steve_pan Posted May 23, 2015 Report Share Posted May 23, 2015 http://www.monoandstereo.com/2015/05/auris-audio-flagship-titan-kt-150-tube.html Quote Link to comment Share on other sites More sharing options...
kurgan999 Posted January 23, 2016 Report Share Posted January 23, 2016 Sledece nedelje mi stize Auris Poison 5 i Fortino 6550, bio sam u fabrici/proizvodnom pogonu, upoznao glavnog i odgovornog, brat i ja ostali bez teksta. Nisam ni sanjao da cu ikada moci da udjem u svet high end-a, zahvaljujuci mojim carapanima i ta zelja ce mi biti uslisena Kada sve bude setupovano , javim utiske Quote Link to comment Share on other sites More sharing options...
ras Posted January 24, 2016 Report Share Posted January 24, 2016 Ne verujem dok ne vidim u Sarenici kod Zike Seljaka. Quote Link to comment Share on other sites More sharing options...
kurgan999 Posted January 24, 2016 Report Share Posted January 24, 2016 i ziku ce da dovedemo da snimi prilog ako treba ioanako mu tonac covek sto radio kao tonac kod mene u kafanu Quote Link to comment Share on other sites More sharing options...
kurgan999 Posted January 24, 2016 Report Share Posted January 24, 2016 slikao sam fortino kutiju kada sam porucio da ne bude da izmisljam cim mi jave iz fabrike da je spremno za preuzimanje kacim slidze Quote Link to comment Share on other sites More sharing options...
acazr Posted January 24, 2016 Report Share Posted January 24, 2016 Lepo izgleda ova kožura s prednje strane. Quote Link to comment Share on other sites More sharing options...
kurgan999 Posted April 8, 2016 Report Share Posted April 8, 2016 Stigla zverka danas , malo je reci da smo brat i ja ostali bez teksta i sa vilicom do poda kada je pokrenuta masinerija Poison5+fortino6550+dac detaljnije cu uskoro napisati Quote Link to comment Share on other sites More sharing options...
prophet Posted April 8, 2016 Report Share Posted April 8, 2016 10 sati ranije, kurgan999 said: +dac DAC je ovo desno na slici? Može malo više detalja o njemu? Lepo za videti nadam se da ćeš istrajati do kraja u izradi man cave-a. Quote Link to comment Share on other sites More sharing options...
giZ_Mo Posted April 8, 2016 Report Share Posted April 8, 2016 On 1/22/2016 at 7:44, kurgan999 said: Sledece nedelje mi stize Auris Poison 5 i Fortino 6550 10 sati ranije, kurgan999 said: Stigla zverka danas Одужи се та недеља нешто. Quote Link to comment Share on other sites More sharing options...
kurgan999 Posted April 9, 2016 Report Share Posted April 9, 2016 On April 8, 2016 at 1:32 PM, stoN_Cold said: On April 8, 2016 at 1:17 PM, prophet said: DAC je ovo desno na slici? Može malo više detalja o njemu? Lepo za videti nadam se da ćeš istrajati do kraja u izradi man cave-a. Jeste skroz desno , jako lepo radi u ovoj prici pusta u fubaru dsdove 64/128 bez problema, 384khz/32bita mu je max pcm produkcija. Sve moguce losless fajlove koje imam je uspeo da pusti( sacd, dsd, flac, dsf, itd.)jako lepa opcija je sto ima i pojacalo za slusalice ko to voli (nisam jos stigao da probam kako zvuce sluske). evo jos nekih tehnickih detalja (prekucao sam iz bookleta koji sam dobio sa proizvodom) usb dsd native&pxm 32/384 3xRca coax, 3x tos links, wifi, preamp i direct analog output, Pojacalo za slusalice. Imace jos dosta posla kako bi se dobio sto bolji ugodjaj , prostorija nerealno odzvanja i moracemo da je malo akusticki tretiramo . Bice to ok na kraju, hvala na lepim zeljama. stone cold : Majstori su mi prostoriju zavrsili pre par dana , nisam imao gde da drzim opremu pa nisam ni preuzeo na vreme. Quote Link to comment Share on other sites More sharing options...
