen on" and "Remote IP" fields as "0.0.0.0" unless you know exactly what you are doing. Quote Link to comment Share on other sites More sharing options...
progpostman Posted January 12, 2015 Report Share Posted January 12, 2015 Tacno ! Sve lep pise,samo ja uvek brzam i na kraju odradim po svome.ko mi je kriv kad sam nestrpljiv. Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted January 12, 2015 Report Share Posted January 12, 2015 Ne znam da li smem ali sto da ne, ja sam izguglao pro verziju, nije sa plej stora. Ubacio je lepo, kad se prvi put pokrene aplikacija ona i pokaze kako na kompu i sta treba da se radi. Sve je lepo objasnjeno i sve radi. Nakon obavljenog setovanja napravis lajberi u fubaru da bi pretrazivanje pesama sa android uredjaja bilo kako treba.Edit: Uklonjen link. Quote Link to comment Share on other sites More sharing options...
dude Posted January 12, 2015 Report Share Posted January 12, 2015 Osnovno pravilo audiopisifilizma ,Wi-Fi mora biti iskljucen Quote Link to comment Share on other sites More sharing options...
fege Posted January 12, 2015 Report Share Posted January 12, 2015 Ne znam da li smem ali sto da ne, ja sam izguglao pro verziju, nije sa plej stora. Ubacio je lepo, kad se prvi put pokrene aplikacija ona i pokaze kako na kompu i sta treba da se radi. Sve je lepo objasnjeno i sve radi. Nakon obavljenog setovanja napravis lajberi u fubaru da bi pretrazivanje pesama sa android uredjaja bilo kako treba.Edit: Uklonjen link. Jimmy pa mogao si coveku da das 1$ za PRO verziju. Toliko para ode na komponente sistema, a ne mozes da das 1$ za lepo napisan controller. Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted January 12, 2015 Report Share Posted January 12, 2015 Ako dodje da ih uzme, dacu mu. Nemam kartice, nemam akaunte racune i slicno. Nije tek tako Quote Link to comment Share on other sites More sharing options...
arnage Posted January 14, 2015 Author Report Share Posted January 14, 2015 Još jedan lep skin. http://anonymousgrafix.deviantart.com/art/Zetro-v2-9-15-11-2014-294961023 Quote Link to comment Share on other sites More sharing options...
zookarma Posted January 14, 2015 Report Share Posted January 14, 2015 Hvala za ovo, mada cesto zna da bude problem instalacija iz raznih razloga, digital je lepo okacio upotrebljivu verziju Ne trazim da nam " okrunis kukuruz " probacu sam definitivno, samo kazem da autor ima podesen sistem na svoj nacin i lako je moguce da ovaj skin ne radi kod svakog. Quote Link to comment Share on other sites More sharing options...
