bodibond Posted May 20, 2014 Author Report Share Posted May 20, 2014 sada sam pogledo ,klikno desnim klikom na my computer-properties i tamo mi pise pod system type-64 bit operating system,x-64 based procesor ,znaci da ipak ima 64 bita? Quote Link to comment Share on other sites More sharing options...
trotter Posted May 20, 2014 Report Share Posted May 20, 2014 A sta ce ti DSD plugin ako nemas DSD fajlove? Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 20, 2014 Author Report Share Posted May 20, 2014 pa ocito mi ne treba, ja sam ovdje radi problema sa zujanjem bio dosao ne radi sacd formata samo mi recite da li sam sve podesio kako treba sta da napravim da mi se ono vise ne pojavljuje na foobaru Quote Link to comment Share on other sites More sharing options...
SomiKnight Posted May 20, 2014 Report Share Posted May 20, 2014 Pa obrises taj fajl iz components foldera, jednostavno. Inace, bas te mrzi da probas wasapi plugin kao sto sam ti rekao? Nema razloga da koristis asio drajvere za slusanje muzike, samo moze da ti izazove probleme, kao sto i jeste, a nista u odnosu na wasapi ne dobijas. Ali, ti kako hoces, tvoja volja. Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 20, 2014 Author Report Share Posted May 20, 2014 Hoce li biti ista ako ostavim taj fajl pod components? Ako nece radje bi ga ostavio da nesto ne pokvarim. Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted May 20, 2014 Report Share Posted May 20, 2014 Nej pokvarish slobodno dilit.Probaj Wasapi ovde http://www.foobar2000.org/components/view/foo_out_wasapi Asio voli u nekim sluchajima da pravi probleme slichne tvom.Dilit i taj sacd ne treba ti ni za krasni. Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 20, 2014 Author Report Share Posted May 20, 2014 Ali ako mi savjetujes wasabi radi zujanja,taj problem sam resio. Mogu li imati i Wasabi i asio na foobaru. Glupo mi je ista instalirati kada mi ne zuji vise. Pa sta ce mi bit ako ostane ona dsd komponenta Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 20, 2014 Author Report Share Posted May 20, 2014 izbriso sam sada dsd asio.dll i sacd decoder ovde i nakon toga mi se ne ponavlja vise onaj natpis kada upalim foobar ali ne mogu vise kao output staviti asio(no drivers found mi je pod asio) i nuforce usb dac, skino sam na onom linku kojeg si mi dao wasabi i odabrao kao output wasabi(push):SPDIF interface (2-icon dac async), evo sta mi se nud pod outputom nakon tih promena dogodilo kada stavim wasabi (event) kao outputmuzika mi ne ide kada mi je pod output ds:spdif interface(2 icon dac async) cini mi se da je bolji zvuk nego kod wasabi (push) ali znate da mi je pre zujalo kada mi je to pod outputom bilo znaci ne mogu vise ono sto sam pre imao na outputu staviti sada sam bas ljut na sebe jer sam se dao nagovoriti posto mi se cini da je sound jos losiji nego pre, trebo sam jednostavno ostaviti kako je bilo sta da stavim pod output Quote Link to comment Share on other sites More sharing options...
D i g i t a L Posted May 21, 2014 Report Share Posted May 21, 2014 http://www.foobar2000.org/components/view/foo_out_asio Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 21, 2014 Author Report Share Posted May 21, 2014 kako da maknem sada taj wasapi? Nemam ga pod uninstall or change a program Quote Link to comment Share on other sites More sharing options...
Willi Studer Posted May 21, 2014 Report Share Posted May 21, 2014 Tvoji drajveri se zovu wasapi, a Wasabi je ovo: Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 21, 2014 Author Report Share Posted May 21, 2014 hahahah Ok wasapi, sori pod preference-components-sam klikno desnim klikom na njega i na remove i sada ga nema vise pod output Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 21, 2014 Author Report Share Posted May 21, 2014 Znaci ono najvaznije mi je da kada sam nabavio taj dac ,posto vec imam foobar instaliran jedino sto sam moro instalirat uz to je bio asio ili wasapi driver i to je to? pod folderom foobar plugin mi se nalazi samo apnote 130701 u kojem je folder sacd plugin , a to ne trebam nista da diram posto ionako nemam muziku u sacdu Jesam li u pravu? Quote Link to comment Share on other sites More sharing options...
