D i g i t a L Posted June 10, 2014 Author Report Share Posted June 10, 2014 Neka je sa srećom mali Arkam DaÄić Hvala Struki . Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 10, 2014 Report Share Posted June 10, 2014 Puk'o si k'o oblanda - neka je srećno i veselo Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted June 10, 2014 Report Share Posted June 10, 2014 Auuu sto mi ovo radite, na kraju cu i ja jedan da kupim! (i imacu kit objektiv do kraja zivota na aparatu jer je HI Fi uvek bitniji) Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 13, 2014 Report Share Posted June 13, 2014 irDaÄići - koja podeÅ¡avanja koristite ? Driver mi je Asio njegov novi - proveravam da li će biti BSOD Latencija na standard jer na low i minimum se dogadjaju prekidi i sranjca Asio buffer size je na 8192 semplova Kakva je situacija kod vas i treba li Å¡tagodj menjati ? Dosad je bilo na wasapi, radilo je odliÄno !!! I na Asio radi odliÄno - koji ostaviti ? Dejan Impuls mi je poslao super Teddy napajanje na probu ... rooooarrr ... joÅ¡ da nabacim posrebreni kabl i prodajem Sony cd, minidisc i risiver ... Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted June 13, 2014 Author Report Share Posted June 13, 2014 Koji plejer? irDAC Kod mene zasad difolt kabal i napajanje, Driver 1.61 Firmware 1.0.7 USB Streaming - minimum latency Asio buffer size - 256 samples Foobar2000 + plugin za Asio http://www.foobar2000.org/components/view/foo_out_asio Output - Asio : Arcam USB Audio Asio Driver Asio - Run with the high process priority - chekiran Sve radi "Like a charm" P.S. Sony ode ooooooooo nnnnnnnnnnnnnnnoooooooooooooooooooo!!!!!!!!!!!!!!!!!!!!!! Dok ovo Gosn Roki chuje bice svashta. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 13, 2014 Report Share Posted June 13, 2014 Aimp 3.55, mada ova podešavanja su na onom Arcam driveru (Ikonica T crvena) Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 13, 2014 Report Share Posted June 13, 2014 Zar su potrebni bilo kakvi drajveri i podešavanja za USB-A? Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 13, 2014 Report Share Posted June 13, 2014 Drajver za 192 mora, do 96 ne (USB), a podešavanja - nemam pojma, zato i pitam ... Meni lepo sviri kako god (Asio ili Wasapi) Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 13, 2014 Report Share Posted June 13, 2014 Asio - Run with the high process priority - chekiran = ovo na Foobaru ? Quote Link to comment Share on other sites More sharing options...
Jimmy_92 Posted June 14, 2014 Report Share Posted June 14, 2014 Vlajo, a od tebe koja rec o irDAC-u? Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 14, 2014 Report Share Posted June 14, 2014 roooaaarrrrrrrrrrr ! Malo Å¡ale apropo mog komÅ¡ije iz Žegepo. IrDaÄićem veoma zadovoljan, dodato napajanje Super Teddy od Dejana Impulsa iz Sombora = ne mogu da se odvojim od sluÅ¡anja muzike !!! Jedino Å¡to mogu da žalim Å¡to ranije nisam otvorio svoj um prema dac-ovima uopÅ¡te i Å¡to ranije nisam uzeo ovog maliÅ¡u ... Ne bih sad hvalospeve, za muziku koju sluÅ¡am ovo je veoma prijatna kombinacija ... Ako imaÅ¡ konkretno pitanje - pitaj slobodno - može i na pm. Sa STP napajanjem je zvuk dobio Ävršći bas, to je ono Å¡to sam dosad primetio ... Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted June 14, 2014 Author Report Share Posted June 14, 2014 Asio - Run with the high process priority - chekiran = ovo na Foobaru ? Da,obelezio sam gore shta su moja podesavanja za irDAC(ispod irDAC) kontrol panel,a shta za foobar2000(ispod foobar2000).Ma u principu kako god da ga podesish(samo da ne pucketa) radi veoma dobro.Do sada sam imao prilike da slusam neke jako skupe DAC-ove koji su mi se dopali,ali mi nije padalo napamet da dam toliki novac za konvertor(i mobilni je bio 10000DM kad se pojavio),a ovi pristupacniji MF DAC-ovi i Lampucere nisu davali rezultat koji bi me odvojio od STX-ice.Arcama pratim od pojavljivanja(oko godinu dana) i nisam video i chuo komentar(osim shto nema izlaz za slushke i shto ima bedan daljinski) da je neko ne zadovoljan sa njim.Opaka naprava. Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted June 14, 2014 Author Report Share Posted June 14, 2014 Zar su potrebni bilo kakvi drajveri i podešavanja za USB-A? Kada je DAC na USB Class II(koji ide do 192khz i ujedno preporuka za vezu sa kompom) komp ga ne prepoznaje bez dodatnog drajvera sa Arcamovog sajta.Sa instalacijom drajvera se dobija kontrol panel sa podeshavanjima(novog firmera,usb stream moda i asio bafera).Inache drajver kao da je pravljen za foobar2000,sa njim radi perfekt na svim(i najnizim podesavanjima),dok sa drugim plejerima ume da krcka. Quote Link to comment Share on other sites More sharing options...
