SUROKVL Posted December 27, 2014 Report Share Posted December 27, 2014 Naravno da nas interesuje! Quote Link to comment Share on other sites More sharing options...
Malkavian Posted December 27, 2014 Author Report Share Posted December 27, 2014 Hvala lepo, mislio sam da je veci entuzijazam u igri pa se brze-bolje prijavio. Napleo sam se ja svakojakih pletenica onoliko. Nema tu vise iznenadjenja za mene. Naravno nisam mislio da je zabranjeno uporedjivati sa drugim kablovima,moze i tu stosta da se sazna. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted December 28, 2014 Author Report Share Posted December 28, 2014 Jedna strana gotova. Druga ce morati da saceka ponedeljak, shvatio sam na pola da mi fali jos jedna parica. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 1, 2015 Author Report Share Posted January 1, 2015 Zavrsene obe strane, spremne za testiranje Quote Link to comment Share on other sites More sharing options...
rokijana Posted January 2, 2015 Report Share Posted January 2, 2015 Dobra "pletenica"..Rasta Kimber . Quote Link to comment Share on other sites More sharing options...
trotter Posted January 2, 2015 Report Share Posted January 2, 2015 SitnopariÄni dread. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 6, 2015 Author Report Share Posted January 6, 2015 Novina je da sam eksperimentisao sa strujnim kablovima punog preseka, razlika je cujna iako sam bio skeptican, pogotovu se primecuje po tome koliko je vise punchy bass postao.Kabl je 2.5 mm2,jako tezak za pletenje a bogami i da se lepo postavi i u IEC utikac. Quote Link to comment Share on other sites More sharing options...
tomicad Posted January 7, 2015 Report Share Posted January 7, 2015 Jel ima neke razlike u zvuku kad se tako kabl 2,5m2 " oljuÅ¡ti" i uplete i onog obiÄnog, kakvog ga kupimo, sa sve izolacijom? Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 7, 2015 Author Report Share Posted January 7, 2015 Nisam probao sa izolacijom, litz pletenje bi trebalo da je najefektivnije bas kod strujnih kablova.Ja sam stavio ferit na IEC stranu za svaki slucaj,kabl sam kupio u elpoku za celih 350 RSD za cetiri metara, IEC i suko uticnice sam imao od nekih proslih eksperimentisanja (56 RDS/kom u kanibalu).Za ispod 300 RSD po komadu mislim da kablovi odlicno rade posao Quote Link to comment Share on other sites More sharing options...
vukashin Posted January 7, 2015 Report Share Posted January 7, 2015 Svaka cast za strpljenje i kvalitetan rad. Jos ako bolje zvuce od nekoliko puta skupljih kablova,eto ustede za neke druge karike sistema. Samo uporedi sa jos nekim kablovima i zajedno sa nekim kolegom, da ne bude placebo efekat. Pozdrav Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 8, 2015 Author Report Share Posted January 8, 2015 To i dalje stoji, ko hoce da ga uporedi, rado cu da mu posaljem.Od poredjenja sam licno poredio sa Chord Carnivalom i Expo zv kablom sa airlocom i bio je bolji od oba.Prijatelj je poredio sa VDH CS122 i QED Revelation, kaze da razlika u zvuku ne opravdava onoliko vise para. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 16, 2015 Author Report Share Posted January 16, 2015 Ponesen pricama po stranim forumima odlucio sam da probam da napravim jos jednu podvrstu kabla za zvucnike.Probacu da napravim razumljiv how to sa slikama.Evo par slicica, a utiske prenosim kad zavsim sa obe strane. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 17, 2015 Author Report Share Posted January 17, 2015 Nadam se da ljude i dalje interesuje Hi-Fi Probacu da objasnim korak po korak kako sam napravio pletenicu Mk3. Od materijala sam upotrebio: Lak zicu 0.90mm narucenu u MG-u iz Nisa (post iznad). Obelezivace za kablove slika u postu iznad, veoma korisni kad ne znam gde sam stao a i da pletenica bude ravnomerna. 8 kom. pozlacene banane iz kanibala. vunica ili kanap u dve boje. Prvo sam poceo tako sto sam isekao 2x10x2 metra zice, po pet za minus i plus vodove. poredjao sam ih po svom nazovi stolcicu, izmerio po 10cm od svakog i zavezao vunicu ispod, iznad nje stoji obelezivac za kabl, da ne bi slkliznuo na dno kabla a ida bi zice mogle da se razlikuju jedna od druge. Natavak ispod. Isto to sam ponovio sa druge strane, ali sa drugom bojom vunice. Bitno je zapaziti da se na prvom redu redjaju brojevi od jedan do pet, a na drugom obrnutim redosledom tj. od pet do jedan jer se i zice tako ukrstaju pri pletenju. Kad sam imao po pet obelezenih zica sa svake strane poceo sam da pletem tako sto sam uzeo prvu zicu sa leve strane i poslednju zicu sa desne i ukstio ih desnu preko leve izmedju dva reda. Ovaj proces se ponavlja za sve ostale zice istim redosledom. Posle nekog vremena obrazuje se pletenica, u pocetku je veoma rasirena i ne treba da se previse forsira da bi bila uza, sama ce se skupiti kako se plete u duzinu. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 17, 2015 Author Report Share Posted January 17, 2015 Ja sam isao na dva metra duzine, ne bih isao preko dva i po metra zbog kapacitivnosti.Posto sam ostavio 10 cm na pocetku, koje se pletenjem pretvore u 15 cm, isto toliko sam ostavio i sa druge strane.Te krajeve sam isto upleo sa leve i desne strane. Izmerio sam prema banani koliko kabla treba da ogulim i poceo da gulim sa ziletom.Ogoljenje zice tesno ulaze u bananu i bez uvijanja tako da su se lepo kompresovale pod srafom (odsrafio sam da proverim). E sad sto se merenja tice, multimetar nisam ozbiljno koristio do sada tako da cu mozda da se izlupetam ali me slobodno ispravite ako gresim. I prosla pletenica i ova nova imaju odlicno nizak otpor od 00.01 oma. Ono po cemu se dosta razlikuju i pretpostavljam da je to zbog izolacije, je kapacitivnost.Pletenica Mk2 ima visoku kapacitivnost od 560 pF ako ne gresim. Nastavak ispod. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 17, 2015 Author Report Share Posted January 17, 2015 U odnosu na pletenicu Mk3 koja ima odlicnih 160 pF. Naravno za kraj moram da napomenem da bez multimera ne bih pokusavao da zakacim zice u pojacalo bez provere za kratak spoj. Niza kapacitivnost se definitivno oseca u basu, zakljucio sam da je bolje plesti sa manje zica veceg preseka nego sa vise manjeg uprkos logici.Za sada sviraju jedno sat vremena, videcemo da li imaju neke ocigledne mane na duze strane. Quote Link to comment Share on other sites More sharing options...
