wwweljko Posted August 27, 2015 Author Report Share Posted August 27, 2015 Izmene u sistemu : Quote Link to comment Share on other sites More sharing options...
Dubwiser Posted August 27, 2015 Report Share Posted August 27, 2015 Veljo, Krupni koraci. Da li je to Yamaha AS700 ili? Kimberi o kojima pricasmo? A taj DAC svi hvale, nisam ga slusao ali moze ti biti bingo... Svaka cast, vezuj i uzivaj! Quote Link to comment Share on other sites More sharing options...
wwweljko Posted August 27, 2015 Author Report Share Posted August 27, 2015 Jeste A700 , Morao sam da izbalansiram sistem . Bio mi je : amp-1200e, zvucnici-800e , izvor-150e. Sad je : amp-700 , zvucnici-800e , dac-750. Kimber 4PR su u pitanju , videcu sta bolje radi odissey2 ili Kimber , jedan ce morati na KP. Na prvo slusnje, jos se usvirava , Rega je opasna sprava. Quote Link to comment Share on other sites More sharing options...
ab Posted August 27, 2015 Report Share Posted August 27, 2015 Regica tipujem na Kimber ako je jJamaha svetlije puti Quote Link to comment Share on other sites More sharing options...
wwweljko Posted August 27, 2015 Author Report Share Posted August 27, 2015 I ja tako mislim , malo je svetliji zvuk . Mislim da ce "bakarni" Kimber to lepo da ispegla. Odgovara mi , Odissey je skuplji. Quote Link to comment Share on other sites More sharing options...
jager Posted August 27, 2015 Report Share Posted August 27, 2015 Cestitam na promjeni i lijepim spravama Quote Link to comment Share on other sites More sharing options...
trotter Posted August 27, 2015 Report Share Posted August 27, 2015 Bravo Weljko, cestitke na uredjajima! Uzivaj u slusanju i ne razmisljaj uopste prvih desetak dana o razlikama u odnosu na prethodni setup. Kad se priviknes na zvuk onda ces moci racionalnije da ocenis gde bi, eventualno, moglo da se proba sa intervencijom sa kablovima. Kad se to usvira i ti se priviknes i "naucis" novi zvuk mozda i nece biti potrebe, iako je normalno da si sada prvenstveno koncentrisan na poredjenje i uocavanje razlika. Quote Link to comment Share on other sites More sharing options...
jager Posted August 28, 2015 Report Share Posted August 28, 2015 Zasto si mjenjao primare ? Jel moze objasnjenje ... bas me zanima. Quote Link to comment Share on other sites More sharing options...
wwweljko Posted August 28, 2015 Author Report Share Posted August 28, 2015 Hteo sam da kupim skuplje zvucnike , koje bi ispratile i21 , evo2-20 nikako da se prodaju. Onda sam odlucio da kupim bolji DAC (od planiranog-do 200e ) i malo slabiji Amp( od i21) i napravim neki balans u sistemu. Zakljucak : zvuk posle nekih 2-3 sata , i ako je i21 bolji od A700 , sistem u celini daje bolji zvuk od prethodnog. Quote Link to comment Share on other sites More sharing options...
jager Posted August 28, 2015 Report Share Posted August 28, 2015 Kakav je zvuk bez rege ? U odnosu na primare . Quote Link to comment Share on other sites More sharing options...
ivanp Posted August 28, 2015 Report Share Posted August 28, 2015 Samo sam radoznao. Nisam ništa od toga slušao. Da li će Yamaha u odnosu na Primare dokazati da je možda sve vreme "car bio go"? Tj da se ne izražavam u enigmama, da Yamaha nije ništa lošija.............? Quote Link to comment Share on other sites More sharing options...
wwweljko Posted August 28, 2015 Author Report Share Posted August 28, 2015 Kakav je zvuk bez rege ? U odnosu na primare . Svetliji , i21 je imao bolju kontrolu pri glasnijem sluÅ¡anju...Bolji je i21 ali nije ni A700 za poceni vanje, jako dobro pojaÄalo. Kao minus kod i21 , kod mene u sistemu, je možda malo naporan zvuk na duže sluÅ¡anje.Sad je zvuk svilenkast.Ali nema 700 kik kao i21 .TeÅ¡ko napisati i opisati ,treba Äuti. Quote Link to comment Share on other sites More sharing options...
jager Posted August 28, 2015 Report Share Posted August 28, 2015 Drago mi je da si zadovoljan s yamahom , vjerujem da tu kablovi imaju sta da kazu (samo bez srebra ) da nebude nervoze rega je tu da udari pecat i da uzivas ... Quote Link to comment Share on other sites More sharing options...
wwweljko Posted August 28, 2015 Author Report Share Posted August 28, 2015 Drago mi je da si zadovoljan s yamahom , vjerujem da tu kablovi imaju sta da kazu (samo bez srebra ) da nebude nervoze rega je tu da udari pecat i da uzivas ... Ima tu jos igre sa izvorom. Za sada su Transporti : - Pioneer DVD-535 (400$ cena novog) -> AQ VDM-a - Samsung TV (pusta flac) -> low-cost optical cabl - SONY cdp-xe270 je zanemaren jer nemam iole kvalitetan oticki kabl. U planu je , najverovatnije , MacMini+HiFace2 i neki kvalitetniji coax-cable (za sada je AQ VDM-A). Quote Link to comment Share on other sites More sharing options...
arnage Posted August 28, 2015 Report Share Posted August 28, 2015 Siv, lep... Super je, neka te lepo služi. Quote Link to comment Share on other sites More sharing options...
