Jimmy_92 Posted December 28, 2014 Report Share Posted December 28, 2014 Ej ima logike jer od skoro koristim laptop za muziku! Win7 je na njemu, 64bit. Namesti osam sve kao gore navedeno i videcemo, tajm vil tel. Hvala Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 28, 2014 Report Share Posted December 28, 2014 Ne pomaze, opet isti djavo. Aj vraticu na desktop da vidim sta se desava tamo. p.s. Kako da uradim ovo, ne znam da li je to to sto sam ja podesio: Then set your CPU to allow background processing. Zar to nije po difoltu podeseno? Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted December 28, 2014 Report Share Posted December 28, 2014 Ma baci to i kupi H80 ! Quote Link to comment Share on other sites More sharing options...
trotter Posted December 28, 2014 Report Share Posted December 28, 2014 Ne pomaze, opet isti djavo. Aj vraticu na desktop da vidim sta se desava tamo. p.s. Kako da uradim ovo, ne znam da li je to to sto sam ja podesio: Then set your CPU to allow background processing. Zar to nije po difoltu podeseno? - In control panel select "system" - Go to "Advanced system settings" and then the "Performance" tab - Set processor scheduling as "Background Services" - Click "Apply" then "OK" Quote Link to comment Share on other sites More sharing options...
trotter Posted December 28, 2014 Report Share Posted December 28, 2014 Ovo sve sam prepisao sa jednog foruma gde se pricalo o slicnom problemu sa arcam dacom. Ko zna da li je to, ali ne kosta te nista da probas. Probaj i sa drugim usb kablom, probaj i na drugom usb portu na laptopu sa kablom koji sad koristis. Probaj i sa originalnim arcam napajanjem. Probaj sa drugim plejerom (jriver, aimp, foobar...). Negde je problem, treba pronaci gde. Quote Link to comment Share on other sites More sharing options...
trotter Posted December 28, 2014 Report Share Posted December 28, 2014 Da bi proverio koji usb port na laptopu ne deli hub sa drugim uredjajima, pogledaj ovde kako da proveris (podnaslov usb port) http://www.thewelltemperedcomputer.com/SW/Windows/Win7/USBDAC.htm Nazalost, desktop i laptop nisu isto, problemi sa usb dacovima su daleko cesci sa laptopovima, pa se treba potruditi malo ako se problem pojavi. Ako bude radilo ok sa desktopa, znaces da je problem sa podesavanjima na laptopu. Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 28, 2014 Report Share Posted December 28, 2014 Evo slusam vec oko 1h sa desktopa i sve je ok, znaci do laptopa je i to me manje vise raduje jer je sve kul sa dac-om i napajanjem. E sad cu da se bacim na trazenje problematike, hvala Trotter-u na pomoci, javicu sta sam napravio Quote Link to comment Share on other sites More sharing options...
Vlajo Posted December 28, 2014 Report Share Posted December 28, 2014 Ja sumnjam na ta divlja napajanja koja koristite. Koja divlja napajanja ? Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted December 28, 2014 Author Report Share Posted December 28, 2014 Valjda je mislio na ova sto se dobijaju uz dac,makar sam ja tako razumeo. Quote Link to comment Share on other sites More sharing options...
Bane025 Posted December 28, 2014 Report Share Posted December 28, 2014 Ponovio sam se i ja sa napajanjem od komšije @impulsa.... . @Jimmy_018 kakva je situacija sa prekidanjem,kada stavite default usb kabl,onaj koji ste dobili uz uređaj ? Da li i tad pucka ? Meni se puckanje desilo samo sa usb kablom od 5m dužine... Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted December 28, 2014 Report Share Posted December 28, 2014 Ne persirajte mi, ja sam podmladak ovde. Sa dektopa sve radi kako treba, znaci do laptopa je. Igracu se malo da vidim sta je. Ali da menjam kablove i da isprobavam sa difolt ne zelim, zasto kupih transparent usb. Cinjenica je da je sve kako treba i da nije do hardvera vec do softvera verovatno, ne znam zasto bi isti usb sa desktopom bio ok a sa laptopom ne. Quote Link to comment Share on other sites More sharing options...
