Mingus,Mingus Posted February 2, 2014 Report Share Posted February 2, 2014 Gde ih nabavljas i koja je cena.... Quote Link to comment Share on other sites More sharing options...
goran_p Posted February 2, 2014 Report Share Posted February 2, 2014 Sonic line radnja u Novom Sadu cena 36 din kom Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted February 2, 2014 Report Share Posted February 2, 2014 Da li mislis na ovo http://www.sonicline.rs/strane_levo/ostalo_main.html Quote Link to comment Share on other sites More sharing options...
goran_p Posted February 3, 2014 Report Share Posted February 3, 2014 Da upravo ta prodavnica Quote Link to comment Share on other sites More sharing options...
Kurajber Posted February 3, 2014 Report Share Posted February 3, 2014 Moje iskustvo je sledece....Kada rezem CDR diskove sve je ok, medjutim ako narezem na pisi brisi tj. CDRW disk ,cd plejer ne cita a dvd rom hoce... Quote Link to comment Share on other sites More sharing options...
Froggy Posted February 4, 2014 Report Share Posted February 4, 2014 CD-RW disk traži drugaÄiju tehnologiju od one koja se koristi za (audio) CD ili CD-R diskove, i ako ta tehnologija nije ugraÄ‘ena, CD plejer neće "prepoznati" format. Quote Link to comment Share on other sites More sharing options...
Mingus,Mingus Posted February 4, 2014 Report Share Posted February 4, 2014 Da upravo ta prodavnica Na sajtu pise da ima ju TAIYO YUDEN verovatno jvc ili nesto drugo. Quote Link to comment Share on other sites More sharing options...
Spachek Posted February 5, 2014 Author Report Share Posted February 5, 2014 Citah ovde neke slicne teme, pa se razmisljam ako je laser oslabio da li mi je pametno na laseru pomeriti onaj potenciometar? Inace laser nosi oznaku kss 210a Quote Link to comment Share on other sites More sharing options...
trotter Posted February 5, 2014 Report Share Posted February 5, 2014 ako je laser oslabio da li mi je pametno na laseru pomeriti onaj potenciometar? Da je oslabio laser, bilo bi problema i sa Äitanjem diskova koje si narezao pre dva meseca na istim diskovima koje sada uopÅ¡te ne Äita. Quote Link to comment Share on other sites More sharing options...
Spachek Posted February 5, 2014 Author Report Share Posted February 5, 2014 Da je oslabio laser, bilo bi problema i sa Äitanjem diskova koje si narezao pre dva meseca na istim diskovima koje sada uopÅ¡te ne Äita. Otvorio sam plejer i posmatrao rad lasera, samo na kratko zavrti disk i vidi se pomeranje lasera, zatim izbaci, a onda sam ubacio isti verbatim koji hoce da cita narezan pre par meseci, njega normalno vrti i ocita za par sekundi, svaku numeru pusta bez problema. Onda uzmem i uporedim dva diska naizgled ista, od istog proizvodjaca, skapiram da onaj koji nece da procita je u stvari laznjak Verbatim, boja je dosta tamnija[bela], unutar prstena [providni deo diska] na originalu su ugravirani na plastici, a na divljaku samo odstampani, podaci na disku [Verbatim, CD-R, 700 MB....] su daleko losije odradjeni u odnosu na original, tanja slova i nema ostrih ivica. Uh, a taman sam pomislio da mi je laser spreman za kantu. Valja li pored svega ocistiti laser stapicem za usi i destilovanom vodom, napominjem da to pre nikad nisam radio i ne bih voleo da nesto zahebem Koje biste mi jos diskove preporucili osim ovih JVC sto svi hvale, te ne mogu da nadjem u mom gradu Quote Link to comment Share on other sites More sharing options...
Froggy Posted February 5, 2014 Report Share Posted February 5, 2014 A da li je uzeto u obzir da po default-u nije ukljuÄeno finaliziranje diskova posle rezanja (tzv. Disc-At-Once) već je ostala otvorena sesija (Track-At-Once), pa zato stacionarni CD plejeri ne prepoznaju (tj. ne mogu da proÄitaju) narezani CD-R, a kompjuterov ureÄ‘aj može...? Quote Link to comment Share on other sites More sharing options...
trotter Posted February 5, 2014 Report Share Posted February 5, 2014 Može biti ovo Å¡to Froggy kaže ako već nisi to proveravao i eliminisao kao razlog. JVC možeÅ¡ i da naruÄiÅ¡ da ti poÅ¡alju na kućnu adresu. ÄŒišćenje kako si opisao, samo nežno i pažljivo i sve će biti u redu. Bez pritezanja, laka ruka. Quote Link to comment Share on other sites More sharing options...
Spachek Posted February 5, 2014 Author Report Share Posted February 5, 2014 A da li je uzeto u obzir da po default-u nije ukljuÄeno finaliziranje diskova posle rezanja (tzv. Disc-At-Once) već je ostala otvorena sesija (Track-At-Once), pa zato stacionarni CD plejeri ne prepoznaju (tj. ne mogu da proÄitaju) narezani CD-R, a kompjuterov ureÄ‘aj može...? probao Froggy obe opcije, definitivno nije do toga, ipak mislim da su krs diskovi u pitanju, ne znam kako to nisam primetio odmah, sigurno sam desetak komada srezao pokusavajuci da provalim sta je u pitanju. @Trotter, imas neki link odakle bih mogao da porucim ? Quote Link to comment Share on other sites More sharing options...
trotter Posted February 5, 2014 Report Share Posted February 5, 2014 Mislim da imam negde mail ili broj telefona, samo da potražim pa javljam. Quote Link to comment Share on other sites More sharing options...
trotter Posted February 5, 2014 Report Share Posted February 5, 2014 Poslao PP. Quote Link to comment Share on other sites More sharing options...
markoinidza Posted February 28, 2014 Report Share Posted February 28, 2014 laser pri kraju Quote Link to comment Share on other sites More sharing options...