53ch Posted August 28, 2015 Report Share Posted August 28, 2015 Svaka Äast,a i prostor super izgleda,sve na svome mjestu,uživaj u muzici Quote Link to comment Share on other sites More sharing options...
Hektolitar Posted August 28, 2015 Report Share Posted August 28, 2015 Da li je tema otvorena samo za hvalospeve ili moze i misljenje koje je sve samo nije tapsanje po ramenu? Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted August 29, 2015 Report Share Posted August 29, 2015 Mišljenje je kao d***, svako ga ima + tu je potreba da se skinu gaće i maše se drugima ispred nosa. Quote Link to comment Share on other sites More sharing options...
53ch Posted August 29, 2015 Report Share Posted August 29, 2015 Da li je tema otvorena samo za hvalospeve ili moze i misljenje koje je sve samo nije tapsanje po ramenu? Budimo malo realni,u ova vremena teÅ¡ko je odvojit dinar za bilo Å¡ta,a kamoli za neki skupi ureÄ‘aj,pa kad se netko potrudi da uspije kupit neÅ¡to,ostvarit neku svoju želju i uz to je zadovoljan da je zvukom iÅ¡ao korak napred i da to bolje zvuÄi ja mu skidam kapu i davam podrÅ¡ku,druga stvar,nije moguÄe davat kritike samo na temelju slika,a da se taj odreÄ‘eni sistem nije Äuo,moguÄa su samo nagaÄ‘anja,i zadnje svakom pa i najskupljem i najboljem sistemu moguÄe je naći manu,nekome će se svidjet,a nekome ne,po tome ni jedan sistem tu na forumu ne valja,a to nije istina,najbitnije je da je vlasnik sistema zadovoljan i da uživa u istome.... Quote Link to comment Share on other sites More sharing options...
wwweljko Posted August 29, 2015 Author Report Share Posted August 29, 2015 @53ch , svaka ti je ko Njegoševa Quote Link to comment Share on other sites More sharing options...
53ch Posted August 29, 2015 Report Share Posted August 29, 2015 ☺ Quote Link to comment Share on other sites More sharing options...
53ch Posted August 29, 2015 Report Share Posted August 29, 2015 Nevezano uz temu,vidio sam u galeriji sliku vaÅ¡ega Treka ? Izgleda da nam je joÅ¡ jedna stvar zajedniÄka,biciklizam !!! Quote Link to comment Share on other sites More sharing options...
Hektolitar Posted August 29, 2015 Report Share Posted August 29, 2015 Mišljenje je kao d***, svako ga ima + tu je potreba da se skinu gaće i maše se drugima ispred nosa. Aha, znaci umesto mahanja necim ispred necijeg nosa pozeljnije je uvuci se nekome u ono sto svako ima! Ok, budimo onda maliciozni - bravo www sto ste kupili losije pojacalo a prodali bolje! Bravo sto se zalite da ne mozete da prodate zvucnike a niste se setili da su mozda skupi pa im valja sniziti cenu! Bravo za liniju manjeg otpora. Bravo! Uzivajte u muzici! Quote Link to comment Share on other sites More sharing options...
Aibo Posted August 29, 2015 Report Share Posted August 29, 2015 ÄŒovek je prodavao zvuÄnike koji su joÅ¡ uvek u garanciji upola cene. Da je sreće da su svi prodavci toliko realni. Ako si veÄ hteo da kritikujeÅ¡ promenu na loÅ¡ije daj kaži Å¡ta imaÅ¡ otvoreno i jasno - mislim da si se zajebao zbog tog i tog, kraj. A ne da prvo provociraÅ¡ sa kvazi pitanjem koje proziva i pokretaÄa teme i sve ljude koji su ostavili pozitivne komentare. @ wwweljko Jel Yamaha pala polovna i koliko je plaćena ako nije tajna? Pretpostavljam da ne bi menjao bolje polovno pojaÄalo za loÅ¡ije novo a da ti ne ostane kinte iz te razmene. Quote Link to comment Share on other sites More sharing options...
Hektolitar Posted August 29, 2015 Report Share Posted August 29, 2015 Ma i to je garant bila kupovina na popustu. Polakomio se na nisku cenu, jebo kvalitet... Sad mu djavo kriv. Eh, da je jedini... Dalje, kad nesto u datim okolnostima ne mozetda se proda onda je skupo. Kad se okolnosti promene... Quote Link to comment Share on other sites More sharing options...