Iron man Posted December 29, 2014 Report Share Posted December 29, 2014 Da li se isto ponasa kad je laptop na punjacu i kad je na baterijama samo? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted December 29, 2014 Report Share Posted December 29, 2014 Cinjenica je da je sve kako treba i da nije do hardvera vec do softvera verovatno, ne znam zasto bi isti usb sa desktopom bio ok a sa laptopom ne. Ne mora da znaÄi da je softverski problem, s obzirom da najverovatnije nisu u pitanju identiÄni USB kontroleri na desktopu i laptopu... Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted January 8, 2015 Report Share Posted January 8, 2015 Mrckao sam laptop i ne znam tacno zasto je prestalo ali je prestalo, ne secka vise. Pu pu pu E sad, imam jedno pitanje a da ne otvaram novu temu. Koja je najisplativija opcija strimovanja, ne mogu da se glupiram i da se trudim da utisam PC. Kad vec imam laptop mislim da je lakse trimovati lepo sa bilo koje pozicije u sobi. Da jurim neku od onih Lodzitekovih naprava ili postoji nesto malkice jeftinije a da ne pravim kompromis u kvalitetu reprodukcije? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted January 8, 2015 Report Share Posted January 8, 2015 Za jeftinije od polovnog SB Touch-a, koji je (ako ga uopšte nađeš) oko 200-250 evra, a da strimuje kako treba, teško ćeš naći adekvatnu opciju. Quote Link to comment Share on other sites More sharing options...
trotter Posted January 8, 2015 Report Share Posted January 8, 2015 Prodaje li neko kod nas Sonos Connect? Vidim da je cena po amazonima oko 300 nesto dolara, novo. Quote Link to comment Share on other sites More sharing options...
Iron man Posted January 8, 2015 Report Share Posted January 8, 2015 Mrckao sam laptop i ne znam tacno zasto je prestalo ali je prestalo, ne secka vise. Pu pu pu E sad, imam jedno pitanje a da ne otvaram novu temu. Koja je najisplativija opcija strimovanja, ne mogu da se glupiram i da se trudim da utisam PC. Kad vec imam laptop mislim da je lakse trimovati lepo sa bilo koje pozicije u sobi. Da jurim neku od onih Lodzitekovih naprava ili postoji nesto malkice jeftinije a da ne pravim kompromis u kvalitetu reprodukcije? + DAC Quote Link to comment Share on other sites More sharing options...
Alexandar Posted January 8, 2015 Report Share Posted January 8, 2015 ^Novija, standalone verzija, je bolja (i prakticnija). Za malo visu cenu. Quote Link to comment Share on other sites More sharing options...
laky Posted January 8, 2015 Report Share Posted January 8, 2015 ^Novija, standalone verzija, je bolja (i prakticnija). Za malo visu cenu. gde ima i po kojoj ceni. Quote Link to comment Share on other sites More sharing options...
Alexandar Posted January 8, 2015 Report Share Posted January 8, 2015 Ne bih znao, samo rekoh. Posto sam probao obe verzije.. Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted January 9, 2015 Report Share Posted January 9, 2015 https://www.apple.com/airport-express/ Ovo mi znaci treba? A kako ide sinhronizacija sa androidom i windows masinom, nema nekih komplikacija? P.S. Znaci i da USB veza nije moguca tu. Quote Link to comment Share on other sites More sharing options...
gvlada Posted January 9, 2015 Report Share Posted January 9, 2015 Ðаправи за тај новац тихи комп, који је много флекÑибилнији и можеш још да кориÑтиш и уÑб везу. Другар за 250е ÑаÑтавио комп који може и филм да пуÑти а има кућиште величине Сони 2. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted January 9, 2015 Report Share Posted January 9, 2015 Ðаправи за тај новац тихи комп, који је много флекÑибилнији и можеш још да кориÑтиш и уÑб везу. Другар за 250е ÑаÑтавио комп који може и филм да пуÑти а има кућиште величине Сони 2. Potvrdjujem, ja sam napravio takav komp, i za manje novca. Quote Link to comment Share on other sites More sharing options...
zustroy Posted January 9, 2015 Report Share Posted January 9, 2015 @gvlada, vlaja Jel mozete malo detaljnije o komponentama koje ste koristili? Quote Link to comment Share on other sites More sharing options...
garson Posted January 9, 2015 Report Share Posted January 9, 2015 Predlozi: Ploca+CPU: ASUS J1800I-C http://www.asus.com/Motherboards/J1800IC/ Nije nesto sto se prosirivosti tice, zahteva SODIMM DDR3L mem. module, dual core CPU ili jos bolje ASRock Q1900M http://www.asrock.com/mb/Intel/Q1900M/ quad core CPU, klasicna DDR3 memorija, dobra prosirivost (pci-e x16 i 2x pci-ex1) - neki manji SSD, 60 GB npr Kingston V300 - neko miniITX ili mATX kuciste npr LC Power 1340Mi mini, ima dc-dc napajanje od 75W, pasivno hladjeno Cooler Master Mini ITX Elite 110 Cooler Master Mini ITX Elite 120 Cooler Master Mini ITX Elite 130 - memorija dosta je i 4GB za te potrebe Sve ovo ukupno je tipa 20k dinara. Quote Link to comment Share on other sites More sharing options...