Spachek Posted March 2, 2014 Author Report Share Posted March 2, 2014 Ma sve je u redu, samo sam trebao uraditi sto mi je neko predlozio iz prethodnih postova, konvertovati iz FLAC-a u WAV, narezati i sve normalno radi Quote Link to comment Share on other sites More sharing options...
Vise njih TUPI KO UD ;) Posted March 14, 2014 Report Share Posted March 14, 2014 Mislim da imam negde mail ili broj telefona, samo da potražim pa javljam. Da li moze i meni ova informacija na PP? Hvala. Quote Link to comment Share on other sites More sharing options...
Spachek Posted December 21, 2014 Author Report Share Posted December 21, 2014 Nekad bese sve to ok, medjutim ponovo se javio isti problem, isto prebacio iz Flac-a u Wav, narezao, medjutim cd plejer nece da ga ocita. U medjuvremenu je promenjen racunar, jos da mi kaze da i to ima nekakve veze pa da se obesim. Quote Link to comment Share on other sites More sharing options...
Spachek Posted December 21, 2014 Author Report Share Posted December 21, 2014 Nece pa nece, ovog puta koristio maxell-ove silver diskove, probao vise razlicitih programa za rezanje ali plejer nece da ih ocita, ama bas nista mi ne pada na pamet sta bi moglo da bude problem. Probao direktno iz Flaca da rezem preko Burn-a, prebacio iz flaca u wav, rezao preko Foobara, Nera,EAC-a. sve sto mi je palo na pamet i opet nece, naravno racunar ocita svaki od tih diskova. Da napomenem da sam cak skidao razlicite ripove ali ne pomaze, mozda mi je sudjeno da kupujem diskove, pa makar Bugare, njih cita bez cimanja Quote Link to comment Share on other sites More sharing options...
SUROKVL Posted December 22, 2014 Report Share Posted December 22, 2014 Probaj te diskove Å¡to si narezao da li rade na drugom pleeru ! Quote Link to comment Share on other sites More sharing options...
alenvprekrÅ¡ku Posted December 22, 2014 Report Share Posted December 22, 2014 Å ta Äe ti uopÅ¡te diskovi? Quote Link to comment Share on other sites More sharing options...
perodeformero Posted December 22, 2014 Report Share Posted December 22, 2014 Da ih sluša. Quote Link to comment Share on other sites More sharing options...
Vlajo Posted December 22, 2014 Report Share Posted December 22, 2014 Å ta Äe ti uopÅ¡te diskovi? Vrlo dobro pitanje ! Imam kolekciju omiljenih diskova koju ne sluÅ¡am, a ne bih ih dao ni za kakvo blago. Digitalizacija jbg. Quote Link to comment Share on other sites More sharing options...
Froggy Posted December 22, 2014 Report Share Posted December 22, 2014 Nece pa nece, ovog puta koristio maxell-ove silver diskove, probao vise razlicitih programa za rezanje ali plejer nece da ih ocita, ama bas nista mi ne pada na pamet sta bi moglo da bude problem. Probao direktno iz Flaca da rezem preko Burn-a, prebacio iz flaca u wav, rezao preko Foobara, Nera,EAC-a. sve sto mi je palo na pamet i opet nece, naravno racunar ocita svaki od tih diskova. Da napomenem da sam cak skidao razlicite ripove ali ne pomaze, mozda mi je sudjeno da kupujem diskove, pa makar Bugare, njih cita bez cimanja Ne znam da li je tvoj sluÄaj sliÄan mom, ali 'ajd' da podelim iskustvo. Narežem neki od ovih jeftinih Verbatim CD-R Å¡to izgledaju ovako: ...i JVC XL-V131 CD plejer iz 1989. godine (joÅ¡ savrÅ¡eno funkcionalan, za divno Äudo), neće ni da ih omiriÅ¡e, dok one Verbatim CD-R diskove koje sam rezao poÄetkom ovog milenijuma (u nazivu su imali reÄ "AZO") Äita bez imalo problema (i preskakanja). Onda taj jeftini Verbatim CD-R sa slike ubacim u Philips CD723 (koji ima mogućnost Äitanja finaliziranih CD-RW diskova) i sve proÄ‘e bez ikakvih problema. Moj zakljuÄak je da laseri starijih CD plejera izgleda nisu u stanju da oÄitaju informacije sa praznih medija novijeg datuma proizvodnje (bez obzira kog proizvoÄ‘aÄa), dok CD/DVD plejeri sa ugraÄ‘enom tehnologijom za Äitanje CD-RW diskova taj problem nemaju. Uzgred, da li je CD plejer koji koristiÅ¡ i dalje Yamaha CDX 730? Ako je verovati bazi podataka na HifiEngine sajtu, i taj model je iz 1989. godine, pa me ne bi Äudilo da je u pitanju isti problem kao kod mog JVC-a Quote Link to comment Share on other sites More sharing options...
