232 -
Gender
Not Telling
1,252 profile views
Play_Select's Achievements
AUGUST 6, 2010 New Interconnect Cable Has High Electrical Capacitance There has been a change in the interconnect cable affecting the following models: Sl1200MK2. SL1210MK2, Sl1200MK5, SL1210MK5. This changeover likely occured in product with 2009 date codes. So that would be serial numbers beginning (GE9A. 9 is 2009, A is January) The change involves the interconnect cable electrical capacitance. The older cables had a total capacitance of approx 120pF, the new cable is approx 325pF. This change makes the newer models incompatible with most high output cartridges since the total load capacitance for uniform frequency response is typically under 300pF total. Most preamps have 100pF internal, some have more. Adding that to the 325pF of the cable will produce a peak in the high frequency response, with the most likely affect being exaggerated surface noise and sibilance. Resolution: KAB has notified Panasonic QC and send a letter to Pansonic, Osaka Japan on 8/6/10. A response from USA has been recevied 10/13/10: "There was a wiring change in production that did affect the cable capacitance of this model. As you know there are several factors to determine the overall capacitance of the system, but suffice it to say, the old cable had a lower capacitance. Because of the adverse effects, the factory has discontinued the new cable RJL2P001B12 and have reverted back to the old cable RJL4P002S12 in production, since September 2009." So it appears this will be corrected and eventually new production tables will have the original cable. All KAB units shipped after 8/4/10 will have the cable replaced with the older 125pF cable. This does not affect the SL-1210M5G nor does it affect KAB Cardas Rewire mods.
Nemoj da kupujes RJL2P009S12. Objasnjenje je na stranici https://www.kabusa.com/frameset.htm?/m1200.htm Preporuka za RCA kabal Technics RCA Gold High-Fidelity Interlink Signaal Kabel CODE: RJL4P002S12 Technics Original SL-1210 M5G Hi Fidelity Cable. Is a beautifully constructed cable featuring OFC conductors, crimped and soldered to fully over molded connectors. The handles are square shaped allowing these connectors to fit onto RCA jacks with spacing as little as 1/2". 45" long. 90pF capacitance. Order stock cable to the right or choose custom terminations. Also see our Litz cables above offered with 1200 PCB terminations as well. This is one stereo cable set for one turntable. Fits all 1200 models from MK2 thru MK6
Nije moguća vizuelna kontrola Concorde modela, sa overhang gauge-om, zbog natpisa ispod rupe na unutraÅ¡njem delu gauge-a. IzboÄen natpis ne dozvoljava montažu do samog kraja, Å¡to nije sluÄaj sa headshell-om kome taj natpis ne smeta. Prava kontrola jedino je moguća sa montažom gumenog prstena koji reÅ¡ava problem teksta na gauge-u. Link koji si postavio za Ortofon gumeni prsten navodi njegovu debljinu od 0,8mm U tom sluÄaju overhang je 51,5 + 0,8 = 52,3mm
OM serija se montira na headshell dok je concorde integrisan, sve ostalo je identiÄno ( važi za isti model om i concorde )
Nisam znao da se gumeni prsten isporuÄuje uz neke modele Concord serije dok nisam kupio Nightclub 2 ( prsten nije bio namontiran ) Možda se isporuÄuje i uz 2m PnP ???
Gumeni prsten se ne isporuÄuje uz svaki Ortofon Concorde. U originalnom pakovanju Ortofon nightclub II isporuÄen je prsten i gumena navlaka koja se navlaÄi na ruÄicu konkorda. Zanimljiva stvar vezana za concorde seriju je i overhang koji je 51,5mm. Sa dodatkom gumenog prstena dobijaÅ¡ taÄno 52mm.
@ Milos Technics 1210 is the best !
Ne kupuj Stanton str 8-80 za sluÅ¡anje muzike jer je konstruisan za skreÄ. Nije sluÄajno na njemu Stanton 500 zvuÄnica koja nije previÅ¡e osetljiva na velike gazne greÅ¡ke !!! JoÅ¡ gora varijanta je montiranje HI-FI zvuÄnice na pravu ruÄku. ( Pogledaj malo po netu sliÄne gramofone, za skreÄ, firme Vestax )
Tomu sam jednom prilikom upoznao na berzi. Odmah da budem jasan - nisam niciji PR ! Covek ima znanje, strpljenje i vestinu da ceka na Ebay povoljnu kupovinu svega i da kasnije robu preproda na nasem trzistu po manje-vise povoljnim cenama. Za razliku od preprodavaca sa KP koji nabave ( otkup ) 1210 po 200-250 EU, srede ga ( cesto obrisu samo prasinu ) i postave oglas za prodaju po 400 - 450 EU.
Toma ( Majstor ) prodaje pomenute gramofone PREPORUCUJEM KUPOVINU !
Preprodavac Technics gramofona sa KP oÄigledno Äita ovaj forum. Naveo je da ofarbani gramofon 1210 nije sklapan iz viÅ¡e komada Zanimljivo da navodi da je "odradio" oko 50 komada, a nisam primetio silne pozitivne ocene na KP za pomenute "restauracije" Å ta reći..............
LEILI zelim da uziva u novom gramofonu
Prva verzija. Sigurno su mnogo prešli...