Zvukoljub Posted June 14, 2014 Report Share Posted June 14, 2014 @DimnjaÄare, Å¡ta fali daljinskom? Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted June 14, 2014 Author Report Share Posted June 14, 2014 Meni lichno nishta,jako mi je zanimljiv,shkljocam sa njim foobar non-stop iako imam mausa pored sebe.To je bilo pod "video i chuo komentar".Nekim struchnjacima se nije dopao. Quote Link to comment Share on other sites More sharing options...
Kaiser Posted June 14, 2014 Report Share Posted June 14, 2014 Za Foobar koristite WASAPI i izbegavajte ASIO. To je preporuka F2K developera, onaj Piter. Za perfektan ASIO samo JRiver. Nista bolje. Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted June 14, 2014 Author Report Share Posted June 14, 2014 Pavlovski,pojma on nema.To stoji josh od 0.9 verzije foobara.Tad jeste Asio bio problematican.Nije on probo Arcam Asio sa foobarom.Sa STX-icom sam morao da jaknem bafer kad sam koristio STX Asio,ali sa irDAC-om je sasvim druga pricha. Inace Wassapi je nekad bio Windowsov drajver i mnogo veci uticaj ima Win na njega nego na Asio.Inache je preporuka Arkamovih ljudi za Asio foobar2000 ili Winamp. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 19, 2014 Report Share Posted June 19, 2014 Instalirao foobar plugin za sacd, pozajmio par sacd iso fajlova na probu ... Sunce ti poljubim ... šta se dogadja, da li je placebo ili je zvuk toliko dobar ? Ima li još neko probanja sa sacd iso fajlovima ? Na foobaru piše dst64 ? Šta je to ? Quote Link to comment Share on other sites More sharing options...
gvlada Posted June 19, 2014 Report Share Posted June 19, 2014 Слушам ја СÐЦД, што преко фообара и компа, што Ñа диÑкова па у авр. Разлика је приметна и много боља на Ñтрани СÐЦД формата. Реци ми твој дак преко уÑб, можеш пуÑтити дÑд, доп или пребацује у пцм? Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 19, 2014 Report Share Posted June 19, 2014 SACD je Äudo od zvuka. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 19, 2014 Report Share Posted June 19, 2014 Koliko ja vidim, mada može i mala savetodavna pomoć - mislim da Äita direktno dsd, sad nisam 100% siguran ... Quote Link to comment Share on other sites More sharing options...
Vlajo Posted June 19, 2014 Report Share Posted June 19, 2014 SACD je Äudo od zvuka. Imam utisak da su neÅ¡to tiÅ¡i snimci u odnosu na standardni cd (flac, ape itd... ) ? Quote Link to comment Share on other sites More sharing options...
Kaiser Posted June 19, 2014 Report Share Posted June 19, 2014 SACD su remasterinzi, dakle iz samog pocetka bolji zvuk, a benefite samog formata, nesto sam skepticna. Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted June 19, 2014 Report Share Posted June 19, 2014 Jesu, tiÅ¡i su 6 dB. treba proveriti da li Arcam puÅ¡ta DSD nativno ili ih konvertuje u PCM. Å to se tiÄe samog formata, DSD ima rezoluciju manju od 24/192 ali je algoritam konverzije takav da zvuÄi mnogo prirodnije. Quote Link to comment Share on other sites More sharing options...
Kaiser Posted June 19, 2014 Report Share Posted June 19, 2014 Pavlovski,pojma on nema.To stoji josh od 0.9 verzije foobara.Tad jeste Asio bio problematican.Nije on probo Arcam Asio sa foobarom.Sa STX-icom sam morao da jaknem bafer kad sam koristio STX Asio,ali sa irDAC-om je sasvim druga pricha. Inace Wassapi je nekad bio Windowsov drajver i mnogo veci uticaj ima Win na njega nego na Asio.Inache je preporuka Arkamovih ljudi za Asio foobar2000 ili Winamp. Cim Arkan tako kaze onda vozi f2k na asio i uzivaj. Quote Link to comment Share on other sites More sharing options...