SomiKnight Posted May 21, 2014 Report Share Posted May 21, 2014 kada mi je pod output ds:spdif interface(2 icon dac async) cini mi se da je bolji zvuk nego kod wasabi (push) ali znate sada sam bas ljut na sebe jer sam se dao nagovoriti posto mi se cini da je sound jos losiji nego pre Bas tako, cini ti se. Wasapi i asio imaju ISTI zvuk, sa tom razlikom koja ti je vec recena da sa asio mozes da imas problema zbog drajvera. Wasapi event bi trebalo da radi na ogromnoj vecini dac-ova a narocito na novijim, tako da je jako cudno kako kod tebe ne radi, ali nebitno, radi push. Da zakljucimo, wasapi radi, a to ti je kao resenje odmah savetovano, medjutim posto se izgleda ne razumes u racunar i rad na njemu, ti se ljutis jer smo te mi "nagovorili"... svaka ti cast. Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 21, 2014 Author Report Share Posted May 21, 2014 Ne ljutim se nista,pomogli ste mi svi dosada mnogo i hvala vam na tome. Mislim samo da sam neke stvari nepotrebno kompliciro Zato sam i tu sto se ne kuzim u takve stvari. Moze bit da je to placebo efekt i da imaju isti zvuk ali moram reci da mi je tada kada sam imo problema sa zujanjem sound bio bolji. Molim da mi odgovorite na pitanje koje sam prije postavio:kada sam nabavio taj dac ,posto vec imam foobar instaliran jedino sto sam moro instalirat uz to je bio asio ili wasapi driver i nuforce driver i to je to? (vratio sam ga ponovo na asio ali nebitno ocito je to sve jedno te isto, ako sta bude imam link i za asio i wasapi) evo kako su moje sadasnje postavke(NuforceUSBaudio, asio,components)pa ako neko moze pogledati i reci da li je to sve ok i sta se da napraviti da dobijem maksimalan zvuk od toga daca ? Molim vas da mi odgovorite (znam da sam naporan ) Quote Link to comment Share on other sites More sharing options...
trotter Posted May 21, 2014 Report Share Posted May 21, 2014 +1 za Somija, da ne ponavljam sta je napisao, rekao je sve bitno Ne trebaju ti nikakvi pluginovi za Foobar (DSD, SACD, trte mrte...) ako ne koristiÅ¡ takve fajlove. Wasapi će stabilnije da ti radi od Asio, i to je jedino Å¡to ti treba ako, na primer, sluÅ¡aÅ¡ samo flac ili sliÄno (bez trte mrte). Nije mi jasno kako nemaÅ¡ event mode? Taj Nuforce je asinhroni USB Dac i za takve je najbolja konfiguracija za Foobar sledeća: - WASAPI event mode (predviÄ‘en za USB) - Buffer Length staviti najniže, dakle, na 50 ms - Output Format 24 bit (jer tako piÅ¡e u linku sa Nuforce sajta, pisao sam već) Ostalo: - u Windows podeÅ¡avanjima postaviti takoÄ‘e 24 bit (jer tako piÅ¡e u linku sa Nuforce sajta, pisao sam već) - u Foobar podeÅ¡avanjima na Advanced pa Playback pa Full File Buffering up to: staviti vrednost u KB na primer 500000 - u istom odeljku podeÅ¡avanja podići Thread priority na najviÅ¡i nivo, kao i Äekirati Wasapi High worker process priority - na internetu pogledati (Å¡to znaÄi ima i ovde na forumu) kako podesiti laptop ako se koristi najviÅ¡e za audio potrebe (poÅ¡teno, mrzi me da piÅ¡em) Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 21, 2014 Author Report Share Posted May 21, 2014 trotteru hvala ti na odgovoru. Kazem ti da sam bio instaliro wasapi i da mi event nije radio,sada zasto ne znam Skinuo sam wasapi i opet mi event mode ne radi ne znam zasto? Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 21, 2014 Author Report Share Posted May 21, 2014 upalio sam jedan stari toshibin (toshiba teccra)laptop na kojem mi je otisla graficka i koji jedva radi(trebalo mi je preko 5min. da ga upalim), on je inace puno skuplji laptop od ovog svog kojeg imam i isto sam nuforce driver instaliro i wasapi i kod njega mi se ista stvar dogodila event mi ne radi, instaliro sam onda asio i kada sam spojio dac i pustio muziku nisam mogo da verujem, puno bolji je zvuk nego na ovom mom hp laptopu ,baš se oseti onako kako je ostriji, da mi je sada samo znati sta da napravim da mi na ovom bude isti takav sound(ne znam dali ima veze ali taj toshibin je inace imo puno kvalitetniju ugradenu zvucnu nego ovaj moj sad). Na ovom svom laptopu svira mi kada je na outputu 16 ili 32 bita, a kada na outputu je 24bita muzika nece da ide i pise da ne podrzava ju Jos sam primetio da mi u foobar folderu pod components nema wasapi.dll a ima nuforceasio.dll iako mi je na playeru pod prefernce-components -wasapi output support Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 21, 2014 Author Report Share Posted May 21, 2014 na ovom starom laptopu ima pod advanced samo 16bita,znaci foobar preferences-output-device-asio:NuforceUSBaudio, puno je bolji zvuk nego na ovom kojeg koristim Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 22, 2014 Author Report Share Posted May 22, 2014 Ostalo: - u Windows podešavanjima postaviti takođe 24 bit (jer tako piše u linku sa Nuforce sajta, pisao sam već) Kako da u windowsima postavim na 24 bita i da na internetu nadjem kako podesiti laptop ako se koristi najviše za audio potrebe Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 23, 2014 Author Report Share Posted May 23, 2014 sta da stavim pod default device spdif interface (dac) ili speakers? Quote Link to comment Share on other sites More sharing options...
seizmos Posted May 23, 2014 Report Share Posted May 23, 2014 Druze, koristi edit, nema smisla da pises ovoliko postova za redom zbog modova a isto tako i forumasa koji citaju. Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 23, 2014 Author Report Share Posted May 23, 2014 imas pravo seizmos moze li mi neko odgovoriti sta da stavim pod default device spdif interface (dac) ili speakers? Ekipa preporucujem svakom da izbegava ovaj dac,posto sam im vec vratio liniju pre ovoga,zadrzat cu ga . Ovaj dac ne vredi 300 evra ,ma nema sanse, jedino ako ja nisam nesto podesio u foobaru ili na laptopu kako treba pa nisam dobio maksimalan zvuk od njega ali cisto sumnjam. Isto tako moram da kazem da je i u snimkama stvar. Evo imam jedan album od junior wellsa sa rutrackera (come on in this house,403mb) i na njemu je zvuk cist bez ikakvog suma i taj album je zaista uzitak slusati,ali velika vecina albuma koje imam na laptopu i oni moji orginalni koje sam ripo(imam samo albume u losslessu i mp3 320) imaju sumove i kada ih pojacam na vise od pola uvijek su dosta izrazeni ti sumovi i onda zna glava zaboliti. Quote Link to comment Share on other sites More sharing options...
zek Posted May 23, 2014 Report Share Posted May 23, 2014 Vrati taj DAC!!!!! Quote Link to comment Share on other sites More sharing options...
bodibond Posted May 23, 2014 Author Report Share Posted May 23, 2014 Ja sad ne znam dali taj dac u potpunosti zaobilazi onu ugradjenu zvucnu , ne bi me usi smjele tolko jako boliti,iduca dva ili tri dana necu uopste moci slusat muziku. Nije mi nitko odgovorio sta da stavim pod default player-usb dac ili speakers Quote Link to comment Share on other sites More sharing options...