rrapaic Posted January 18, 2015 Report Share Posted January 18, 2015 Meni ovo iznad izgleda ODLICNO . Definitino je lepo videti tu boju bakra, a i geometrija pletenice je za respect. Posto se autor vec izvestio u pletenju, neki sledeci korak (Mk4 ) bi bilo kombinovanje punih zica razlicitog preseka; ako se ne varam, poznat primer je upravo Kimber kabl. A iz svog iskustva mogu reci da kombinacija razlicitih preseka daje vrlo interesantne rezultate (na zalost nikad vremena za pletenje...) Pozz Quote Link to comment Share on other sites More sharing options...
gvlada Posted January 18, 2015 Report Share Posted January 18, 2015 Кимбер је лицнаÑÑ‚ унутар Ñваког кабла, није пун преÑек. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 18, 2015 Author Report Share Posted January 18, 2015 Razmisljao sam i da iskombinujem razlicite preseke, ali to onda prestaje da bude isplativo, a to je nekako cilj iza cele price, da se dobije solidan kabl za razumne pare, koji je bolji od 50% navikanih butik kablova.Ako bas ne budem znao sta cu sa parama jednog dana mozda narucim GPOCC zicu. Quote Link to comment Share on other sites More sharing options...
wwweljko Posted January 18, 2015 Report Share Posted January 18, 2015 Da li je cena za 30m/200 $. 7 $ po metru . Nije mnogo , mozda sa dadzbinama izadje 10-12$. Mozda bi mogli da iskombinujemo neku grupnu nabavku. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 19, 2015 Author Report Share Posted January 19, 2015 Zavisi od preseka zice, 24AWG je najskuplji na spulnu, 18AWG je najskuplji kad se uzima na stopu tj. 30cm.Za ovaj standardni 2x5 kabl treba 40 metara za 2x2 metra par.Isplativo bi bilo eventualno da se naruci 16 AWG pa da se pravi sa po jednom zicom kao anticables.Moze da se iskombinuje neka grupna nabavka, sto da ne. Quote Link to comment Share on other sites More sharing options...
rrapaic Posted January 19, 2015 Report Share Posted January 19, 2015 Кимбер је лицнаÑÑ‚ унутар Ñваког кабла, није пун преÑек. Znam to; mislio sam na cinjenicu da postoji vise raznih preseka u jednom kablu. Ali, hvala za opasku (u ime onih koji nisu videli Kimber). Pozz Quote Link to comment Share on other sites More sharing options...
surferlola Posted January 19, 2015 Report Share Posted January 19, 2015 cao svaka cast Malkaviane na trudu. jesi li razmisljao da kabel ubacis u neku izolaciju, koja ce spreciti upliv smetnji? Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted January 19, 2015 Report Share Posted January 19, 2015 Pa zica je lakirana sto sprecava oksidaciju bakra, a pretpostavljam da u nekoj meri vrsi ulogu dielektrika. Uostalom tako golisav je, paradoksalno, u jako dobroj izolaciji, tj. vazduhu. "Samo" treba da se dobro pobrine oko postavljanja samog kabla u prostoru kako bi bio daleko od svih (ako je to uopste moguce) izvora smetnji. Quote Link to comment Share on other sites More sharing options...
Malkavian Posted January 19, 2015 Author Report Share Posted January 19, 2015 Odaljio sam ih dovoljno da im nista ne smeta, o izolaciji sam razmisljao, ali ne postoji neki razuman nacin da se to uradi a da se izolacija ne mesa u ukrstanje kablova.Jedino sto mi pada na pamet je neki spray on absorber vibracija, ali gde to da nadjem? Quote Link to comment Share on other sites More sharing options...
milovan1963 Posted January 20, 2015 Report Share Posted January 20, 2015 Odaljio sam ih dovoljno da im nista ne smeta, o izolaciji sam razmisljao, ali ne postoji neki razuman nacin da se to uradi a da se izolacija ne mesa u ukrstanje kablova.Jedino sto mi pada na pamet je neki spray on absorber vibracija, ali gde to da nadjem? Odaljio sam ih dovoljno da im nista ne smeta, o izolaciji sam razmisljao, ali ne postoji neki razuman nacin da se to uradi a da se izolacija ne mesa u ukrstanje kablova.Jedino sto mi pada na pamet je neki spray on absorber vibracija, ali gde to da nadjem? pamucna kosuljica preko njih, a preko nje bakarni shirm...Medjutim ako slucajno ogrebes 2 zice pri pletenju na istom mestu ( + i - ) i dodje do spoja, eto kurslusa... Quote Link to comment Share on other sites More sharing options...