prophet Posted April 9, 2016 Report Share Posted April 9, 2016 2 minuta ranije, kurgan999 said: Jeste skroz desno , jako lepo radi u ovoj prici pusta u fubaru dsdove 64/128 bez problema, 384khz/32bita mu je max pcm produkcija. Sve moguce losless fajlove koje imam je uspeo da pusti( sacd, dsd, flac, dsf, itd.)jako lepa opcija je sto ima i pojacalo za slusalice ko to voli (nisam jos stigao da probam kako zvuce sluske). evo jos nekih tehnickih detalja (prekucao sam iz bookleta koji sam dobio sa proizvodom) usb dsd native&pxm 32/384 3xRca coax, 3x tos links, wifi, preamp i direct analog output, Pojacalo za slusalice. Ko je autor tog DAC-a? Koji čip(ovi), koji interfejs na ulazu, kakav je izlazni stepen i napajanje? To bi trebalo da stoji u brošuri. Quote Link to comment Share on other sites More sharing options...
steve_pan Posted July 2, 2016 Report Share Posted July 2, 2016 Sa poslednjeg sajma u Minhenu Quote Link to comment Share on other sites More sharing options...
steve_pan Posted February 6, 2017 Report Share Posted February 6, 2017 CES 2017 Quote Link to comment Share on other sites More sharing options...
steve_pan Posted February 28, 2017 Report Share Posted February 28, 2017 Nesto sveze.. Dizajn 10+ od mene http://www.monoandstereo.com/2017/02/auris-audio-forte-150-mono-power.html Quote Link to comment Share on other sites More sharing options...
Dacho Posted September 26, 2018 Report Share Posted September 26, 2018 Čestitke vašim momcima na uspjehu. Quote Link to comment Share on other sites More sharing options...
Golum Posted February 7, 2021 Report Share Posted February 7, 2021 Love is in the air: Mono & Stereo © 2020: NEW AURIS TANGENTA “HAWK” TONEARM (monoandstereo.com) Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted February 7, 2021 Report Share Posted February 7, 2021 Nije mi jasno. Da li je u pitanju ova ručica, ali rebrendirana ili sam nešto pomešao? Quote Link to comment Share on other sites More sharing options...
InSides Posted February 7, 2021 Report Share Posted February 7, 2021 Ах. Видим да је дизајнер још инспирисан Reed ручицама. Није то лоша тачка за инспирацију. Quote Link to comment Share on other sites More sharing options...
Zexx Posted February 7, 2021 Report Share Posted February 7, 2021 Quote Link to comment Share on other sites More sharing options...
Golum Posted February 7, 2021 Report Share Posted February 7, 2021 1 sat ranije, R_R said: Nije mi jasno. Da li je u pitanju ova ručica, ali rebrendirana ili sam nešto pomešao? Ova objava i prica idu u prilog prici koja je isla za Supreme audio i coveka koji zaista stoji iza rucice.. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted February 7, 2021 Report Share Posted February 7, 2021 Hvala, ali ne vidim zašto ne može jednostavno da se odgovori “DA”, već mora izokola, bez da se potvrdi, ali da se dovoljno sugeriše da je odgovor potvrdan. Kako god, nadam se da će konstruktor sada imati više sreće sa promocijom ručice na ovom forumu i šire. Quote Link to comment Share on other sites More sharing options...
InSides Posted February 7, 2021 Report Share Posted February 7, 2021 Претпостављам да нико нема информације од прве руке. Мени лично најбоље од приче је "hear no evil, see no evil, speak no evil" став уредника линковане публикације. Quote Link to comment Share on other sites More sharing options...
zflazar Posted February 7, 2021 Report Share Posted February 7, 2021 čestitke! Radujem se najavi tri ručke u tri cenovna razreda kao i opcija biranja finiša manje kićenog (ako sam dobro shvatio). Quote Link to comment Share on other sites More sharing options...
dj.nik Posted February 7, 2021 Report Share Posted February 7, 2021 Ima vesti iz prve ruke a ima i bliskih prvoj ruci, koji iz nekog razloga više postuju na drugim forumima. Quote Link to comment Share on other sites More sharing options...
srdjan_cvetkovic Posted February 7, 2021 Report Share Posted February 7, 2021 Hvala za info. Koliko vidim, ručica je u osnovi ista, a ova nova Auris bi pre mogla da bude evolucija prethodne. Mislim da je dobra odluka da se ponudi i mat verzija iste, ne samo ova zlaćana. Kako god, nadam se da će konstruktor sada imati bolju poslovnu saradnju i veći uspeh u plasmanu na naše i svetsko tržište. Quote Link to comment Share on other sites More sharing options...
